    4. Test Withings v0.0.x
    • MassiveAttack
      MassiveAttack last edited by
      hallo!
      jedes mal wenn ich den adapter starten möchte, bekomme ich ein mail mit einem temporären login code. was mache ich falsch? mein login in der app funktioniert ja mit user/pw.
        tombox @MassiveAttack last edited by
        @massiveattack Ist leider ein Manko den man so hinnehmen muss
        MassiveAttack 1 Reply Last reply Reply Quote 0
        • MassiveAttack
          MassiveAttack @tombox last edited by MassiveAttack
          @tombox
          würde ich, wenn der adapter starten würde 🙂
          withings.0
          	1346	2022-08-18 13:09:56.349	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          withings.0
          	1346	2022-08-18 13:09:56.347	info	terminating
          withings.0
          	1346	2022-08-18 13:09:56.322	error	resultArray is not iterable
          withings.0
          	1346	2022-08-18 13:09:56.321	error	TypeError: resultArray is not iterable at Withings.login (/opt/iobroker/node_modules/iobroker.withings/main.js:226:26) at processTicksAndRejections (node:internal/process/task_queues:96:5) at Withings.onReady (/opt/iobroker/node_modules/iobroker.withings/main.js:69:5)
          withings.0
          	1346	2022-08-18 13:09:56.315	error	unhandled promise rejection: resultArray is not iterable
          withings.0
          	1346	2022-08-18 13:09:56.314	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          withings.0
          	1346	2022-08-18 13:09:56.311	error	{"errors":[{"message":"redirect_uri_mismatch: The redirect URI provided is missing or does not match partner callback url"}]}
          withings.0
          	1346	2022-08-18 13:09:53.479	info	starting. Version 0.0.10 in /opt/iobroker/node_modules/iobroker.withings, node: v16.17.0, js-controller: 4.0.23
            @massiveattack callback url stimmt anscheinend nicht hast du wie vorgegeben Callback URI: http://localhost
            • MassiveAttack
              @tombox said in Test Withings v0.0.x:
              http://localhost
              peinlich, hatte wohl https geschrieben 🙄
              danke, funktioniert jetzt
              • Pr3mut05
                Pr3mut05 last edited by Pr3mut05
                Ich bekomme ständig E-Mails mit dem temporären Passwort
                Wie kann ich denn das abschalten 😕
                OK - Wurde zwei Kommentare davor beantwortet 😉
                • ESP8266
                  ESP8266 @Pr3mut05 last edited by ESP8266
                  @tombox , es fängt wieder an.
                  Kaum ein Upgrade gefahren, kann er sich nicht wieder einloggen.
                  Auf der Seite habe ich alles bestätigt.
                  Zurück zu 0.0.10 und geht wieder.
                    tombox @ESP8266 last edited by
                    @esp8266 War noch ein Fehler danke für den Hinweis ist mit 0.0.13 behoben
                    ESP8266 1 Reply Last reply Reply Quote 1
                    • ESP8266
                      ESP8266 @tombox last edited by ESP8266
                      @tombox , das Problem besteht weiterhin. Auch ein Neustart behebt es nicht.
                      Mom...du schreibst 0.0.13 dann ist installiere ich mal vom Github.
                      Alles gut, lüppt.
                        MrLee last edited by
                        Moin!
                        Bin auf der .13 von Github und habe leider das selbe Problem...mache ich was falsch (erste Installation des Adapters)
                        withings.0
                        2022-10-23 16:02:25.302	error	{"status":503,"error":"Invalid Params: Missing [refresh_token]"}
                        withings.0
                        2022-10-23 16:02:25.191	warn	Please check username and password
                        • ESP8266
                          ESP8266 @MrLee last edited by
                          @mrlee , Adapter neu starten.
                            MrLee @ESP8266 last edited by
                            @esp8266
                            Moin, dank für die Info...
                            passiert aber leider genau das Selbe im log und Adapter bleibt gelb.
                            withings.0
                            2022-10-24 08:35:28.460	error	{"status":503,"error":"Invalid Params: Missing [refresh_token]"}
                            withings.0
                            2022-10-24 08:35:28.349	warn	Please check username and password
                            withings.0
                            2022-10-24 08:35:25.260	info	starting. Version 0.0.13 (non-npm: TA2k/ioBroker.withings) in /opt/iobroker/node_modules/iobroker.withings, node: v16.17.1, js-controller: 4.0.23
                            withings.0
                            2022-10-24 08:35:24.709	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                            host.iobroker_host-neu
                            2022-10-24 08:35:21.479	info	instance system.adapter.withings.0 started with pid 15809
                            2022-10-24 08:35:18.817	info	instance system.adapter.withings.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2022-10-24 08:35:18.197	info	stopInstance system.adapter.withings.0 send kill signal
                            withings.0
                            2022-10-24 08:35:18.170	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            withings.0
                            2022-10-24 08:35:18.167	info	terminating
                            withings.0
                            2022-10-24 08:35:18.161	info	Got terminate signal TERMINATE_YOURSELF
                            2022-10-24 08:35:18.154	info	stopInstance system.adapter.withings.0 (force=false, process=true)
                            2022-10-24 08:35:08.695	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2022-10-24 08:35:00.051	info	instance system.adapter.dwd.0 started with pid 15780
                            withings.0 2022-10-24 08:34:09.785	error	{"status":503,"error":"Invalid Params: Missing [refresh_token]"}
                            withings.0 2022-10-24 08:34:09.673	warn	Please check username and password
                            Bekomme auch jedesmal wenn ich den Adapter starte eine Mail von withings
                            Hier ist Ihr vorläufiger Anmeldecode
                            Habe ich bei Withinhgs was falsch eingestellt?
                            bis denne
                            Mr.Lee
                            stony2k 1 Reply Last reply Reply Quote 0
                            • stony2k
                              stony2k @MrLee last edited by stony2k
                              seit dem Updates des Adapter wird die Zeit von total_sleep_time anders angegeben. Sind das nun Sekunden? Wobei das dann komischerweise nicht mit den Angaben in der App übereinstimmt.
                              Beispiel: aktuell hat der Datenpunkt den Wert 24300, was 6,7 h sein müssten. Laut der App sind es aber nur 6:45 Min
                              @mrlee sagte in Test Withings v0.0.x:
                              bis denne
                              Mr.Lee
                              Die Mail bekomme ich auch, ist in meinen Augen einfach zu ignorieren
                              oberfragger 1 Reply Last reply Reply Quote 0
                              • oberfragger
                                oberfragger @stony2k last edited by
                                @stony2k said in Test Withings v0.0.x:
                                bis denne
                                Mr.Lee
                                die Rechnung stimmt doch!
                                24300 Sekunden = 405 Minuten = 6,75h
                                0,75h = 45 Minuten (0,75*60)
                                -> 6,75h = 6h 45 Minuten
                                • stony2k
                                  stony2k @oberfragger last edited by
                                  @oberfragger sagte in Test Withings v0.0.x:
                                  bis denne
                                  Mr.Lee
                                  Ok du hast recht. Ich Trottel 😄
                                  Hast du eine Idee, wie ich mir das in ein lesbares Format umwandeln kann? Also per Formel oder Javascript?
                                  • ESP8266
                                    ESP8266 @stony2k last edited by ESP8266
                                    @stony2k , das habe ich hier im Thread schon mal gepostet.
                                     on({id: "withings.0.28587019.measures.measuregrps01.1.value"/*value*/, change: "ne"}, async function (obj) {
                                    >   var value = obj.state.val;
                                    >   var oldValue = obj.oldState.val;
                                    >   setState("0_userdata.0.Withings.Aktuelle_Gewichte.XXXX.Gewicht"/*Gewicht*/, Math.round((parseFloat(getState("withings.0.28587019.measures.measuregrps01.1.value").val) / 1000)*10)/10);
                                    >   setState("0_userdata.0.Withings.Aktuelle_Gewichte.XXXX.Datum"/*Datum*/, (String(formatDate(getDateObject((parseFloat(getState("withings.0.28587019.measures.measuregrps01.created").val) * 1000)), "DD.MM.YYYY"))));
                                    >   setState("0_userdata.0.Withings.Aktuelle_Gewichte.XXXX.Zeit"/*Zeit*/, (String(formatDate(getDateObject((parseFloat(getState("withings.0.28587019.measures.measuregrps01.created").val) * 1000)), "hh:mm:ss"))));
                                    Da ist auch die Zeit drin. Eine Formel und einem Zeitstempel. Also nicht anderes.
                                    stony2k Damrak2022 2 Replies Last reply Reply Quote 1
                                    • Damrak2022
                                      Damrak2022 @tombox last edited by Damrak2022
                                      @tombox Hallo, ich muss mal wieder nachfragen:
                                      Unter sleep summary habe ich 19 Unterordner. Das scheint soweit okay zu sein, da die Anzahl der Unterordner nicht mehr wird.
                                      Meine Adaptereinstellungen sehen so aus:
                                      Was ich aber weniger verstehe ist die Darstellung unterhalb von sleep summary/series01/data
                                      Hier wird mir jetzt als created der 26.10.2022 um 17:47 Uhr angezeigt, mit einer totalsleeptime von 5100
                                      Wenn ich nun aber unter sleep summary/series02/data schaue wird mir hier als created erneut der 26.10.2022 um 15:05 Uhr angezeigt mit einer totalsleeptime von 16260
                                      Das macht es nahezu unmöglich die Daten verlässlich weiterzuverarbeiten, oder hat hier jemand einen Tipp, wie man das bewerkstelligt?
                                      Warum gibt es nicht pro Tag nur eine Datenausgabe? Ist es möglich das so zu machen?
                                      Dann noch was ganz wichtiges: Ich habe unterhalb von Sleep mittlerweile 191 Unterordner
                                      • stony2k
                                        stony2k @ESP8266 last edited by stony2k
                                        @esp8266 sagte in Test Withings v0.0.x:
                                        Leider doch nicht das, was ich brauche. Es geht sich nicht um den Zeitstempel des Datenpunktes, sondern den Wert. Der Datenpunkt enthält als Wert die Zeit, die man geschlafen hat in Sekunden.
                                        • Damrak2022
                                          Damrak2022 @stony2k last edited by
                                          @stony2k Sorry, kannst Du mir das näher erklären, denn so fit bin ich nicht. Hast Du das hinbekommen, das Du immer nur den korrekten Wert erhält? Und wie muss ich das machen? Es wäre toll, wenn Du mir das erklären könntest - Danke
                                          • stony2k
                                            stony2k @Damrak2022 last edited by stony2k
                                            @damrak2022 sagte in Test Withings v0.0.x:
                                            Bekomme das gerade nicht hin, habs mir nochmal angeschaut. @ESP8266 nutzt ja dem timestamp der der Erstellung des Datenpunktes. Wir wollen ja Sekunden in eine Uhrzeit umwandeln. Bisher habe ich es noch nicht hinbekommen.
                                            Edit: Hiermit konnte ich den Wert nun richtig formatieren: https://forum.iobroker.net/topic/15033/erledigt-sekunden-in-stunden-und-minuten-anzeigen/2?_=1666943596811
                                            516
                                            96182
