    3. Einsteigerfragen
    4. JS-Controller update, was jetzt
      silbroker @Thomas Braun last edited by
      pi@raspberrypi:~ $ iobroker restart
      pi@raspberrypi:~ $ iobroker status
      node:internal/modules/cjs/loader:988
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
          at Function.Module._load (node:internal/modules/cjs/loader:833:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
          at node:internal/main/run_main_module:22:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      pi@raspberrypi:~ $
        Thomas Braun Most Active @silbroker last edited by
        @silbroker
        iobroker stop
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
        iobroker start
          @thomas-braun sagte in JS-Controller update, was jetzt:
          iobroker start
          pi@raspberrypi:~ $ cd /opt/iobroker
          pi@raspberrypi:/opt/iobroker $
          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
          npm WARN old lockfile
          npm WARN old lockfile The package-lock.json file was created with an old version of npm,
          npm WARN old lockfile so supplemental metadata must be fetched from the registry.
          npm WARN old lockfile This is a one-time fix-up, please be patient...
          npm WARN deprecated @types/keyv@4.2.0: This is a stub types definition. keyv provides its own type definitions, so you do not need this installed.
          added 682 packages, removed 21 packages, and changed 29 packages in 2m
          101 packages are looking for funding
            run `npm fund` for details
          pi@raspberrypi:/opt/iobroker $ iobroker start
          jetzt ist sie wieder online. Muss ich sonst noch etwas machen / beachten?
            @silbroker
            iobroker update -i
            iobroker status
              pi@raspberrypi:/opt/iobroker $ iobroker update -i
              Used repository: beta
              Adapter    "admin"        : 6.2.23   , installed 4.1.12 [Updatable]
              Adapter    "deconz"       : 1.3.21   , installed 2.0.5
              Adapter    "discovery"    : 3.1.0    , installed 3.1.0
              Adapter    "info"         : 1.9.21   , installed 1.9.21
              Adapter    "jarvis"       : 3.0.15   , installed 2.2.5  [Updatable]
              Adapter    "javascript"   : 6.0.3    , installed 4.10.8 [Updatable]
              Adapter    "loxone"       : 3.0.0    , installed 2.2.3  [Updatable]
              Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
              Adapter    "shelly"       : 6.2.4    , installed 4.1.2  [Updatable]
              Adapter    "socketio"     : 6.1.10   , installed 3.1.5  [Updatable]
              Adapter    "sonos"        : 2.2.3    , installed 2.1.1  [Updatable]
              Adapter    "vis"          : 1.4.15   , installed 1.4.15
              Adapter    "web"          : 5.2.10   , installed 3.1.0  [Updatable]
              pi@raspberrypi:/opt/iobroker $ iobroker status
              Objects type: jsonl
              States  type: jsonl
                @silbroker Was willste denn mit dem alten Kram beta-testen?
                Stell das Repo auf stable und dann zieh das alles auf den stabilen Stand.
                  @silbroker sagte in JS-Controller update, was jetzt:
                  Und was ist das für eine Version?
                  deconz
                  github:	1.3.21
                  latest:	1.3.21 for 5 months
                  stable:	1.3.21 for 5 months
                    Das konnte ich nicht updaten weil der JS-Controller zu alt war. 🤔
                      Und nicht nur der...
                      iob repo list
                        wie schalte ich diesen auf stable
                          Da wo du es auch auf Beta umgestellt hast.
                          Oder über die Kommandozeile.
                          iob repo list
                          posten.
                            pi@raspberrypi:/opt/iobroker $ iob repo list
                            Active repo(s): beta
                              @silbroker
                              iobroker repo unset beta
                              iobroker repo set stable
                              iobroker update
                                Used repository: stable
                                Adapter    "admin"        : 6.2.23   , installed 6.2.23
                                Adapter    "discovery"    : 3.0.5    , installed 3.1.0
                                Adapter    "info"         : 1.9.19   , installed 1.9.21
                                Adapter    "shelly"       : 6.0.0    , installed 4.1.2  [Updatable]
                                Adapter    "simple-api"   : 2.7.0    , installed 2.7.2
                                Adapter    "socketio"     : 4.2.0    , installed 3.1.5  [Updatable]
                                Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
                                Adapter    "web"          : 4.3.0    , installed 3.1.0  [Updatable]
                                Was ist den die repo beta?
                                  Der Beta-Kanal. Aber wozu fährst du Beta, wenn du dein System eh nicht auf Stand hältst?
                                  Bring das jetzt auf Stand.
                                  iobroker upgrade all
                                    @silbroker
                                    Und den deconz kannste wieder auf V1 bringen, ich glaube die Entwicklung von V2 wurde eingestellt.
                                    iobroker upgrade deconz@1.3.21
                                      So jetzt bin ich wieder aktuell. Danke viel Mals. wie oft muss ich das updaten?
                                      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                                      Adapter    "jarvis"       : 3.0.15   , installed 3.0.15
                                      Adapter    "javascript"   : 6.0.3    , installed 6.0.3
                                      Adapter    "loxone"       : 3.0.0    , installed 3.0.0
                                      Adapter    "shelly"       : 6.0.0    , installed 6.0.0
                                      Adapter    "sonos"        : 2.2.3    , installed 2.2.3
                                        Öfter als bisher/ (aka nie...)
                                        Knöpf dir das alle paar Wochen / 1x im Monat vor.
                                        Und zwar das Gesamtsystem aus Betriebssytem und dem ioBroker. Befehle dafür hast du ja jetzt.
                                          Ok,
                                          die Reihenfolge ist node
                                          danach JS-Controller
                                          danach ioBroker?
                                            Thomas Braun Most Active @silbroker last edited by Thomas Braun
                                            @silbroker
                                            Du hast das Betriebssystem vergessen...
                                            sudo apt update
                                            sudo apt full-upgrade
                                            (im Zweifel einen Reboot danach)
                                            sudo reboot
                                            iobroker update
                                            iobroker upgrade
                                            nodejs fließt (im 16er-Zweig) mit den Updates des Betriebssystems mit.
                                            3784
