    3. Einsteigerfragen
    4. Installation
    5. Node npm - Infos zum (tats.) Versionsstand
    • Q
      qwerty1896 last edited by qwerty1896
      Sorry, würde es auch gern im schwarzen Kasten anzeigen lassen. Hier das Resultat:
      Used repository: default
      hash unchanged, use cached sources
      Cannot get any information of "_repoInfo". Ignored.
      update done
      Adapter "accuweather" : 1.2.1 , installed 1.2.1
      Adapter "admin" : 6.2.22 , installed 6.2.22
      Adapter "backitup" : 2.4.12 , installed 2.4.12
      Adapter "daswetter" : 3.1.3 , installed 3.1.3
      Adapter "discovery" : 3.0.5 , installed 3.0.5
      Adapter "dwd" : 2.8.3 , installed 2.8.3
      Adapter "echarts" : 1.0.12 , installed 1.0.12
      Adapter "fahrplan" : 1.2.2 , installed 1.2.2
      Adapter "flot" : 1.11.0 , installed 1.11.0
      Adapter "history" : 2.2.0 , installed 2.2.0
      Adapter "hue" : 3.7.1 , installed 3.7.1
      Adapter "ical" : 1.13.1 , installed 1.13.1
      Adapter "icons-mfd-svg" : 1.1.0 , installed 1.1.0
      Adapter "javascript" : 6.0.3 , installed 6.0.3
      Controller "js-controller" : 4.0.23 , installed 3.3.22 [Updateable]
      Adapter "pushover" : 3.0.3 , installed 3.0.3
      Adapter "pvforecast" : 2.3.0 , installed 2.3.0
      Adapter "simple-api" : 2.7.0 , installed 2.7.0
      Adapter "socketio" : 4.2.0 , installed 4.2.0
      Adapter "sonoff" : 2.5.1 , installed 2.5.1
      Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1
      Adapter "telegram" : 1.14.1 , installed 1.14.1
      Adapter "vis" : 1.4.15 , installed 1.4.15
      Adapter "vis-hqwidgets" : 1.3.0 , installed 1.3.0
      Adapter "vis-inventwo" : 3.3.1 , installed 3.3.1
      Adapter "vis-material-advanced": 1.7.2 , installed 1.7.2
      Adapter "vis-timeandweather": 1.2.2 , installed 1.2.2
      Adapter "web" : 4.3.0 , installed 4.3.0
      Adapter "ws" : 1.3.0 , installed 1.3.0
      Homoran Thomas Braun 3 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @qwerty1896 last edited by
        @qwerty1896 sagte in Node npm - Infos zum (tats.) Versionsstand:
        wäre nett!
          Thomas Braun Most Active @qwerty1896 last edited by
          @qwerty1896
          Schwarzer Kasten
          Bring den js-controller auf Stand. Der Rest ist es ja auch.
            Änderungen und Erweiterungen in älteren Posts bitte mit EDIT: kennzeichnen!
            • Q
              qwerty1896 @Homoran last edited by
              pi@raspberrypi:~ $ iob update
              Used repository: stable
              Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
              Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
              pi@raspberrypi:~ $ iob repo list
              Active repo(s): stable
                @qwerty1896
                Sollte passen.
                Nächstes Projekt: nodejs auf die empfohlene Version 16 bringen.
                • Q
                  qwerty1896 @Thomas Braun last edited by
                  Vielen Dank. Erst mal mache ich ein Backup.
                  Erst dann traue ich mich an nodsjs 16.
                    @qwerty1896
                    Backitup läuft ja hoffentlich ohnehin täglich?
                    • Q
                      Tja. Am sichersten ist mir eine 1:1-Kopie des SD-Karte.
                      • Q
                        qwerty1896 @qwerty1896 last edited by
                        Hallol Thomas,
                        ich will die "Sache" jetzt mal angehen auf:
                        node.js 16.18.0 und npm 8.19.2
                        Ist das so richtig?
                        a)
                        curl -sL https://deb.nodesource.com/setup_16.18 | sudo -E bash
                        sudo apt install nodejs
                        sudo ln -s /usr/bin/node /usr/bin/nodejs
                        b)
                        sudo apt install nodejs=16.18-deb-1nodesource1
                        oder
                        sudo apt install nodejs=16.18.0-deb-1nodesource1
                          Thomas Braun Most Active @qwerty1896 last edited by Thomas Braun
                          Ist das so richtig?
                          Eher nicht. Hängt davon an welche Grundvoraussetzungen da bei dir gegeben sind.
                          Wie sieht das bei dir aus?
                          uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                            @qwerty1896
                            Wenn der Stand von oben noch aktuell ist:
                            Einfach per (Editor von Hand)
                            sudo nano /etc/apt/sources.list.d/nodesource.list
                            aus node_14.x ein node_16.x machen,
                            Dann
                            iob stop
                            sudo apt update
                            sudo apt full-upgrade
                            iob start
                            abwarten, bis alles wieder läuft. Kann etwas dauern.
                            • Q
                              Ich habe nicht verändert. Wie mehr nicht?
                                @qwerty1896
                                Nö, das ist so simpel.
                                • Q
                                  Das schaffe auch ich. Erst noch das Backup. Ich gebe eine Rückmeldung.
                                  Das hat aber nicht lange gedauert... (max. 3 Min)...
                                    @qwerty1896
                                    • Q
                                      pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                      armv7l
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      v16.18.0
                                      v16.18.0
                                      8.19.2
                                      4.0.23
                                      pi
                                      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                                      /home/pi
                                      OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                      OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                      OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                      Paketlisten werden gelesen… Fertig
                                      Abhängigkeitsbaum wird aufgebaut… Fertig
                                      Statusinformationen werden eingelesen… Fertig
                                      Alle Pakete sind aktuell.
                                      nodejs:
                                        Installiert:           16.18.0-deb-1nodesource1
                                        Installationskandidat: 16.18.0-deb-1nodesource1
                                        Versionstabelle:
                                       *** 16.18.0-deb-1nodesource1 500
                                              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                              100 /var/lib/dpkg/status
                                           12.22.12~dfsg-1~deb11u1 500
                                              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                      Sieht das gut aus? Ich denke ja... Der ioBroker startet schon mal...
                                        @qwerty1896
                                        Ja, passt. Und so simpel ist ein Wechsel der nodeJS-Installation.
                                        • Q
                                          VIELEN DANK.
                                          Die Anleitung zur aktuellen Version hat mich schon ein wenig abgeschreckt!
                                          Es passt nicht ganz:
                                          Gibt es "irgendwo" eine gute Anleitung für die influxdb und Grafana-Installation?
                                            Wie meinst du das?
                                            Zu influx und Grafana findest du hier die Repos:
                                            https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                                            Q 1 Reply Last reply Reply Quote 1
                                            node npm versionsstand
                                            1882
