    4. ERROR: Process exited with code 25
      marcdo70 @Thomas Braun last edited by
      login as: pi
      pi@192.168.178.74's password:
      Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Sun Oct 30 14:59:21 2022 from 192.168.178.92
      pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
      pi@raspberrypi:~ $ ^C
      pi@raspberrypi:~ $ iob update
      Used repository: Stable (default)
      Adapter    "admin"        : 6.2.23   , installed 6.2.22 [Updatable]
      Adapter    "alexa2"       : 3.19.10  , installed 3.19.9 [Updatable]
      Adapter    "backitup"     : 2.4.12   , installed 2.4.12
      Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
      Adapter    "denon"        : 1.13.4   , installed 1.13.4
      Adapter    "discovery"    : 3.0.5    , installed 3.0.5
      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
      Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
      Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.11.9   , installed 1.11.9
      Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
      Adapter    "node-red"     : 4.0.0    , installed 4.0.0
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "telegram"     : 1.14.1   , installed 1.14.1
      Adapter    "text2command" : 2.2.2    , installed 2.2.2
      Adapter    "vis"          : 1.4.15   , installed 1.4.15
      Adapter    "wled"         : 0.6.7    , installed 0.6.7
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ iobroker upgrade javascript@6.0.3 --debug
      This upgrade of "javascript" will introduce the following changes:
      -> 6.0.3:
      Downgrade Typescript to prevent errors with global typescript scripts
      -> 6.0.2:
      -> 6.0.1:
      Fixed the wizard schedule
      Done small fixes on GUI
      Would you like to upgrade javascript from @6.0.0 to @6.0.3 now? [(y)es, (n)o]: y
      Update javascript from @6.0.0 to @6.0.3
      NPM version: 8.19.2
      Installing iobroker.javascript@6.0.3... (System call)
      npm ERR! code ENOTDIR
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/argparse
      npm ERR! dest /opt/iobroker/node_modules/.argparse-S5zfMSQi
      npm ERR! errno -20
      npm ERR! ENOTDIR: not a directory, rename '/opt/iobroker/node_modules/argparse' -> '/opt/iobroker/node_modules/.argparse-S5zfMSQi'
      npm ERR!     /home/iobroker/.npm/_logs/2022-10-30T14_10_17_873Z-debug-0.log
      host.raspberrypi Cannot install iobroker.javascript@6.0.3: 236
      pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
      ln: failed to create symbolic link '/usr/bin/nodejs': File exists
      pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.18.0
      v16.18.0
      8.19.2
      4.0.23
      pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      tty
      /home/pi
      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
      Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
      Reading package lists... Done
      Building dependency tree
      11 packages can be upgraded. Run 'apt list --upgradable' to see them.
      nodejs:
        Installed: 16.18.0-deb-1nodesource1
        Candidate: 16.18.0-deb-1nodesource1
        Version table:
       *** 16.18.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u2 500
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $
        Thomas Braun Most Active @marcdo70 last edited by
        @marcdo70
        Hat nichts mit deinem Problem zu tun, aber nutze die Gelegenheit für ein wenig Systempflege.
          Ja hab ich auch gesehen, Danke
            @thomas-braun sagte in ERROR: Process exited with code 25:
            @marcdo70
            So gemacht, aber wie mach ich jetzt mit meinem Fehller weiter
            pi@raspberrypi:~ $ iobroker upgrade alexa2
            This upgrade of "alexa2" will introduce the following changes:
            -> 3.19.10:
            Fix issue in retry handling when rate limit exceeded is returned by Amazon
            Do not clean up Smart Home Device objects for now - delete manually if you remove a device
            Would you like to upgrade alexa2 from @3.19.9 to @3.19.10 now? [(y)es, (n)o]: y
            Update alexa2 from @3.19.9 to @3.19.10
            NPM version: 8.19.2
            Installing iobroker.alexa2@3.19.10... (System call)
            host.raspberrypi Cannot install iobroker.alexa2@3.19.10: 236
              @marcdo70
              iobroker update
              iobroker upgrade alexa2 --debug
                Geht nicht
                login as: pi
                Last login: Sun Oct 30 15:05:29 2022 from 192.168.178.92
                pi@raspberrypi:~ $ iobroker update
                pi@raspberrypi:~ $ iobroker upgrade alexa2 --debug
                -> 3.19.10:
                Do not clean up Smart Home Device objects for now - delete manually if you remov        e a device
                NPM version: 8.19.2
                npm ERR! errno -20
                npm ERR!     /home/iobroker/.npm/_logs/2022-10-30T14_43_17_519Z-debug-0.log
                pi@raspberrypi:~ $
                  @marcdo70
                  rm -rf /opt/iobroker/node_modules/.argparse-S5zfMSQi
                  Loggst du dich für jeden Befehl neu ein?
                    Hatte Console ausversehen geschlossen, aber da passiert gar nichts
                    login as: pi
                    -> 3.19.10:
                    NPM version: 8.19.2
                    npm ERR! errno -20
                    pi@raspberrypi:~ $ iobroker upgrade js-controller --debug
                    Cannot update js-controller using this command. Please use "iobroker upgrade self" instead!
                    pi@raspberrypi:~ $ iobroker upgrade self
                    Host    "raspberrypi"    is up to date.
                    pi@raspberrypi:~ $ rm -rf /opt/iobroker/node_modules/.argparse-S5zfMSQi
                    pi@raspberrypi:~ $
                      @marcdo70
                      Da passiert schon was. Die Datei wurde gelöscht.
                      Versuch das Upgrade jetzt nochmal.
                        @marcdo70
                        ok
                        pi@raspberrypi:~ $
                        -> 3.19.10:
                        NPM version: 8.19.2
                        npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
                        npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
                        added 75 packages, removed 13 packages, and changed 95 packages in 23s
                        103 packages are looking for funding
                          run `npm fund` for details
                        Update "system.adapter.alexa2.0"
                        upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
                        upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
                        upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
                        upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
                        upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
                        upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
                        upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
                        upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
                        upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
                        upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
                        upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
                        upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
                        upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
                        upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
                        upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
                        upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
                        upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
                        upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
                        upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
                        upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
                        upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
                        upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
                        pi@raspberrypi:~ $
                        Thomas Braun M 2 Replies Last reply Reply Quote 0
                          @marcdo70
                          Geht wohl jetzt. Heb den Rest auch auf die aktuelle Version.
                            marcdo70 @marcdo70 last edited by
                            @marcdo70 sagte in ERROR: Process exited with code 25:
                            @marcdo70
                            ok
                            pi@raspberrypi:~ $
                            -> 3.19.10:
                            NPM version: 8.19.2
                            pi@raspberrypi:~ $
                            Hat bei dem Adapter funktioniert wie es aussieht
                              @marcdo70
                              Vielen lieben Dank. Gott sei Dank. Das hat echt mein bischen Wissen überfordert.
                              GLG Marcus
                              4278
