    4. ERROR: Process exited with code 25
      marcdo70 @Homoran last edited by
      login as: pi
      pi@192.168.178.74's password:
      Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Thu Oct 27 15:11:45 2022 from 192.168.178.92
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ iob update
       Connection is closed.
      Uncaught Rejection: Error: Objects DB is not allowed to start in the current Mul        tihost environment
          at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/        lib/objects/objectsInRedisClient.js:632:23)
          at processTicksAndRejections (node:internal/process/task_queues:96:5)
       Unable to subscribe to evicted Keyspace events from Redis Server: Connection is        closed.
       Unable to subscribe to meta namespace "meta." changes: Connection is closed.
      pi@raspberrypi:~ $ iobroker upgrade javascript@6.0.3 --debug
      Uncaught Rejection: Error: States DB is not allowed to start in the current Multihost environment
          at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:579:23)
      pi@raspberrypi:~ $ ^C
      pi@raspberrypi:~ $
        marcdo70 @marcdo70 last edited by
        @marcdo70
        SO? Alles neu für mich gerade
          @marcdo70
          login as: pi
          Last login: Thu Oct 27 15:22:19 2022 from 192.168.178.92
          Used repository: Stable (default)
          Adapter    "admin"        : 6.2.23   , installed 6.2.22 [Updatable]
          Adapter    "alexa2"       : 3.19.10  , installed 3.19.9 [Updatable]
          Adapter    "backitup"     : 2.4.12   , installed 2.4.12
          Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
          Adapter    "denon"        : 1.13.4   , installed 1.13.4
          Adapter    "discovery"    : 3.0.5    , installed 3.0.5
          Adapter    "dwd"          : 2.8.3    , installed 2.8.3
          Adapter    "harmony"      : 1.2.2    , installed 1.2.2
          Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
          Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
          Adapter    "info"         : 1.9.19   , installed 1.9.19
          Adapter    "iot"          : 1.11.9   , installed 1.11.9
          Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
          Adapter    "node-red"     : 4.0.0    , installed 4.0.0
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
          Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
          Adapter    "telegram"     : 1.14.1   , installed 1.14.1
          Adapter    "text2command" : 2.2.2    , installed 2.2.2
          Adapter    "vis"          : 1.4.15   , installed 1.4.15
          Adapter    "wled"         : 0.6.7    , installed 0.6.7
          This upgrade of "javascript" will introduce the following changes:
          -> 6.0.3:
          Downgrade Typescript to prevent errors with global typescript scripts
          -> 6.0.2:
          -> 6.0.1:
          Fixed the wizard schedule
          Done small fixes on GUI
          Would you like to upgrade javascript from @6.0.0 to @6.0.3 now? [(y)es, (n)o]: y
          Update javascript from @6.0.0 to @6.0.3
          NPM version: 8.19.2
          Installing iobroker.javascript@6.0.3... (System call)
          npm ERR! code ENOTDIR
          npm ERR! syscall rename
          npm ERR! path /opt/iobroker/node_modules/argparse
          npm ERR! dest /opt/iobroker/node_modules/.argparse-S5zfMSQi
          npm ERR! errno -20
          npm ERR! ENOTDIR: not a directory, rename '/opt/iobroker/node_modules/argparse' -> '/opt/iobroker/node_modules/.argparse-S5zfMSQi'
          npm ERR!     /home/iobroker/.npm/_logs/2022-10-27T15_11_54_736Z-debug-0.log
          host.raspberrypi Cannot install iobroker.javascript@6.0.3: 236
          pi@raspberrypi:~ $
            Ich komm nicht dahinter warum ich immer code25 Abruch bekomme und den ALexa2 und den Script Adapter nicht updaten kann, so funktioniert leider meine Spachausgabe auf meiner Alexa nicht mehr. Was kann ich tun?
              Homoran Global Moderator Administrators @marcdo70 last edited by
                marcdo70 @Homoran last edited by marcdo70
                @homoran Hab ich doch schon versucht, aber da tut sich nichts. Hab diese Zeile in mein Putty gehauen, aber Fehler bleibt
                  @marcdo70 sagte in ERROR: Process exited with code 25:
                  Sorry, hab kein Ergebnis gesehen
                    login as: pi
                    Last login: Sun Oct 30 14:59:21 2022 from 192.168.178.92
                    pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                    pi@raspberrypi:~ $
                      aber Fehler bleibt
                      und das?
                        Thomas Braun Most Active @marcdo70 last edited by
                        @marcdo70
                        Was sagt
                        sudo ln -s /usr/bin/node /usr/bin/nodejs
                        uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                          marcdo70 @Thomas Braun last edited by
                          login as: pi
                          pi@raspberrypi:~ $
                          -> 6.0.3:
                          -> 6.0.2:
                          -> 6.0.1:
                          NPM version: 8.19.2
                          npm ERR! errno -20
                          npm ERR!     /home/iobroker/.npm/_logs/2022-10-30T14_10_17_873Z-debug-0.log
                          pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                          ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                          pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                          armv7l
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.18.0
                          v16.18.0
                          8.19.2
                          4.0.23
                          pi
                          pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                          tty
                          /home/pi
                          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                          Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                          Reading package lists... Done
                          Building dependency tree
                          11 packages can be upgraded. Run 'apt list --upgradable' to see them.
                          nodejs:
                            Installed: 16.18.0-deb-1nodesource1
                            Candidate: 16.18.0-deb-1nodesource1
                            Version table:
                           *** 16.18.0-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                  100 /var/lib/dpkg/status
                               10.24.0~dfsg-1~deb10u2 500
                          pi@raspberrypi:~ $
                          pi@raspberrypi:~ $
                            @marcdo70
                            Hat nichts mit deinem Problem zu tun, aber nutze die Gelegenheit für ein wenig Systempflege.
                              Ja hab ich auch gesehen, Danke
                                @thomas-braun sagte in ERROR: Process exited with code 25:
                                @marcdo70
                                So gemacht, aber wie mach ich jetzt mit meinem Fehller weiter
                                pi@raspberrypi:~ $ iobroker upgrade alexa2
                                This upgrade of "alexa2" will introduce the following changes:
                                -> 3.19.10:
                                Fix issue in retry handling when rate limit exceeded is returned by Amazon
                                Do not clean up Smart Home Device objects for now - delete manually if you remove a device
                                Would you like to upgrade alexa2 from @3.19.9 to @3.19.10 now? [(y)es, (n)o]: y
                                Update alexa2 from @3.19.9 to @3.19.10
                                NPM version: 8.19.2
                                Installing iobroker.alexa2@3.19.10... (System call)
                                host.raspberrypi Cannot install iobroker.alexa2@3.19.10: 236
                                  @marcdo70
                                  iobroker update
                                  iobroker upgrade alexa2 --debug
                                    Geht nicht
                                    login as: pi
                                    Last login: Sun Oct 30 15:05:29 2022 from 192.168.178.92
                                    pi@raspberrypi:~ $ iobroker update
                                    pi@raspberrypi:~ $ iobroker upgrade alexa2 --debug
                                    -> 3.19.10:
                                    Do not clean up Smart Home Device objects for now - delete manually if you remov        e a device
                                    NPM version: 8.19.2
                                    npm ERR! errno -20
                                    npm ERR!     /home/iobroker/.npm/_logs/2022-10-30T14_43_17_519Z-debug-0.log
                                    pi@raspberrypi:~ $
                                      @marcdo70
                                      rm -rf /opt/iobroker/node_modules/.argparse-S5zfMSQi
                                      Loggst du dich für jeden Befehl neu ein?
                                        Hatte Console ausversehen geschlossen, aber da passiert gar nichts
                                        login as: pi
                                        -> 3.19.10:
                                        NPM version: 8.19.2
                                        npm ERR! errno -20
                                        pi@raspberrypi:~ $ iobroker upgrade js-controller --debug
                                        Cannot update js-controller using this command. Please use "iobroker upgrade self" instead!
                                        pi@raspberrypi:~ $ iobroker upgrade self
                                        Host    "raspberrypi"    is up to date.
                                        pi@raspberrypi:~ $ rm -rf /opt/iobroker/node_modules/.argparse-S5zfMSQi
                                        pi@raspberrypi:~ $
                                          @marcdo70
                                          Da passiert schon was. Die Datei wurde gelöscht.
                                          Versuch das Upgrade jetzt nochmal.
                                            @marcdo70
                                            ok
                                            pi@raspberrypi:~ $
                                            -> 3.19.10:
                                            NPM version: 8.19.2
                                            npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
                                            npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
                                            added 75 packages, removed 13 packages, and changed 95 packages in 23s
                                            103 packages are looking for funding
                                              run `npm fund` for details
                                            Update "system.adapter.alexa2.0"
                                            upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
                                            upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
                                            upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
                                            upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
                                            upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
                                            upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
                                            upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
                                            upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
                                            upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
                                            upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
                                            upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
                                            upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
                                            upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
                                            upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
                                            upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
                                            upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
                                            upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
                                            upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
                                            upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
                                            upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
                                            upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
                                            upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
                                            pi@raspberrypi:~ $
                                            Thomas Braun M 2 Replies Last reply Reply Quote 0
                                            4278
