    4. Test Adapter mihome-vacuum 3.8.x
    • haselchen
      haselchen Most Active @Thomas Braun last edited by haselchen
      @dirkhe
      mihome-vacuum.0	2022-10-31 15:30:26.254	error	(1229) sendMessage throws error ==>MESSAGE TIMEOUT
      Gerade auf die "neueste" Version upgedatet, wird das Log mit der Meldung vollgespammt.
        dirkhe Developer @haselchen last edited by
        @haselchen ok, teste nochmal, wodran das liegen kann, vermute aber mal, dass irgendwas mit der karte ist
        haselchen Thomas Braun Vumer 3 Replies Last reply Reply Quote 0
        • haselchen
          haselchen Most Active @dirkhe last edited by
          @dirkhe
          Ich bin zurück auf die V3.60
          Da kommt das bei Adapterstart
          mihome-vacuum.0	2022-10-31 15:46:34.580	warn	(2752) Error at history: MESSAGE TIMEOUT
          Aber nur 1 mal und dann ist Ruhe.
            Thomas Braun Most Active @dirkhe last edited by Thomas Braun
            @dirkhe
            2022-10-31 15:49:05.781  - debug: mihome-vacuum.0 (46620) update_Map got new expires:1667229545
            2022-10-31 15:49:05.781  - debug: mihome-vacuum.0 (46620) update_Map got new time:1667227743
            2022-10-31 15:49:05.919  - debug: mihome-vacuum.0 (46620) MIIO Receive Timeout for "get_sound_volume" <<<
            2022-10-31 15:49:05.919  - error: mihome-vacuum.0 (46620) sendMessage throws error ==>MESSAGE TIMEOUT
            2022-10-31 15:49:05.920  - debug: mihome-vacuum.0 (46620) ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
            2022-10-31 15:49:05.920  - debug: mihome-vacuum.0 (46620) Message= {"id":28,"method":"get_consumable"}
            2022-10-31 15:49:07.922  - debug: mihome-vacuum.0 (46620) MIIO Receive Timeout for "get_consumable" <<<
            2022-10-31 15:49:07.923  - error: mihome-vacuum.0 (46620) sendMessage throws error ==>MESSAGE TIMEOUT
            2022-10-31 15:49:07.924  - debug: mihome-vacuum.0 (46620) ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
            2022-10-31 15:49:07.925  - debug: mihome-vacuum.0 (46620) Startup: setGetConsumable Answer: false
            2022-10-31 15:49:14.446  - debug: mihome-vacuum.0 (46620) Receive <<< Helo <<< 2131002000000000046c6895635fe06affffffffffffffffffffffffffffffff
            2022-10-31 15:49:24.450  - debug: mihome-vacuum.0 (46620) Receive <<< Helo <<< 2131002000000000046c6895635fe074ffffffffffffffffffffffffffffffff
            2022-10-31 15:49:27.927  - debug: mihome-vacuum.0 (46620) get params for stock Vacuum
            2022-10-31 15:49:27.928  - debug: mihome-vacuum.0 (46620) Message= {"id":29,"method":"get_status"}
            2022-10-31 15:49:29.931  - debug: mihome-vacuum.0 (46620) MIIO Receive Timeout for "get_status" <<<
            2022-10-31 15:49:29.932  - error: mihome-vacuum.0 (46620) sendMessage throws error ==>MESSAGE TIMEOUT
            2022-10-31 15:49:29.934  - debug: mihome-vacuum.0 (46620) ERROR at setGetStatus: TypeError: Cannot read properties of undefined (reading 'result')
            2022-10-31 15:49:29.935  - debug: mihome-vacuum.0 (46620) Message= {"id":30,"method":"get_network_info"}
            2022-10-31 15:49:31.937  - debug: mihome-vacuum.0 (46620) MIIO Receive Timeout for "get_network_info" <<<
            2022-10-31 15:49:31.938  - error: mihome-vacuum.0 (46620) sendMessage throws error ==>MESSAGE TIMEOUT
            2022-10-31 15:49:31.939  - debug: mihome-vacuum.0 (46620) Error at getSetNetwork: TypeError: Cannot read properties of undefined (reading 'result')
            2022-10-31 15:49:31.939  - debug: mihome-vacuum.0 (46620) Message= {"id":31,"method":"get_sound_volume"}
            2022-10-31 15:49:33.941  - debug: mihome-vacuum.0 (46620) MIIO Receive Timeout for "get_sound_volume" <<<
            2022-10-31 15:49:33.942  - error: mihome-vacuum.0 (46620) sendMessage throws error ==>MESSAGE TIMEOUT
            2022-10-31 15:49:33.942  - debug: mihome-vacuum.0 (46620) ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
            2022-10-31 15:49:33.943  - debug: mihome-vacuum.0 (46620) Message= {"id":32,"method":"get_consumable"}
            2022-10-31 15:49:33.950  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[{"main_brush_work_time":1160,"side_brush_work_time":330668,"filter_work_time":1160,"sensor_dirty_time":1228}],"id":32}
            2022-10-31 15:49:33.951  - debug: mihome-vacuum.0 (46620) Startup: setGetConsumable Answer: true
            2022-10-31 15:49:33.951  - debug: mihome-vacuum.0 (46620) Startup: Delete setGetConsumable
            2022-10-31 15:49:33.952  - debug: mihome-vacuum.0 (46620) Message= {"id":33,"method":"get_carpet_mode"}
            2022-10-31 15:49:33.960  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":33}
            2022-10-31 15:49:33.960  - info: mihome-vacuum.0 (46620) create state for carpet_mode
            2022-10-31 15:49:33.961  - debug: mihome-vacuum.0 (46620) Message= {"id":34,"method":"get_carpet_mode"}
            2022-10-31 15:49:33.970  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":34}
            2022-10-31 15:49:34.454  - debug: mihome-vacuum.0 (46620) Receive <<< Helo <<< 2131002000000000046c6895635fe07effffffffffffffffffffffffffffffff
            2022-10-31 15:49:44.458  - debug: mihome-vacuum.0 (46620) Receive <<< Helo <<< 2131002000000000046c6895635fe088ffffffffffffffffffffffffffffffff
            2022-10-31 15:49:54.060  - debug: mihome-vacuum.0 (46620) get params for stock Vacuum
            2022-10-31 15:49:54.060  - debug: mihome-vacuum.0 (46620) Message= {"id":35,"method":"get_status"}
            2022-10-31 15:49:54.068  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":2880,"state":8,"battery":100,"clean_time":83,"clean_area":1482500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":35}
            2022-10-31 15:49:54.069  - debug: mihome-vacuum.0 (46620) setGetStatus {"msg_ver":8,"msg_seq":2880,"state":8,"battery":100,"clean_time":83,"clean_area":1482500,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
            2022-10-31 15:49:54.070  - debug: mihome-vacuum.0 (46620) Message= {"id":36,"method":"get_network_info"}
            2022-10-31 15:49:54.076  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":"unknown_method","id":36}
            2022-10-31 15:49:54.077  - debug: mihome-vacuum.0 (46620) Message= {"id":37,"method":"get_sound_volume"}
            2022-10-31 15:49:54.084  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[90],"id":37}
            2022-10-31 15:49:54.085  - debug: mihome-vacuum.0 (46620) Message= {"id":38,"method":"get_carpet_mode"}
            2022-10-31 15:49:54.096  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":38}
            2022-10-31 15:49:54.462  - debug: mihome-vacuum.0 (46620) Receive <<< Helo <<< 2131002000000000046c6895635fe092ffffffffffffffffffffffffffffffff
            2022-10-31 15:50:04.465  - debug: mihome-vacuum.0 (46620) Receive <<< Helo <<< 2131002000000000046c6895635fe09cffffffffffffffffffffffffffffffff
            2022-10-31 15:50:14.189  - debug: mihome-vacuum.0 (46620) get params for stock Vacuum
            2022-10-31 15:50:14.190  - debug: mihome-vacuum.0 (46620) Message= {"id":39,"method":"get_status"}
            2022-10-31 15:50:14.200  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":2882,"state":8,"battery":100,"clean_time":83,"clean_area":1482500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":39}
            2022-10-31 15:50:14.202  - debug: mihome-vacuum.0 (46620) setGetStatus {"msg_ver":8,"msg_seq":2882,"state":8,"battery":100,"clean_time":83,"clean_area":1482500,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
            2022-10-31 15:50:14.205  - debug: mihome-vacuum.0 (46620) Message= {"id":40,"method":"get_network_info"}
            2022-10-31 15:50:14.215  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":"unknown_method","id":40}
            2022-10-31 15:50:14.217  - debug: mihome-vacuum.0 (46620) Message= {"id":41,"method":"get_sound_volume"}
            2022-10-31 15:50:14.229  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[90],"id":41}
            2022-10-31 15:50:14.230  - debug: mihome-vacuum.0 (46620) Message= {"id":42,"method":"get_carpet_mode"}
            2022-10-31 15:50:14.247  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":42}
            2022-10-31 15:50:14.468  - debug: mihome-vacuum.0 (46620) Receive <<< Helo <<< 2131002000000000046c6895635fe0a6ffffffffffffffffffffffffffffffff
            2022-10-31 15:50:24.471  - debug: mihome-vacuum.0 (46620) Receive <<< Helo <<< 2131002000000000046c6895635fe0b0ffffffffffffffffffffffffffffffff
            2022-10-31 15:50:34.355  - debug: mihome-vacuum.0 (46620) get params for stock Vacuum
            2022-10-31 15:50:34.355  - debug: mihome-vacuum.0 (46620) Message= {"id":43,"method":"get_status"}
            2022-10-31 15:50:34.363  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":2884,"state":8,"battery":100,"clean_time":83,"clean_area":1482500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":43}
            2022-10-31 15:50:34.364  - debug: mihome-vacuum.0 (46620) setGetStatus {"msg_ver":8,"msg_seq":2884,"state":8,"battery":100,"clean_time":83,"clean_area":1482500,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
            2022-10-31 15:50:34.365  - debug: mihome-vacuum.0 (46620) Message= {"id":44,"method":"get_network_info"}
            2022-10-31 15:50:34.372  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":"unknown_method","id":44}
            2022-10-31 15:50:34.374  - debug: mihome-vacuum.0 (46620) Message= {"id":45,"method":"get_sound_volume"}
            2022-10-31 15:50:34.392  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[90],"id":45}
            2022-10-31 15:50:34.394  - debug: mihome-vacuum.0 (46620) Message= {"id":46,"method":"get_carpet_mode"}
            2022-10-31 15:50:34.405  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":46}
            2022-10-31 15:50:34.475  - debug: mihome-vacuum.0 (46620) Receive <<< Helo <<< 2131002000000000046c6895635fe0baffffffffffffffffffffffffffffffff
            2022-10-31 15:50:44.478  - debug: mihome-vacuum.0 (46620) Receive <<< Helo <<< 2131002000000000046c6895635fe0c4ffffffffffffffffffffffffffffffff
            2022-10-31 15:50:54.478  - debug: mihome-vacuum.0 (46620) get params for stock Vacuum
            2022-10-31 15:50:54.479  - debug: mihome-vacuum.0 (46620) Message= {"id":47,"method":"get_status"}
            2022-10-31 15:50:54.485  - debug: mihome-vacuum.0 (46620) Receive <<< Helo <<< 2131002000000000046c6895635fe0ceffffffffffffffffffffffffffffffff
            2022-10-31 15:50:54.488  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":2886,"state":8,"battery":100,"clean_time":83,"clean_area":1482500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":47}
            2022-10-31 15:50:54.490  - debug: mihome-vacuum.0 (46620) setGetStatus {"msg_ver":8,"msg_seq":2886,"state":8,"battery":100,"clean_time":83,"clean_area":1482500,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
            2022-10-31 15:50:54.493  - debug: mihome-vacuum.0 (46620) Message= {"id":48,"method":"get_network_info"}
            2022-10-31 15:50:54.504  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":"unknown_method","id":48}
            2022-10-31 15:50:54.505  - debug: mihome-vacuum.0 (46620) Message= {"id":49,"method":"get_sound_volume"}
            2022-10-31 15:50:54.518  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[90],"id":49}
            2022-10-31 15:50:54.520  - debug: mihome-vacuum.0 (46620) Message= {"id":50,"method":"get_carpet_mode"}
            2022-10-31 15:50:54.547  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":50}
            2022-10-31 15:51:04.491  - debug: mihome-vacuum.0 (46620) Receive <<< Helo <<< 2131002000000000046c6895635fe0d8ffffffffffffffffffffffffffffffff
            2022-10-31 15:51:14.496  - debug: mihome-vacuum.0 (46620) Receive <<< Helo <<< 2131002000000000046c6895635fe0e2ffffffffffffffffffffffffffffffff
            2022-10-31 15:51:14.645  - debug: mihome-vacuum.0 (46620) get params for stock Vacuum
            2022-10-31 15:51:14.646  - debug: mihome-vacuum.0 (46620) Message= {"id":51,"method":"get_status"}
            2022-10-31 15:51:14.653  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":2888,"state":8,"battery":100,"clean_time":83,"clean_area":1482500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":51}
            2022-10-31 15:51:14.654  - debug: mihome-vacuum.0 (46620) setGetStatus {"msg_ver":8,"msg_seq":2888,"state":8,"battery":100,"clean_time":83,"clean_area":1482500,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
            2022-10-31 15:51:14.656  - debug: mihome-vacuum.0 (46620) Message= {"id":52,"method":"get_network_info"}
            2022-10-31 15:51:14.664  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":"unknown_method","id":52}
            2022-10-31 15:51:14.665  - debug: mihome-vacuum.0 (46620) Message= {"id":53,"method":"get_sound_volume"}
            2022-10-31 15:51:14.671  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[90],"id":53}
            2022-10-31 15:51:14.673  - debug: mihome-vacuum.0 (46620) Message= {"id":54,"method":"get_carpet_mode"}
            2022-10-31 15:51:14.682  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":54}
            2022-10-31 15:51:24.503  - debug: mihome-vacuum.0 (46620) Receive <<< Helo <<< 2131002000000000046c6895635fe0ecffffffffffffffffffffffffffffffff
            2022-10-31 15:51:34.508  - debug: mihome-vacuum.0 (46620) Receive <<< Helo <<< 2131002000000000046c6895635fe0f6ffffffffffffffffffffffffffffffff
            2022-10-31 15:51:34.783  - debug: mihome-vacuum.0 (46620) get params for stock Vacuum
            2022-10-31 15:51:34.784  - debug: mihome-vacuum.0 (46620) Message= {"id":55,"method":"get_status"}
            2022-10-31 15:51:34.793  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":2890,"state":8,"battery":100,"clean_time":83,"clean_area":1482500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":55}
            2022-10-31 15:51:34.796  - debug: mihome-vacuum.0 (46620) setGetStatus {"msg_ver":8,"msg_seq":2890,"state":8,"battery":100,"clean_time":83,"clean_area":1482500,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
            2022-10-31 15:51:34.799  - debug: mihome-vacuum.0 (46620) Message= {"id":56,"method":"get_network_info"}
            2022-10-31 15:51:34.810  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":"unknown_method","id":56}
            2022-10-31 15:51:34.812  - debug: mihome-vacuum.0 (46620) Message= {"id":57,"method":"get_sound_volume"}
            2022-10-31 15:51:34.821  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[90],"id":57}
            2022-10-31 15:51:34.823  - debug: mihome-vacuum.0 (46620) Message= {"id":58,"method":"get_carpet_mode"}
            2022-10-31 15:51:34.837  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":58}
            2022-10-31 15:51:44.512  - debug: mihome-vacuum.0 (46620) Receive <<< Helo <<< 2131002000000000046c6895635fe100ffffffffffffffffffffffffffffffff
            2022-10-31 15:51:54.516  - debug: mihome-vacuum.0 (46620) Receive <<< Helo <<< 2131002000000000046c6895635fe10affffffffffffffffffffffffffffffff
            2022-10-31 15:51:54.939  - debug: mihome-vacuum.0 (46620) get params for stock Vacuum
            2022-10-31 15:51:54.941  - debug: mihome-vacuum.0 (46620) Message= {"id":59,"method":"get_status"}
            2022-10-31 15:51:54.949  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":2892,"state":8,"battery":100,"clean_time":83,"clean_area":1482500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":59}
            2022-10-31 15:51:54.950  - debug: mihome-vacuum.0 (46620) setGetStatus {"msg_ver":8,"msg_seq":2892,"state":8,"battery":100,"clean_time":83,"clean_area":1482500,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
            2022-10-31 15:51:54.955  - debug: mihome-vacuum.0 (46620) Message= {"id":60,"method":"get_network_info"}
            2022-10-31 15:51:54.966  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":"unknown_method","id":60}
            2022-10-31 15:51:54.968  - debug: mihome-vacuum.0 (46620) Message= {"id":61,"method":"get_sound_volume"}
            2022-10-31 15:51:54.990  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[90],"id":61}
            2022-10-31 15:51:54.992  - debug: mihome-vacuum.0 (46620) Message= {"id":62,"method":"get_carpet_mode"}
            2022-10-31 15:51:55.018  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":62}
            2022-10-31 15:52:04.522  - debug: mihome-vacuum.0 (46620) Receive <<< Helo <<< 2131002000000000046c6895635fe114ffffffffffffffffffffffffffffffff
            2022-10-31 15:52:14.525  - debug: mihome-vacuum.0 (46620) Receive <<< Helo <<< 2131002000000000046c6895635fe11effffffffffffffffffffffffffffffff
            2022-10-31 15:52:15.111  - debug: mihome-vacuum.0 (46620) get params for stock Vacuum
            2022-10-31 15:52:15.113  - debug: mihome-vacuum.0 (46620) Message= {"id":63,"method":"get_status"}
            2022-10-31 15:52:15.122  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":2894,"state":8,"battery":100,"clean_time":83,"clean_area":1482500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":63}
            2022-10-31 15:52:15.123  - debug: mihome-vacuum.0 (46620) setGetStatus {"msg_ver":8,"msg_seq":2894,"state":8,"battery":100,"clean_time":83,"clean_area":1482500,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
            2022-10-31 15:52:15.125  - debug: mihome-vacuum.0 (46620) Message= {"id":64,"method":"get_network_info"}
            2022-10-31 15:52:15.133  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":"unknown_method","id":64}
            2022-10-31 15:52:15.135  - debug: mihome-vacuum.0 (46620) Message= {"id":65,"method":"get_sound_volume"}
            2022-10-31 15:52:15.154  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[90],"id":65}
            2022-10-31 15:52:15.155  - debug: mihome-vacuum.0 (46620) Message= {"id":66,"method":"get_carpet_mode"}
            2022-10-31 15:52:15.171  - debug: mihome-vacuum.0 (46620) MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":66}
            Was mir auffällt:
            Nach der Zeile
            wird es ruhiger im Log.
              Thomas Braun Most Active @haselchen last edited by
              Was mir auch auffällt:
              echad@chet:/opt/iobroker $ npm ls canvas
              iobroker.inst@3.0.0 /opt/iobroker
              ├─┬ iobroker.echarts@1.0.12
              │ ├── canvas@2.10.2
              │ └─┬ jsdom@19.0.0
              │   └── canvas@2.10.2 deduped
              ├─┬ iobroker.iot@1.12.2
              │ ├── canvas@2.10.2 deduped
              │ └─┬ jsdom@20.0.0
              ├─┬ iobroker.mihome-vacuum@3.8.2 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.mihome-vacuum.git#09c38cd54117c5d187e8a43f8a0972623de27066)
              └─┬ iobroker.parcel@0.0.23
                └─┬ jsdom@20.0.1
              deduped canvas führt nicht mehr wie zuvor zur Meldung, dass canvas gar nicht installiert sei.
                dirkhe Developer @Thomas Braun last edited by
                @thomas-braun Das liegt wahrscheinlich daran, dass ich die Version in der package hochgezogen habe. Der Adapter nutzt jetzt auch 2.10.2, genau wie die anderen Adapter, daher scheint das jetzt zu funktionieren, vermute ich.
                Daher würde ich mich jetzt mal auf die timeouts konzentrieren. Ich bekomme sie nämlich nicht. Entweder hat sich in der Zwischenzeit an der socket irgendwas getan oder an dem letzten commit von meisterTR, weil es sich ja hauptsächlich um die Karte handelt, d versuche ich mal die debugs oben zu analysieren
                  dirkhe Developer @Thomas Braun last edited by dirkhe
                  Also wenn ich mir das oben so anschaue, wird das natürlich ruhiger, sobald das helo durchgekommen ist. Was mich wundert ist, dass normalerweise abgewartet wird, bis er sich verbunden hat, bevor er anfängt den robby zu fragen. Da scheint die Änderung zu sein. Ich veruche das mal zu anlysieren. Dass nach dem helo noch timeouts kommen, liegt daran, dass die anfragen asnchron sind, die also vor der helo ANtwort bereits losgeschickt wurden
                    @dirkhe
                    Ich hab jetzt zum Testen (und damit nicht noch mehr ins Log gekübelt wird) fast alle anderen Adapter ausgeknipst. Jetzt bekomme ich auch keine TimeOuts mehr. Wird wohl mit der Auslastung zusammenhängen.
                    [Edit:] Hab jetzt peu a peu alle Instanzen wieder hochgefahren, bislang bleibt es ruhig, keine TimeOuts mehr.
                      Also wie oben geschrieben, der darf nicht abfragen, wenn er nicht connected ist, das muss wohl irgendwo raus genommen worden sein, ich suche noch
                      • da_Woody
                        da_Woody @dirkhe last edited by
                        @dirkhe irgendwie versteh ich das mit canvas nicht.
                        woody@ioBroker:/opt/iobroker$ npm ls canvas
                        [sudo] Passwort für woody:
                        ├── canvas@2.10.1
                        ├─┬ iobroker.energiefluss@1.3.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#410151c990ec5f34351dbe28f14355cbc956be2d)
                        │ └── canvas@2.10.1 deduped
                        │ ├── canvas@2.10.1 deduped
                        │ └─┬ jsdom@20.0.0
                        └─┬ iobroker.mihome-vacuum@3.8.1
                        die karte funktioniert für meinen roborock S6Pure nicht mehr. zwischenzeitlich hat sie nach der letzten canvas diskussion funktioniert, dann wieder nicht mehr.
                          dirkhe Developer @da_Woody last edited by
                          @da_woody das mit den canvas scheint echt ein problem zu sein. Ich habe da auch keine Idee zu. Stand denn bei dir, dass es nicht installert ist?
                          • Vumer
                            Vumer @dirkhe last edited by Vumer
                            @dirkhe
                            einmal um
                            2022-11-01 00:51:29.065 - error: mihome-vacuum.0 (3992) sendMessage throws error ==>MESSAGE TIMEOUT
                            und dann ab
                            2022-11-01 01:34:02.235 - error: mihome-vacuum.0 (3992) sendMessage throws error ==>MESSAGE TIMEOUT
                            2022-11-01 01:34:04.236 - error: mihome-vacuum.0 (3992) sendMessage throws error ==>MESSAGE TIMEOUT
                            2022-11-01 01:34:06.237 - error: mihome-vacuum.0 (3992) sendMessage throws error ==>MESSAGE TIMEOUT
                            2022-11-01 01:34:08.240 - error: mihome-vacuum.0 (3992) sendMessage throws error ==>MESSAGE TIMEOUT
                            2022-11-01 06:02:32.848 - error: mihome-vacuum.0 (3992) sendMessage throws error ==>MESSAGE TIMEOUT
                            2022-11-01 06:02:34.849 - error: mihome-vacuum.0 (3992) sendMessage throws error ==>MESSAGE TIMEOUT
                            2022-11-01 06:02:36.850 - error: mihome-vacuum.0 (3992) sendMessage throws error ==>MESSAGE TIMEOUT
                            2022-11-01 06:02:38.852 - error: mihome-vacuum.0 (3992) sendMessage throws error ==>MESSAGE TIMEOUT
                            2022-11-01 06:02:40.853 - error: mihome-vacuum.0 (3992) sendMessage throws error ==>MESSAGE TIMEOUT
                            was aber eventuell wichtig ist, der Roboter hängt nicht die ganze Zeit am Strom.
                            Sobald der Roboter 100% geladen ist, wird die Ladestation mithilfe der Zigbeesteckdose ausgeschaltet.
                            Eingeschaltet wir die bei 80% , beim Start des Roboters und um 6:02
                            Denn ich hab festgestellt dass wenn der Roboter im Tiefschlaf ist und ich dem Adapter manuell neu starte bleibt der Adapter rot
                              A Former User @Vumer last edited by
                              @vumer Hi, folgender Tip von mir:
                              1. ich hatte mal im Roboterforum gelesen, dass das Abschalten der Spannungsversorgung bei den Saugern zu Problemen fuehrt, was das akkumanagement angeht.. du bewirkst damit genau das Gegenteil..
                                Ich hab seit 2017 den ersten Xaomi Roborock S5, immer am Strom, Akku ist noch top in Schuss.
                              2. Wenn er im Tiefschlaf ist, kannst du ihn nicht wecken und der Adapter bekommt keine Antwort, daher wird dieser Rot. Tiefschlaf vermeide ich bei den Saugern, lasse online, dann funktionieren die wie ein Uhrwerk (aus der Schweiz).. 🙂
                              Vumer 1 Reply Last reply Reply Quote 0
                              • da_Woody
                                @dirkhe sagte in Test für mihome-vacuum:
                                wo sollte das stehn? ich kapier nicht, warum canvas solche probs macht. mihome? vllt sollte da aus der roborock sache ein adapter gemacht werden? https://forum.iobroker.net/topic/56098/tester-gesucht-roborock-api
                                ich kann nur als tester mit einem adapter mitmachen. mit scripten kann ich zu wenig helfen...
                                  Thomas Braun Most Active @da_Woody last edited by
                                  @da_woody sagte in Test für mihome-vacuum:
                                  Im Log File. Z. B. beim Adapter (Neu)-Start wird das gemeldet.
                                  • da_Woody
                                    da_Woody @Thomas Braun last edited by
                                    @thomas-braun wow, nach stoppen und umstellen auf debug startet das ding nicht mehr.
                                    wenn ich auf "get device" klicke, dann "error login failed", nichts geändert...
                                    ich pfeif drauf. immer probleme damit. so oft verwend ich das ding eh nicht.
                                      Und was steht im Log?
                                      da_Woody D 2 Replies Last reply Reply Quote 0
                                      • da_Woody
                                        v6.2.23
                                        38
                                        0
                                        Log-Größe: 58.2 KB
                                        mihome-vacuum.0
                                        Zeit
                                        debug
                                        Nachricht
                                        mihome-vacuum.0
                                        2022-11-01 14:14:39.756	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":174}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:39.747	debug	Message= {"id":174,"method":"get_carpet_mode"}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:39.746	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-11-01 14:14:39.746	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F0"],"id":173}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:39.742	debug	Message= {"id":173,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:39.742	debug	MIIO RECIVE: {"result":[90],"id":172}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:39.732	debug	Message= {"id":172,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:39.615	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":171}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:39.593	debug	Message= {"id":171,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:39.592	debug	setGetStatus {"msg_ver":2,"msg_seq":1784,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:39.592	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1784,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":170}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:39.586	debug	Message= {"id":170,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:39.585	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:14:34.810	debug	Receive <<< Helo <<< 21310020000000001329b53563611bbaffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:14:24.807	debug	Receive <<< Helo <<< 21310020000000001329b53563611bb0ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:14:19.490	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":169}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:19.479	debug	Message= {"id":169,"method":"get_carpet_mode"}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:19.479	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-11-01 14:14:19.479	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F17"],"id":168}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:19.473	debug	Message= {"id":168,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:19.473	debug	MIIO RECIVE: {"result":[90],"id":167}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:19.464	debug	Message= {"id":167,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:19.346	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":166}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:19.324	debug	Message= {"id":166,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:19.324	debug	setGetStatus {"msg_ver":2,"msg_seq":1783,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:19.323	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1783,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":165}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:19.317	debug	Message= {"id":165,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:14:19.317	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:14:14.803	debug	Receive <<< Helo <<< 21310020000000001329b53563611ba6ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:14:04.800	debug	Receive <<< Helo <<< 21310020000000001329b53563611b9cffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:13:59.198	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":164}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:59.186	debug	Message= {"id":164,"method":"get_carpet_mode"}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:59.185	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-11-01 14:13:59.184	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F16"],"id":163}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:59.177	debug	Message= {"id":163,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:59.177	debug	MIIO RECIVE: {"result":[90],"id":162}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:59.172	debug	Message= {"id":162,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:59.070	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":161}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:59.049	debug	Message= {"id":161,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:59.048	debug	setGetStatus {"msg_ver":2,"msg_seq":1782,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:59.048	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1782,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":160}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:59.042	debug	Message= {"id":160,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:59.042	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:13:54.792	debug	Receive <<< Helo <<< 21310020000000001329b53563611b92ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:13:44.789	debug	Receive <<< Helo <<< 21310020000000001329b53563611b88ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:13:38.948	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":159}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:38.938	debug	Message= {"id":159,"method":"get_carpet_mode"}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:38.938	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-11-01 14:13:38.937	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F15"],"id":158}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:38.933	debug	Message= {"id":158,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:38.933	debug	MIIO RECIVE: {"result":[90],"id":157}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:38.928	debug	Message= {"id":157,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:38.833	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":156}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:38.812	debug	Message= {"id":156,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:38.812	debug	setGetStatus {"msg_ver":2,"msg_seq":1781,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:38.811	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1781,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":155}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:38.805	debug	Message= {"id":155,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:38.805	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:13:34.786	debug	Receive <<< Helo <<< 21310020000000001329b53563611b7effffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:13:24.782	debug	Receive <<< Helo <<< 21310020000000001329b53563611b74ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:13:18.608	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":154}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:18.598	debug	Message= {"id":154,"method":"get_carpet_mode"}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:18.598	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-11-01 14:13:18.598	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F14"],"id":153}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:18.593	debug	Message= {"id":153,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:18.592	debug	MIIO RECIVE: {"result":[90],"id":152}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:18.587	debug	Message= {"id":152,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:18.477	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":151}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:18.455	debug	Message= {"id":151,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:18.455	debug	setGetStatus {"msg_ver":2,"msg_seq":1780,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:18.455	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1780,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":150}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:18.449	debug	Message= {"id":150,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:13:18.448	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:13:14.779	debug	Receive <<< Helo <<< 21310020000000001329b53563611b6affffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:13:04.776	debug	Receive <<< Helo <<< 21310020000000001329b53563611b60ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:12:58.345	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":149}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:58.334	debug	Message= {"id":149,"method":"get_carpet_mode"}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:58.334	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-11-01 14:12:58.334	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F13"],"id":148}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:58.328	debug	Message= {"id":148,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:58.328	debug	MIIO RECIVE: {"result":[90],"id":147}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:58.323	debug	Message= {"id":147,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:58.227	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":146}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:58.205	debug	Message= {"id":146,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:58.205	debug	setGetStatus {"msg_ver":2,"msg_seq":1779,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:58.205	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1779,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":145}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:58.196	debug	Message= {"id":145,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:58.196	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:12:54.773	debug	Receive <<< Helo <<< 21310020000000001329b53563611b56ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:12:44.768	debug	Receive <<< Helo <<< 21310020000000001329b53563611b4cffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:12:37.758	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":144}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:37.749	debug	Message= {"id":144,"method":"get_carpet_mode"}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:37.749	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-11-01 14:12:37.749	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F12"],"id":143}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:37.745	debug	Message= {"id":143,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:37.744	debug	MIIO RECIVE: {"result":[90],"id":142}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:37.739	debug	Message= {"id":142,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:35.361	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":141}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:35.337	debug	Message= {"id":141,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:35.337	debug	setGetStatus {"msg_ver":2,"msg_seq":1778,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:35.336	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1778,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":140}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:35.329	debug	Message= {"id":140,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:35.329	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:12:34.765	debug	Receive <<< Helo <<< 21310020000000001329b53563611b42ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:12:24.754	debug	Receive <<< Helo <<< 21310020000000001329b53563611b38ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:12:15.197	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":139}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:15.185	debug	Message= {"id":139,"method":"get_carpet_mode"}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:15.184	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-11-01 14:12:15.183	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F11"],"id":138}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:15.178	debug	Message= {"id":138,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:15.178	debug	MIIO RECIVE: {"result":[90],"id":137}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:15.173	debug	Message= {"id":137,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:15.080	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":136}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:15.059	debug	Message= {"id":136,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:15.058	debug	setGetStatus {"msg_ver":2,"msg_seq":1777,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:15.058	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1777,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":135}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:15.052	debug	Message= {"id":135,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:12:15.052	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:12:14.751	debug	Receive <<< Helo <<< 21310020000000001329b53563611b2effffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:12:04.744	debug	Receive <<< Helo <<< 21310020000000001329b53563611b24ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:11:54.945	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":134}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:54.937	debug	Message= {"id":134,"method":"get_carpet_mode"}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:54.937	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-11-01 14:11:54.936	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F10"],"id":133}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:54.931	debug	Message= {"id":133,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:54.931	debug	MIIO RECIVE: {"result":[90],"id":132}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:54.923	debug	Message= {"id":132,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:54.765	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":131}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:54.744	debug	Message= {"id":131,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:54.743	debug	setGetStatus {"msg_ver":2,"msg_seq":1776,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:54.743	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1776,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":130}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:54.741	debug	Receive <<< Helo <<< 21310020000000001329b53563611b1affffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:11:54.737	debug	Message= {"id":130,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:54.737	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:11:44.737	debug	Receive <<< Helo <<< 21310020000000001329b53563611b10ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:11:34.734	debug	Receive <<< Helo <<< 21310020000000001329b53563611b06ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:11:34.643	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":129}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:34.635	debug	Message= {"id":129,"method":"get_carpet_mode"}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:34.635	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-11-01 14:11:34.634	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F9"],"id":128}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:34.630	debug	Message= {"id":128,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:34.630	debug	MIIO RECIVE: {"result":[90],"id":127}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:34.624	debug	Message= {"id":127,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:34.513	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":126}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:34.492	debug	Message= {"id":126,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:34.492	debug	setGetStatus {"msg_ver":2,"msg_seq":1775,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:34.492	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1775,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":125}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:34.481	debug	Message= {"id":125,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:34.481	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:11:24.732	debug	Receive <<< Helo <<< 21310020000000001329b53563611afcffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:11:14.729	debug	Receive <<< Helo <<< 21310020000000001329b53563611af2ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:11:14.422	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":124}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:14.415	debug	Message= {"id":124,"method":"get_carpet_mode"}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:14.414	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-11-01 14:11:14.414	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F8"],"id":123}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:14.410	debug	Message= {"id":123,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:14.410	debug	MIIO RECIVE: {"result":[90],"id":122}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:14.404	debug	Message= {"id":122,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:14.316	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":121}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:14.293	debug	Message= {"id":121,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:14.293	debug	setGetStatus {"msg_ver":2,"msg_seq":1774,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:14.293	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1774,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":120}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:14.281	debug	Message= {"id":120,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:11:14.281	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:11:04.724	debug	Receive <<< Helo <<< 21310020000000001329b53563611ae8ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:10:54.720	debug	Receive <<< Helo <<< 21310020000000001329b53563611adeffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:10:54.187	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":119}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:54.177	debug	Message= {"id":119,"method":"get_carpet_mode"}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:54.177	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-11-01 14:10:54.176	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F7"],"id":118}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:54.172	debug	Message= {"id":118,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:54.172	debug	MIIO RECIVE: {"result":[90],"id":117}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:54.167	debug	Message= {"id":117,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:54.053	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":116}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:54.028	debug	Message= {"id":116,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:54.028	debug	setGetStatus {"msg_ver":2,"msg_seq":1773,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:54.027	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1773,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":115}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:54.021	debug	Message= {"id":115,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:54.021	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:10:44.714	debug	Receive <<< Helo <<< 21310020000000001329b53563611ad4ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:10:34.706	debug	Receive <<< Helo <<< 21310020000000001329b53563611acaffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:10:33.868	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":114}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:33.861	debug	Message= {"id":114,"method":"get_carpet_mode"}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:33.861	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-11-01 14:10:33.861	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F6"],"id":113}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:33.855	debug	Message= {"id":113,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:33.854	debug	MIIO RECIVE: {"result":[90],"id":112}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:33.848	debug	Message= {"id":112,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:33.683	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":111}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:33.661	debug	Message= {"id":111,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:33.661	debug	setGetStatus {"msg_ver":2,"msg_seq":1772,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:33.660	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1772,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":110}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:33.654	debug	Message= {"id":110,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:33.654	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:10:24.702	debug	Receive <<< Helo <<< 21310020000000001329b53563611ac0ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:10:14.697	debug	Receive <<< Helo <<< 21310020000000001329b53563611ab6ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:10:13.551	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":109}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:13.545	debug	Message= {"id":109,"method":"get_carpet_mode"}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:13.543	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-11-01 14:10:13.542	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F5"],"id":108}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:13.537	debug	Message= {"id":108,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:13.537	debug	MIIO RECIVE: {"result":[90],"id":107}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:13.532	debug	Message= {"id":107,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:13.418	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":106}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:13.396	debug	Message= {"id":106,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:13.395	debug	setGetStatus {"msg_ver":2,"msg_seq":1771,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:13.395	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1771,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":105}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:13.384	debug	Message= {"id":105,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:10:13.384	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:10:04.693	debug	Receive <<< Helo <<< 21310020000000001329b53563611aacffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:09:54.690	debug	Receive <<< Helo <<< 21310020000000001329b53563611aa2ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:09:53.241	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":104}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:53.234	debug	Message= {"id":104,"method":"get_carpet_mode"}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:53.234	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-11-01 14:09:53.234	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F4"],"id":103}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:53.229	debug	Message= {"id":103,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:53.229	debug	MIIO RECIVE: {"result":[90],"id":102}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:53.220	debug	Message= {"id":102,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:53.114	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":101}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:53.093	debug	Message= {"id":101,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:53.093	debug	setGetStatus {"msg_ver":2,"msg_seq":1770,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:53.092	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1770,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":100}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:53.082	debug	Message= {"id":100,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:53.082	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:09:44.686	debug	Receive <<< Helo <<< 21310020000000001329b53563611a98ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:09:34.684	debug	Receive <<< Helo <<< 21310020000000001329b53563611a8effffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:09:32.973	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":99}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:32.964	debug	Message= {"id":99,"method":"get_carpet_mode"}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:32.964	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-11-01 14:09:32.963	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F3"],"id":98}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:32.958	debug	Message= {"id":98,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:32.957	debug	MIIO RECIVE: {"result":[90],"id":97}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:32.951	debug	Message= {"id":97,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:32.854	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":96}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:32.831	debug	Message= {"id":96,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:32.831	debug	setGetStatus {"msg_ver":2,"msg_seq":1769,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:32.831	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1769,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":95}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:32.824	debug	Message= {"id":95,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:32.824	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:09:24.678	debug	Receive <<< Helo <<< 21310020000000001329b53563611a84ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:09:14.675	debug	Receive <<< Helo <<< 21310020000000001329b53563611a7affffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:09:12.653	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":94}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:12.633	debug	Message= {"id":94,"method":"get_carpet_mode"}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:12.632	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-11-01 14:09:12.631	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F2"],"id":93}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:12.624	debug	Message= {"id":93,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:12.622	debug	MIIO RECIVE: {"result":[90],"id":92}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:12.613	debug	Message= {"id":92,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:12.514	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":91}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:12.491	debug	Message= {"id":91,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:12.491	debug	setGetStatus {"msg_ver":2,"msg_seq":1768,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:12.491	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1768,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":90}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:12.485	debug	Message= {"id":90,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:09:12.484	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:09:04.672	debug	Receive <<< Helo <<< 21310020000000001329b53563611a70ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:08:54.669	debug	Receive <<< Helo <<< 21310020000000001329b53563611a66ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.432	debug	finish logs all [{"Datum":"28.10","Start":"19:57","Saugzeit":"32 min","Fläche":"22.35 m²","Error":0,"Ende":true},{"Datum":"28.10","Start":"15:18","Saugzeit":"6 min","Fläche":"5.87 m²","Error":8,"Ende":false},{"Datum":"27.10","Start":"12:16","Saugzeit":"2 min","Fläche":"0 m²","Error":8,"Ende":false},{"Datum":"27.10","Start":"12:10","Saugzeit":"5 min","Fläche":"2.22 m²","Error":0,"Ende":false},{"Datum":"13.9","Start":"19:42","Saugzeit":"30 min","Fläche":"24.64 m²","Error":0,"Ende":true},{"Datum":"6.9","Start":"15:18","Saugzeit":"6 min","Fläche":"2 m²","Error":8,"Ende":false},{"Datum":"30.7","Start":"20:43","Saugzeit":"41 min","Fläche":"24.05 m²","Error":0,"Ende":true},{"Datum":"1.7","Start":"16:20","Saugzeit":"22 min","Fläche":"22.3 m²","Error":0,"Ende":true},{"Datum":"9.6","Start":"19:18","Saugzeit":"24 min","Fläche":"24.63 m²","Error":0,"Ende":true},{"Datum":"30.5","Start":"19:26","Saugzeit":"28 min","Fläche":"24.72 m²","Error":0,"Ende":true},{"Datum":"10.5","Start":"15:09","Saugzeit":"25 min","Fläche":"24.65 m²","Error":0,"Ende":true},{"Datum":"6.5","Start":"19:24","Saugzeit":"26 min","Fläche":"24.11 m²","Error":0,"Ende":true},{"Datum":"29.4","Start":"19:33","Saugzeit":"36 min","Fläche":"23.96 m²","Error":0,"Ende":true},{"Datum":"19.2","Start":"19:32","Saugzeit":"1 min","Fläche":"0.51 m²","Error":0,"Ende":false},{"Datum":"23.1","Start":"19:44","Saugzeit":"29 min","Fläche":"25.02 m²","Error":0,"Ende":true},{"Datum":"22.1","Start":"20:13","Saugzeit":"10 min","Fläche":"12.37 m²","Error":0,"Ende":false},{"Datum":"21.1","Start":"10:22","Saugzeit":"1 min","Fläche":"1.29 m²","Error":0,"Ende":false},{"Datum":"18.1","Start":"20:20","Saugzeit":"27 min","Fläche":"24.17 m²","Error":0,"Ende":true},{"Datum":"6.1","Start":"19:10","Saugzeit":"12 min","Fläche":"14.82 m²","Error":0,"Ende":false},{"Datum":"6.1","Start":"15:36","Saugzeit":"32 min","Fläche":"24.57 m²","Error":0,"Ende":true}]
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.432	debug	MIIO RECIVE: {"result":[[1641479793,1641486963,1910,24567500,0,1,2,1,52]],"id":89}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.423	debug	Message= {"id":89,"method":"get_clean_record","params":[1641479793]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.422	debug	MIIO RECIVE: {"result":[[1641492626,1641493350,696,14817500,0,0,2,1,60]],"id":88}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.413	debug	Message= {"id":88,"method":"get_clean_record","params":[1641492626]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.412	debug	MIIO RECIVE: {"result":[[1642533653,1642535288,1625,24167500,0,1,2,1,52]],"id":87}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.403	debug	Message= {"id":87,"method":"get_clean_record","params":[1642533653]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.402	debug	MIIO RECIVE: {"result":[[1642756938,1642756995,57,1292500,0,0,2,1,60]],"id":86}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.396	debug	Message= {"id":86,"method":"get_clean_record","params":[1642756938]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.396	debug	MIIO RECIVE: {"result":[[1642878816,1642879423,607,12367500,0,0,2,1,60]],"id":85}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.389	debug	Message= {"id":85,"method":"get_clean_record","params":[1642878816]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.387	debug	MIIO RECIVE: {"result":[[1642963476,1642965232,1756,25020000,0,1,2,1,52]],"id":84}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.373	debug	Message= {"id":84,"method":"get_clean_record","params":[1642963476]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.372	debug	MIIO RECIVE: {"result":[[1645295524,1645295556,32,512500,0,0,2,1,60]],"id":83}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.366	debug	Message= {"id":83,"method":"get_clean_record","params":[1645295524]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.364	debug	MIIO RECIVE: {"result":[[1651253588,1651255767,2179,23957500,0,1,2,1,52]],"id":82}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.358	debug	Message= {"id":82,"method":"get_clean_record","params":[1651253588]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.358	debug	MIIO RECIVE: {"result":[[1651857884,1651859471,1587,24110000,0,1,2,1,52]],"id":81}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.353	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":80}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.352	debug	Message= {"id":81,"method":"get_clean_record","params":[1651857884]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.352	debug	MIIO RECIVE: {"result":[[1652188174,1652189692,1518,24647500,0,1,2,1,52]],"id":79}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.336	debug	Message= {"id":80,"method":"get_carpet_mode"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.335	info	create state for carpet_mode
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.335	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":78}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.334	debug	Message= {"id":79,"method":"get_clean_record","params":[1652188174]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.332	debug	MIIO RECIVE: {"result":[[1653931567,1653933520,1684,24717500,0,1,2,1,52]],"id":77}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.327	debug	Message= {"id":78,"method":"get_carpet_mode"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.326	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.326	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F0"],"id":76}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.325	debug	Message= {"id":77,"method":"get_clean_record","params":[1653931567]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.324	debug	MIIO RECIVE: {"result":[[1654795117,1654796567,1450,24625000,0,1,2,1,52]],"id":75}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.319	debug	Message= {"id":76,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.319	debug	Startup: Delete setGetConsumable
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.319	debug	Startup: setGetConsumable Answer: true
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.318	debug	MIIO RECIVE: {"result":[{"main_brush_work_time":41889,"side_brush_work_time":41889,"filter_work_time":41889,"filter_element_work_time":0,"sensor_dirty_time":71089}],"id":74}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.317	debug	Message= {"id":75,"method":"get_clean_record","params":[1654795117]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.310	debug	MIIO RECIVE: {"result":[[1656685244,1656686572,1328,22302500,0,1,2,1,52]],"id":73}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.305	debug	Message= {"id":74,"method":"get_consumable"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.305	debug	Startup: Delete setGetCleanSummary
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.305	debug	Startup: setGetCleanSummary Answer: true
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.304	debug	MIIO RECIVE: {"result":[76749,992120000,76,[1666979871,1666963083,1666865760,1666865404,1663090972,1662470282,1659206624,1656685244,1654795117,1653931567,1652188174,1651857884,1651253588,1645295524,1642963476,1642878816,1642756938,1642533653,1641492626,1641479793]],"id":72}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.303	debug	Message= {"id":73,"method":"get_clean_record","params":[1656685244]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.302	debug	MIIO RECIVE: {"result":[[1659206624,1659209105,2481,24045000,0,1,2,1,52]],"id":71}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.297	debug	Message= {"id":72,"method":"get_clean_summary"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.297	debug	MIIO RECIVE: {"result":[90],"id":70}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.296	debug	Message= {"id":71,"method":"get_clean_record","params":[1659206624]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.296	debug	MIIO RECIVE: {"result":[[1662470282,1662514759,383,2000000,8,0,2,1,34]],"id":69}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.291	debug	Message= {"id":70,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.289	debug	Message= {"id":69,"method":"get_clean_record","params":[1662470282]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.289	debug	MIIO RECIVE: {"result":[[1663090972,1663093345,1773,24642500,0,1,2,1,52]],"id":68}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.276	debug	Message= {"id":68,"method":"get_clean_record","params":[1663090972]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.276	debug	MIIO RECIVE: {"result":[[1666865404,1666865708,302,2215000,0,0,2,1,60]],"id":67}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.254	debug	Message= {"id":67,"method":"get_clean_record","params":[1666865404]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.254	debug	MIIO RECIVE: {"result":[[1666865760,1666909702,141,0,8,0,2,1,34]],"id":66}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.246	debug	Message= {"id":66,"method":"get_clean_record","params":[1666865760]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.244	debug	MIIO RECIVE: {"result":[[1666963083,1666979819,385,5867500,8,0,2,1,29]],"id":65}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.237	debug	Message= {"id":65,"method":"get_clean_record","params":[1666963083]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.236	debug	MIIO RECIVE: {"result":[[1666979871,1666981820,1949,22352500,0,1,2,1,52]],"id":64}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.229	debug	Message= {"id":64,"method":"get_clean_record","params":[1666979871]}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.226	debug	MIIO RECIVE: {"result":[76749,992120000,76,[1666979871,1666963083,1666865760,1666865404,1663090972,1662470282,1659206624,1656685244,1654795117,1653931567,1652188174,1651857884,1651253588,1645295524,1642963476,1642878816,1642756938,1642533653,1641492626,1641479793]],"id":63}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.223	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-54},"id":62}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.206	debug	Message= {"id":63,"method":"get_clean_summary"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.205	debug	MIIO RECIVE: {"result":[{"main_brush_work_time":41889,"side_brush_work_time":41889,"filter_work_time":41889,"filter_element_work_time":0,"sensor_dirty_time":71089}],"id":61}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.199	debug	Message= {"id":62,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.199	debug	Message= {"id":61,"method":"get_consumable"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.199	debug	MIIO RECIVE: {"result":[],"id":60}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.190	debug	Message= {"id":60,"method":"get_room_mapping"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.190	debug	Mappointer_updated
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.189	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F0"],"id":59}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:52.180	debug	Message= {"id":59,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:51.879	debug	MIIO RECIVE: {"result":["retry"],"id":58}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:51.873	debug	Message= {"id":58,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:51.572	debug	MIIO RECIVE: {"result":["retry"],"id":57}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:51.566	debug	Message= {"id":57,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:51.266	debug	MIIO RECIVE: {"result":["retry"],"id":56}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:51.260	debug	Message= {"id":56,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:51.117	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                        mihome-vacuum.0
                                        2022-11-01 14:08:51.109	info	create states for water box
                                        mihome-vacuum.0
                                        2022-11-01 14:08:51.109	info	change states from State control.fan_power
                                        mihome-vacuum.0
                                        2022-11-01 14:08:51.107	debug	setGetStatus {"msg_ver":2,"msg_seq":1767,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:51.107	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":1767,"state":8,"battery":100,"clean_time":1949,"clean_area":22352500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":55}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:51.099	debug	Message= {"id":55,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:51.099	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:08:44.660	debug	Receive <<< Helo <<< 21310020000000001329b53563611a5cffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:08:34.656	debug	Receive <<< Helo <<< 21310020000000001329b53563611a52ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:08:31.098	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:08:31.097	debug	MIIO Receive Timeout for "get_map_v1" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:08:29.096	debug	Message= {"id":54,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:29.096	debug	Startup: setGetConsumable Answer: false
                                        mihome-vacuum.0
                                        2022-11-01 14:08:29.096	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:08:29.096	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:08:29.095	debug	MIIO Receive Timeout for "get_consumable" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:08:27.095	debug	Message= {"id":53,"method":"get_consumable"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:27.095	debug	Startup: setGetCleanSummary Answer: false
                                        mihome-vacuum.0
                                        2022-11-01 14:08:27.095	debug	ERROR at setGetCleanSummary: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:08:27.094	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:08:27.094	debug	MIIO Receive Timeout for "get_clean_summary" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:08:25.094	debug	Message= {"id":52,"method":"get_clean_summary"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:25.094	debug	ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:08:25.094	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:08:25.093	debug	MIIO Receive Timeout for "get_sound_volume" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:08:24.653	debug	Receive <<< Helo <<< 21310020000000001329b53563611a48ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:08:23.092	debug	Message= {"id":51,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:23.092	debug	Error at getSetNetwork: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:08:23.092	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:08:23.092	debug	MIIO Receive Timeout for "get_network_info" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:08:21.090	debug	Message= {"id":50,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:21.090	debug	ERROR at setGetStatus: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:08:21.090	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:08:21.090	debug	MIIO Receive Timeout for "get_status" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:08:19.089	debug	Message= {"id":49,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:08:19.089	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:08:14.649	debug	Receive <<< Helo <<< 21310020000000001329b53563611a3effffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:08:04.646	debug	Receive <<< Helo <<< 21310020000000001329b53563611a34ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:07:59.088	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:07:59.087	debug	MIIO Receive Timeout for "get_map_v1" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:07:57.086	debug	Message= {"id":48,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:07:57.086	debug	Startup: setGetConsumable Answer: false
                                        mihome-vacuum.0
                                        2022-11-01 14:07:57.086	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:07:57.086	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:07:57.085	debug	MIIO Receive Timeout for "get_consumable" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:07:55.083	debug	Message= {"id":47,"method":"get_consumable"}
                                        mihome-vacuum.0
                                        2022-11-01 14:07:55.083	debug	Startup: setGetCleanSummary Answer: false
                                        mihome-vacuum.0
                                        2022-11-01 14:07:55.083	debug	ERROR at setGetCleanSummary: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:07:55.083	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:07:55.082	debug	MIIO Receive Timeout for "get_clean_summary" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:07:54.643	debug	Receive <<< Helo <<< 21310020000000001329b53563611a2affffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:07:53.082	debug	Message= {"id":46,"method":"get_clean_summary"}
                                        mihome-vacuum.0
                                        2022-11-01 14:07:53.081	debug	ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:07:53.081	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:07:53.080	debug	MIIO Receive Timeout for "get_sound_volume" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:07:51.079	debug	Message= {"id":45,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:07:51.079	debug	Error at getSetNetwork: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:07:51.079	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:07:51.078	debug	MIIO Receive Timeout for "get_network_info" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:07:49.078	debug	Message= {"id":44,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:07:49.078	debug	ERROR at setGetStatus: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:07:49.078	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:07:49.077	debug	MIIO Receive Timeout for "get_status" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:07:47.077	debug	Message= {"id":43,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:07:47.076	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:07:44.635	debug	Receive <<< Helo <<< 21310020000000001329b53563611a20ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:07:34.632	debug	Receive <<< Helo <<< 21310020000000001329b53563611a16ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:07:27.076	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:07:27.076	debug	MIIO Receive Timeout for "get_map_v1" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:07:25.074	debug	Message= {"id":42,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:07:25.074	debug	Startup: setGetConsumable Answer: false
                                        mihome-vacuum.0
                                        2022-11-01 14:07:25.074	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:07:25.073	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:07:25.073	debug	MIIO Receive Timeout for "get_consumable" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:07:24.628	debug	Receive <<< Helo <<< 21310020000000001329b53563611a0cffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:07:23.072	debug	Message= {"id":41,"method":"get_consumable"}
                                        mihome-vacuum.0
                                        2022-11-01 14:07:23.071	debug	Startup: setGetCleanSummary Answer: false
                                        mihome-vacuum.0
                                        2022-11-01 14:07:23.071	debug	ERROR at setGetCleanSummary: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:07:23.071	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:07:23.071	debug	MIIO Receive Timeout for "get_clean_summary" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:07:21.070	debug	Message= {"id":40,"method":"get_clean_summary"}
                                        mihome-vacuum.0
                                        2022-11-01 14:07:21.070	debug	ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:07:21.070	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:07:21.069	debug	MIIO Receive Timeout for "get_sound_volume" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:07:19.069	debug	Message= {"id":39,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:07:19.069	debug	Error at getSetNetwork: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:07:19.061	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:07:19.061	debug	MIIO Receive Timeout for "get_network_info" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:07:17.060	debug	Message= {"id":38,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:07:17.060	debug	ERROR at setGetStatus: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:07:17.059	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:07:17.059	debug	MIIO Receive Timeout for "get_status" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:07:15.059	debug	Message= {"id":37,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:07:15.058	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:07:14.625	debug	Receive <<< Helo <<< 21310020000000001329b53563611a02ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:07:04.622	debug	Receive <<< Helo <<< 21310020000000001329b535636119f8ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:06:55.058	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:06:55.057	debug	MIIO Receive Timeout for "get_map_v1" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:06:54.609	debug	Helo message Timeout
                                        mihome-vacuum.0
                                        2022-11-01 14:06:53.056	debug	Message= {"id":36,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:06:53.056	debug	Startup: setGetConsumable Answer: false
                                        mihome-vacuum.0
                                        2022-11-01 14:06:53.056	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:06:53.056	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:06:53.056	debug	MIIO Receive Timeout for "get_consumable" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:06:51.054	debug	Message= {"id":35,"method":"get_consumable"}
                                        mihome-vacuum.0
                                        2022-11-01 14:06:51.054	debug	Startup: setGetCleanSummary Answer: false
                                        mihome-vacuum.0
                                        2022-11-01 14:06:51.054	debug	ERROR at setGetCleanSummary: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:06:51.054	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:06:51.054	debug	MIIO Receive Timeout for "get_clean_summary" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:06:49.052	debug	Message= {"id":34,"method":"get_clean_summary"}
                                        mihome-vacuum.0
                                        2022-11-01 14:06:49.052	debug	ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:06:49.049	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:06:49.049	debug	MIIO Receive Timeout for "get_sound_volume" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:06:47.045	debug	Message= {"id":33,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:06:47.045	debug	Error at getSetNetwork: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:06:47.045	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:06:47.044	debug	MIIO Receive Timeout for "get_network_info" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:06:45.044	debug	Message= {"id":32,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:06:45.044	debug	ERROR at setGetStatus: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:06:45.044	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:06:45.043	debug	MIIO Receive Timeout for "get_status" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:06:43.043	debug	Message= {"id":31,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:06:43.042	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:06:42.607	debug	Receive <<< Helo <<< 21310020000000001329b535636119e2ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:06:32.604	debug	Receive <<< Helo <<< 21310020000000001329b535636119d8ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:06:23.041	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:06:23.041	debug	MIIO Receive Timeout for "get_map_v1" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:06:22.600	debug	Receive <<< Helo <<< 21310020000000001329b535636119ceffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:06:21.040	debug	Message= {"id":30,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:06:21.039	debug	Startup: setGetConsumable Answer: false
                                        mihome-vacuum.0
                                        2022-11-01 14:06:21.039	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:06:21.039	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:06:21.038	debug	MIIO Receive Timeout for "get_consumable" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:06:19.038	debug	Message= {"id":29,"method":"get_consumable"}
                                        mihome-vacuum.0
                                        2022-11-01 14:06:19.038	debug	Startup: setGetCleanSummary Answer: false
                                        mihome-vacuum.0
                                        2022-11-01 14:06:19.037	debug	ERROR at setGetCleanSummary: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:06:19.037	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:06:19.037	debug	MIIO Receive Timeout for "get_clean_summary" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:06:17.036	debug	Message= {"id":28,"method":"get_clean_summary"}
                                        mihome-vacuum.0
                                        2022-11-01 14:06:17.036	debug	ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:06:17.036	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:06:17.035	debug	MIIO Receive Timeout for "get_sound_volume" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:06:15.035	debug	Message= {"id":27,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:06:15.035	debug	Error at getSetNetwork: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:06:15.035	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:06:15.034	debug	MIIO Receive Timeout for "get_network_info" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:06:13.033	debug	Message= {"id":26,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:06:13.033	debug	ERROR at setGetStatus: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:06:13.033	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:06:13.033	debug	MIIO Receive Timeout for "get_status" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:06:12.596	debug	Receive <<< Helo <<< 21310020000000001329b535636119c4ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:06:11.032	debug	Message= {"id":25,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:06:11.031	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:06:02.588	debug	Receive <<< Helo <<< 21310020000000001329b535636119baffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:05:52.585	debug	Receive <<< Helo <<< 21310020000000001329b535636119b0ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:05:51.031	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:05:51.030	debug	MIIO Receive Timeout for "get_map_v1" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:05:49.029	debug	Message= {"id":24,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:05:49.029	debug	Startup: setGetConsumable Answer: false
                                        mihome-vacuum.0
                                        2022-11-01 14:05:49.029	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:05:49.029	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:05:49.028	debug	MIIO Receive Timeout for "get_consumable" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:05:47.028	debug	Message= {"id":23,"method":"get_consumable"}
                                        mihome-vacuum.0
                                        2022-11-01 14:05:47.027	debug	Startup: setGetCleanSummary Answer: false
                                        mihome-vacuum.0
                                        2022-11-01 14:05:47.027	debug	ERROR at setGetCleanSummary: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:05:47.026	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:05:47.026	debug	MIIO Receive Timeout for "get_clean_summary" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:05:45.025	debug	Message= {"id":22,"method":"get_clean_summary"}
                                        mihome-vacuum.0
                                        2022-11-01 14:05:45.025	debug	ERROR at setGetSoundVolume: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:05:45.025	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:05:45.024	debug	MIIO Receive Timeout for "get_sound_volume" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:05:43.024	debug	Message= {"id":21,"method":"get_sound_volume"}
                                        mihome-vacuum.0
                                        2022-11-01 14:05:43.024	debug	Error at getSetNetwork: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:05:43.024	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:05:43.023	debug	MIIO Receive Timeout for "get_network_info" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:05:42.582	debug	Receive <<< Helo <<< 21310020000000001329b535636119a6ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:05:41.022	debug	Message= {"id":20,"method":"get_network_info"}
                                        mihome-vacuum.0
                                        2022-11-01 14:05:41.022	debug	ERROR at setGetStatus: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:05:41.022	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:05:41.021	debug	MIIO Receive Timeout for "get_status" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:05:39.020	debug	Message= {"id":19,"method":"get_status"}
                                        mihome-vacuum.0
                                        2022-11-01 14:05:39.020	debug	get params for stock Vacuum
                                        mihome-vacuum.0
                                        2022-11-01 14:05:38.399	info	discover Login failed
                                        mihome-vacuum.0
                                        2022-11-01 14:05:38.399	debug	Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"","pwd":0,"child":0,"desc":"登录验证失败"}
                                        mihome-vacuum.0
                                        2022-11-01 14:05:38.202	debug	Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"child":0,"desc":"登录验证失败"}
                                        mihome-vacuum.0
                                        2022-11-01 14:05:38.072	debug	Xiaomi Cloud: Logging in
                                        mihome-vacuum.0
                                        2022-11-01 14:05:32.579	debug	Receive <<< Helo <<< 21310020000000001329b5356361199cffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:05:22.576	debug	Receive <<< Helo <<< 21310020000000001329b53563611992ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0
                                        2022-11-01 14:05:19.019	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:05:19.018	debug	MIIO Receive Timeout for "get_map_v1" <<<
                                        mihome-vacuum.0
                                        2022-11-01 14:05:17.018	debug	Message= {"id":18,"method":"get_map_v1"}
                                        mihome-vacuum.0
                                        2022-11-01 14:05:17.018	debug	Startup: setGetConsumable Answer: false
                                        mihome-vacuum.0
                                        2022-11-01 14:05:17.017	debug	ERROR at setGetConsumable: TypeError: Cannot read properties of undefined (reading 'result')
                                        mihome-vacuum.0
                                        2022-11-01 14:05:17.017	error	sendMessage throws error ==>MESSAGE TIMEOUT
                                        mihome-vacuum.0
                                        2022-11-01 14:05:17.017	debug	MIIO Receive Timeout for "get_consumable" <<<
                                        da knallts nur so rein...
                                          Thomas Braun Most Active @da_Woody last edited by
                                          @da_woody sagte in Test für mihome-vacuum:
                                          Receive <<< Helo <<< 21310020000000001329b53563611bbaffffffffffffffffffffffffffffffff
                                          Du bist doch verbunden. Sonst gäbe es das Helo nicht.
                                            dirkhe Developer @Thomas Braun last edited by
                                            So, das mit dem timeout Fehlermeldungen kann ich nun aufklären.
                                            Das Verhalten hat sich nicht geändert, es wurde nur seit der Version > 3.6.0 das Timeout per error geloggt.
                                            Dass der Robbi manchal keine Lust hat zu antwortern ist ja schon seit Ewigkeiten so, das dauert dann halt manchmal ein paar Minuten.
                                            Ich habe bei mir aktuell das Verhalten angepasst (werde ich nach ein paar Test nachher online stellen):
                                            Wenn ein Timeout kommt, gebe ich folgende Meldungen aus:
                                            Das bedeutet, es kommt jetzt beim Start das mit den 10 Minuten einmal als Fehler und sonst nur noch als Warnungen
                                            haselchen 1 Reply Last reply Reply Quote 1
                                            129
                                            9938
