    3. Einsteigerfragen
    4. JS-Controller update, was jetzt
      Thomas Braun Most Active @silbroker last edited by
      @silbroker
      iobroker restart
      iobroker status
        silbroker @Thomas Braun last edited by
        pi@raspberrypi:~ $ iobroker restart
        pi@raspberrypi:~ $ iobroker status
        node:internal/modules/cjs/loader:988
          throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
            at Function.Module._load (node:internal/modules/cjs/loader:833:27)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
            at node:internal/main/run_main_module:22:47 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
        pi@raspberrypi:~ $
          @silbroker
          iobroker stop
          cd /opt/iobroker
          sudo -H -u iobroker npm install iobroker.js-controller
          iobroker start
            @thomas-braun sagte in JS-Controller update, was jetzt:
            iobroker start
            pi@raspberrypi:~ $ cd /opt/iobroker
            pi@raspberrypi:/opt/iobroker $
            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
            npm WARN old lockfile
            npm WARN old lockfile The package-lock.json file was created with an old version of npm,
            npm WARN old lockfile so supplemental metadata must be fetched from the registry.
            npm WARN old lockfile This is a one-time fix-up, please be patient...
            npm WARN deprecated @types/keyv@4.2.0: This is a stub types definition. keyv provides its own type definitions, so you do not need this installed.
            added 682 packages, removed 21 packages, and changed 29 packages in 2m
            101 packages are looking for funding
              run `npm fund` for details
            pi@raspberrypi:/opt/iobroker $ iobroker start
            jetzt ist sie wieder online. Muss ich sonst noch etwas machen / beachten?
              @silbroker
              iobroker update -i
              iobroker status
                pi@raspberrypi:/opt/iobroker $ iobroker update -i
                Used repository: beta
                Adapter    "admin"        : 6.2.23   , installed 4.1.12 [Updatable]
                Adapter    "deconz"       : 1.3.21   , installed 2.0.5
                Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                Adapter    "info"         : 1.9.21   , installed 1.9.21
                Adapter    "jarvis"       : 3.0.15   , installed 2.2.5  [Updatable]
                Adapter    "javascript"   : 6.0.3    , installed 4.10.8 [Updatable]
                Adapter    "loxone"       : 3.0.0    , installed 2.2.3  [Updatable]
                Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
                Adapter    "shelly"       : 6.2.4    , installed 4.1.2  [Updatable]
                Adapter    "socketio"     : 6.1.10   , installed 3.1.5  [Updatable]
                Adapter    "sonos"        : 2.2.3    , installed 2.1.1  [Updatable]
                Adapter    "vis"          : 1.4.15   , installed 1.4.15
                Adapter    "web"          : 5.2.10   , installed 3.1.0  [Updatable]
                pi@raspberrypi:/opt/iobroker $ iobroker status
                Objects type: jsonl
                States  type: jsonl
                  @silbroker Was willste denn mit dem alten Kram beta-testen?
                  Stell das Repo auf stable und dann zieh das alles auf den stabilen Stand.
                    @silbroker sagte in JS-Controller update, was jetzt:
                    Und was ist das für eine Version?
                    deconz
                    github:	1.3.21
                    latest:	1.3.21 for 5 months
                    stable:	1.3.21 for 5 months
                      Das konnte ich nicht updaten weil der JS-Controller zu alt war. 🤔
                        Und nicht nur der...
                        iob repo list
                          wie schalte ich diesen auf stable
                            Da wo du es auch auf Beta umgestellt hast.
                            Oder über die Kommandozeile.
                            iob repo list
                            posten.
                              pi@raspberrypi:/opt/iobroker $ iob repo list
                              Active repo(s): beta
                                @silbroker
                                iobroker repo unset beta
                                iobroker repo set stable
                                iobroker update
                                  Used repository: stable
                                  Adapter    "admin"        : 6.2.23   , installed 6.2.23
                                  Adapter    "discovery"    : 3.0.5    , installed 3.1.0
                                  Adapter    "info"         : 1.9.19   , installed 1.9.21
                                  Adapter    "shelly"       : 6.0.0    , installed 4.1.2  [Updatable]
                                  Adapter    "simple-api"   : 2.7.0    , installed 2.7.2
                                  Adapter    "socketio"     : 4.2.0    , installed 3.1.5  [Updatable]
                                  Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
                                  Adapter    "web"          : 4.3.0    , installed 3.1.0  [Updatable]
                                  Was ist den die repo beta?
                                    Der Beta-Kanal. Aber wozu fährst du Beta, wenn du dein System eh nicht auf Stand hältst?
                                    Bring das jetzt auf Stand.
                                    iobroker upgrade all
                                      @silbroker
                                      Und den deconz kannste wieder auf V1 bringen, ich glaube die Entwicklung von V2 wurde eingestellt.
                                      iobroker upgrade deconz@1.3.21
                                        So jetzt bin ich wieder aktuell. Danke viel Mals. wie oft muss ich das updaten?
                                        Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                                        Adapter    "jarvis"       : 3.0.15   , installed 3.0.15
                                        Adapter    "javascript"   : 6.0.3    , installed 6.0.3
                                        Adapter    "loxone"       : 3.0.0    , installed 3.0.0
                                        Adapter    "shelly"       : 6.0.0    , installed 6.0.0
                                        Adapter    "sonos"        : 2.2.3    , installed 2.2.3
                                          Öfter als bisher/ (aka nie...)
                                          Knöpf dir das alle paar Wochen / 1x im Monat vor.
                                          Und zwar das Gesamtsystem aus Betriebssytem und dem ioBroker. Befehle dafür hast du ja jetzt.
                                            Ok,
                                            die Reihenfolge ist node
                                            danach JS-Controller
                                            danach ioBroker?
                                            3784
