    3. Einsteigerfragen
    4. Sonoff 3.0 ZigBee Stick - diverse Fehlermeldungen beim Start
      Thomas Braun Most Active @Kintaro829 last edited by
      @kintaro829
      Das ist zu wenig.
      Im Log File dürfte viel mehr stehen.
        Kintaro829 @Thomas Braun last edited by Kintaro829
        Ich kann meinen Beitrag oben leider nicht mehr bearbeiten. Habe das gesamte Log gelöscht und nur die Ausgabe beim Start des Adapters hinzugefügt.
        2022-10-30 13:58:34.273 - info: host.ioBroker "system.adapter.zigbee.0" enabled
        2022-10-30 13:58:34.290 - info: host.ioBroker instance system.adapter.zigbee.0 started with pid 719
        2022-10-30 13:58:35.526 - info: zigbee.0 (719) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.0, js-controller: 4.0.23
        2022-10-30 13:58:35.578 - info: zigbee.0 (719) delete old Backup files. keep only last 10
        2022-10-30 13:58:35.579 - info: zigbee.0 (719) Starting Zigbee npm ...
        2022-10-30 13:58:35.759 - info: zigbee.0 (719) Installed Version: iobroker.zigbee@1.7.5
        2022-10-30 13:58:35.953 - error: zigbee.0 (719) Configuration is not consistent with adapter state/backup!
        2022-10-30 13:58:35.953 - error: zigbee.0 (719) - PAN ID: configured=1234, adapter=1234
        2022-10-30 13:58:35.953 - error: zigbee.0 (719) - Extended PAN ID: configured=123123123, adapter=123123123
        2022-10-30 13:58:35.953 - error: zigbee.0 (719) - Network Key: configured=123123123123, adapter=123123123123
        2022-10-30 13:58:35.954 - error: zigbee.0 (719) - Channel List: configured=11, adapter=11
        2022-10-30 13:58:35.954 - error: zigbee.0 (719) Please update configuration to prevent further issues.
        2022-10-30 13:58:35.954 - error: zigbee.0 (719) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
        2022-10-30 13:58:35.954 - error: zigbee.0 (719) Re-commissioning your network will require re-pairing of all devices!
        2022-10-30 13:58:36.014 - error: zigbee.0 (719) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
        2022-10-30 13:58:36.014 - error: zigbee.0 (719) Failed to start Zigbee
        2022-10-30 13:58:36.014 - error: zigbee.0 (719) Error herdsman start
        2022-10-30 13:58:46.016 - info: zigbee.0 (719) Try to reconnect. 1 attempts left
        2022-10-30 13:58:46.017 - info: zigbee.0 (719) Starting Zigbee npm ...
        2022-10-30 13:58:46.029 - info: zigbee.0 (719) Installed Version: iobroker.zigbee@1.7.5
        2022-10-30 13:58:46.153 - error: zigbee.0 (719) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
        2022-10-30 13:58:46.154 - error: zigbee.0 (719) Failed to start Zigbee
        2022-10-30 13:58:46.154 - error: zigbee.0 (719) Error herdsman start
          Thomas Braun Most Active @Kintaro829 last edited by Thomas Braun
          @kintaro829
          2022-10-30 13:58:35.953 - error: zigbee.0 (719) - PAN ID: configured=1234, adapter=1688
          2022-10-30 13:58:35.953 - error: zigbee.0 (719) - Extended PAN ID: configured=00134b0026d15f3d, adapter=00134b0026d15f3d
          2022-10-30 13:58:35.953 - error: zigbee.0 (719) - Network Key: configured=01031507090a0d0f00020406080a0c0d, adapter=8d134e576f6a2b95426c8723d698e09a
          Diese vier Einstellungen müssen gleich sein. Also entsprechend anpassen.
          K 2 Replies Last reply Reply Quote 0
            Danke, aber woher nimmt sich der Adapter bzw. die Konfiguration (?) diese Werte. Ich kann das lediglich in den ZigBee Einstellungen ändern.
            Kann ich das auf einer anderen Ebene angleichen und anpassen wie ich möchte?
              @kintaro829
              Wo die 'Gegenstelle' dazu ist weiß ich nicht. Ich hab's bei mir immer in den Adapter-Einstellungen angepasst.
                Also ich kann dir definitiv sagen, dass der Transportkey vorher von mir bearbeitet wurde und es handelt sich um den neuen Key.
                Daher verstehe ich nicht wie der Adapter den Key bekommen hat. Zuvor habe ich die Werte verändert und deswegen kam es zu den falschen Informationen. Also gehe ich davon aus das der Adapter diese irgendwo zwischenspeichert o.ä.?
                  @kintaro829
                  Wie gesagt: Ich weiß es nicht.
                    Danke dir für den Hinweis mit den gleichen Werten. Damit funktioniert es nun nach meiner Anpassung.
                    Vielleicht hat noch jemand einen Tipp wie der Transportkey geändert werden kann (inkl. Adapter).
                      Kannst du mir bitte einen gefallen tun und die IDs in deiner Nachricht etwas abändern?
                      Ich weiß nicht, ob das so gut ist, wenn das nachträglich geändert werden kann und nun im Netz umherschwirrt.
                        @kintaro829
                        Spielt nur lokal eine Rolle.
                        997
