    3. Einsteigerfragen
    4. JS-Controller update, was jetzt
      silbroker @Thomas Braun last edited by
      pi@raspberrypi:~ $ curl -sL https:deb.nodesource.com/setup_16.x | sudo -E bash -                             pi@raspberrypi:~ $ sudo apt update
      Hit:1 http://phoscon.de/apt/deconz buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:3 http://archive.raspberrypi.org/debian buster InRelease
      Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
      Reading package lists... Done
      Building dependency tree
      All packages are up to date.
      pi@raspberrypi:~ $ apt policy nodejs
      nodejs:
        Installed: 12.22.12-deb-1nodesource1
        Candidate: 12.22.12-deb-1nodesource1
        Version table:
       *** 12.22.12-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u2 500
      pi@raspberrypi:~ $
      jetzt habe ich 12.22.12
        Thomas Braun Most Active @silbroker last edited by
        @silbroker
        sudo apt update
        apt policy nodejs
          @silbroker
          Und mal in die
          cat /etc/apt/sources.list.d/nodesource.list
          schauen.
            pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/nodesource.list
            deb https://deb.nodesource.com/node_12.x buster main
            deb-src https://deb.nodesource.com/node_12.x buster main
            so?
              @silbroker
              Nach dem Installationsskript für nodejs16 sollte die eigentlich so aussehen:
              deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
              deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
              Was sagt denn:
              curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
              so?
                pi@raspberrypi:~ $ sudo apt install -y nodejs
                The following packages will be upgraded:
                  nodejs
                1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                Need to get 24.2 MB of archives.
                After this operation, 2,727 kB of additional disk space will be used.
                Get:1 https://deb.nodesource.com/node_16.x buster/main armhf nodejs armhf 16.18.0-deb-1nodesource1 [24.2 MB]
                Fetched 24.2 MB in 2s (10.3 MB/s)
                apt-listchanges: Reading changelogs...
                (Reading database ... 57436 files and directories currently installed.)
                Preparing to unpack .../nodejs_16.18.0-deb-1nodesource1_armhf.deb ...
                Unpacking nodejs (16.18.0-deb-1nodesource1) over (14.20.1-deb-1nodesource1) ...
                Setting up nodejs (16.18.0-deb-1nodesource1) ...
                Processing triggers for man-db (2.8.5-2) ...
                deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main
                deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main
                pi@raspberrypi:~ $
                jetzt ist gegangen.
                  @silbroker sagte in JS-Controller update, was jetzt:
                  Wo kam denn die 14.20.1 nun her?
                    habe zuerst die 14er kopiert und ausgeführt
                    und dann gemerkt das es geht.
                    Danach noch die 16er
                      @silbroker
                      Und was kommt bei
                      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                      jetzt um's Eck?
                        Mach bitte nicht irgendwas nebenher von dem ich nichts weiß. Das macht es nicht leichter dir zu helfen! Im Gegenteil...
                          pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                          armv7l
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.18.0
                          v16.18.0
                          8.19.2
                          pi
                          pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                          /home/pi
                          Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
                          nodejs:
                            Installed: 16.18.0-deb-1nodesource1
                            Candidate: 16.18.0-deb-1nodesource1
                            Version table:
                           *** 16.18.0-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                            @silbroker
                            iobroker restart
                            iobroker status
                              pi@raspberrypi:~ $ iobroker restart
                              pi@raspberrypi:~ $ iobroker status
                              node:internal/modules/cjs/loader:988
                                throw err;
                              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                  at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
                                  at Function.Module._load (node:internal/modules/cjs/loader:833:27)
                                  at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                  at node:internal/main/run_main_module:22:47 {
                                code: 'MODULE_NOT_FOUND',
                                requireStack: []
                              pi@raspberrypi:~ $
                                @silbroker
                                iobroker stop
                                cd /opt/iobroker
                                sudo -H -u iobroker npm install iobroker.js-controller
                                iobroker start
                                  @thomas-braun sagte in JS-Controller update, was jetzt:
                                  iobroker start
                                  pi@raspberrypi:~ $ cd /opt/iobroker
                                  pi@raspberrypi:/opt/iobroker $
                                  pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                                  npm WARN old lockfile
                                  npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                                  npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                                  npm WARN old lockfile This is a one-time fix-up, please be patient...
                                  npm WARN deprecated @types/keyv@4.2.0: This is a stub types definition. keyv provides its own type definitions, so you do not need this installed.
                                  added 682 packages, removed 21 packages, and changed 29 packages in 2m
                                  101 packages are looking for funding
                                    run `npm fund` for details
                                  pi@raspberrypi:/opt/iobroker $ iobroker start
                                  jetzt ist sie wieder online. Muss ich sonst noch etwas machen / beachten?
                                    @silbroker
                                    iobroker update -i
                                    iobroker status
                                      pi@raspberrypi:/opt/iobroker $ iobroker update -i
                                      Used repository: beta
                                      Adapter    "admin"        : 6.2.23   , installed 4.1.12 [Updatable]
                                      Adapter    "deconz"       : 1.3.21   , installed 2.0.5
                                      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                      Adapter    "info"         : 1.9.21   , installed 1.9.21
                                      Adapter    "jarvis"       : 3.0.15   , installed 2.2.5  [Updatable]
                                      Adapter    "javascript"   : 6.0.3    , installed 4.10.8 [Updatable]
                                      Adapter    "loxone"       : 3.0.0    , installed 2.2.3  [Updatable]
                                      Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
                                      Adapter    "shelly"       : 6.2.4    , installed 4.1.2  [Updatable]
                                      Adapter    "socketio"     : 6.1.10   , installed 3.1.5  [Updatable]
                                      Adapter    "sonos"        : 2.2.3    , installed 2.1.1  [Updatable]
                                      Adapter    "vis"          : 1.4.15   , installed 1.4.15
                                      Adapter    "web"          : 5.2.10   , installed 3.1.0  [Updatable]
                                      pi@raspberrypi:/opt/iobroker $ iobroker status
                                      Objects type: jsonl
                                      States  type: jsonl
                                        @silbroker Was willste denn mit dem alten Kram beta-testen?
                                        Stell das Repo auf stable und dann zieh das alles auf den stabilen Stand.
                                          Und was ist das für eine Version?
                                          deconz
                                          github:	1.3.21
                                          latest:	1.3.21 for 5 months
                                          stable:	1.3.21 for 5 months
                                            Das konnte ich nicht updaten weil der JS-Controller zu alt war. 🤔
                                            3784
