    3. Off Topic
    4. Upgrade von Debian 10 'Buster' auf 11 'Bullseye'
      Thomas Braun Most Active @Supernils last edited by Thomas Braun
      @supernils
      Stell die Quellen um:
      sudo sed -i 's/bullseye\/updates/bullseye-security/g' /etc/apt/sources.list
      sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list
      sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list.d/*
      Dann
      sudo apt update
        Supernils @Thomas Braun last edited by
        @thomas-braun said in Upgrade von Debian 10 'Buster' auf 11 'Bullseye':
        @supernils
        Dann
        sudo apt update
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Get:2 https://deb.nodesource.com/node_16.x bullseye InRelease [4,586 B]
        Get:3 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
        Get:4 http://raspbian.raspberrypi.org/raspbian bullseye/contrib armhf Packages [60.2 kB]
        Get:5 http://raspbian.raspberrypi.org/raspbian bullseye/non-free armhf Packages [106 kB]
        Get:6 http://raspbian.raspberrypi.org/raspbian bullseye/rpi armhf Packages [1,360 B]
        Get:7 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [307 kB]
        Get:8 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages [783 B]
        Fetched 504 kB in 6s (80.2 kB/s)
        Reading package lists... Done
        Building dependency tree
        All packages are up to date.
          @supernils
          cat /etc/debian_version
            @supernils
            10.13
              @supernils
              Das kann doch gar nicht sein.
              Bitte vollständige Ein- wie Ausgabezeilen posten. Inkl. login prompt.
                @supernils
                Linux raspberrypi4-iobroker 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
                The programs included with the Debian GNU/Linux system are free software;
                the exact distribution terms for each program are described in the
                individual files in /usr/share/doc/*/copyright.
                Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                permitted by applicable law.
                Last login: Wed Oct 26 12:17:39 2022 from 192.168.192.2
                pi@raspberrypi4-iobroker:~ $ sudo apt update
                Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
                Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list:1 and /etc/apt/sources.list.d/pivpn-bullseye.list:1
                W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:1 and /etc/apt/sources.list.d/pivpn-bullseye.list:1
                W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list:1 and /etc/apt/sources.list.d/pivpn-bullseye.list:1
                W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:1 and /etc/apt/sources.list.d/pivpn-bullseye.list:1
                pi@raspberrypi4-iobroker:~ $ cat /etc/debian_version
                10.13
                  @supernils sagte in Upgrade von Debian 10 'Buster' auf 11 'Bullseye':
                  Die Doubletten müssen aus den Dateien raus.
                  Es darf pro Repo nur einen Eintrag im gesamten /etc/apt/* geben.
                    Das hatte ich bereits gefixt. Hat aber nicht gebracht...
                    Ich versuche es nochmal. Ich kommentiere den Eintrag
                    deb http://raspbian.raspberrypi.org/raspbian/ bullseye main
                    in pivpn-bullseye.list
                    Ergebnis:
                    Last login: Wed Oct 26 12:49:28 2022 from 192.168.192.2
                    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                      @supernils
                      cat /etc/apt/sources.list
                      cat /etc/apt/sources.list.d/*
                      apt policy base-files
                        @supernils
                        pi@raspberrypi4-iobroker:~ $ cat /etc/apt/sources.list
                        deb http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
                        # Uncomment line below then 'apt-get update' to enable 'apt-get source'
                        #deb-src http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-fre        e rpi
                        pi@raspberrypi4-iobroker:~ $ cat /etc/apt/sources.list.d/*
                        deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/no        de_16.x bullseye main
                        deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.co        m/node_16.x bullseye main
                        #deb http://raspbian.raspberrypi.org/raspbian/ bullseye main
                        deb http://archive.raspberrypi.org/debian/ bullseye main
                        #deb-src http://archive.raspberrypi.org/debian/ bullseye main
                        ### Disabled by raspberrypi-sys-mods ###
                        pi@raspberrypi4-iobroker:~ $ apt policy base-files
                        base-files:
                          Installed: 10.3+rpi1+deb10u13
                          Candidate: 10.3+rpi1+deb10u13
                          Version table:
                             11.1+rpi1+deb11u5 -1
                                 -1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package        s
                         *** 10.3+rpi1+deb10u13 100
                                100 /var/lib/dpkg/status
                          Da hast du aber mal mit dem Pinning/der Priority herumgespielt. Mit -1 gegen 100 kommt da natürlich nie was an bzw. wird nie aus dem bullseye Repo was installiert werden.
                          Ich müsste aber jetzt auch buddeln, wo am das so einstellt. Es sollte in
                          ls -lA /etc/apt/preferences.d/
                          eine Definitionsdatei geben, wenn es richtig gemacht wurde.
                            Supernils @Thomas Braun last edited by Supernils
                            Ja dort liegt eine pivpn-limit-bullseye
                            Package: *
                            Pin: release n=bullseye
                            Pin-Priority: -1
                            Package: wireguard wireguard-dkms wireguard-tools
                            Pin-Priority: 100
                            Nach dem Löschen der Datei funktioniert das Update. Da wäre ich nie drauf gekommen. Vielen Dank.
                              @supernils
                              Das ist die Gefahr, wenn man da ThirdParty-Repos anlegt. Die können dir den Paketmanager komplett aus dem Ruder laufen lassen.
                              Was ist denn pivpn-bullseye.list für Zeuch?
                                @supernils
                                Das ist wireguard
                                  @supernils
                                  Die Quelle würde ich komplett stilllegen.
                                  wireguard kommt auch über die regulären debian-Repos rein.
                                    @supernils
                                    Aber erst nach dem Upgrade auf bullseye stilllegen, richtig? Was würde auf buster passieren?
                                      Nichts.
                                        Nichts.
                                        Sicher? Dann würde doch buster als Quelle verwendet werden. Unterscheiden sich die Pakete nicht?
                                          @supernils Du hast doch jetzt alle Quellen auf bullseye gesetzt? Dann greift der Paketmanager auch auf diese Quellen zurück.
                                            @supernils
                                            Mit
                                            apt policy wireguard*
                                            siehst du die derzeitige Rangfolge.
                                            309
                                            82733
