    3. Einsteigerfragen
    4. JS-Controller update, was jetzt
      silbroker @Thomas Braun last edited by silbroker
      pi@raspberrypi:~ $ curl -sL https:deb.nodesource.com/setup_16.x | sudo -E bash -                                                 pi@raspberrypi:~ $ sudo apt install -y nodejs
      Reading package lists... Done
      Building dependency tree
      nodejs is already the newest version (12.19.0-1nodesource1).
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      wiso sagt er 12.19 sei due neueste?
        Thomas Braun Most Active @silbroker last edited by
        @silbroker
        sudo apt update
        apt policy nodejs
          pi@raspberrypi:~ $ sudo apt update
          Hit:1 http://phoscon.de/apt/deconz buster InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:3 http://archive.raspberrypi.org/debian buster InRelease
          Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
          191 packages can be upgraded. Run 'apt list --upgradable' to see them.
          pi@raspberrypi:~ $ apt policy nodejs
          nodejs:
            Installed: 12.19.0-1nodesource1
            Candidate: 12.22.12-deb-1nodesource1
            Version table:
               12.22.12-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
           *** 12.19.0-1nodesource1 100
                  100 /var/lib/dpkg/status
               10.24.0~dfsg-1~deb10u2 500
          das heist?
            Thomas Braun Most Active @silbroker last edited by Thomas Braun
            @silbroker sagte in JS-Controller update, was jetzt:
            Das heißt, dass du zunächst mal den Stau da auflösen wirst.
            sudo apt update
            sudo apt full-upgrade
            sudo reboot
            Dann nodejs@16 installieren und dann schauen wir mal weiter nach dem ioBroker.
              pi@raspberrypi:~ $ curl -sL https:deb.nodesource.com/setup_16.x | sudo -E bash -                             pi@raspberrypi:~ $ sudo apt update
              All packages are up to date.
              nodejs:
                Installed: 12.22.12-deb-1nodesource1
                Version table:
               *** 12.22.12-deb-1nodesource1 500
              pi@raspberrypi:~ $
              jetzt habe ich 12.22.12
                @silbroker
                sudo apt update
                apt policy nodejs
                  @silbroker
                  Und mal in die
                  cat /etc/apt/sources.list.d/nodesource.list
                  schauen.
                    pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/nodesource.list
                    deb https://deb.nodesource.com/node_12.x buster main
                    deb-src https://deb.nodesource.com/node_12.x buster main
                    so?
                      @silbroker
                      Nach dem Installationsskript für nodejs16 sollte die eigentlich so aussehen:
                      deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                      deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                      Was sagt denn:
                      curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
                      so?
                        The following packages will be upgraded:
                          nodejs
                        1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                        Need to get 24.2 MB of archives.
                        After this operation, 2,727 kB of additional disk space will be used.
                        Get:1 https://deb.nodesource.com/node_16.x buster/main armhf nodejs armhf 16.18.0-deb-1nodesource1 [24.2 MB]
                        Fetched 24.2 MB in 2s (10.3 MB/s)
                        apt-listchanges: Reading changelogs...
                        (Reading database ... 57436 files and directories currently installed.)
                        Preparing to unpack .../nodejs_16.18.0-deb-1nodesource1_armhf.deb ...
                        Unpacking nodejs (16.18.0-deb-1nodesource1) over (14.20.1-deb-1nodesource1) ...
                        Setting up nodejs (16.18.0-deb-1nodesource1) ...
                        Processing triggers for man-db (2.8.5-2) ...
                        deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main
                        deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main
                        pi@raspberrypi:~ $
                        jetzt ist gegangen.
                          Wo kam denn die 14.20.1 nun her?
                            habe zuerst die 14er kopiert und ausgeführt
                            und dann gemerkt das es geht.
                            Danach noch die 16er
                              @silbroker
                              Und was kommt bei
                              uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                              jetzt um's Eck?
                                Mach bitte nicht irgendwas nebenher von dem ich nichts weiß. Das macht es nicht leichter dir zu helfen! Im Gegenteil...
                                  pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                  armv7l
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v16.18.0
                                  v16.18.0
                                  8.19.2
                                  pi
                                  pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                                  /home/pi
                                  Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
                                  nodejs:
                                    Installed: 16.18.0-deb-1nodesource1
                                    Candidate: 16.18.0-deb-1nodesource1
                                    Version table:
                                   *** 16.18.0-deb-1nodesource1 500
                                          500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                    @silbroker
                                    iobroker restart
                                    iobroker status
                                      pi@raspberrypi:~ $ iobroker restart
                                      pi@raspberrypi:~ $ iobroker status
                                      node:internal/modules/cjs/loader:988
                                        throw err;
                                      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
                                          at Function.Module._load (node:internal/modules/cjs/loader:833:27)
                                          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                          at node:internal/main/run_main_module:22:47 {
                                        code: 'MODULE_NOT_FOUND',
                                        requireStack: []
                                      pi@raspberrypi:~ $
                                        @silbroker
                                        iobroker stop
                                        cd /opt/iobroker
                                        sudo -H -u iobroker npm install iobroker.js-controller
                                        iobroker start
                                          @thomas-braun sagte in JS-Controller update, was jetzt:
                                          iobroker start
                                          pi@raspberrypi:~ $ cd /opt/iobroker
                                          pi@raspberrypi:/opt/iobroker $
                                          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                                          npm WARN old lockfile
                                          npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                                          npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                                          npm WARN old lockfile This is a one-time fix-up, please be patient...
                                          npm WARN deprecated @types/keyv@4.2.0: This is a stub types definition. keyv provides its own type definitions, so you do not need this installed.
                                          added 682 packages, removed 21 packages, and changed 29 packages in 2m
                                          101 packages are looking for funding
                                            run `npm fund` for details
                                          pi@raspberrypi:/opt/iobroker $ iobroker start
                                          jetzt ist sie wieder online. Muss ich sonst noch etwas machen / beachten?
                                            @silbroker
                                            iobroker update -i
                                            iobroker status
                                            3784
