    4. ERROR: Process exited with code 25
      marcdo70 @marcdo70 last edited by
      @marcdo70
      login as: pi
      pi@192.168.178.74's password:
      Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Thu Oct 27 15:22:19 2022 from 192.168.178.92
      pi@raspberrypi:~ $ iob update
      Used repository: Stable (default)
      Adapter    "admin"        : 6.2.23   , installed 6.2.22 [Updatable]
      Adapter    "alexa2"       : 3.19.10  , installed 3.19.9 [Updatable]
      Adapter    "backitup"     : 2.4.12   , installed 2.4.12
      Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
      Adapter    "denon"        : 1.13.4   , installed 1.13.4
      Adapter    "discovery"    : 3.0.5    , installed 3.0.5
      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
      Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
      Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.11.9   , installed 1.11.9
      Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
      Adapter    "node-red"     : 4.0.0    , installed 4.0.0
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "telegram"     : 1.14.1   , installed 1.14.1
      Adapter    "text2command" : 2.2.2    , installed 2.2.2
      Adapter    "vis"          : 1.4.15   , installed 1.4.15
      Adapter    "wled"         : 0.6.7    , installed 0.6.7
      pi@raspberrypi:~ $ iobroker upgrade javascript@6.0.3 --debug
      This upgrade of "javascript" will introduce the following changes:
      -> 6.0.3:
      Downgrade Typescript to prevent errors with global typescript scripts
      -> 6.0.2:
      -> 6.0.1:
      Fixed the wizard schedule
      Done small fixes on GUI
      Would you like to upgrade javascript from @6.0.0 to @6.0.3 now? [(y)es, (n)o]: y
      Update javascript from @6.0.0 to @6.0.3
      NPM version: 8.19.2
      Installing iobroker.javascript@6.0.3... (System call)
      npm ERR! code ENOTDIR
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/argparse
      npm ERR! dest /opt/iobroker/node_modules/.argparse-S5zfMSQi
      npm ERR! errno -20
      npm ERR! ENOTDIR: not a directory, rename '/opt/iobroker/node_modules/argparse' -> '/opt/iobroker/node_modules/.argparse-S5zfMSQi'
      npm ERR!     /home/iobroker/.npm/_logs/2022-10-27T15_11_54_736Z-debug-0.log
      host.raspberrypi Cannot install iobroker.javascript@6.0.3: 236
      pi@raspberrypi:~ $
        marcdo70 @Homoran last edited by
        Ich komm nicht dahinter warum ich immer code25 Abruch bekomme und den ALexa2 und den Script Adapter nicht updaten kann, so funktioniert leider meine Spachausgabe auf meiner Alexa nicht mehr. Was kann ich tun?
          Homoran Global Moderator Administrators @marcdo70 last edited by
            marcdo70 @Homoran last edited by marcdo70
            @homoran Hab ich doch schon versucht, aber da tut sich nichts. Hab diese Zeile in mein Putty gehauen, aber Fehler bleibt
              @marcdo70 sagte in ERROR: Process exited with code 25:
              Sorry, hab kein Ergebnis gesehen
                login as: pi
                Last login: Sun Oct 30 14:59:21 2022 from 192.168.178.92
                pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                pi@raspberrypi:~ $
                  aber Fehler bleibt
                  und das?
                    Thomas Braun Most Active @marcdo70 last edited by
                    @marcdo70
                    Was sagt
                    sudo ln -s /usr/bin/node /usr/bin/nodejs
                    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                      marcdo70 @Thomas Braun last edited by
                      login as: pi
                      pi@raspberrypi:~ $ ^C
                      pi@raspberrypi:~ $
                      -> 6.0.3:
                      -> 6.0.2:
                      -> 6.0.1:
                      NPM version: 8.19.2
                      npm ERR! errno -20
                      npm ERR!     /home/iobroker/.npm/_logs/2022-10-30T14_10_17_873Z-debug-0.log
                      pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                      ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                      pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                      armv7l
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.18.0
                      v16.18.0
                      8.19.2
                      4.0.23
                      pi
                      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                      tty
                      /home/pi
                      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                      Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                      Reading package lists... Done
                      Building dependency tree
                      11 packages can be upgraded. Run 'apt list --upgradable' to see them.
                      nodejs:
                        Installed: 16.18.0-deb-1nodesource1
                        Candidate: 16.18.0-deb-1nodesource1
                        Version table:
                       *** 16.18.0-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                              100 /var/lib/dpkg/status
                           10.24.0~dfsg-1~deb10u2 500
                      pi@raspberrypi:~ $
                      pi@raspberrypi:~ $
                        @marcdo70
                        Hat nichts mit deinem Problem zu tun, aber nutze die Gelegenheit für ein wenig Systempflege.
                          Ja hab ich auch gesehen, Danke
                            @thomas-braun sagte in ERROR: Process exited with code 25:
                            @marcdo70
                            So gemacht, aber wie mach ich jetzt mit meinem Fehller weiter
                            pi@raspberrypi:~ $ iobroker upgrade alexa2
                            This upgrade of "alexa2" will introduce the following changes:
                            -> 3.19.10:
                            Fix issue in retry handling when rate limit exceeded is returned by Amazon
                            Do not clean up Smart Home Device objects for now - delete manually if you remove a device
                            Would you like to upgrade alexa2 from @3.19.9 to @3.19.10 now? [(y)es, (n)o]: y
                            Update alexa2 from @3.19.9 to @3.19.10
                            NPM version: 8.19.2
                            Installing iobroker.alexa2@3.19.10... (System call)
                            host.raspberrypi Cannot install iobroker.alexa2@3.19.10: 236
                              @marcdo70
                              iobroker update
                              iobroker upgrade alexa2 --debug
                                Geht nicht
                                login as: pi
                                Last login: Sun Oct 30 15:05:29 2022 from 192.168.178.92
                                pi@raspberrypi:~ $ iobroker update
                                pi@raspberrypi:~ $ iobroker upgrade alexa2 --debug
                                -> 3.19.10:
                                Do not clean up Smart Home Device objects for now - delete manually if you remov        e a device
                                NPM version: 8.19.2
                                npm ERR! errno -20
                                npm ERR!     /home/iobroker/.npm/_logs/2022-10-30T14_43_17_519Z-debug-0.log
                                pi@raspberrypi:~ $
                                  @marcdo70
                                  rm -rf /opt/iobroker/node_modules/.argparse-S5zfMSQi
                                  Loggst du dich für jeden Befehl neu ein?
                                    Hatte Console ausversehen geschlossen, aber da passiert gar nichts
                                    login as: pi
                                    -> 3.19.10:
                                    NPM version: 8.19.2
                                    npm ERR! errno -20
                                    pi@raspberrypi:~ $ iobroker upgrade js-controller --debug
                                    Cannot update js-controller using this command. Please use "iobroker upgrade self" instead!
                                    pi@raspberrypi:~ $ iobroker upgrade self
                                    Host    "raspberrypi"    is up to date.
                                    pi@raspberrypi:~ $ rm -rf /opt/iobroker/node_modules/.argparse-S5zfMSQi
                                    pi@raspberrypi:~ $
                                      @marcdo70
                                      Da passiert schon was. Die Datei wurde gelöscht.
                                      Versuch das Upgrade jetzt nochmal.
                                        @marcdo70
                                        ok
                                        pi@raspberrypi:~ $
                                        -> 3.19.10:
                                        NPM version: 8.19.2
                                        npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
                                        npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
                                        added 75 packages, removed 13 packages, and changed 95 packages in 23s
                                        103 packages are looking for funding
                                          run `npm fund` for details
                                        Update "system.adapter.alexa2.0"
                                        upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
                                        upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
                                        upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
                                        upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
                                        upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
                                        upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
                                        upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
                                        upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
                                        upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
                                        upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
                                        upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
                                        upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
                                        upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
                                        upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
                                        upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
                                        upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
                                        upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
                                        upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
                                        upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
                                        upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
                                        upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
                                        upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
                                        pi@raspberrypi:~ $
                                        Thomas Braun M 2 Replies Last reply Reply Quote 0
                                          @marcdo70
                                          Geht wohl jetzt. Heb den Rest auch auf die aktuelle Version.
                                            @marcdo70
                                            ok
                                            pi@raspberrypi:~ $
                                            -> 3.19.10:
                                            NPM version: 8.19.2
                                            pi@raspberrypi:~ $
                                            Hat bei dem Adapter funktioniert wie es aussieht
                                            4278
