    4. JavaScript
    5. Json für SourceAnalytics
    • N
      Nordischerjung @crunchip last edited by
      @crunchip So wäre es in einem Extra DP in 0_userdate, reicht dir das?
      let myArrSourcA=[];
      let myBlacklist=[];
      // Beispiel Blacklist: ['sourceanalytix.0.sonoff__0__SonoffPow3__ENERGY_Total','sourceanalytix.0.sonoff__3__Nous1__ENERGY_Total']
      async function calcJson(){
      myArrSourcA=[];
      $('sourceanalytix.0.*.currentYear.delivered.01_currentDay').each( function( id4, i){
          let idy = id4.split('.');
          if (getObject(id4).common.unit=="kWh" && !myBlacklist.toString().includes(idy[2])){
           let helper=idy[2].split('__');
           let helper2=helper[helper.length-2];
           let theName=getObject(idy[0]+'.'+idy[1]+'.'+idy[2]).common.name   //idy[2].split('__');
           if(theName == undefined)  theName="no Name" ;
           //log( getObject(idy[0]+'.'+idy[1]+'.'+idy[2]).common.name )
                             myArrSourcA.push({
                                 "Name": theName,
                                 "Gestern":getState(id4.replace("01_currentDay","01_previousDay")).val.toFixed(2),
                                 "Heute": getState(id4).val,
                                 "Monat":getState(id4.replace("01_currentDay","03_currentMonth")).val.toFixed(2),
                                 "Jahr": getState(id4.replace("01_currentDay","05_currentYear")).val.toFixed(2),
                                 "Gestern Kosten":getState(id4.replace("delivered.01_currentDay","earnings.01_previousDay")).val.toFixed(2),
                                 "Heute Kosten": getState(id4.replace("delivered.01_currentDay","earnings.01_currentDay")).val.toFixed(2),
                                 "Monats Kosten":getState(id4.replace("delivered.01_currentDay","earnings.03_currentMonth")).val.toFixed(2),
                                 "Jahres Kosten": getState(id4.replace("delivered.01_currentDay","earnings.05_currentYear")).val.toFixed(2)
                             } // ende unit abfrage
      //log(JSON.stringify(myArrSourcA))
      return myArrSourcA;
      async function writeDatapoint(){
      if (!(await existsStateAsync('0_userdata.0.StromJson.StromJsonEin'))) {
             await createStateAsync('0_userdata.0.StromJson.StromJsonEin', "",{type: "string", name: "JSON SourcAnalytics", role: "value", read: true, write: true, } ); }
      // log(JSON.stringify(await calcJson()))
      setState('0_userdata.0.StromJson.StromJsonEin',JSON.stringify(await calcJson()));
      writeDatapoint();
      schedule(' * * * * *',  function () { writeDatapoint();
        liv-in-sky @crunchip last edited by
        @crunchip sagte in Json für SourceAnalytics:
        @liv-in-sky sagte in Json für SourceAnalytics:
        $('sourceanalytix.0.*.currentYear.consumed.01_currentDay').each( function( id4, i){
        Weiss nicht ob du es übersehen hast, für Stromeinspeisung, müsste ich dann noch zuätzlich delivered mit einbauen, geht das so einfach?🤔
        wo muss du das den einbauen - das deliverd - als namenszusatz - wo ist den das delivered gespeichert - oder sind das einfach minus werte - gibt es da einen dp dafür ? habe nicht so viel kenntnis vonsourceanalytics wie du !
          liv-in-sky @metaxa last edited by
          @metaxa sagte in Json für SourceAnalytics:
          Sind für keine listeinträge irgendwelche Platzhalter zu setzen, oder einfach leer lassen?
          leer lassen
          • N
            Nordischerjung @liv-in-sky last edited by Nordischerjung
            @liv-in-sky das sieht ähnlich aus, nur das die Ordner delivered und earnings heißen
            In dem Script habe ich das schon angepasst. Du kannst dir dann ja Gedanken machen, wie du das in deinem Script einpflegst. Mit Var= true für Einspeisung oder oder oder 😁
              liv-in-sky @Nordischerjung last edited by
              @nordischerjung sagte in Json für SourceAnalytics:
              let myArrSourcA=[];
              let myBlacklist=[];
              myArrSourcA=[];
                                     myArrSourcA.push({
                                         "Name": theName,
              return myArrSourcA;
              writeDatapoint();
              @crunchip achso , da gibt es einen delivered folder
              das kann man einfach einfügen, da es unter currentYear ist und man das gut ersetzen kann - soweit ich weiß kann man auch werte im json widget farblich markieren, wenn sie z.b. negativ wären. wenn es aber dann kein consumed gibt, muss man es so machen wie im beispiel von @Nordischerjung - einen extra selektor und dann auch einfach in das array pushen (etwas doof, da man das irgendwie kenntlich machen sollte in der tab
              oder hat du da mehrere davon und willst eine eigene tabelle dafür ?
              könnt ich aber def. einfügen beim script
                liv-in-sky @Nordischerjung last edited by liv-in-sky
                gute idee - ich könnte einfach einen weitern wert in das json setzen - und damit könnte man dann den delivery- wert farblich machen oder einfach den generierten wert auch im widget (delivered/consumed) mit anzeigen
                  blacklist
                  Das ist natürlich die perfekte Profilösung!
                  "unverschämt ein"
                  Gibt es event. auch eine "whitelist"?
                  Für den Fall wenn man aus einer langen SA Liste nur 3 Devices will?
                  "unverschämt aus"
                  whitelist ist machbar aber etwas komplizierter - werd mal drüber nachdenken und muss dafür zeit haben
                    liv-in-sky @crunchip last edited by liv-in-sky
                    @crunchip
                    @Nordischerjung
                    bitte testen - mit delivered - enthält eine extra spalte für delivered/consumed - spaltenname ist "Richtung" ; mir ist nix besseres eingefallen - im widget weitere spalte hinzufügen
                    blacklist funktioniert auch mit delivered werten
                    gas wird nicht abgefragt, außer ihr habt ein fracking feld im garten ?
                    let myArrSourcA=[];
                    let myBlacklist=[];
                    let dataPunkt='0_userdata.0.StromJson.StromJson';
                    let theSchedule=' * * * * *';
                    myArrSourcA=[];
                         if ( !myBlacklist.toString().includes(idy[2])){
                            let theName=getObject(idy[0]+'.'+idy[1]+'.'+idy[2]).common.name;   //idy[2].split('__');
                              myArrSourcA.push({
                                               "Name": theName,
                                               "Jahres Kosten": getState(id4.replace("delivered.01_currentDay","earnings.05_currentYear")).val.toFixed(2),
                                               "Richtung": "<span style=color:green>delivered"
                                           myArrSourcA.push({
                                               "Name": theName,
                                               "Gestern Kosten":getState(id4.replace("consumed.01_currentDay","costs.01_previousDay")).val.toFixed(2),
                                               "Heute Kosten": getState(id4.replace("consumed.01_currentDay","costs.01_currentDay")).val.toFixed(2),
                                               "Monats Kosten":getState(id4.replace("consumed.01_currentDay","costs.03_currentMonth")).val.toFixed(2),
                                               "Jahres Kosten": getState(id4.replace("consumed.01_currentDay","costs.05_currentYear")).val.toFixed(2),
                                               "Richtung": "<span style=color:red>consumed"
                    return myArrSourcA;
                    if (!(await existsStateAsync(dataPunkt))) {
                           await createStateAsync(dataPunkt, "",{type: "string", name: "JSON SourcAnalytics", role: "value", read: true, write: true, } ); }
                    setState(dataPunkt,JSON.stringify(await calcJson()));
                    writeDatapoint();
                    schedule(theSchedule,  function () { writeDatapoint();
                    ich habe keine deliv-werte - daher sieht man die auch nicht
                    • N
                      @crunchip
                      @Nordischerjung
                      Ich auch nicht, hatte es nur für @crunchip gemacht. ich habe leider kein Stromerzeuger
                      Edit:
                      Schnell getestet, funktioniert
                        crunchip Forum Testing Most Active @liv-in-sky last edited by crunchip
                        ja
                        nein, nur das eine Balkonkraftwerk
                        nein, sind nicht negativ, laufen halt nur unter der anderen Kategorie, daher andere Objektstruktur
                        ich guck mir den aktuellen Stand morgen mal an, war heute den ganzen Tag unterwegs
                        edit:
                        hab doch mal schnell das script importiert, allerdings
                        javascript.0
                        2022-10-25 22:25:00.187	error	at processImmediate (node:internal/timers:437:9)
                        javascript.0
                        2022-10-25 22:25:00.186	error	at runNextTicks (node:internal/process/task_queues:61:5)
                        javascript.0
                        2022-10-25 22:25:00.185	error	at runMicrotasks (<anonymous>)
                        javascript.0
                        2022-10-25 22:25:00.185	error	at writeDatapoint (script.js.Visualisierung.Strom-jsonListe:71:41)
                        javascript.0
                        2022-10-25 22:25:00.184	error	at calcJson (script.js.Visualisierung.Strom-jsonListe:10:61)
                        javascript.0
                        2022-10-25 22:25:00.183	error	at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:915:29)
                        javascript.0
                        2022-10-25 22:25:00.183	error	at script.js.Visualisierung.Strom-jsonListe:22:123
                        javascript.0
                        2022-10-25 22:25:00.182	error	script.js.Visualisierung.Strom-jsonListe: TypeError: Cannot read properties of null (reading 'toFixed')
                        javascript.0
                        2022-10-25 22:25:00.180	warn	at processImmediate (node:internal/timers:437:9)
                        javascript.0
                        2022-10-25 22:25:00.179	warn	at runNextTicks (node:internal/process/task_queues:61:5)
                        javascript.0
                        2022-10-25 22:25:00.179	warn	at runMicrotasks (<anonymous>)
                        javascript.0
                        2022-10-25 22:25:00.178	warn	at writeDatapoint (script.js.Visualisierung.Strom-jsonListe:71:41)
                        javascript.0
                        2022-10-25 22:25:00.177	warn	at calcJson (script.js.Visualisierung.Strom-jsonListe:10:61)
                        javascript.0
                        2022-10-25 22:25:00.176	warn	at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:915:29)
                        javascript.0
                        2022-10-25 22:25:00.175	warn	at script.js.Visualisierung.Strom-jsonListe:22:45
                        javascript.0
                        2022-10-25 22:25:00.168	warn	getState "sourceanalytix.0.javascript__0__ShellyVerbrauch__shellyplus1pm#7c87ce64d518#1__Relay0__gesamt.currentYear.earnings.01_previousDay" not found (3)
                        guck ich morgen warum
                        liv-in-sky N 2 Replies Last reply Reply Quote 0
                          moin - sind da datenpunkte, die nicht bzw. noch nie beschrieben sind ?
                          • N
                            Nordischerjung @crunchip last edited by Nordischerjung
                            @liv-in-sky @crunchip sagte in Json für SourceAnalytics:
                            Moin, gibt es vielleicht diesen DP nicht? Sieht die Struktur bei dem anders aus?
                              @liv-in-sky ja, das Jahr, Kraftwerk läuft ja noch kein Jahr, aber das müsste ja dann bei anderen Geräten auch kommen, die noch kein Jahr laufen
                                @crunchip
                                tja - das weiß ich nicht - ich wollte aber nicht für jeden einzelnen prüfen, ob da was drin steht - bitte mit sourceanal.-entwickler klären
                                was kann ich tun ? du kannst einfach ändern, falls ein dp ärger macht z.b. bei "Gestern":
                                           myArrSourcA.push({
                                                            "Name": theName,
                                                            "Gestern": "not available", //getState(id4.replace("01_currentDay","01_previousDay")).val.toFixed(2),
                                • N
                                  @liv-in-sky @crunchip eigentlich sollte dann 0 drin stehen. Ist bei meinem Test auch so.
                                  Zeig doch mal bitte ein Screenshot von den DPs
                                    crunchip Forum Testing Most Active @Nordischerjung last edited by crunchip
                                    @nordischerjung @liv-in-sky ich habe die zwei noch ausstehenden Datenpunkte in orange hinterlegten nun beschrieben mit 0.
                                    allerdings weiß ich nun wo der Fehler liegt, den angemeckerten DP gibt es bei mir nicht, obwohl eigentlich die Preisdefinition(earnings) richtig ist für`s BKW
                                    N liv-in-sky 2 Replies Last reply Reply Quote 0
                                    • N
                                      @crunchip Hast du bei der Einstellung am DP Kosten berechnen aktiviert?
                                      liv-in-sky crunchip 2 Replies Last reply Reply Quote 0
                                        @crunchip
                                        wenn es das nicht gibt, bitte im script auskommentieren oder eigene werte eingeben
                                        bin von dem ausgegangen
                                        https://forum.iobroker.net/post/879679
                                          @nordischerjung
                                          danke - muss man wohl aktivieren 🙂
                                          • N
                                            @liv-in-sky Ja, das ist der Haken für den Ordner earnings
                                            8864
