    3. Einsteigerfragen
    4. JS-Controller update, was jetzt
      silbroker @silbroker last edited by
      @silbroker
      pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
      ln: failed to create symbolic link '/usr/bin/nodejs': File exists
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v12.19.0
      v12.19.0
      6.14.8
      internal/modules/cjs/loader.js:834
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:831:15)
          at Function.Module._load (internal/modules/cjs/loader.js:687:27)
          at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
          at internal/main/run_main_module.js:17:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      pi@raspberrypi:~ $
        Thomas Braun Most Active @silbroker last edited by Thomas Braun
        @silbroker
        Zuerst mal die angegammelte, tote nodejs@12 Installation in die Gegenwart holen. Node@16 ist angesagt.
        Also seit November 2020 das System nicht mehr angepackt?
        Ist der Rest auch so verfallen?
          silbroker @Thomas Braun last edited by silbroker
          pi@raspberrypi:~ $ curl -sL https:deb.nodesource.com/setup_16.x | sudo -E bash -                                                 pi@raspberrypi:~ $ sudo apt install -y nodejs
          Reading package lists... Done
          Building dependency tree
          nodejs is already the newest version (12.19.0-1nodesource1).
          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          wiso sagt er 12.19 sei due neueste?
            @silbroker
            sudo apt update
            apt policy nodejs
              pi@raspberrypi:~ $ sudo apt update
              Hit:1 http://phoscon.de/apt/deconz buster InRelease
              Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Hit:3 http://archive.raspberrypi.org/debian buster InRelease
              Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
              191 packages can be upgraded. Run 'apt list --upgradable' to see them.
              pi@raspberrypi:~ $ apt policy nodejs
              nodejs:
                Installed: 12.19.0-1nodesource1
                Candidate: 12.22.12-deb-1nodesource1
                Version table:
                   12.22.12-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
               *** 12.19.0-1nodesource1 100
                      100 /var/lib/dpkg/status
                   10.24.0~dfsg-1~deb10u2 500
              das heist?
                @silbroker sagte in JS-Controller update, was jetzt:
                Das heißt, dass du zunächst mal den Stau da auflösen wirst.
                sudo apt update
                sudo apt full-upgrade
                sudo reboot
                Dann nodejs@16 installieren und dann schauen wir mal weiter nach dem ioBroker.
                  pi@raspberrypi:~ $ curl -sL https:deb.nodesource.com/setup_16.x | sudo -E bash -                             pi@raspberrypi:~ $ sudo apt update
                  All packages are up to date.
                  nodejs:
                    Installed: 12.22.12-deb-1nodesource1
                    Version table:
                   *** 12.22.12-deb-1nodesource1 500
                  pi@raspberrypi:~ $
                  jetzt habe ich 12.22.12
                    @silbroker
                    sudo apt update
                    apt policy nodejs
                      @silbroker
                      Und mal in die
                      cat /etc/apt/sources.list.d/nodesource.list
                      schauen.
                        pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/nodesource.list
                        deb https://deb.nodesource.com/node_12.x buster main
                        deb-src https://deb.nodesource.com/node_12.x buster main
                        so?
                          @silbroker
                          Nach dem Installationsskript für nodejs16 sollte die eigentlich so aussehen:
                          deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                          deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                          Was sagt denn:
                          curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
                          so?
                            The following packages will be upgraded:
                              nodejs
                            1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                            Need to get 24.2 MB of archives.
                            After this operation, 2,727 kB of additional disk space will be used.
                            Get:1 https://deb.nodesource.com/node_16.x buster/main armhf nodejs armhf 16.18.0-deb-1nodesource1 [24.2 MB]
                            Fetched 24.2 MB in 2s (10.3 MB/s)
                            apt-listchanges: Reading changelogs...
                            (Reading database ... 57436 files and directories currently installed.)
                            Preparing to unpack .../nodejs_16.18.0-deb-1nodesource1_armhf.deb ...
                            Unpacking nodejs (16.18.0-deb-1nodesource1) over (14.20.1-deb-1nodesource1) ...
                            Setting up nodejs (16.18.0-deb-1nodesource1) ...
                            Processing triggers for man-db (2.8.5-2) ...
                            deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main
                            deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main
                            pi@raspberrypi:~ $
                            jetzt ist gegangen.
                              Wo kam denn die 14.20.1 nun her?
                                habe zuerst die 14er kopiert und ausgeführt
                                und dann gemerkt das es geht.
                                Danach noch die 16er
                                  @silbroker
                                  Und was kommt bei
                                  uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                  jetzt um's Eck?
                                    Mach bitte nicht irgendwas nebenher von dem ich nichts weiß. Das macht es nicht leichter dir zu helfen! Im Gegenteil...
                                      pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                      armv7l
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      v16.18.0
                                      v16.18.0
                                      8.19.2
                                      pi
                                      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                                      /home/pi
                                      Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
                                      nodejs:
                                        Installed: 16.18.0-deb-1nodesource1
                                        Candidate: 16.18.0-deb-1nodesource1
                                        Version table:
                                       *** 16.18.0-deb-1nodesource1 500
                                              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                        @silbroker
                                        iobroker restart
                                        iobroker status
                                          pi@raspberrypi:~ $ iobroker restart
                                          pi@raspberrypi:~ $ iobroker status
                                          node:internal/modules/cjs/loader:988
                                            throw err;
                                              at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
                                              at Function.Module._load (node:internal/modules/cjs/loader:833:27)
                                              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                              at node:internal/main/run_main_module:22:47 {
                                            requireStack: []
                                          pi@raspberrypi:~ $
                                            @silbroker
                                            iobroker stop
                                            cd /opt/iobroker
                                            sudo -H -u iobroker npm install iobroker.js-controller
                                            iobroker start
                                            3784
