    4. JavaScript
    5. Json für SourceAnalytics
      liv-in-sky @Nordischerjung last edited by
      @nordischerjung
      bitte mal das hier testen
      let myArrSourcA=[];
      async function calcJson(){
      $('sourceanalytix.0.*.currentYear.consumed.01_currentDay').each( function( id4, i){
           let idy = id4.split('.');
           let theName=getObject(idy[0]+'.'+idy[1]+'.'+idy[2]).common.name//idy[2].split('__');
           if(theName == undefined)  theName="no Name" ;
           //log( getObject(idy[0]+'.'+idy[1]+'.'+idy[2]).common.name )
                             myArrSourcA.push({
                                 "Name": theName,
                                 "Gestern":getState(id4.replace("01_currentDay","01_previousDay")).val+" kWh",
                                 "Heute": getState(id4).val+" kWh",
                                 "Monat":getState(id4.replace("01_currentDay","03_currentMonth")).val+" kWh",
                                 "Jahr": getState(id4.replace("01_currentDay","05_currentYear")).val+" kWh",
                                 "Gestern Kosten":getState(id4.replace("consumed.01_currentDay","costs.01_previousDay")).val+" €",
                                 "Heute Kosten": getState(id4.replace("consumed.01_currentDay","costs.01_currentDay")).val+" €",
                                 "Monats Kosten":getState(id4.replace("consumed.01_currentDay","costs.03_currentMonth")).val+" €",
                                 "Jahres Kosten": getState(id4.replace("consumed.01_currentDay","costs.05_currentYear")).val+" €"
      //log(JSON.stringify(myArrSourcA))
      return myArrSourcA;
      async function writeDatapoint(){
      if (!(await existsStateAsync('0_userdata.0.StromJson.StromJson'))) {
             await createStateAsync('0_userdata.0.StromJson.StromJson', "",{type: "string", name: "JSON SourcAnalytics", role: "value", read: true, write: true, } ); }
      // log(JSON.stringify(await calcJson()))
      setState('0_userdata.0.StromJson.StromJson',JSON.stringify(await calcJson()));
      writeDatapoint();
      • N
        Nordischerjung @liv-in-sky last edited by
        @liv-in-sky Jetzt so
          crunchip Forum Testing Most Active @liv-in-sky last edited by
          @liv-in-sky kann man nicht "common name" abrufen anstatt der ID?
            liv-in-sky @crunchip last edited by
            @crunchip
              @nordischerjung ich glaube, ich habe was gesehen - ich mach nochmal
                @liv-in-sky ah ok, hatte ich nicht weiter geguckt, bin grad aufn Sprung
                  @crunchip kein problem - die zusammenstellung der id ist wohl falsch um den common.name zu bekommen
                    @nordischerjung
                    bin verwirrt - sollte eigentlich so funktionieren - bei mir tut es das
                    kannst du mal bitte den inhalt des datenpunktes posten 0_userdata.0.StromJson.StromJson
                    siehe chat !
                    N metaxa 2 Replies Last reply Reply Quote 0
                    • N
                      @liv-in-sky So schnell nochmal Probiert, Sorry war mein Fehler. Funktioniert doch. Und dabei sehe ich, das Schlafzimmer wohl bei mir falsch geschrieben ist 😀
                      Ich habe das schon geändert, habe 2 getrennte Widges einmal für Verbrauch und einmal Kosten. Das Ganze auch noch gleich gerundet, da der Adapter zB 0,002343524515 € ausspuckt
                        @nordischerjung
                        dann paßt ja alles (hab schon an meinen coderfähigkeiten gezweifelt 🙂 )- brauchst du noch einen trigger - wir könnten einen schedule alle 10 min einfügen ?
                          @nordischerjung sagte in Json für SourceAnalytics:
                          solange du da drin nix falsches machst 🙂
                          • N
                            @liv-in-sky sagte in Json für SourceAnalytics:
                            @nordischerjung
                            Ne, hab ich schon gemacht. Vielen Dank für dein Code.
                            • metaxa
                              metaxa @liv-in-sky last edited by
                              Servus!
                              Auf der Heimfahrt durchs ital. Kanaltal (Beifahrer 🙂 !) stieß ich hte auf den Thread. Darf ich dich dazu um Hilfe bitten?
                              Via JS habe ich eine JSON aus SA nicht zusammengebracht. Mühsam habe ich mir ein Blockly zusammengeschustert.
                              Ja, arbeitet und sieht dann so in VIS aus:
                              Nur wie ich jetzt dein Script einsetze, ich komm nicht weiter
                              Den DP habe ich sicherheitshalber selbst angelegt
                                "common": {
                                  "name": "StromJson",
                                  "desc": "Manuell erzeugt",
                                  "role": "state",
                                  "type": "json",
                                  "read": true,
                                  "write": true
                                "type": "state",
                                "native": {},
                                "user": "system.user.admin",
                                "ts": 1666641854346,
                                "_id": "0_userdata.0.SromJson.StromJson",
                                "acl": {
                                  "object": 1636,
                                  "state": 1636,
                                  "owner": "system.user.admin",
                              Da tut sich aber nix.
                              Bitte um deinen kurzen Support!
                              LG, mxa
                                liv-in-sky @metaxa last edited by liv-in-sky
                                @metaxa
                                der datenpunkt muss vom type zeichenkette sein - aber das script macht das schon - enfach deinen dp löschen oder den type ändern
                                das script schreibt auch den dp und daher habe ich in diesem script den schedule hinzugefügt - alle 5 minuten - kannst du natürlich anpassen, wie du möchtest. das script in ein neues javascript kopieren und starten (dein blockly script stoppen!) - beim ersten mal werden die daten sofort geschrieben und dann alle 5 min.
                                let myArrSourcA=[];
                                     let helper=idy[2].split('__');
                                     let helper2=helper[helper.length-2];
                                     let theName=getObject(idy[0]+'.'+idy[1]+'.'+idy[2]).common.name   //idy[2].split('__');
                                                       myArrSourcA.push({
                                                           "Name": theName,
                                return myArrSourcA;
                                writeDatapoint();
                                schedule('*/5 * * * *',  function () { writeDatapoint();
                                • metaxa
                                  @liv-in-sky Ganz lieben Dank!
                                  Funktioniert auf Anhieb, nur irgendwie stimmt der Name nicht. Sobald ich oben auf Sortieren klicke, wird ein Datenzeile vermehrfacht angezeigt. Auch ds mit dem Runden müsste ich mir nochmals irgendwo raussaugen.
                                  dp (in Tags wird der Beitrag zu lange, deswegen als att)
                                  0_userdata.0.VIS.JSON.JSON_Strom.txt
                                  SA
                                    @metaxa schau ich mir an - das runden füge ich ein
                                      @metaxa das sotieren über widget funtioniert bei mir auch nicht - ist mir nicht aufgefallen - mal schauen, was das wieder ist 🙂
                                      rantanplan 1 Reply Last reply Reply Quote 0
                                      • rantanplan
                                        rantanplan @liv-in-sky last edited by
                                        Erstmal Danke für Dein Script!!! Läuft soweit bestens.
                                        Schön wäre es noch wenn die Zahlen im deutschen Format übernommen würden, also 1.500,30 und nicht 1,500.30.
                                        Vielleicht klappt dann auch die Sortierung.
                                        Das "Namen" Feld wird richtig sortiert, nur die "Zahlen" Felder machen Probleme.
                                        liv-in-sky metaxa 2 Replies Last reply Reply Quote 0
                                          @metaxa
                                          probiere mal das script
                                          let myArrSourcA=[];
        myArrSourcA.push({
        "Name": theName,
        "Gestern":getState(id4.replace("01_currentDay","01_previousDay")).val.toFixed(2)+" kWh",
        "Monat":getState(id4.replace("01_currentDay","03_currentMonth")).val.toFixed(2)+" kWh",
        "Jahr": getState(id4.replace("01_currentDay","05_currentYear")).val.toFixed(2)+" kWh",
        "Gestern Kosten":getState(id4.replace("consumed.01_currentDay","costs.01_previousDay")).val.toFixed(2)+" €",
        "Heute Kosten": getState(id4.replace("consumed.01_currentDay","costs.01_currentDay")).val.toFixed(2)+" €",
        "Monats Kosten":getState(id4.replace("consumed.01_currentDay","costs.03_currentMonth")).val.toFixed(2)+" €",
        "Jahres Kosten": getState(id4.replace("consumed.01_currentDay","costs.05_currentYear")).val.toFixed(2)+" €"
                                          return myArrSourcA;
                                          writeDatapoint();
                                          und wegen der sortierung im widget - den fehler kann ich nicht wirklich nachvollziehen - habe mal ein paar sachen im widget setting rumgeklickt und jetzt funktioniert es bei der spalte Name - bei den anderen spalten funktioniert es beim ersten klick nicht und dann immer wieder mal bei den nächsten klicks- ich kann dir im moment nicht sagen, ob es am widget liegt ? die daten sind eindeutig und richtig, sonst würden sie ja garnicht angezeigt 🙂
                                          hier mal das widget zum importieren und schau mal, ob du im namen sortieren kannst
                                          [{"tpl":"i-vis-jsontable","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","iTblRowLimit":"20","iTableRefreshRate":"0","iTblSortOrder":"asc","iColCount":"9","iColShow1":"true","iTblHeadTextAlign1":"left","iTblTextAlign1":"left","iTblCellFormat1":"normal","iTblCellImageSize1":"200","iTblCellBooleanCheckbox1":"false","iTblCellBooleanColorFalse1":"#ff0000","iTblCellBooleanColorTrue1":"#00ff00","iTblCellNumberDecimals1":"2","iTblCellNumberDecimalSeperator1":".","iTblCellNumberThousandSeperator1":",","iTblCellThresholdsDp1":"","iTblCellThresholdsText1":"","iOpacityAll":"1","iTblRowEvenColor":"#479de6","iTblRowUnevenColor":"#8dadb9","iTblHeaderColor":"#204565","iRowSpacing":"2.8","iTblRowEvenTextColor":"#ffffff","iTblRowUnevenTextColor":"#ffffff","iTblHeaderTextColor":"#ffffff","iBorderSize":"0","iBorderStyleLeft":"none","iBorderStyleRight":"none","iBorderStyleUp":"none","iBorderStyleDown":"none","iBorderColor":"#ffffff","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"0_userdata.0.StromJson.StromJson","iTblShowHead":true,"iColShow2":"true","iTblHeadTextAlign2":"center","iTblTextAlign2":"center","iTblCellFormat2":"normal","iTblCellImageSize2":"200","iTblCellBooleanCheckbox2":"false","iTblCellBooleanColorFalse2":"#ff0000","iTblCellBooleanColorTrue2":"#00ff00","iTblCellNumberDecimals2":"2","iTblCellNumberDecimalSeperator2":".","iTblCellNumberThousandSeperator2":",","iTblCellThresholdsDp2":"","iTblCellThresholdsText2":"","iColShow3":"true","iTblHeadTextAlign3":"center","iTblTextAlign3":"center","iTblCellFormat3":"normal","iTblCellImageSize3":"200","iTblCellBooleanCheckbox3":"false","iTblCellBooleanColorFalse3":"#ff0000","iTblCellBooleanColorTrue3":"#00ff00","iTblCellNumberDecimals3":"2","iTblCellNumberDecimalSeperator3":".","iTblCellNumberThousandSeperator3":",","iTblCellThresholdsDp3":"","iTblCellThresholdsText3":"","iColShow4":"true","iTblHeadTextAlign4":"center","iTblTextAlign4":"center","iTblCellFormat4":"normal","iTblCellImageSize4":"200","iTblCellBooleanCheckbox4":"false","iTblCellBooleanColorFalse4":"#ff0000","iTblCellBooleanColorTrue4":"#00ff00","iTblCellNumberDecimals4":"2","iTblCellNumberDecimalSeperator4":".","iTblCellNumberThousandSeperator4":",","iTblCellThresholdsDp4":"","iTblCellThresholdsText4":"","iColShow5":"true","iTblHeadTextAlign5":"center","iTblTextAlign5":"center","iTblCellFormat5":"normal","iTblCellImageSize5":"200","iTblCellBooleanCheckbox5":"false","iTblCellBooleanColorFalse5":"#ff0000","iTblCellBooleanColorTrue5":"#00ff00","iTblCellNumberDecimals5":"2","iTblCellNumberDecimalSeperator5":".","iTblCellNumberThousandSeperator5":",","iTblCellThresholdsDp5":"","iTblCellThresholdsText5":"","iColShow6":"true","iTblHeadTextAlign6":"center","iTblTextAlign6":"center","iTblCellFormat6":"normal","iTblCellImageSize6":"200","iTblCellBooleanCheckbox6":"false","iTblCellBooleanColorFalse6":"#ff0000","iTblCellBooleanColorTrue6":"#00ff00","iTblCellNumberDecimals6":"2","iTblCellNumberDecimalSeperator6":".","iTblCellNumberThousandSeperator6":",","iTblCellThresholdsDp6":"","iTblCellThresholdsText6":"","iColShow7":"true","iTblHeadTextAlign7":"center","iTblTextAlign7":"center","iTblCellFormat7":"normal","iTblCellImageSize7":"200","iTblCellBooleanCheckbox7":"false","iTblCellBooleanColorFalse7":"#ff0000","iTblCellBooleanColorTrue7":"#00ff00","iTblCellNumberDecimals7":"2","iTblCellNumberDecimalSeperator7":".","iTblCellNumberThousandSeperator7":",","iTblCellThresholdsDp7":"","iTblCellThresholdsText7":"","iColShow8":"true","iTblHeadTextAlign8":"center","iTblTextAlign8":"center","iTblCellFormat8":"normal","iTblCellImageSize8":"200","iTblCellBooleanCheckbox8":"false","iTblCellBooleanColorFalse8":"#ff0000","iTblCellBooleanColorTrue8":"#00ff00","iTblCellNumberDecimals8":"2","iTblCellNumberDecimalSeperator8":".","iTblCellNumberThousandSeperator8":",","iTblCellThresholdsDp8":"","iTblCellThresholdsText8":"","iColShow9":"true","iTblHeadTextAlign9":"center","iTblTextAlign9":"center","iTblCellFormat9":"normal","iTblCellImageSize9":"200","iTblCellBooleanCheckbox9":"false","iTblCellBooleanColorFalse9":"#ff0000","iTblCellBooleanColorTrue9":"#00ff00","iTblCellNumberDecimals9":"2","iTblCellNumberDecimalSeperator9":".","iTblCellNumberThousandSeperator9":",","iTblCellThresholdsDp9":"","iTblCellThresholdsText9":"","iTblFixedHead":true,"iTblSortAttr":"Name"},"style":{"left":"355px","top":"36px","width":"1069px","height":"259px","font-size":"small","overflow-y":"scroll"},"widgetSet":"vis-inventwo"}]
                                          das bei den spalten - außer Name -- ein problem sein könnte, könnte daran liegen, das es eigentlich zahlen sind aber ich die einheit auch in den daten habe und es daher ein string ist
                                          metaxa 1 Reply Last reply Reply Quote 0
                                            liv-in-sky @rantanplan last edited by
                                            @rantanplan
                                            das mit den zahlen geht nicht, weil ich die daten samt einheit schreibe - ansonsten müßte man das ohne einheiten machen und dafür mehr im widget einstellen
                                            1.500,30 ist keine javascript zahl ! zahlen in javascript haben immer einen punkt als trennzeichen und kein komma
                                            8864
