    4. Javascript: Scripte verschwinden bei Neustart
      TyrionWarMage Developer @crunchip last edited by
      @crunchip @Homoran Genau, bei einem reboot (warm - shutdown/turn on again habe ich bisher nicht gestest)
      @Glasfaser Ist alles up to date, jarvis und zigbee sind github auf grund von bugfixes, die ich brauchte:
      x86_64
      /usr/bin/nodejs
      /usr/local/bin/node
      /usr/local/bin/npm
      v12.22.9
      v16.18.0
      8.19.2
      mediapc
      /opt/iobroker
      Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
      Hit:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
      Hit:3 http://security.ubuntu.com/ubuntu jammy-security InRelease
      Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
      Hit:6 https://download.onlyoffice.com/repo/debian squeeze InRelease
      Hit:7 https://ppa.launchpadcontent.net/jcfp/ppa/ubuntu jammy InRelease
      Hit:8 https://dl.google.com/linux/chrome/deb stable InRelease
      Hit:9 https://packages.matrix.org/debian jammy InRelease
      Hit:10 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2204 ./ InRelease
      Hit:11 https://ppa.launchpadcontent.net/linux-schools/samba-latest/ubuntu jammy InRelease
      Hit:12 https://ppa.launchpadcontent.net/ondrej/nginx/ubuntu jammy InRelease
      Hit:13 https://repo.jellyfin.org/ubuntu jammy InRelease
      Hit:14 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy InRelease
      Ign:15 https://download.webmin.com/download/repository sarge InRelease
      Hit:16 https://download.webmin.com/download/repository sarge Release
      Reading package lists... Done
      Building dependency tree... Done
      All packages are up to date.
      W: https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2204/./InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
      W: https://repo.jellyfin.org/ubuntu/dists/jammy/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
      nodejs:
        Installed: 12.22.9~dfsg-1ubuntu3
        Candidate: 12.22.9~dfsg-1ubuntu3
        Version table:
       *** 12.22.9~dfsg-1ubuntu3 500
              500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
              500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
              100 /var/lib/dpkg/status
      Used repository: stable
      Adapter    "admin"        : 6.2.23   , installed 6.2.23
      Adapter    "backitup"     : 2.4.12   , installed 2.4.12
      Adapter    "denon"        : 1.13.4   , installed 1.13.4
      Adapter    "ecovacs-deebot": 1.4.4   , installed 1.4.4
      Adapter    "history"      : 2.2.0    , installed 2.2.0
      Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
      Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "jarvis"       : 3.0.15   , installed 3.1.0-alpha.47
      Adapter    "javascript"   : 6.0.3    , installed 6.0.3
      Adapter    "kodi"         : 2.0.8    , installed 2.0.8
      Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
      Adapter    "node-red"     : 4.0.0    , installed 4.0.0
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
      Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
      Adapter    "zigbee"       : 1.7.5    , installed 1.7.6
      Homoran Thomas Braun Glasfaser 3 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @TyrionWarMage last edited by
        @tyrionwarmage sagte in Javascript: Scripte verschwinden bei Neustart:
        nicht wirklich!
        node ist falsch, veraltet und doppelt installiert.
          Thomas Braun Most Active @TyrionWarMage last edited by
          @tyrionwarmage
          Da sind auch sonst noch Quellen drin, die zumindest äußerst fragwürdig sind.
          • Glasfaser
            Glasfaser @TyrionWarMage last edited by
            Naja . 🤔 ..
            Die Antwort dazu ... wurde schon von den anderen geschrieben .
            Wäre dann die Frage , wie schaft man soetwas .... !?
              @thomas-braun sagte in Javascript: Scripte verschwinden bei Neustart:
              @tyrionwarmage
              und dann noch für squeeze. wo bleibt der Schliemann
              Glasfaser 1 Reply Last reply Reply Quote 1
              • Glasfaser
                Glasfaser @Homoran last edited by
                Ach ... das sind die Top-Hits aus Formel Eins .
                Hit 1 bis Hit 16
                Thomas Braun 1 Reply Last reply Reply Quote 2
                  Thomas Braun Most Active @Glasfaser last edited by
                  Wobei die Repos wohl in der Tat diese alten Releasenames tragen. Ist vermutlich seit intialem Release nie angepasst worden. Ganz schlechter Stil.
                  Die Zusammenstellung ist und bleibt aber fragwürdig, imho.
                  Von der krummen nodejs-Installation ganz abgesehen.
                    TyrionWarMage Developer @Homoran last edited by
                    @homoran Latest 16.X 🙂 - Habs gefixt (usr bin nodejs ist nen symlink auf die local version):
                    x86_64
                    /usr/bin/nodejs
                    /usr/local/bin/node
                    /usr/local/bin/npm
                    v18.12.0
                    v18.12.0
                    8.19.2
                    @Glasfaser Bekommt man hiermit hin: https://github.com/tj/n 😄
                    @Thomas-Braun Welche Quellen meinst du? Falls du die samba, nginx und php PPA meinst - Die sind absicht. webmin sarge ist default repo für all deb based OS.
                    Ansonsten leider keine Änderung - Hab node version fix -> reboot & script restore -> reboot gemacht
                      Homoran Global Moderator Administrators @TyrionWarMage last edited by Homoran
                      Habs gefixt
                      nö, ist immer noch im falschen Verzeichnisse
                      und node 18 ist für iobroker noch nicht empfohlen
                        Thomas Braun Most Active @TyrionWarMage last edited by Thomas Braun
                        @tyrionwarmage
                        Du hast immer noch die nodejs 12.22.9~dfsg (und deren Konsorten) installiert. Die willst du nicht haben.
                        Entweder alles über n oder über deinen Paketmanager. Beides zusammen gibt nur Chaos.
                        • Glasfaser
                          sehr schlecht ...
                          siehe in die Signatur von @Thomas-Braun wie man es richtig macht
                            TyrionWarMage Developer @Thomas Braun last edited by
                            @thomas-braun n entfernt, alte package version entfernt, neuinstall:
                            x86_64
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v16.18.0
                            v16.18.0
                            8.19.2
                            mediapc
                            /opt/iobroker
                            Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
                            Get:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease [114 kB]
                            Hit:3 https://download.onlyoffice.com/repo/debian squeeze InRelease
                            Hit:4 https://deb.nodesource.com/node_16.x jammy InRelease
                            Hit:5 https://ppa.launchpadcontent.net/jcfp/ppa/ubuntu jammy InRelease
                            Hit:6 https://packages.matrix.org/debian jammy InRelease
                            Hit:7 https://dl.google.com/linux/chrome/deb stable InRelease
                            Get:8 http://security.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
                            Hit:9 http://archive.ubuntu.com/ubuntu jammy InRelease
                            Get:11 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease [99,8 kB]
                            Hit:12 https://ppa.launchpadcontent.net/linux-schools/samba-latest/ubuntu jammy InRelease
                            Hit:13 https://ppa.launchpadcontent.net/ondrej/nginx/ubuntu jammy InRelease
                            Hit:14 https://repo.jellyfin.org/ubuntu jammy InRelease
                            Hit:15 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy InRelease
                            Ign:16 https://download.webmin.com/download/repository sarge InRelease
                            Hit:17 https://download.webmin.com/download/repository sarge Release
                            Fetched 324 kB in 2s (138 kB/s)
                            nodejs:
                              Installed: 16.18.0-deb-1nodesource1
                              Candidate: 16.18.0-deb-1nodesource1
                              Version table:
                             *** 16.18.0-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages
                            Keine Änderung bzgl. des Problems
                            Glasfaser Homoran 2 Replies Last reply Reply Quote 0
                            • Glasfaser
                              Glasfaser @TyrionWarMage last edited by Glasfaser
                              @tyrionwarmage
                              iobroker upload all
                              iobroker stop
                              iobroker fix
                              sudo reboot
                              ACHTUNG EDIT !!
                                wo hast du dein Spiegelverzeichnis?
                                  TyrionWarMage Developer @Glasfaser last edited by
                                  @glasfaser Done
                                  @Homoran 2 externe HDDs mit LVM mirrored volume - Habs mal in ein anderes (frisches) Unterzeichnis geschoben
                                  Leider weiterhin kein Erfolg 😞
                                  • Glasfaser
                                    @tyrionwarmage
                                    Teste ... lege ein JS an .. dann dieses Script .
                                    Speichern ... einmal ausführen ... danach kannst du den iobroker neu starten .
                                    was ist dann !?
                                    var fs = require('fs');
                                    var url_snapshot = 'https://upload.wikimedia.org/wikipedia/de/9/90/FirefoxLogo3.5.png';//Bild URL
                                    request.get({url: url_snapshot, encoding: 'binary'}, function (err, response, body) {
                                            fs.writeFile('/tmp/snap.jpg', body, 'binary', function(err) {
                                                if (err) {
                                                    console.error(err);
                                                     } else {
                                                    console.log('Snapshot sent');
                                                    sendTo('telegram.0', {text: '/tmp/snap.jpg', caption: 'Es hat geklingelt !'});
                                      und das ist nach Systemstart schon verfügbar wenn iobroker startet?
                                        @homoran LVM natürlich, aber nach einem test hat sich herrausgestellt dass das wohl nicht für das externe mirror volume stimmt. Mit nem mirror pfad auf der SSD klappts. Danke für den Hinweis. Werde als nächste mal schauen wie ich mein service file anpassen muss, damit es auf das mirror volume wartet, aber das ist jetzt erstmal nicht so dringend. Die Backups liegen ja noch auf dem externen mirror volume.
                                        An all danke für die Hilfe und die Hinweise zum fixen meiner node installation 😉
                                        1772
