    3. Einsteigerfragen
    4. JS-Controller update, was jetzt
      silbroker @Thomas Braun last edited by
      @thomas-braun sagte in JS-Controller update, was jetzt:
      iobroker start
      pi@raspberrypi:~ $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $
      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
      npm WARN old lockfile
      npm WARN old lockfile The package-lock.json file was created with an old version of npm,
      npm WARN old lockfile so supplemental metadata must be fetched from the registry.
      npm WARN old lockfile This is a one-time fix-up, please be patient...
      npm WARN deprecated @types/keyv@4.2.0: This is a stub types definition. keyv provides its own type definitions, so you do not need this installed.
      added 682 packages, removed 21 packages, and changed 29 packages in 2m
      101 packages are looking for funding
        run `npm fund` for details
      pi@raspberrypi:/opt/iobroker $ iobroker start
      jetzt ist sie wieder online. Muss ich sonst noch etwas machen / beachten?
        Thomas Braun Most Active @silbroker last edited by
        @silbroker
        iobroker update -i
        iobroker status
          pi@raspberrypi:/opt/iobroker $ iobroker update -i
          Used repository: beta
          Adapter    "admin"        : 6.2.23   , installed 4.1.12 [Updatable]
          Adapter    "deconz"       : 1.3.21   , installed 2.0.5
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "info"         : 1.9.21   , installed 1.9.21
          Adapter    "jarvis"       : 3.0.15   , installed 2.2.5  [Updatable]
          Adapter    "javascript"   : 6.0.3    , installed 4.10.8 [Updatable]
          Adapter    "loxone"       : 3.0.0    , installed 2.2.3  [Updatable]
          Adapter    "rpi2"         : 1.3.2    , installed 1.3.1  [Updatable]
          Adapter    "shelly"       : 6.2.4    , installed 4.1.2  [Updatable]
          Adapter    "socketio"     : 6.1.10   , installed 3.1.5  [Updatable]
          Adapter    "sonos"        : 2.2.3    , installed 2.1.1  [Updatable]
          Adapter    "vis"          : 1.4.15   , installed 1.4.15
          Adapter    "web"          : 5.2.10   , installed 3.1.0  [Updatable]
          pi@raspberrypi:/opt/iobroker $ iobroker status
          Objects type: jsonl
          States  type: jsonl
            @silbroker Was willste denn mit dem alten Kram beta-testen?
            Stell das Repo auf stable und dann zieh das alles auf den stabilen Stand.
              @silbroker sagte in JS-Controller update, was jetzt:
              Und was ist das für eine Version?
              deconz
              github:	1.3.21
              latest:	1.3.21 for 5 months
              stable:	1.3.21 for 5 months
                Das konnte ich nicht updaten weil der JS-Controller zu alt war. 🤔
                  Und nicht nur der...
                  iob repo list
                    wie schalte ich diesen auf stable
                      Da wo du es auch auf Beta umgestellt hast.
                      Oder über die Kommandozeile.
                      iob repo list
                      posten.
                        pi@raspberrypi:/opt/iobroker $ iob repo list
                        Active repo(s): beta
                          @silbroker
                          iobroker repo unset beta
                          iobroker repo set stable
                          iobroker update
                            Used repository: stable
                            Adapter    "admin"        : 6.2.23   , installed 6.2.23
                            Adapter    "discovery"    : 3.0.5    , installed 3.1.0
                            Adapter    "info"         : 1.9.19   , installed 1.9.21
                            Adapter    "shelly"       : 6.0.0    , installed 4.1.2  [Updatable]
                            Adapter    "simple-api"   : 2.7.0    , installed 2.7.2
                            Adapter    "socketio"     : 4.2.0    , installed 3.1.5  [Updatable]
                            Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
                            Adapter    "web"          : 4.3.0    , installed 3.1.0  [Updatable]
                            Was ist den die repo beta?
                              Der Beta-Kanal. Aber wozu fährst du Beta, wenn du dein System eh nicht auf Stand hältst?
                              Bring das jetzt auf Stand.
                              iobroker upgrade all
                                @silbroker
                                Und den deconz kannste wieder auf V1 bringen, ich glaube die Entwicklung von V2 wurde eingestellt.
                                iobroker upgrade deconz@1.3.21
                                  So jetzt bin ich wieder aktuell. Danke viel Mals. wie oft muss ich das updaten?
                                  Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                                  Adapter    "jarvis"       : 3.0.15   , installed 3.0.15
                                  Adapter    "javascript"   : 6.0.3    , installed 6.0.3
                                  Adapter    "loxone"       : 3.0.0    , installed 3.0.0
                                  Adapter    "shelly"       : 6.0.0    , installed 6.0.0
                                  Adapter    "sonos"        : 2.2.3    , installed 2.2.3
                                    Öfter als bisher/ (aka nie...)
                                    Knöpf dir das alle paar Wochen / 1x im Monat vor.
                                    Und zwar das Gesamtsystem aus Betriebssytem und dem ioBroker. Befehle dafür hast du ja jetzt.
                                      Ok,
                                      die Reihenfolge ist node
                                      danach JS-Controller
                                      danach ioBroker?
                                        Thomas Braun Most Active @silbroker last edited by Thomas Braun
                                        @silbroker
                                        Du hast das Betriebssystem vergessen...
                                        sudo apt update
                                        sudo apt full-upgrade
                                        (im Zweifel einen Reboot danach)
                                        sudo reboot
                                        iobroker update
                                        iobroker upgrade
                                        nodejs fließt (im 16er-Zweig) mit den Updates des Betriebssystems mit.
                                          ok, das werde ich versuchen zu machen.
                                          Danke nochmals viel mal.
                                          Gruss Silbroker
                                          3784
