[FIX available] Alexa per Alexa2 Totalausfall !?
So jetzt geht es bei mir auch nicht mehr. Hatte den Adapter nicht neu gestartet
Update auf 3.19.10 schlägt fehl
0 verbose cli /usr/bin/node /usr/bin/npm 1 info using npm@8.15.0 2 info using node@v16.17.1 3 timing npm:load:whichnode Completed in 0ms 4 timing config:load:defaults Completed in 5ms 5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 8ms 6 timing config:load:builtin Completed in 10ms 7 timing config:load:cli Completed in 15ms 8 timing config:load:env Completed in 1ms 9 timing config:load:project Completed in 9ms 10 timing config:load:file:/opt/iobroker/.npmrc Completed in 3ms 11 timing config:load:user Completed in 4ms 12 timing config:load:file:/usr/etc/npmrc Completed in 0ms 13 timing config:load:global Completed in 1ms 14 timing config:load:validate Completed in 1ms 15 timing config:load:credentials Completed in 2ms 16 timing config:load:setEnvs Completed in 2ms 17 timing config:load Completed in 51ms 18 timing npm:load:configload Completed in 51ms 19 timing npm:load:mkdirpcache Completed in 2ms 20 timing npm:load:mkdirplogs Completed in 1ms 21 verbose title npm install iobroker.alexa2@3.19.10 22 verbose argv "install" "--save-exact" "iobroker.alexa2@3.19.10" 23 timing npm:load:setTitle Completed in 2ms 24 timing config:load:flatten Completed in 7ms 25 timing npm:load:display Completed in 9ms 26 verbose logfile logs-max:10 dir:/opt/iobroker/.npm/_logs 27 verbose logfile /opt/iobroker/.npm/_logs/2022-10-27T13_22_02_657Z-debug-0.log 28 timing npm:load:logFile Completed in 14ms 29 timing npm:load:timers Completed in 0ms 30 timing npm:load:configScope Completed in 0ms 31 timing npm:load Completed in 84ms 32 timing arborist:ctor Completed in 2ms 33 silly logfile start cleaning logs, removing 2 files 34 silly logfile done cleaning log files 35 timing idealTree:init Completed in 2679ms 36 timing idealTree:userRequests Completed in 37ms 37 silly idealTree buildDeps 38 silly fetch manifest iobroker.alexa2@3.19.10 39 timing arborist:ctor Completed in 0ms 40 http fetch GET 200 https://registry.npmjs.org/iobroker.alexa2 2334ms (cache hit) 41 silly placeDep ROOT iobroker.alexa2@3.19.10 REPLACE for: iobroker.inst@3.0.0 want: 3.19.10 42 silly fetch manifest alexa-remote2@^5.8.3 43 silly fetch manifest https@^1.0.0 44 silly fetch manifest @sentry/node@^7.16.0 45 silly fetch manifest @sentry/integrations@^7.16.0 46 http fetch GET 200 https://registry.npmjs.org/https 50ms (cache hit) 47 http fetch GET 200 https://registry.npmjs.org/alexa-remote2 54ms (cache hit) 48 http fetch GET 200 https://registry.npmjs.org/@sentry%2fnode 57ms (cache hit) 49 http fetch GET 200 https://registry.npmjs.org/@sentry%2fintegrations 66ms (cache hit) 50 timing idealTree:#root Completed in 2473ms 51 silly placeDep node_modules/iobroker.alexa2 @sentry/integrations@7.17.0 OK for: iobroker.alexa2@3.19.10 want: ^7.16.0 52 silly placeDep node_modules/iobroker.alexa2 @sentry/node@7.17.0 OK for: iobroker.alexa2@3.19.10 want: ^7.16.0 53 silly placeDep ROOT alexa-remote2@5.8.3 OK for: iobroker.alexa2@3.19.10 want: ^5.8.3 54 silly placeDep ROOT https@1.0.0 OK for: iobroker.alexa2@3.19.10 want: ^1.0.0 55 silly fetch manifest @sentry/types@7.17.0 56 silly fetch manifest @sentry/utils@7.17.0 57 silly fetch manifest @sentry/core@7.17.0 58 silly fetch manifest alexa-cookie2@^4.1.3 59 silly fetch manifest querystring@^0.2.1 60 http fetch GET 200 https://registry.npmjs.org/@sentry%2ftypes 43ms (cache hit) 61 http fetch GET 200 https://registry.npmjs.org/alexa-cookie2 45ms (cache hit) 62 http fetch GET 200 https://registry.npmjs.org/querystring 45ms (cache hit) 63 http fetch GET 200 https://registry.npmjs.org/@sentry%2futils 54ms (cache hit) 64 http fetch GET 200 https://registry.npmjs.org/@sentry%2fcore 62ms (cache hit) 65 timing idealTree:node_modules/iobroker.alexa2 Completed in 95ms 66 silly placeDep ROOT alexa-cookie2@4.1.3 OK for: alexa-remote2@5.8.3 want: ^4.1.3 67 silly placeDep ROOT querystring@0.2.1 OK for: alexa-remote2@5.8.3 want: ^0.2.1 68 silly fetch manifest cookie@^0.5.0 69 silly fetch manifest http-proxy-middleware@^2.0.6 70 silly fetch manifest http-proxy-response-rewrite@^0.0.1 71 http fetch GET 200 https://registry.npmjs.org/cookie 21ms (cache hit) 72 http fetch GET 200 https://registry.npmjs.org/http-proxy-response-rewrite 22ms (cache hit) 73 http fetch GET 200 https://registry.npmjs.org/http-proxy-middleware 25ms (cache hit) 74 timing idealTree:node_modules/alexa-remote2 Completed in 45ms 75 silly fetch manifest @types/express@^4.17.13 76 http fetch GET 200 https://registry.npmjs.org/@types%2fexpress 8ms (cache hit) 77 silly placeDep node_modules/alexa-cookie2 cookie@0.5.0 OK for: alexa-cookie2@4.1.3 want: ^0.5.0 78 silly placeDep ROOT http-proxy-middleware@2.0.6 OK for: alexa-cookie2@4.1.3 want: ^2.0.6 79 silly placeDep ROOT http-proxy-response-rewrite@0.0.1 OK for: alexa-cookie2@4.1.3 want: ^0.0.1 80 silly fetch manifest @types/http-proxy@^1.17.8 81 silly fetch manifest http-proxy@^1.18.1 82 silly fetch manifest is-plain-obj@^3.0.0 83 silly fetch manifest bufferhelper@^0.2.1 84 silly fetch manifest concat-stream@^1.5.1 85 http fetch GET 200 https://registry.npmjs.org/bufferhelper 37ms (cache hit) 86 http fetch GET 200 https://registry.npmjs.org/@types%2fhttp-proxy 43ms (cache hit) 87 http fetch GET 200 https://registry.npmjs.org/is-plain-obj 42ms (cache hit) 88 http fetch GET 200 https://registry.npmjs.org/concat-stream 42ms (cache hit) 89 http fetch GET 200 https://registry.npmjs.org/http-proxy 50ms (cache hit) 90 timing idealTree:node_modules/alexa-cookie2 Completed in 87ms 91 silly placeDep ROOT @types/http-proxy@1.17.9 OK for: http-proxy-middleware@2.0.6 want: ^1.17.8 92 silly placeDep ROOT http-proxy@1.18.1 OK for: http-proxy-middleware@2.0.6 want: ^1.18.1 93 silly placeDep node_modules/http-proxy-middleware is-plain-obj@3.0.0 OK for: http-proxy-middleware@2.0.6 want: ^3.0.0 94 silly fetch manifest eventemitter3@^4.0.0 95 http fetch GET 200 https://registry.npmjs.org/eventemitter3 8ms (cache hit) 96 timing idealTree:node_modules/http-proxy-middleware Completed in 25ms 97 timing idealTree:node_modules/@types/http-proxy Completed in 1ms 98 silly placeDep node_modules/http-proxy eventemitter3@4.0.7 OK for: http-proxy@1.18.1 want: ^4.0.0 99 timing idealTree:node_modules/http-proxy Completed in 3ms 100 silly placeDep ROOT bufferhelper@0.2.1 OK for: http-proxy-response-rewrite@0.0.1 want: ^0.2.1 101 silly placeDep ROOT concat-stream@1.6.2 OK for: http-proxy-response-rewrite@0.0.1 want: ^1.5.1 102 silly fetch manifest readable-stream@^2.2.2 103 http fetch GET 200 https://registry.npmjs.org/readable-stream 9ms (cache hit) 104 timing idealTree:node_modules/http-proxy-response-rewrite Completed in 25ms 105 timing idealTree:node_modules/bufferhelper Completed in 0ms 106 silly placeDep node_modules/concat-stream readable-stream@2.3.7 OK for: concat-stream@1.6.2 want: ^2.2.2 107 silly fetch manifest isarray@~1.0.0 108 silly fetch manifest string_decoder@~1.1.1 109 http fetch GET 200 https://registry.npmjs.org/isarray 17ms (cache hit) 110 http fetch GET 200 https://registry.npmjs.org/string_decoder 16ms (cache hit) 111 timing idealTree:node_modules/concat-stream Completed in 26ms 112 timing idealTree:node_modules/https Completed in 0ms 113 timing idealTree:node_modules/querystring Completed in 0ms 114 timing idealTree:node_modules/alexa-cookie2/node_modules/cookie Completed in 0ms 115 silly placeDep node_modules/concat-stream isarray@1.0.0 OK for: readable-stream@2.3.7 want: ~1.0.0 116 silly placeDep node_modules/concat-stream string_decoder@1.1.1 OK for: readable-stream@2.3.7 want: ~1.1.1 117 timing idealTree:node_modules/concat-stream/node_modules/readable-stream Completed in 7ms 118 timing idealTree:node_modules/concat-stream/node_modules/isarray Completed in 0ms 119 timing idealTree:node_modules/concat-stream/node_modules/string_decoder Completed in 0ms 120 timing idealTree:node_modules/http-proxy-middleware/node_modules/is-plain-obj Completed in 0ms 121 timing idealTree:node_modules/http-proxy/node_modules/eventemitter3 Completed in 0ms 122 silly placeDep node_modules/iobroker.alexa2 @sentry/types@7.17.0 OK for: @sentry/integrations@7.17.0 want: 7.17.0 123 silly placeDep node_modules/iobroker.alexa2/node_modules/@sentry/integrations @sentry/utils@ OK for: @sentry/integrations@7.17.0 want: 7.17.0 124 timing idealTree:node_modules/iobroker.alexa2/node_modules/@sentry/integrations Completed in 7ms 125 silly placeDep node_modules/iobroker.alexa2 @sentry/core@7.17.0 OK for: @sentry/node@7.17.0 want: 7.17.0 126 silly placeDep node_modules/iobroker.alexa2/node_modules/@sentry/node @sentry/utils@ OK for: @sentry/node@7.17.0 want: 7.17.0 127 timing idealTree:node_modules/iobroker.alexa2/node_modules/@sentry/node Completed in 9ms 128 silly placeDep node_modules/iobroker.alexa2/node_modules/@sentry/core @sentry/utils@ OK for: @sentry/core@7.17.0 want: 7.17.0 129 timing idealTree:node_modules/iobroker.alexa2/node_modules/@sentry/core Completed in 2ms 130 timing idealTree:node_modules/iobroker.alexa2/node_modules/@sentry/types Completed in 0ms 131 timing idealTree:node_modules/iobroker.alexa2/node_modules/@sentry/core/node_modules/@sentry/utils Completed in 0ms 132 timing idealTree:node_modules/iobroker.alexa2/node_modules/@sentry/integrations/node_modules/@sentry/utils Completed in 0ms 133 timing idealTree:node_modules/iobroker.alexa2/node_modules/@sentry/node/node_modules/@sentry/utils Completed in 0ms 134 timing idealTree:buildDeps Completed in 2812ms 135 timing idealTree:fixDepFlags Completed in 21ms 136 timing idealTree Completed in 5554ms 137 timing command:install Completed in 5570ms 138 verbose type version 139 verbose stack @sentry/utils: No matching version found for @sentry/utils@7.17.0. 139 verbose stack at module.exports (/usr/lib/node_modules/npm/node_modules/npm-pick-manifest/lib/index.js:209:23) 139 verbose stack at RegistryFetcher.manifest (/usr/lib/node_modules/npm/node_modules/pacote/lib/registry.js:125:22) 140 verbose cwd /opt/iobroker 141 verbose Linux 4.4.180+ 142 verbose node v16.17.1 143 verbose npm v8.15.0 144 error code ETARGET 145 error notarget No matching version found for @sentry/utils@7.17.0. 146 error notarget In most cases you or one of your dependencies are requesting 146 error notarget a package version that doesn't exist. 147 verbose exit 1 148 timing npm Completed in 5826ms 149 verbose unfinished npm timer reify 1666876922906 150 verbose unfinished npm timer reify:loadTrees 1666876922915 151 verbose code 1 152 error A complete log of this run can be found in: 152 error /opt/iobroker/.npm/_logs/2022-10-27T13_22_02_657Z-debug-0.logWeiss jemand warum?
System ist ein
PlatformBetriebssystem:linux Architektur:x64 CPUs:4 Geschwindigkeit:1501 MHz Modell:Intel(R) Celeron(R) CPU J3455 @ 1.50GHz RAM:11.5 GB System-Betriebszeit:21 T. 07:06:20 Node.js:v16.17.1 time:1666876562132 timeOffset:-120 Adapter-Anzahl:443 NPM:8.15.0 Datenträgergröße:3572.6 GB Freier Festplattenspeicher:2426.5 GB Betriebszeit:5 T. 03:21:58 Aktive Instanzen:28 Pfad:/opt/iobroker/ aktiv:true _nodeCurrent:16.17.1 _nodeNewest:16.18.0 _nodeNewestNext:16.18.0 _npmCurrent:8.15.0 _npmNewest:8.15.0 _npmNewestNext:8.19.2 -
@apollon77 sagte in [FIX available] Alexa per Alexa2 Totalausfall !?:
Version ist dann 3.19.10
kann nicht auf 3.19.10 updaten
trotz
Process exited with code 0bleibt er auf 3.19.9$ iobroker upgrade alexa2@3.19.10 --debug Update alexa2 from @3.19.9 to @3.19.10 NPM version: 8.11.0 Installing iobroker.alexa2@3.19.10... (System call) npm ERR! code ETARGETnpm ERR! notarget No matching version found for @sentry/utils@7.17.0. npm ERR! notarget In most cases you or one of your dependencies are requesting npm ERR! notarget a package version that doesn't exist. npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-10-27T12_58_05_541Z-debug-0.log upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript Process exited with code 0 -
Ja, Sentry hat irgendwie beim Publish von deren kram nen Fehler gemacht grmmpfff
https://github.com/getsentry/publish/issues/1513 ... die sind dran.
Geben wir inhnen ne stunden... Ich ne neue Version und Repo Update dauert genauso lang
kann auch nicht auf die 3.19.10 upgraden, kommt immer ein NPM@error (sentry/utils@7.17.0 ), andere Adapter (Synology, Wireshark) gingen problemlos.
Node 16.18.0 und NPM 8.19.2, debian 10, lxc.ilovegym@VMC123-iobroker /opt/iobroker $ iob upgrade --debug This upgrade of "alexa2" will introduce the following changes: ========================================================================== -> 3.19.10: Fix issue in retry handling when rate limit exceeded is returned by Amazon Do not clean up Smart Home Device objects for now - delete manually if you remove a device ========================================================================== Would you like to upgrade alexa2 from @3.19.9 to @3.19.10 now? [(y)es, (n)o]: y Update alexa2 from @3.19.9 to @3.19.10 NPM version: 8.19.2 Installing iobroker.alexa2@3.19.10... (System call) npm ERR! code ETARGET npm ERR! notarget No matching version found for @sentry/utils@7.17.0. npm ERR! notarget In most cases you or one of your dependencies are requesting npm ERR! notarget a package version that doesn't exist. npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-10-27T13_33_07_142Z-debug-0.logdas npm debuglog:
ilovegym@VMC123-iobroker /opt/iobroker $ cat /home/iobroker/.npm/_logs/2022-10-27T13_33_07_142Z-debug-0.log 0 verbose cli /usr/bin/node /usr/bin/npm 1 info using npm@8.19.2 2 info using node@v16.18.0 3 timing npm:load:whichnode Completed in 0ms 4 timing config:load:defaults Completed in 2ms 5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 6ms 6 timing config:load:builtin Completed in 7ms 7 timing config:load:cli Completed in 3ms 8 timing config:load:env Completed in 0ms 9 timing config:load:file:/opt/iobroker/.npmrc Completed in 3ms 10 timing config:load:project Completed in 19ms 11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms 12 timing config:load:user Completed in 0ms 13 timing config:load:file:/usr/etc/npmrc Completed in 0ms 14 timing config:load:global Completed in 1ms 15 timing config:load:validate Completed in 1ms 16 timing config:load:credentials Completed in 1ms 17 timing config:load:setEnvs Completed in 1ms 18 timing config:load Completed in 36ms 19 timing npm:load:configload Completed in 37ms 20 timing npm:load:mkdirpcache Completed in 1ms 21 timing npm:load:mkdirplogs Completed in 1ms 22 verbose title npm install iobroker.alexa2@3.19.10 23 verbose argv "install" "--save-exact" "iobroker.alexa2@3.19.10" 24 timing npm:load:setTitle Completed in 1ms 25 timing config:load:flatten Completed in 5ms 26 timing npm:load:display Completed in 7ms 27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs 28 verbose logfile /home/iobroker/.npm/_logs/2022-10-27T13_33_07_142Z-debug-0.log 29 timing npm:load:logFile Completed in 7ms 30 timing npm:load:timers Completed in 1ms 31 timing npm:load:configScope Completed in 0ms 32 timing npm:load Completed in 56ms 33 timing arborist:ctor Completed in 1ms 34 silly logfile start cleaning logs, removing 2 files 35 silly logfile done cleaning log files 36 timing idealTree:init Completed in 1962ms 37 timing idealTree:userRequests Completed in 54ms 38 silly idealTree buildDeps 39 silly fetch manifest iobroker.alexa2@3.19.10 40 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.synology 41 http fetch GET 200 https://registry.npmjs.org/iobroker.alexa2 1642ms (cache hit) 42 silly placeDep ROOT iobroker.alexa2@3.19.10 REPLACE for: iobroker.inst@2.0.3 want: 3.19.10 43 silly fetch manifest alexa-remote2@^5.8.3 44 silly fetch manifest https@^1.0.0 45 silly fetch manifest @sentry/node@^7.16.0 46 silly fetch manifest @sentry/integrations@^7.16.0 47 http fetch GET 200 https://registry.npmjs.org/alexa-remote2 1012ms (cache hit) 48 http fetch GET 200 https://registry.npmjs.org/https 1016ms (cache hit) 49 http fetch GET 200 https://registry.npmjs.org/@sentry%2fnode 1022ms (cache hit) 50 http fetch GET 200 https://registry.npmjs.org/@sentry%2fintegrations 1028ms (cache hit) 51 timing idealTree:#root Completed in 2720ms 52 silly placeDep node_modules/iobroker.alexa2 @sentry/integrations@7.17.0 OK for: iobroker.alexa2@3.19.10 want: ^7.16.0 53 silly placeDep node_modules/iobroker.alexa2 @sentry/node@7.17.0 OK for: iobroker.alexa2@3.19.10 want: ^7.16.0 54 silly placeDep ROOT alexa-remote2@5.8.3 OK for: iobroker.alexa2@3.19.10 want: ^5.8.3 55 silly placeDep ROOT https@1.0.0 OK for: iobroker.alexa2@3.19.10 want: ^1.0.0 56 silly fetch manifest @sentry/types@7.17.0 57 silly fetch manifest @sentry/utils@7.17.0 58 silly fetch manifest @sentry/core@7.17.0 59 silly fetch manifest cookie@^0.4.1 60 silly fetch manifest alexa-cookie2@^4.1.3 61 silly fetch manifest querystring@^0.2.1 62 silly fetch manifest ws@^8.8.1 63 silly fetch manifest uuid@^8.3.2 64 http fetch GET 200 https://registry.npmjs.org/@sentry%2ftypes 39ms (cache hit) 65 http fetch GET 200 https://registry.npmjs.org/@sentry%2fcore 46ms (cache hit) 66 http fetch GET 200 https://registry.npmjs.org/cookie 51ms (cache hit) 67 http fetch GET 200 https://registry.npmjs.org/querystring 53ms (cache hit) 68 http fetch GET 200 https://registry.npmjs.org/uuid 54ms (cache hit) 69 http fetch GET 200 https://registry.npmjs.org/alexa-cookie2 60ms (cache hit) 70 http fetch GET 200 https://registry.npmjs.org/ws 62ms (cache hit) 71 http fetch GET 200 https://registry.npmjs.org/@sentry%2futils 72ms (cache hit) 72 timing idealTree:node_modules/iobroker.alexa2 Completed in 91ms 73 silly fetch manifest bufferutil@^4.0.1 74 http fetch GET 200 https://registry.npmjs.org/bufferutil 10ms (cache hit) 75 silly fetch manifest utf-8-validate@^5.0.2 76 http fetch GET 200 https://registry.npmjs.org/utf-8-validate 8ms (cache hit) 77 silly placeDep ROOT alexa-cookie2@4.1.3 OK for: alexa-remote2@5.8.3 want: ^4.1.3 78 silly placeDep ROOT querystring@0.2.1 OK for: alexa-remote2@5.8.3 want: ^0.2.1 79 silly placeDep node_modules/alexa-remote2 uuid@8.3.2 OK for: alexa-remote2@5.8.3 want: ^8.3.2 80 silly placeDep node_modules/alexa-remote2 ws@8.10.0 OK for: alexa-remote2@5.8.3 want: ^8.8.1 81 silly fetch manifest http-proxy-middleware@^2.0.6 82 silly fetch manifest http-proxy-response-rewrite@^0.0.1 83 http fetch GET 200 https://registry.npmjs.org/http-proxy-middleware 23ms (cache hit) 84 http fetch GET 200 https://registry.npmjs.org/http-proxy-response-rewrite 26ms (cache hit) 85 timing idealTree:node_modules/alexa-remote2 Completed in 83ms 86 silly fetch manifest @types/express@^4.17.13 87 http fetch GET 200 https://registry.npmjs.org/@types%2fexpress 10ms (cache hit) 88 silly placeDep ROOT http-proxy-middleware@2.0.6 OK for: alexa-cookie2@4.1.3 want: ^2.0.6 89 silly placeDep ROOT http-proxy-response-rewrite@0.0.1 OK for: alexa-cookie2@4.1.3 want: ^0.0.1 90 silly fetch manifest @types/http-proxy@^1.17.8 91 silly fetch manifest http-proxy@^1.18.1 92 silly fetch manifest is-plain-obj@^3.0.0 93 silly fetch manifest micromatch@^4.0.2 94 silly fetch manifest bufferhelper@^0.2.1 95 http fetch GET 200 https://registry.npmjs.org/bufferhelper 17ms (cache hit) 96 http fetch GET 200 https://registry.npmjs.org/@types%2fhttp-proxy 22ms (cache hit) 97 http fetch GET 200 https://registry.npmjs.org/is-plain-obj 21ms (cache hit) 98 http fetch GET 200 https://registry.npmjs.org/http-proxy 23ms (cache hit) 99 http fetch GET 200 https://registry.npmjs.org/micromatch 23ms (cache hit) 100 timing idealTree:node_modules/alexa-cookie2 Completed in 57ms 101 silly placeDep ROOT @types/http-proxy@1.17.9 OK for: http-proxy-middleware@2.0.6 want: ^1.17.8 102 silly placeDep ROOT http-proxy@1.18.1 OK for: http-proxy-middleware@2.0.6 want: ^1.18.1 103 silly placeDep node_modules/http-proxy-middleware is-plain-obj@3.0.0 OK for: http-proxy-middleware@2.0.6 want: ^3.0.0 104 silly placeDep ROOT micromatch@4.0.5 OK for: http-proxy-middleware@2.0.6 want: ^4.0.2 105 timing idealTree:node_modules/http-proxy-middleware Completed in 16ms 106 timing idealTree:node_modules/@types/http-proxy Completed in 0ms 107 timing idealTree:node_modules/http-proxy Completed in 0ms 108 silly placeDep ROOT bufferhelper@0.2.1 OK for: http-proxy-response-rewrite@0.0.1 want: ^0.2.1 109 timing idealTree:node_modules/http-proxy-response-rewrite Completed in 4ms 110 timing idealTree:node_modules/bufferhelper Completed in 0ms 111 timing idealTree:node_modules/https Completed in 0ms 112 timing idealTree:node_modules/micromatch Completed in 0ms 113 timing idealTree:node_modules/querystring Completed in 0ms 114 timing idealTree:node_modules/alexa-remote2/node_modules/uuid Completed in 0ms 115 timing idealTree:node_modules/alexa-remote2/node_modules/ws Completed in 0ms 116 timing idealTree:node_modules/http-proxy-middleware/node_modules/is-plain-obj Completed in 1ms 117 silly placeDep node_modules/iobroker.alexa2 @sentry/types@7.17.0 OK for: @sentry/integrations@7.17.0 want: 7.17.0 118 silly placeDep node_modules/iobroker.alexa2/node_modules/@sentry/integrations @sentry/utils@ OK for: @sentry/integrations@7.17.0 want: 7.17.0 119 timing idealTree:node_modules/iobroker.alexa2/node_modules/@sentry/integrations Completed in 12ms 120 silly placeDep node_modules/iobroker.alexa2 @sentry/core@7.17.0 OK for: @sentry/node@7.17.0 want: 7.17.0 121 silly placeDep node_modules/iobroker.alexa2/node_modules/@sentry/node @sentry/utils@ OK for: @sentry/node@7.17.0 want: 7.17.0 122 silly placeDep node_modules/iobroker.alexa2 cookie@0.4.2 OK for: @sentry/node@7.17.0 want: ^0.4.1 123 timing idealTree:node_modules/iobroker.alexa2/node_modules/@sentry/node Completed in 45ms 124 silly placeDep node_modules/iobroker.alexa2/node_modules/@sentry/core @sentry/utils@ OK for: @sentry/core@7.17.0 want: 7.17.0 125 timing idealTree:node_modules/iobroker.alexa2/node_modules/@sentry/core Completed in 5ms 126 timing idealTree:node_modules/iobroker.alexa2/node_modules/@sentry/types Completed in 0ms 127 timing idealTree:node_modules/iobroker.alexa2/node_modules/cookie Completed in 0ms 128 timing idealTree:node_modules/iobroker.alexa2/node_modules/@sentry/core/node_modules/@sentry/utils Completed in 0ms 129 timing idealTree:node_modules/iobroker.alexa2/node_modules/@sentry/integrations/node_modules/@sentry/utils Completed in 0ms 130 timing idealTree:node_modules/iobroker.alexa2/node_modules/@sentry/node/node_modules/@sentry/utils Completed in 0ms 131 timing idealTree:buildDeps Completed in 3045ms 132 timing idealTree:fixDepFlags Completed in 81ms 133 timing idealTree Completed in 5147ms 134 timing command:install Completed in 5162ms 135 verbose type version 136 verbose stack @sentry/utils: No matching version found for @sentry/utils@7.17.0. 136 verbose stack at module.exports (/usr/lib/node_modules/npm/node_modules/npm-pick-manifest/lib/index.js:209:23) 136 verbose stack at RegistryFetcher.manifest (/usr/lib/node_modules/npm/node_modules/pacote/lib/registry.js:125:22) 137 verbose cwd /opt/iobroker 138 verbose Linux 5.15.64-1-pve 139 verbose node v16.18.0 140 verbose npm v8.19.2 141 error code ETARGET 142 error notarget No matching version found for @sentry/utils@7.17.0. 143 error notarget In most cases you or one of your dependencies are requesting 143 error notarget a package version that doesn't exist. 144 verbose exit 1 145 timing npm Completed in 5402ms 146 verbose unfinished npm timer reify 1666877587370 147 verbose unfinished npm timer reify:loadTrees 1666877587378 148 verbose code 1 149 error A complete log of this run can be found in: 149 error /home/iobroker/.npm/_logs/2022-10-27T13_33_07_142Z-debug-0.log ilovegym@VMC123-iobroker /opt/iobroker $ -
User berichtet es geht jetzt
@apollon77 ja, lief jetzt durch, Adapter geht wieder, Danke fuers Update!
@apollon77 Adapter installation auf 3.19.10 kein Problem, aber SmartDevices gehen (noch ) nicht.
@toste sagte in [FIX available] Alexa per Alexa2 Totalausfall !?:
Ja ich hoffe ich bekomme noch Rückmeldung von Amazon zum Warum.
Ich hoffe Inständig das nicht irgendwelche "dummen User" (sorry) den Adapter-Code anpassen um die Smart Home device infos schneller zu laden und damit Probleme für alle anderen verursachen.
Da kannste aber sicher sein ! Kommt ja nicht umsonst alle paar Wochen vor dass mal wieder ein Riegel reingeschoben wird.
@apollon77 Wäre sehr ärgerlich. Die Akzeptanz hier im Hause sinkt von mal zu mal. Aber gibt es alternativen?
@djmarc75 naja wenn dem so sein sollte und Amazon nicht die verursachenden user separat behandeln und sperren möchte oder anschreiben, bleibt nur die Variante das Smart Home daten laden wieder auszubauen
@djmarc75 sagte in [FIX available] Alexa per Alexa2 Totalausfall !?:
@homoran sagte in [FIX available] Alexa per Alexa2 Totalausfall !?:
warum noch ein Thread???
@toste Verbinde die Geräte nicht mit Amazon only sondern nutze welche die von nativen Adaptern unterstützt werden
mich würde das nicht jucken, ich nutze eh weder Räume noch Skills in der AlexaApp.
Aber ich spreche da nur für mich ! -
@apollon77 aber SmartDevices gehen (noch ) nicht.
bei mir gehen sie, ob sie vor 2 Std auch funktioniert haben. Kann ich nicht sagen
Smart Home Devices (TUYA-Geräte) sind zwar in den Objekten vorhanden, lassen sich aber nicht schalten.
@old_engineer bitte mal warten da die SmartHomeDevices seitens Amazon im Moment nicht funktionieren.... und bitte nicht den Adapter unnötig neu starten und auch nicht manuell nach SmartHomeDevices scannen!
@djmarc75 said in [FIX available] Alexa per Alexa2 Totalausfall !?:
OK, dann warte ich mal. Ich habe angefangen die Tuya Geräte redundant über Alexa zu steuern, da der Tuya Adapter auch gerne aussteigt.
@old_engineer sagte in [FIX available] Alexa per Alexa2 Totalausfall !?:
Da hätte ich ja gern in nem anderen Thread oder einerm GitHub Issue Beweise für.
