      Sammydk @Sammydk last edited by Sammydk
      @sammydk
      Und hier die Config.ini
      [MakeImage]
      ;LogImageLocation = /log/source
      WaitBeforeTakingPicture = 5
      ;LogfileRetentionInDays = 15
      Brightness = 0
      Contrast = 1
      Saturation = 0
      LEDIntensity = 8
      ImageQuality = 12
      ImageSize = VGA
      FixedExposure = false
      [Alignment]
      InitialRotate = 179
      InitialMirror = false
      SearchFieldX = 20
      SearchFieldY = 20
      AlignmentAlgo = default
      FlipImageSize = false
      /config/ref0.jpg 122 222
      /config/ref1.jpg 236 22
      [Digits]
      Model = /config/dig-class100_s1d-md-v1.0_q.tflite
      CNNGoodThreshold = 0.5
      ;LogImageLocation = /log/digit
      ;LogfileRetentionInDays = 3
      main.dig1 205 101 33 55 false
      main.dig2 240 101 37 56 false
      main.dig3 279 102 32 54 false
      main.digi4 313 102 37 54 false
      [Analog]
      Model = /config/ana-class100_i32s100dr-v1.0_q.tflite
      ;LogImageLocation = /log/analog
      main.ana1 398 174 99 99 false
      main.ana2 354 280 98 96 false
      main.ana3 250 323 97 97 false
      main.ana4 139 277 98 95 false
      [PostProcessing]
      main.DecimalShift = 0
      PreValueUse = true
      PreValueAgeStartup = 720
      AllowNegativeRates = false
      ;main.MaxRateValue = 0.5
      ;main.MaxRateType = AbsoluteChange
      ;main.ExtendedResolution = false
      ;main.IgnoreLeadingNaN = true
      ErrorMessage = true
      CheckDigitIncreaseConsistency = false
      [MQTT]
      Uri = mqtt://192.168.###.8:1883
      MainTopic = #############
      ClientID = ##############
      user = #########
      password = #########
      ;SetRetainFlag = true
      ;[InfluxDB]
      ;Uri = undefined
      ;Database =
      ;Measurement = undefined
      ;user = undefined
      ;password = undefined
      ;[GPIO]
      ;IO0 = input disabled 10 false false
      ;IO1 = input disabled 10 false false
      ;IO3 = input disabled 10 false false
      ;IO4 = built-in-led disabled 10 false false
      ;IO12 = input-pullup disabled 10 false false
      ;IO13 = input-pullup disabled 10 false false
      LEDType = WS2812
      LEDNumbers = 2
      LEDColor = 150 150 150
      [AutoTimer]
      AutoStart = true
      Intervall = 4.85
      [Debug]
      Logfile = false
      [System]
      ;TimeZone = CET-1CEST,M3.5.0,M10.5.0/3
      TimeServer = 192.168.###.1
      ;AutoAdjustSummertime = false
      ;Hostname = undefined
      SetupMode = false
      Jens Meyer 1 Reply Last reply Reply Quote 0
        Fubak 0 @jomjol last edited by
        @jomjol Okay, mir war nicht klar das er sich die Punkte neu suchen muss.
        • Jens Meyer
          Jens Meyer @Sammydk last edited by Jens Meyer
          @sammydk
          Setz mal CheckDigitIncreaseConsistency = false
          Auf true
          Das sollte dein Problem eleminieren
            Sammydk @Jens Meyer last edited by
            @jens-meyer
            Hallo Jens, danke für den TIP, ich werde es beobachten.
            • Jens Meyer
              Jens Meyer @jomjol last edited by
              @jomjol
              Hallo,ich muss aber auch mal fragen.. wie läuft das Setup für einen gaszähler ab?
              Was für ein file gibt es da? (Referenzbild) ? Kann ja nicht das selbe wie für die Wasseruhr sein? Und nach dem Komma sind ja auch dig und keine Analogen Zeiger.. muss man da auch die digitalen Zähler zum einstellen nehmen und erkennt er dann die 3 zahlen nach dem Komma? Oder wie habt ihr das gemacht?
                jomjol @Jens Meyer last edited by
                @jens-meyer sagte in Wasserzähler - Version 2 - all-in-device:
                @jomjol
                Ich verstehe deine Frage nicht ganz. Das läuft wie beim Wasserzähler, nur dass du eben die analogen Zähler deaktivierst. Die Position des Kommas kannst du dann in der Konfiguration festlegen.
                Hoffe, dass hilft.
                • Jens Meyer
                  @jomjol
                  ja so ist das ok, danke für die info... wo und wie kann ich den die position des kommas festlegen in der config?
                    @jomjol
                    Hast du die Konfiguration schonmal durchgeführt? Ist eigentlich kaum zu übersehen:
                    • Jens Meyer
                      @jomjol
                      Vielen Dank, hat mir sehr geholfen
                      • Jens Meyer
                        Jens Meyer @Jens Meyer last edited by Jens Meyer
                        @jens-meyer
                        das passt doch hinten und vorn nicht, ich bin schon seit stunden am hin und her probieren mit den dig und dem referenzbild , es will einfach nicht... bei der wasseruhr gibts keine probleme, da wird alles korekt angezeigt wie es soll
                        nur der blöde gaszähler macht probleme
                        • BananaJoe
                          BananaJoe Most Active @Jens Meyer last edited by BananaJoe
                          @jens-meyer deine Zahlenrahmen sind alle unterschiedlich groß.
                          Du kannst deren Größe in Pixeln angeben - mache die alle gleich groß.
                          Achte beim Referenzbild darauf die Zahlen genau gerade auszurichten,
                          Dann die Kästen alle gleich groß - und die müssten dann alle auf dem gleichen Y-Wert liegen
                          Und vergiss die letzte Zahl mit den vielen Strichen, lass die einfach weg
                          Jens Meyer 2 Replies Last reply Reply Quote 0
                          • Jens Meyer
                            Jens Meyer @BananaJoe last edited by
                            @bananajoe
                            danke für die tips... probiere ich dann gleich und melde mich
                              JoergH @Jens Meyer last edited by JoergH
                              @bananajoe
                              Der innere Rahmen muss exakt die Zahlen umfassen, der äußere sollte dann auch nicht über die Walzen hinauslangen. Ich habe den gleichen Zähler und bei mir funktioniert es inzwischen einwandfrei.
                              Auch die Wasserzähler habe ich in den letzten Tagen durch viel getüftel endlich alle zum Laufen gebracht.
                              Zunächst habe ich die Gehäuse alle aus schwarem Filament gedruckt und gedacht es wäre hilfreich, wenn diese Licht schlucken um Blendungen zu vermeiden. Wie sich herausstellte, ist das genau falsch!
                              Inzwischen habe ich alle aus weissem Filament gedruckt und das funktioniert erheblich besser!
                              Nachdem ich von Thingiverse zunächst die Druckvorlagen runtergeladen hatte und mit denen nicht glücklich wurde, habe ich meine eigenen entworfen und diese gedruckt. Dabei habe ich bei unterschiedlichen Zählern auch mit dem Abstand gespielt und festgestellt, dass ein Abstand von eher 8 cm zum Zähler besser funktioniert, als wenn er größer ist. Selbst mein Zisternenzähler, der durch Schwebeteilchen ziemlich getrübt ist, funktioniert so bestens!
                              • Jens Meyer
                                Jens Meyer @JoergH last edited by
                                @joergh
                                ja das mit den Rahmen um die Ziffern weiss ich, mein Wasserzähler läuft ja korrekt
                                aber ich werde erstmal alles in einer Grösse machen und auf einer Achse anordnen (y)
                                und mal sehen...ich denke die Spiegelungen kommen vom Spiegel selbst... (spiegelvariante vom Wasserzähler)
                                • Jens Meyer
                                  Jens Meyer @BananaJoe last edited by Jens Meyer
                                  @bananajoe
                                  wenn ich die Rahmen alle gleich gross habe und alle auf einer y-Achse liegen , liegt der Rahmen aber nicht mehr genau um die Zahl
                                  da ja die Zahlen im Zähler mal etwas weiter oben und eine andere wieder etwas weiter unten steht
                                  so nochmal nachjustiert... sieht aber auch nicht besser aus...
                                  • BananaJoe
                                    @jens-meyer irgendwie bist du ziemlich schräg, sowohl horizontal als auch vertikal
                                    und 91.88 ist doch gut? (wenn auch 0.01 daneben)
                                    • Jens Meyer
                                      @bananajoe
                                      ist nicht der raw wert entscheidend? habs nun einigermassen hinbekommen
                                      musste auf eine stelle nach dem komma , die letzten 2 will er nicht
                                      • Jens Meyer
                                        @bananajoe
                                        Hallo, ich hab da mal noch ne Frage..
                                        Mit einer Komma Stelle zeigt es den Wert richtig an… nach neu Ausrichtung
                                        Sobald ich aber 2 Komma stellen einstelle , und einem zusätzlichen dig stimmt der raw Wert garnicht mehr der richtige Wert ist 091.9 das wird mir bei einer Komma stelle auch angezeigt.. bei allen werten gleich und wenn ich die 2 kommastelle aktiviere zeigt mir der raw Wert 970,19 an versteh ich nicht.. Spiegelungen?
                                        Mehrmals probiert.. Wechsel ich zurück auf eine kommastelle ist alles wieder richtig 2 kommastelle falsche werte
                                        Ps: das Referenzbild sieht gerade aus mit dem gitterlinien
                                        • BananaJoe
                                          @jens-meyer Eventuell bewegen sich die hinteren Stellen auch einfach zu schnell. Wenn die Anzeige zwischen den Zahlen steht geht es regelmäßig schief. Ich hab meinen Gaszähler nur auf die m³, mir reicht das (sind dann halt ca. 11kWh Schritte)
                                          • Jens Meyer
                                            @bananajoe
                                            Ok, danke für die info… da ist eine kommastelle schon gut denke ich , könnte ja auch ein Sensor dran bauen, ist mir aber zu umständlich das mit der Cam ist ne gute Lösung,vielleicht druck ich mir noch ne Schablone.. oder ne gerade Variante wo die Camera ohne Spiegel davor sitzt… mal sehen
                                            Aber danke für deine Hilfe
                                            238
                                            3411
                                            2023076
