    3. Einsteigerfragen
    4. JS-Controller update, was jetzt
      Thomas Braun Most Active @silbroker last edited by
      @silbroker
      sudo apt update
      apt policy nodejs
        @silbroker
        Und mal in die
        cat /etc/apt/sources.list.d/nodesource.list
        schauen.
          silbroker @Thomas Braun last edited by
          pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/nodesource.list
          deb https://deb.nodesource.com/node_12.x buster main
          deb-src https://deb.nodesource.com/node_12.x buster main
          so?
            @silbroker
            Nach dem Installationsskript für nodejs16 sollte die eigentlich so aussehen:
            deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
            deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
            Was sagt denn:
            curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
            so?
              pi@raspberrypi:~ $ sudo apt install -y nodejs
              Reading package lists... Done
              Building dependency tree
              The following packages will be upgraded:
                nodejs
              1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              Need to get 24.2 MB of archives.
              After this operation, 2,727 kB of additional disk space will be used.
              Get:1 https://deb.nodesource.com/node_16.x buster/main armhf nodejs armhf 16.18.0-deb-1nodesource1 [24.2 MB]
              Fetched 24.2 MB in 2s (10.3 MB/s)
              apt-listchanges: Reading changelogs...
              (Reading database ... 57436 files and directories currently installed.)
              Preparing to unpack .../nodejs_16.18.0-deb-1nodesource1_armhf.deb ...
              Unpacking nodejs (16.18.0-deb-1nodesource1) over (14.20.1-deb-1nodesource1) ...
              Setting up nodejs (16.18.0-deb-1nodesource1) ...
              Processing triggers for man-db (2.8.5-2) ...
              deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main
              deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main
              pi@raspberrypi:~ $
              jetzt ist gegangen.
                @silbroker sagte in JS-Controller update, was jetzt:
                Wo kam denn die 14.20.1 nun her?
                  habe zuerst die 14er kopiert und ausgeführt
                  und dann gemerkt das es geht.
                  Danach noch die 16er
                    @silbroker
                    Und was kommt bei
                    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    jetzt um's Eck?
                      Mach bitte nicht irgendwas nebenher von dem ich nichts weiß. Das macht es nicht leichter dir zu helfen! Im Gegenteil...
                        pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                        armv7l
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.18.0
                        v16.18.0
                        8.19.2
                        pi
                        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                        /home/pi
                        Hit:1 http://phoscon.de/apt/deconz buster InRelease
                        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                        Hit:3 http://archive.raspberrypi.org/debian buster InRelease
                        Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
                        All packages are up to date.
                        nodejs:
                          Installed: 16.18.0-deb-1nodesource1
                          Candidate: 16.18.0-deb-1nodesource1
                          Version table:
                         *** 16.18.0-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                100 /var/lib/dpkg/status
                             10.24.0~dfsg-1~deb10u2 500
                          @silbroker
                          iobroker restart
                          iobroker status
                            pi@raspberrypi:~ $ iobroker restart
                            pi@raspberrypi:~ $ iobroker status
                            node:internal/modules/cjs/loader:988
                              throw err;
                            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
                                at Function.Module._load (node:internal/modules/cjs/loader:833:27)
                                at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                at node:internal/main/run_main_module:22:47 {
                              code: 'MODULE_NOT_FOUND',
                              requireStack: []
                            pi@raspberrypi:~ $
                              @silbroker
                              iobroker stop
                              cd /opt/iobroker
                              sudo -H -u iobroker npm install iobroker.js-controller
                              iobroker start
                                @thomas-braun sagte in JS-Controller update, was jetzt:
                                iobroker start
                                pi@raspberrypi:~ $ cd /opt/iobroker
                                pi@raspberrypi:/opt/iobroker $
                                pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                                npm WARN old lockfile
                                npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                                npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                                npm WARN old lockfile This is a one-time fix-up, please be patient...
                                npm WARN deprecated @types/keyv@4.2.0: This is a stub types definition. keyv provides its own type definitions, so you do not need this installed.
                                added 682 packages, removed 21 packages, and changed 29 packages in 2m
                                101 packages are looking for funding
                                  run `npm fund` for details
                                pi@raspberrypi:/opt/iobroker $ iobroker start
                                jetzt ist sie wieder online. Muss ich sonst noch etwas machen / beachten?
                                  @silbroker
                                  iobroker update -i
                                  iobroker status
                                    pi@raspberrypi:/opt/iobroker $ iobroker update -i
                                    Used repository: beta
                                    Adapter    "admin"        : 6.2.23   , installed 4.1.12 [Updatable]
                                    Adapter    "deconz"       : 1.3.21   , installed 2.0.5
                                    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                    Adapter    "info"         : 1.9.21   , installed 1.9.21
                                    Adapter    "jarvis"       : 3.0.15   , installed 2.2.5  [Updatable]
                                    Adapter    "javascript"   : 6.0.3    , installed 4.10.8 [Updatable]
                                    Adapter    "loxone"       : 3.0.0    , installed 2.2.3  [Updatable]
                                    Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
                                    Adapter    "shelly"       : 6.2.4    , installed 4.1.2  [Updatable]
                                    Adapter    "socketio"     : 6.1.10   , installed 3.1.5  [Updatable]
                                    Adapter    "sonos"        : 2.2.3    , installed 2.1.1  [Updatable]
                                    Adapter    "vis"          : 1.4.15   , installed 1.4.15
                                    Adapter    "web"          : 5.2.10   , installed 3.1.0  [Updatable]
                                    pi@raspberrypi:/opt/iobroker $ iobroker status
                                    Objects type: jsonl
                                    States  type: jsonl
                                      @silbroker Was willste denn mit dem alten Kram beta-testen?
                                      Stell das Repo auf stable und dann zieh das alles auf den stabilen Stand.
                                        Und was ist das für eine Version?
                                        deconz
                                        github:	1.3.21
                                        latest:	1.3.21 for 5 months
                                        stable:	1.3.21 for 5 months
                                          Das konnte ich nicht updaten weil der JS-Controller zu alt war. 🤔
                                            Und nicht nur der...
                                            iob repo list
                                            3784
