    • Sternmiere
      Sternmiere @Armilar last edited by
      @armilar sagte in SONOFF NSPanel mit Lovelace UI:
      SetOption146 1
      Super, vielen Dank! Hat geklappt!
      • Armilar
        Armilar Most Active Forum Testing @Sternmiere last edited by Armilar
        @sternmiere
        Perfekt. Das mit der cardQR klappt auch. Hab es in die v3.5.0 noch reingenommen. Falls du vorher testen möchtest:
        function GenerateQRPage austauschen (siehe Spoiler)
        function GenerateQRPage(page: PageQR): Payload[] {
            try {
                activePage = page;
                var id = page.items[0].id
                var out_msgs: Array<Payload> = [];
                out_msgs.push({ payload: 'pageType~cardQR' });
                let o = getObject(id)
                var heading = page.heading !== undefined ? page.heading : o.common.name.de
                var textQR = page.items[0].id + '.ACTUAL' !== undefined ? getState(page.items[0].id + '.ACTUAL').val : 'WIFI:T:undefined;S:undefined;P:undefined;H:undefined;'
                var hiddenPWD = false;
                if (page.items[0].hidePassword !== undefined && page.items[0].hidePassword == true) {
                    hiddenPWD = true
                const tempstr = textQR.split(';');
                for (let w = 0; w < tempstr.length - 1; w++) {
                    if (tempstr[w].substring(0, 1) == 'S') {
                        var optionalValue1 = tempstr[w].slice(2);
                    if (tempstr[w].substring(0, 1) == 'P') {
                        var optionalValue2 = tempstr[w].slice(2);
                var type1 = 'text';
                var internalName1 = 'SSID';
                var iconId1 = Icons.GetIcon('wifi');
                var displayName1 = 'SSID';
                var type2 = 'text';
                var internalName2 = 'Passwort';
                var iconId2 = Icons.GetIcon('key');
                var displayName2 = 'Passwort';
                if (hiddenPWD) {
                    type2 = 'disable';
                    iconId2 = '';
                    displayName2 = '';
                out_msgs.push({
                    payload: 'entityUpd~' +                     //entityUpd
                        heading + '~' +                         //heading
                        GetNavigationString(pageId) + '~' +     //navigation
                        textQR + '~' +                          //textQR
                        type1 + '~' +                           //type
                        internalName1 + '~' +                   //internalName
                        iconId1 + '~' +                         //iconId
                        65535 + '~' +                           //iconColor
                        displayName1 + '~' +                    //displayName
                        optionalValue1 + '~' +                  //optionalValue
                        type2 + '~' +                           //type
                        internalName2 + '~' +                   //internalName
                        iconId2 + '~' +                         //iconId
                        displayName2 + '~' +                    //displayName
                        optionalValue2
                });                       //optionalValue
                //entityUpd,heading,navigation,textQR[,type,internalName,iconId,displayName,optionalValue]x2
                return out_msgs
            } catch (err) {
                console.warn('function GenerateQRPage: ' + err.message);
        type PageItem austauschen (siehe Spoiler) / fast am Ende des TS-Script
        type PageItem = {
            icon: (string | undefined),
            icon2: (string | undefined),
            onColor: (RGB | undefined),
            offColor: (RGB | undefined),
            useColor: (boolean | undefined),
            interpolateColor: (boolean | undefined),
            minValueBrightness: (number | undefined),
            maxValueBrightness: (number | undefined),
            minValueColorTemp: (number | undefined),
            maxValueColorTemp: (number | undefined),
            minValue: (number | undefined),
            maxValue: (number | undefined),
            name: (string | undefined),
            secondRow: (string | undefined),
            buttonText: (string | undefined),
            unit: (string | undefined),
            navigate: (boolean | undefined),
            colormode: (string | undefined),
            adapterPlayerInstance: (string | undefined),
            mediaDevice: (string | undefined),
            targetPage: (string | undefined),
            speakerList: (string[] | undefined),
            hidePassword: (boolean | undefined)
        Definition cardQR im PageItem um ", hidePassword: true" erweitern
        var WLAN: PageQR =
                    "type": "cardQR",
                    "heading": "Gäste WLAN",
                    "useColor": true,
                    "subPage": true,
                    "parent": Subpages_1,
                    "items": [<PageItem>{ id: "alias.0.NSPanel_1.Guest_Wifi", hidePassword: true }]
        Sternmiere 1 Reply Last reply Reply Quote 0
        • Sternmiere
          Sternmiere @Armilar last edited by Sternmiere
          @armilar
          Diesen Fehler bekomme ich bei mir:
          (local var) iconId2: any
          Subsequent variable declarations must have the same type.  Variable 'iconId2' must be of type 'any', but here has type 'string'.(2403)
          index345678910.(2569, 13): 'iconId2' was also declared here.
          Wenn ich das var vor iconId2 in der Abfrage hiddenPWD entferne, dann kann ich das Skript speichern. Und dann ist das PW auch ausgeblendet!
          • Armilar
            @sternmiere
            Dummer copy/paste-Fehler von mir - sorry
            Alle Variablen-Deklarationen in dem Block sollten raus. Dafür die oberen wieder rein:
                    if (hiddenPWD) {
                        type2 = 'disable';
                        iconId2 = '';
                        displayName2 = '';
            Ich korrigiere das gleich oben im vorherigen Post nochmal...
            Edit: Erledigt, oberer Post (Spoiler 1) korrigiert.
            • Sternmiere
              @armilar
              hatte ich bei mir lokal auch schon so eingebaut!
              Damit klappt das 1A! Super! Vielen Dank für die schnelle Umsetzung!
              • Armilar
                @sternmiere
                Gerne 👍
                • Armilar
                  Armilar Most Active Forum Testing @Armilar last edited by
                  Upgrade auf TS-Script 3.5.0
                  und Neuer Parameter in zum Ausblenden des WLAN-Passwortes in der cardQR (Hotfix)
                  Ebenfalls neue TFT-Firmware v3.5.0
                  FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.5.0.tft
                  TS-Script v3.5.0
                  • Mit Beispiel-Seiten
                    https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/ioBroker/NsPanelTs.ts
                  • Ohne Beispiel-Seiten
                    https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/ioBroker/NsPanelTs_without_Examples.ts
                  Änderungen
                  • Die Hintergrundfarbe lässt sich jetzt ändern:
                  export const config: Config = {
                      defaultBackgroundColor: Black,      //New Parameter
                  • cardPower (Energiefluss)
                    https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Card-Definitionen-(Seiten)#cardpower-ab-ts-script-v341
                  • Layout 2 für popUpNotification (Skript erweitert Datenpunkte unter 0_userdata.0...)
                    Beschreibung in der Wiki folgt. Blockly-Emulator zum Testen im nachfolgenden Post...
                  • popUpShutter erweitert um Tilt-Funktion
                  • Direkte Navigation über Datenpunkt
                    Beschreibung in Wiki folgt...
                  Armilar 2 Replies Last reply Reply Quote 2
                  • Armilar
                    Emulations-Test-Blockly für popUpNotify (Layout 2)
                    https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Card-Definitionen-(Seiten)#emulator-layout-2
                    • Sternmiere
                      Hab das Update inkl TFT gleich mal ausgeführt.
                      Bislang klappt alles.
                      Aber eine Frage zum Update selbst:
                      Ich finde es recht kompliziert und fehleranfällig, die einzelnen Teile rund um meine Seitengestaltung und Konfiguration herum zu kopieren.
                      Wäre es nicht möglich, den Block mit der Konfiguration (export const config: Config...) in eine eigene TS-Datei auszulagern?
                      Und kann man nicht ebenso innerhalb des nspanel-Ordners die Seitengestaltung in eigene TS-Datei(en) auszulagern?
                      Würde den Update-Vorgang wahrscheinlich vereinfachen.
                      Armilar 1 Reply Last reply Reply Quote 1
                      • Armilar
                        @sternmiere
                        Ist in Planung zu den kälteren und dunkleren Tagen des Jahres 😉
                        • Sternmiere
                          Cool!
                          Noch ein zwei andere Fragen:
                          Wenn ich zwischen den Hauptseiten blättere, dann kann ich aktuell nicht sauber durch die Seiten scrollen. Ich bleibe bei der zweiten Seite hängen, muss dann einmal in eine Unterscheite (oder waren bis der Screensaver angeht) und dann kann ich zur nächsten Seite blättern. Ist das ein Konfigurationsfehler bei mir?
                          Und gibt es die Möglichkeit, wenn ich bei der letzten Seite angekommen bin, mit einem Klick nach rechts dann wieder auf die erste Seite zu springen? Damit man dann quasi im Ring durch die Seiten scrollen kann.
                          Armilar K 2 Replies Last reply Reply Quote 0
                          • Armilar
                            @sternmiere
                            Probleme beim Scrollen habe ich eigentlich gaaaaanz selten mal. Wenn die Seiten grundsätzlich funktionieren, würde ich einen Konfigurationsfehler ausschließen.
                            Aber die Idee am Ende auf die erste Seite weiter zu springen finde ich Mega. Sehe ich mir die Tage mal an.
                            • Sternmiere
                              Sternmiere last edited by Sternmiere
                              Moin, bzgl. meiner Scroll/Blätterproblematik mache ich, wenn ich mit allen Seiten fertig bin, mal ein kurzes Video.
                              Ansonsten habe ich aktuell ein Problem bei der Anzeige meines Garagentor-Status:
                              Ich habe das Garagentor als "Tor" unter Geräte eingerichtet. Allerdings musste ich den Datenpunkt ACTUAL von value.bind auf boolean umstellen, da ich bei mir nur via Reed-Kontakt den geschlossenen Zustand vom Garagentor abfragen kann.
                              Wenn ich nun diesen Alias als PageItem angebe, wird in der Grid kein Icon angezeigt - auch nicht, wenn ich explizit ein Icon angebe.
                              Aktuell habe ich mir jetzt als workaround damit beholfen, dass ich das Garagentor nochmals als sensor.door eingebunden habe und hier dann mit dem Icon "garage" überschreibe.
                              Ist das ein Fehler im Skript? Oder wird der Geräte-Typ "Tor" schlicht noch nicht unterstützt?
                              //Update zur Frage:
                              <PageItem>{ id: "alias.0.Kontaktsensoren.Garage", offColor: MSGreen, onColor: MSRed, name: "Garagentor", icon: "garage", icon2: "garage-open" }
                              So sieht mein PageItem zum Garagentor aktuell aus. Ich dachte, mit icon2 kann ich im offenen Zustand das Icon austauschen. Falsch gedacht. Ist das Tor offen, wird das Icon nur rot, bleibt aber bei dem icon garage. Wozu ist denn dann icon2 da?
                              Armilar 2 Replies Last reply Reply Quote 0
                                Tom_W last edited by
                                also mittlerweile bin ich durchgestiegen, vielen Dank Armilar für deine Geduld. 🙂
                                Aber eine Frage habe ich noch: Gibt es irgendwo eine Übersicht mit allen zur Verfügung stehenden Icons?
                                • Sternmiere
                                  Die Icon-Übersicht findest Du hier:
                                  https://htmlpreview.github.io/?https://github.com/jobr99/Generate-HASP-Fonts/blob/master/cheatsheet.html
                                  • Armilar
                                    @sternmiere
                                    Das VirtualDevice "Tor" (gate) mit SET (switch.gate) ist noch nicht implementiert. Kann ich aber mit aufnehmen. Wenn ein Gerätetyp nicht im TS-Script angelegt ist, dann kann dieser auch nicht eingebunden werden.
                                    Die Wahl auf den Gerätetyp Fenster (analog Tür) ist soweit okay, jedoch sind die Icons nicht überschreibbar (noch nicht). Wäre die Bessere Wahl für einen boolschen Wert wahrscheinlich socket oder light gewesen.
                                    Ich werde das Tor heute noch testweise implementieren und informiere dich dann.
                                      Gre4t0ne @Armilar last edited by
                                      @armilar DANKE! Bei mir hing hinten noch ein 'URLS' drann...
                                      • Armilar
                                        @sternmiere sagte in SONOFF NSPanel mit Lovelace UI:
                                        function CreateEntity(pageItem: PageItem, placeId: number, useColors: boolean = false): string {
                                                        case 'blind':
                                                            type = 'shutter';
                                                            iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : Icons.GetIcon('window-open');
                                                            iconColor = GetIconColor(pageItem, existsState(pageItem.id + '.ACTUAL') ? getState(pageItem.id + '.ACTUAL').val : true, useColors);
                                                            return '~' + type + '~' + pageItem.id + '~' + iconId + '~' + iconColor + '~' + name + '~';
                                                        case 'gate':
                                                            type = 'text';
                                                            if (existsState(pageItem.id + '.ACTUAL')) {
        if (getState(pageItem.id + '.ACTUAL').val == 0 || getState(pageItem.id + '.ACTUAL').val === false) {
        iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : Icons.GetIcon('garage');
        iconColor = GetIconColor(pageItem, false, useColors);
        var gateState = findLocale('window', 'closed');
        } else {
        iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : Icons.GetIcon('garage-open');
        iconId = pageItem.icon2 !== undefined ? Icons.GetIcon(pageItem.icon2) : Icons.GetIcon('garage-open');
        iconColor = GetIconColor(pageItem, true, useColors);
        var gateState = findLocale('window', 'opened');
        RegisterEntityWatcher(pageItem.id + '.ACTUAL');
                                                            return '~' + type + '~' + pageItem.id + '~' + iconId + '~' + iconColor + '~' + name + '~' + gateState;
                                                        case 'door':
                                                        case 'window':
                                                            type = 'text';
                                        Irgendwo in der "function CreateEntity" gibt es de Typen 'blind' und 'door'
                                        dazwischen (siehe oben) den case 'gate': einbauen. Dann sollte es funktionieren.
                                        Es wird auf boolean oder number geprüft, deshalb sollte auch ein Reed-Kontakt mit true/false funktionieren.
                                        Sternmiere 1 Reply Last reply Reply Quote 1
                                        • Sternmiere
                                          Moin,
                                          klappt soweit super. Allerdings wird bei mir bei geschlossenem Garagentor das offene Symbol gezeigt und umgedreht.
                                          Das liegt schlicht an meinem Reed-Kontakt, der bei geschlossenem Tor TRUE liefert.
                                          Kann ich das im Alias irgendwo invertieren? Oder macht es hier Sinn, noch eine Abfrage für den Status einzubauen, was das TRUE letztendlich bedeutet?
                                          Armilar 2 Replies Last reply Reply Quote 1
                                          • Armilar
                                            @sternmiere
                                            <PageItem>{ id: "alias.0.Kontaktsensoren.Garage", offColor: MSGreen, onColor: MSRed, name: "Garagentor", icon: "garage-open", icon2: "garage" }
                                            Da du ja die cardGrid verwendest und den Text opened/closed nicht benötigst, könntest du jetzt einfach die Icons (icon/icon2) ebenfalls drehen (siehe PageItem --> einfachste Variante)
                                            Alternativ kannst du auf den ACTUAL im Alias reagieren und den "val" über eine Funktion im Alias invertieren.
                                            !val
                                            Oder über einen zusätzlichen Datenpunkt gehen, der die Invertierung macht
                                            lovelace ui nspanel sonoff
                                            271
                                            7720
                                            6628888
