    3. Cloud Dienste
    4. [FIX available] Alexa per Alexa2 Totalausfall !?
    • DJMarc75
      DJMarc75 @apollon77 last edited by
      @apollon77 sagte in Alexa per Alexa2 Totalausfall !?:
      (aber auch nicht neu gestartet)
      dann starte mal lieber nicht neu 😀
      Gibt aber zweiten Thread mit issues seit vorhin
      okay, danke... ich beobachte !
      • Old_Engineer
        Old_Engineer @emil70 last edited by
        @emil70 Hier steht auch alles. Die verbundenen Cloud Services funktionieren bei direkter Verwendung (Tuya Smartlife App) und über den Echo.
          Andere Skills auch betroffen?
          • DJMarc75
            @apollon77 hier mal die letzten LOGs... bin dann wohl mal blockiert und hab den Adapter mal deaktiviert.
            alexa2.0
            	2022-10-27 08:34:50.558	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            alexa2.0
            	2022-10-27 08:34:50.558	debug	Plugin sentry destroyed
            alexa2.0
            	2022-10-27 08:34:50.556	info	terminating
            alexa2.0
            	2022-10-27 08:34:50.553	info	Got terminate signal TERMINATE_YOURSELF
            alexa2.0
            	2022-10-27 08:34:34.656	debug	Alexa-Remote: rate exceeded response ... Retrying once in 50666ms
            alexa2.0
            	2022-10-27 08:34:34.655	debug	Alexa-Remote: Response: {"message":"Too many requests. Try again in some time."}
            alexa2.0
            	2022-10-27 08:34:34.570	debug	Alexa-Remote: Sending Request with {"host":"eu-api-alexa.amazon.de","path":"/api/phoenix?includeRelationships=true","method":"GET","timeout":30000,"headers":{}}
            alexa2.0
            	2022-10-27 08:33:52.701	debug	Alexa-Remote: rate exceeded response ... Retrying once in 41868ms
            alexa2.0
            	2022-10-27 08:33:52.700	debug	Alexa-Remote: Response: {"message":"Too many requests. Try again in some time."}
            alexa2.0
            	2022-10-27 08:33:52.619	debug	Alexa-Remote: Sending Request with {"host":"eu-api-alexa.amazon.de","path":"/api/phoenix?includeRelationships=true","method":"GET","timeout":30000,"headers":{}}
            alexa2.0
            	2022-10-27 08:33:14.721	debug	Alexa-Remote: rate exceeded response ... Retrying once in 37896ms
            alexa2.0
            	2022-10-27 08:33:14.721	debug	Alexa-Remote: Response: {"message":"Too many requests. Try again in some time."}
              Ok, also der Fehler liegt daaran das Amazon why ever mal wieder Rate Limkits an gemacht hat. und dann kommt der Adapter aus nem anderen grund nicht mehr hoch wenn man Ihn neu startet.
              Ich schaue gerade was ich tun kann und hab auch schon meinen Amazon Kontakt angeschrieben
              MyzerAT 1 Reply Last reply Reply Quote 3
              • MyzerAT
                MyzerAT @apollon77 last edited by MyzerAT
                @apollon77
                warum machen die das ? bei mir ist alles auf 360 sekunden eingestellt, diesmal werden nicht mal phrasen für die Echos übernommen aus dem iobroker
                  apollon77 @MyzerAT last edited by
                  @myzerat Bei mir geht alles ... NUR wenn du den Adapter neu startet hängt er in der Initialisieirung und DAS ist ggf dein problem. Damit reagiert er auf gar nichts.
                  Arbeite an Fix
                  MyzerAT 1 Reply Last reply Reply Quote 1
                  • MyzerAT
                    @apollon77
                    ich hatte ihn gar nicht neu gestartet, ist mir aufgefallen als ichum 4 uhr aufs WC ging und alles dunkel geblieben ist .
                    DANKE
                    DJMarc75 apollon77 2 Replies Last reply Reply Quote 0
                    • DJMarc75
                      DJMarc75 @MyzerAT last edited by
                      @myzerat schau mal in den DP rein wie lange der Adapter online ist, kann ja sein dass der sich irgendwie heute Nacht mal kurz verabschiedet hat:
                      system.adapter.alexa2.0.uptime
                        @myzerat Ja ok, geräte gehen vllt seitdem generell nicht mehr wegen dem Rate Limit.
                          Jemand gerade Zeit GitHub Version zu testen?
                          DJMarc75 1 Reply Last reply Reply Quote 1
                          • DJMarc75
                            @apollon77 immer her damit
                              apollon77 @DJMarc75 last edited by
                              @djmarc75 Dann go. Bei mir läufts.
                              Die Behebt einen Bug im Retry Management wen rate limited was den "Adapterstart" fixen sollte. Und da die rate limuts auf der Versionsnummer basieren geht auch damit alles wieder soweit ich getestet hab. Hätte gern "eine" zweite meinung bevoir ich es release"
                              • DJMarc75
                                Initialisierung läuft.... Zweitmeinung kommt gleich
                                  @djmarc75 STOP WARTE! ... da fehlt noch was .. paar mins
                                    @DJMarc75 Jetzt ... Version ist dann 3.19.10
                                    DJMarc75 Fabio Negalein 3 Replies Last reply Reply Quote 1
                                    • DJMarc75
                                      @apollon77 mit 3.19.10
                                      alexa2.0
                                      	2022-10-27 09:25:06.721	info	Initialization Done ...
                                      ich mach mich jetzt mal ans Testen der einzelnen Devices und DPs
                                        @djmarc75 ALso keine AHnung was amazon getan hat ... Smart-Geräte tun vllt immer noch nicht ... aber Rest sollte
                                        • DJMarc75
                                          @apollon77 die wichtigen DPs z.B. unter Player funktionieren. Commands ebenso und auch die States aktualisieren sich. SmartDevices teste ich nachher auf dem Hauptsystem.
                                            @djmarc75 Ich denke ich gebe die version auf jeden Fall raus und direkt auch in Stable das das Startproblen behoben ist
                                            DJMarc75 haselchen 2 Replies Last reply Reply Quote 1
                                            1.2k
                                            70
                                            7727
