    4. Test Withings v0.0.x
    • ESP8266
      ESP8266 @MrLee last edited by
      @mrlee , Adapter neu starten.
        MrLee @ESP8266 last edited by
        @esp8266
        Moin, dank für die Info...
        passiert aber leider genau das Selbe im log und Adapter bleibt gelb.
        withings.0
        2022-10-24 08:35:28.460	error	{"status":503,"error":"Invalid Params: Missing [refresh_token]"}
        withings.0
        2022-10-24 08:35:28.349	warn	Please check username and password
        withings.0
        2022-10-24 08:35:25.260	info	starting. Version 0.0.13 (non-npm: TA2k/ioBroker.withings) in /opt/iobroker/node_modules/iobroker.withings, node: v16.17.1, js-controller: 4.0.23
        withings.0
        2022-10-24 08:35:24.709	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        host.iobroker_host-neu
        2022-10-24 08:35:21.479	info	instance system.adapter.withings.0 started with pid 15809
        2022-10-24 08:35:18.817	info	instance system.adapter.withings.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-10-24 08:35:18.197	info	stopInstance system.adapter.withings.0 send kill signal
        withings.0
        2022-10-24 08:35:18.170	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        withings.0
        2022-10-24 08:35:18.167	info	terminating
        withings.0
        2022-10-24 08:35:18.161	info	Got terminate signal TERMINATE_YOURSELF
        2022-10-24 08:35:18.154	info	stopInstance system.adapter.withings.0 (force=false, process=true)
        2022-10-24 08:35:08.695	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-10-24 08:35:00.051	info	instance system.adapter.dwd.0 started with pid 15780
        withings.0 2022-10-24 08:34:09.785	error	{"status":503,"error":"Invalid Params: Missing [refresh_token]"}
        withings.0 2022-10-24 08:34:09.673	warn	Please check username and password
        Bekomme auch jedesmal wenn ich den Adapter starte eine Mail von withings
        Hier ist Ihr vorläufiger Anmeldecode
        Habe ich bei Withinhgs was falsch eingestellt?
        bis denne
        Mr.Lee
        stony2k 1 Reply Last reply Reply Quote 0
        • stony2k
          stony2k @MrLee last edited by stony2k
          seit dem Updates des Adapter wird die Zeit von total_sleep_time anders angegeben. Sind das nun Sekunden? Wobei das dann komischerweise nicht mit den Angaben in der App übereinstimmt.
          Beispiel: aktuell hat der Datenpunkt den Wert 24300, was 6,7 h sein müssten. Laut der App sind es aber nur 6:45 Min
          @mrlee sagte in Test Withings v0.0.x:
          bis denne
          Mr.Lee
          Die Mail bekomme ich auch, ist in meinen Augen einfach zu ignorieren
          oberfragger 1 Reply Last reply Reply Quote 0
          • oberfragger
            oberfragger @stony2k last edited by
            @stony2k said in Test Withings v0.0.x:
            bis denne
            Mr.Lee
            die Rechnung stimmt doch!
            24300 Sekunden = 405 Minuten = 6,75h
            0,75h = 45 Minuten (0,75*60)
            -> 6,75h = 6h 45 Minuten
            • stony2k
              stony2k @oberfragger last edited by
              @oberfragger sagte in Test Withings v0.0.x:
              bis denne
              Mr.Lee
              Ok du hast recht. Ich Trottel 😄
              Hast du eine Idee, wie ich mir das in ein lesbares Format umwandeln kann? Also per Formel oder Javascript?
              • ESP8266
                ESP8266 @stony2k last edited by ESP8266
                @stony2k , das habe ich hier im Thread schon mal gepostet.
                 on({id: "withings.0.28587019.measures.measuregrps01.1.value"/*value*/, change: "ne"}, async function (obj) {
                >   var value = obj.state.val;
                >   var oldValue = obj.oldState.val;
                >   setState("0_userdata.0.Withings.Aktuelle_Gewichte.XXXX.Gewicht"/*Gewicht*/, Math.round((parseFloat(getState("withings.0.28587019.measures.measuregrps01.1.value").val) / 1000)*10)/10);
                >   setState("0_userdata.0.Withings.Aktuelle_Gewichte.XXXX.Datum"/*Datum*/, (String(formatDate(getDateObject((parseFloat(getState("withings.0.28587019.measures.measuregrps01.created").val) * 1000)), "DD.MM.YYYY"))));
                >   setState("0_userdata.0.Withings.Aktuelle_Gewichte.XXXX.Zeit"/*Zeit*/, (String(formatDate(getDateObject((parseFloat(getState("withings.0.28587019.measures.measuregrps01.created").val) * 1000)), "hh:mm:ss"))));
                Da ist auch die Zeit drin. Eine Formel und einem Zeitstempel. Also nicht anderes.
                stony2k Damrak2022 2 Replies Last reply Reply Quote 1
                • Damrak2022
                  Damrak2022 @tombox last edited by Damrak2022
                  @tombox Hallo, ich muss mal wieder nachfragen:
                  Unter sleep summary habe ich 19 Unterordner. Das scheint soweit okay zu sein, da die Anzahl der Unterordner nicht mehr wird.
                  Meine Adaptereinstellungen sehen so aus:
                  Was ich aber weniger verstehe ist die Darstellung unterhalb von sleep summary/series01/data
                  Hier wird mir jetzt als created der 26.10.2022 um 17:47 Uhr angezeigt, mit einer totalsleeptime von 5100
                  Wenn ich nun aber unter sleep summary/series02/data schaue wird mir hier als created erneut der 26.10.2022 um 15:05 Uhr angezeigt mit einer totalsleeptime von 16260
                  Das macht es nahezu unmöglich die Daten verlässlich weiterzuverarbeiten, oder hat hier jemand einen Tipp, wie man das bewerkstelligt?
                  Warum gibt es nicht pro Tag nur eine Datenausgabe? Ist es möglich das so zu machen?
                  Dann noch was ganz wichtiges: Ich habe unterhalb von Sleep mittlerweile 191 Unterordner
                  • stony2k
                    stony2k @ESP8266 last edited by stony2k
                    @esp8266 sagte in Test Withings v0.0.x:
                    Leider doch nicht das, was ich brauche. Es geht sich nicht um den Zeitstempel des Datenpunktes, sondern den Wert. Der Datenpunkt enthält als Wert die Zeit, die man geschlafen hat in Sekunden.
                    • Damrak2022
                      Damrak2022 @stony2k last edited by
                      @stony2k Sorry, kannst Du mir das näher erklären, denn so fit bin ich nicht. Hast Du das hinbekommen, das Du immer nur den korrekten Wert erhält? Und wie muss ich das machen? Es wäre toll, wenn Du mir das erklären könntest - Danke
                      • stony2k
                        stony2k @Damrak2022 last edited by stony2k
                        @damrak2022 sagte in Test Withings v0.0.x:
                        Bekomme das gerade nicht hin, habs mir nochmal angeschaut. @ESP8266 nutzt ja dem timestamp der der Erstellung des Datenpunktes. Wir wollen ja Sekunden in eine Uhrzeit umwandeln. Bisher habe ich es noch nicht hinbekommen.
                        Edit: Hiermit konnte ich den Wert nun richtig formatieren: https://forum.iobroker.net/topic/15033/erledigt-sekunden-in-stunden-und-minuten-anzeigen/2?_=1666943596811
                        • Damrak2022
                          @stony2k Ich habe jetzt in den Adapter Einstellungen das mal auf "den Schlaf alle 24 Stunden abrufen" umgestellt und jetzt sieht es so aus, ds ich nur noch einen Eintrag pro Tag habe. Wenn das so bleibt - perfekt.
                          • Damrak2022
                            Damrak2022 @ESP8266 last edited by
                            @esp8266 Sorry für den Doppelpost. Ich habe mein Problem hier schonmal beschrieben:
                            https://forum.iobroker.net/topic/59500/withings-sleep-mehrere-datenpunkte-pro-nacht-zusammenfassen?_=1667493340054
                            Mir gelingt es nicht die Daten so zusammenzufassen, das ich pro Tag nur einen Wert erhalte, welchen ich dann in Node Red darstellen kann.
                            Dies bezieht sich auf den Schlaf genauso, wie z.B. auf die Schritte und sonstigen Werte. Kannst Du mir erklären wie ich das zusammenfasse. Ich habe keine Idee wie ich das umsetzen könnte.
                            • ESP8266
                              ESP8266 @Damrak2022 last edited by
                              @damrak2022 , ich kann dir da nicht weiter helfen. Ich nutze das nicht.
                              Withings ist eh im Moment mal wieder nicht zu erreichen.
                              • Damrak2022
                                @esp8266 Danke ich habe mittlerweile für mich eine Lösung gefunden, wie ich es darstelle.
                                • stony2k
                                  Hat auch jemand von eich das Problem, dass die Daten von der Waage nicht mehr komplett ausgelesen werden? Die Schlafwerte werden weiterhin angezeigt, bei den Daten der Waage wird nur noch die Pulswellengeschwindigkeit ausgelesen. Alle Datenpunkte gelöscht, Adapter neu gestartet, keine Besserung. Es wird aber für den aktuellen Tag unter withings.0.25505597.measures.measuregrps01 ein wenig an Daten erzeugt:Bildschirm­foto 2022-11-18 um 07.05.01.png
                                  ESP8266 S 2 Replies Last reply Reply Quote 0
                                  • ESP8266
                                    @stony2k , kann ich erst Morgen testen. Habe nur Gewichte.
                                      somansch @stony2k last edited by somansch
                                      @stony2k
                                      ist bei mir leider genauso (von Anfang an). Ich habe daher im Moment den "FHEM" Adapter im Einsatz, um mir über diesen Weg diese Daten zu holen und eine vernünftige Historie zu sehen.
                                      • ESP8266
                                        ESP8266 last edited by ESP8266
                                        @stony2k sagte in Test Withings v0.0.x:
                                        Hat auch jemand von eich das Problem, dass die Daten von der Waage nicht mehr komplett ausgelesen werden? Die Schlafwerte werden weiterhin angezeigt, bei den Daten der Waage wird nur noch die Pulswellengeschwindigkeit ausgelesen. Alle Datenpunkte gelöscht, Adapter neu gestartet, keine Besserung. Es wird aber für den aktuellen Tag unter withings.0.25505597.measures.measuregrps01 ein wenig an Daten erzeugt:!
                                        Wie versprochen mal getestet heute. Ich habe nur Gewichte von mir und meiner Regierung, sind aber ohne Fehler vollständig aktualisiert worden.
                                          somansch @ESP8266 last edited by somansch
                                          @esp8266
                                          Was sagt das Datum bei "measuregrps02" bei dir? Steht dort dann das Datum der vorherigen Messung?
                                          Ich habe heute eine neue Messung und die Werte sind verteilt in measuregrps01, 02 und 03 😠 Das Datum entsprechend jeweils von heute. Das Problem ist, dass dann manchmal zB. der Wert für das Gewicht in measuregrps01 und manchmal in den anderen measuregrps aktualisiert wird. Somit ist keine zuverlässige Anzeige möglich. Wie geschrieben, behelfe ich mir momentan über den Umweg mit "FHEM", aber eigentlich wollte ich dieses System dann irgendwann abschalten....
                                          • ESP8266
                                            @somansch , mein Datum wird aus dem Zeitstempel um konvertiert.
                                            Ich
                                            Meine Frau
                                            516
                                            96182
