    4. [gelöst] Skript Frage - 2tes Gerät 10 Minuten später
      paul53 last edited by
      Nach dem Setzen (setState()) wird offenbar ein boolscher Wert geliefert und nach ca. einer Sekunde (ack: true) ein String. Dann versuche es mal so:
      on({id: idAktor_Notlicht, ack: true}, function(dp) {
          log(dp.state.val + ' ' + typeof dp.state.val);
      • N
        noxx last edited by
        hmm, nun geht nix mehr 🙂
        Entweder spinnt iobroker oder er mag den "Befehl" nicht
        fhem.0	2017-07-17 18:20:18.935	warn	Readings "Swi" still not found in "ESP03_Innenlicht" after JsonList2
        fhem.0	2017-07-17 18:20:18.455	info	Unknown state "ESP03_Innenlicht.Swi
        fhem.0	2017-07-17 18:20:08.256	warn	Readings "Swi" still not found in "ESP03_Heizung" after JsonList2
        fhem.0	2017-07-17 18:20:07.581	info	Unknown state "ESP03_Heizung.Swi
        fhem.0	2017-07-17 18:20:04.155	warn	Readings "Swi" still not found in "ESP03_Notlicht" after JsonList2
        fhem.0	2017-07-17 18:20:03.622	info	Unknown state "ESP03_Notlicht.Swi
        fhem.0	2017-07-17 18:20:03.133	warn	Readings "Swi" still not found in "ESP03_Innenlicht" after JsonList2
        fhem.0	2017-07-17 18:20:02.568	info	Unknown state "ESP03_Innenlicht.Swi
        host.raspberrypi	2017-07-17 18:20:01.139	info	Restart adapter system.adapter.javascript.0 because enabled
        host.raspberrypi	2017-07-17 18:20:01.137	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
        javascript.0	2017-07-17 18:20:01.019	error	at Timer.listOnTimeout (timers.js:92:15)
        javascript.0	2017-07-17 18:20:01.019	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:479:11)
        javascript.0	2017-07-17 18:20:01.019	error	at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:175:10)
        javascript.0	2017-07-17 18:20:01.019	error	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1501:34)
        javascript.0	2017-07-17 18:20:01.019	error	at Object. (script.js.common.Astro:103:4)
        javascript.0	2017-07-17 18:20:01.019	error	at zeiten_speichern (script.js.common.Astro:63:44)
        javascript.0	2017-07-17 18:20:01.019	error	TypeError: Cannot read property 'toLocaleTimeString' of undefined
        javascript.0	2017-07-17 18:20:00.995	error	uncaught exception: Cannot read property 'toLocaleTimeString' of undefined
        javascript.0	2017-07-17 18:20:00.971	error	Longitude or latitude does not set. Cannot use astro.
        javascript.0	2017-07-17 18:20:00.969	error	Longitude or latitude does not set. Cannot use astro.
        fhem.0	2017-07-17 18:20:00.412	warn	Readings "Cou" still not found in "ESP04_Gaszaehler" after JsonList2
        fhem.0	2017-07-17 18:20:00.343	warn	Unknown event "ESPEasy ESP03_Notlicht on"
        fhem.0	2017-07-17 18:20:00.314	warn	Unknown event "ESPEasy ESP03_Innenlicht off"
        fhem.0	2017-07-17 18:19:59.775	info	Unknown state "ESP04_Gaszaehler.Cou
        fhem.0	2017-07-17 18:19:57.120	warn	Readings "Swi" still not found in "ESP03_Aussenlicht" after JsonList2
        fhem.0	2017-07-17 18:19:56.556	info	Unknown state "ESP03_Aussenlicht.Swi
        fhem.0	2017-07-17 18:19:55.878	warn	Readings "Tem" still not found in "ESP03_Temperatur" after JsonList2
        fhem.0	2017-07-17 18:19:55.368	info	Unknown state "ESP03_Temperatur.Tem
        javascript.0	2017-07-17 18:19:39.299	info	script.js.common.Müllkalender2push: registered 0 subscriptions and 1 schedule
        javascript.0	2017-07-17 18:19:39.286	info	Start javascript script.js.common.Müllkalender2push
        javascript.0	2017-07-17 18:19:39.281	info	script.js.common.Müllkalender: registered 1 subscription and 1 schedule
        javascript.0	2017-07-17 18:19:39.253	info	script.js.common.Müllkalender: Muellwarnung.GelbeTonne
        javascript.0	2017-07-17 18:19:39.252	info	script.js.common.Müllkalender: Muellwarnung.GrueneTonne
        javascript.0	2017-07-17 18:19:39.250	info	script.js.common.Müllkalender: Muellwarnung.BlaueTonne
        javascript.0	2017-07-17 18:19:39.248	info	script.js.common.Müllkalender: Muellwarnung.Reststoff
        javascript.0	2017-07-17 18:19:39.239	info	Start javascript script.js.common.Müllkalender
        javascript.0	2017-07-17 18:19:39.235	info	script.js.common.Hühnerstall: registered 4 subscriptions and 1 schedule
        javascript.0	2017-07-17 18:19:39.214	info	Start javascript script.js.common.Hühnerstall
        javascript.0	2017-07-17 18:19:39.209	info	script.js.common.LowBat: registered 4 subscriptions and 1 schedule
        javascript.0	2017-07-17 18:19:39.204	info	script.js.common.LowBat: lowbat(4):
        javascript.0	2017-07-17 18:19:39.047	info	Start javascript script.js.common.LowBat
        javascript.0	2017-07-17 18:19:39.034	info	script.js.common.Denon: registered 39 subscriptions and 0 schedules
        javascript.0	2017-07-17 18:19:39.021	error	script.js.common.Denon: ungültige IP Adresse
        javascript.0	2017-07-17 18:19:38.982	info	Start javascript script.js.common.Denon
        javascript.0	2017-07-17 18:19:38.975	info	script.js.common.Astro: registered 0 subscriptions and 9 schedules
        javascript.0	2017-07-17 18:19:38.953	error	Longitude or latitude does not set. Cannot use astro.
        javascript.0	2017-07-17 18:19:38.952	error	Longitude or latitude does not set. Cannot use astro.
        javascript.0	2017-07-17 18:19:38.951	error	Longitude or latitude does not set. Cannot use astro.
        javascript.0	2017-07-17 18:19:38.950	error	Longitude or latitude does not set. Cannot use astro.
        javascript.0	2017-07-17 18:19:38.948	error	Longitude or latitude does not set. Cannot use astro.
        javascript.0	2017-07-17 18:19:38.919	info	Start javascript script.js.common.Astro
        javascript.0	2017-07-17 18:19:38.912	info	script.js.common.PoolPumpe: registered 2 subscriptions and 1 schedule
        javascript.0	2017-07-17 18:19:38.812	info	Start javascript script.js.common.PoolPumpe
        javascript.0	2017-07-17 18:19:38.600	info	received all objects
        javascript.0	2017-07-17 18:19:37.748	info	received all states
        javascript.0	2017-07-17 18:19:35.912	info	requesting all objects
        javascript.0	2017-07-17 18:19:35.905	info	requesting all states
        javascript.0	2017-07-17 18:19:35.861	info	starting. Version 3.2.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.6.2
        host.raspberrypi	2017-07-17 18:19:31.130	info	instance system.adapter.javascript.0 started with pid 997
        fhem.0	2017-07-17 18:19:30.282	warn	Readings "Cou" still not found in "ESP04_Gaszaehler" after JsonList2
        fhem.0	2017-07-17 18:19:29.746	info	Unknown state "ESP04_Gaszaehler.Cou
        fhem.0	2017-07-17 18:19:08.277	warn	Readings "Swi" still not found in "ESP03_Heizung" after JsonList2
        fhem.0	2017-07-17 18:19:07.506	info	Unknown state "ESP03_Heizung.Swi
        fhem.0	2017-07-17 18:19:04.032	warn	Readings "Swi" still not found in "ESP03_Notlicht" after JsonList2
        fhem.0	2017-07-17 18:19:03.563	info	Unknown state "ESP03_Notlicht.Swi
        fhem.0	2017-07-17 18:19:03.092	warn	Readings "Swi" still not found in "ESP03_Innenlicht" after JsonList2
        fhem.0	2017-07-17 18:19:02.503	info	Unknown state "ESP03_Innenlicht.Swi
        host.raspberrypi	2017-07-17 18:19:01.104	info	Restart adapter system.adapter.javascript.0 because enabled
        host.raspberrypi	2017-07-17 18:19:01.102	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
        javascript.0	2017-07-17 18:19:01.014	error	at Timer.listOnTimeout (timers.js:92:15)
        javascript.0	2017-07-17 18:19:01.014	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:479:11)
        javascript.0	2017-07-17 18:19:01.014	error	at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:175:10)
        javascript.0	2017-07-17 18:19:01.014	error	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1501:34)
        javascript.0	2017-07-17 18:19:01.014	error	at Object. (script.js.common.Astro:103:4)
        javascript.0	2017-07-17 18:19:01.014	error	at zeiten_speichern (script.js.common.Astro:63:44)
        javascript.0	2017-07-17 18:19:01.014	error	TypeError: Cannot read property 'toLocaleTimeString' of undefined
        javascript.0	2017-07-17 18:19:00.991	error	uncaught exception: Cannot read property 'toLocaleTimeString' of undefined
        javascript.0	2017-07-17 18:19:00.962	error	Longitude or latitude does not set. Cannot use astro.
        javascript.0	2017-07-17 18:19:00.960	error	Longitude or latitude does not set. Cannot use astro.
        fhem.0	2017-07-17 18:19:00.680	warn	Readings "Cou" still not found in "ESP04_Gaszaehler" after JsonList2
        fhem.0	2017-07-17 18:19:00.363	warn	Unknown event "ESPEasy ESP03_Notlicht on"
        fhem.0	2017-07-17 18:19:00.280	warn	Unknown event "ESPEasy ESP03_Innenlicht off"
        fhem.0	2017-07-17 18:18:59.715	info	Unknown state "ESP04_Gaszaehler.Cou
        fhem.0	2017-07-17 18:18:57.102	warn	Readings "Swi" still not found in "ESP03_Aussenlicht" after JsonList2
        fhem.0	2017-07-17 18:18:56.477	info	Unknown state "ESP03_Aussenlicht.Swi
        fhem.0	2017-07-17 18:18:55.818	warn	Readings "Tem" still not found in "ESP03_Temperatur" after JsonList2
        fhem.0	2017-07-17 18:18:55.290	info	Unknown state "ESP03_Temperatur.Tem
        javascript.0	2017-07-17 18:18:48.280	info	script.js.common.Müllkalender2push: registered 0 subscriptions and 1 schedule
        javascript.0	2017-07-17 18:18:48.267	info	Start javascript script.js.common.Müllkalender2push
        javascript.0	2017-07-17 18:18:48.263	info	script.js.common.Müllkalender: registered 1 subscription and 1 schedule
        javascript.0	2017-07-17 18:18:48.228	info	script.js.common.Müllkalender: Muellwarnung.GelbeTonne
        javascript.0	2017-07-17 18:18:48.227	info	script.js.common.Müllkalender: Muellwarnung.GrueneTonne
        javascript.0	2017-07-17 18:18:48.225	info	script.js.common.Müllkalender: Muellwarnung.BlaueTonne
        javascript.0	2017-07-17 18:18:48.223	info	script.js.common.Müllkalender: Muellwarnung.Reststoff
        javascript.0	2017-07-17 18:18:48.214	info	Start javascript script.js.common.Müllkalender
        javascript.0	2017-07-17 18:18:48.210	info	script.js.common.Hühnerstall: registered 4 subscriptions and 1 schedule
        javascript.0	2017-07-17 18:18:48.192	info	Start javascript script.js.common.Hühnerstall
        javascript.0	2017-07-17 18:18:48.187	info	script.js.common.LowBat: registered 4 subscriptions and 1 schedule
        javascript.0	2017-07-17 18:18:48.183	info	script.js.common.LowBat: lowbat(4):
        javascript.0	2017-07-17 18:18:48.009	info	Start javascript script.js.common.LowBat
        javascript.0	2017-07-17 18:18:48.003	info	script.js.common.Denon: registered 39 subscriptions and 0 schedules
        javascript.0	2017-07-17 18:18:47.997	error	script.js.common.Denon: ungültige IP Adresse
        javascript.0	2017-07-17 18:18:47.962	info	Start javascript script.js.common.Denon
        javascript.0	2017-07-17 18:18:47.956	info	script.js.common.Astro: registered 0 subscriptions and 9 schedules
        javascript.0	2017-07-17 18:18:47.940	error	Longitude or latitude does not set. Cannot use astro.
        javascript.0	2017-07-17 18:18:47.939	error	Longitude or latitude does not set. Cannot use astro.
        javascript.0	2017-07-17 18:18:47.938	error	Longitude or latitude does not set. Cannot use astro.
        javascript.0	2017-07-17 18:18:47.937	error	Longitude or latitude does not set. Cannot use astro.
        javascript.0	2017-07-17 18:18:47.936	error	Longitude or latitude does not set. Cannot use astro.
        javascript.0	2017-07-17 18:18:47.907	info	Start javascript script.js.common.Astro
        javascript.0	2017-07-17 18:18:47.901	info	script.js.common.PoolPumpe: registered 2 subscriptions and 1 schedule
        javascript.0	2017-07-17 18:18:47.786	info	Start javascript script.js.common.PoolPumpe
        javascript.0	2017-07-17 18:18:47.619	info	received all objects
        javascript.0	2017-07-17 18:18:46.891	info	received all states
        javascript.0	2017-07-17 18:18:45.212	info	requesting all objects
        javascript.0	2017-07-17 18:18:45.204	info	requesting all states
        javascript.0	2017-07-17 18:18:45.161	info	starting. Version 3.2.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.6.2
          Du solltest erst einmal die Koordinaten eingeben, damit die Funktion isAstroDay() funktionieren kann.
            Erzeuge erst einmal ein reines Test-Skript, damit wir über die Werte Bescheid wissen.
            var idTemp = "fhem.0.ESP03_Temperatur.Temperature"/*ESP03_Temperatur Temperature*/;
            var idAktor_Innenlicht = "fhem.0.ESP03_Innenlicht.state"/*ESP03_Innenlicht state*/;
            var idAktor_Notlicht = "fhem.0.ESP03_Notlicht.state"/*ESP03_Notlicht state*/;
            var idAktor_Heizung = "fhem.0.ESP03_Heizung.state"/*ESP03_Heizung state*/;
            var temp = getState(idTemp).val;
            var aktor_Innenlicht = getState(idAktor_Innenlicht).val;
            var aktor_Notlicht = getState(idAktor_Notlicht).val;
            var aktor_Heizung = getState(idAktor_Heizung).val;
            var timer = null;
            log('Temp ' + temp + ' ' + typeof temp);
            log('Innen ' + aktor_Innenlicht + ' ' + typeof aktor_Innenlicht);
            log('Not ' + aktor_Notlicht + ' ' + typeof aktor_Notlicht);
            log('Heizung ' + aktor_Heizung + ' ' + typeof aktor_Heizung);
            • N
              noxx last edited by
              sind drin, auch vorher schon.
              hatte iobroker gerade upgedatet (discovery/vis)
              nun spinnt er… wenns wieder läuft, kommt das LOG
              • N
                noxx last edited by
                so
                22:12:56.811	[info]	javascript.0 Start javascript script.js.common.test
                22:12:56.815	[info]	javascript.0 script.js.common.test: Temp 18.5 number
                22:12:56.816	[info]	javascript.0 script.js.common.test: Innen Swi: off string
                22:12:56.816	[info]	javascript.0 script.js.common.test: Not Swi: off string
                22:12:56.818	[info]	javascript.0 script.js.common.test: Heizung Swi: off string
                22:12:56.819	[info]	javascript.0 script.js.common.test: registered 0 subscriptions and 0 schedules
                  Dann sollte das Skript an ein paar Stellen umgebaut werden.
                  var idTemp = "fhem.0.ESP03_Temperatur.Temperature"/ESP03_Temperatur Temperature/;
                  var idAktor_Innenlicht = "fhem.0.ESP03_Innenlicht.state"/ESP03_Innenlicht state/;
                  var idAktor_Notlicht = "fhem.0.ESP03_Notlicht.state"/ESP03_Notlicht state/;
                  var idAktor_Heizung = "fhem.0.ESP03_Heizung.state"/ESP03_Heizung state/;
                  ! var temp = getState(idTemp).val;
                  var aktor_Innenlicht = false;
                  if(getState(idAktor_Innenlicht).val.indexOf('on') != -1) aktor_Innenlicht = true;
                  var aktor_Notlicht = false;
                  if(getState(idAktor_Notlicht).val.indexOf('on') != -1) aktor_Notlicht = true;
                  var aktor_Heizung = false;
                  if(getState(idAktor_Heizung).val.indexOf('on') != -1) aktor_Heizung = true;
                  var timer = null;
                  ! function Zeitschaltung()
                  var nacht = compareTime('22:00', '06:00', 'between');
                  if(nacht && !isAstroDay())
                  if(!aktor_Innenlicht) setState(idAktor_Innenlicht, true);
                  else if(aktor_Innenlicht) setState(idAktor_Innenlicht, false);
                  ! function heizung()
                  if (temp < 0)
                  if (!aktor_Heizung) setState(idAktor_Heizung, true);
                  else if (aktor_Heizung) setState(idAktor_Heizung, false);
                  ! schedule('* * * * *', Zeitschaltung);
                  ! on(idTemp, function(dp) {
                  temp = dp.state.val;
                  heizung();
                  ! on({id: idAktor_Innenlicht, ack: true}, function(dp) {
                  if(typeof dp.state.val == 'string') {
                  if(dp.state.val.indexOf('on') != -1) aktor_Innenlicht = true;
                  else aktor_Innenlicht = false;
                  if(timer) clearTimeout(timer);
                  if(!aktor_Innenlicht) { // schaltet aus
                  setState(idAktor_Notlicht, true); // Notlicht ein
                  timer = setTimeout(function() {
                  setState(idAktor_Notlicht, false);
                  }, 600000); // nach 10 Minuten aus
                  ! on({id: idAktor_Notlicht, ack: true}, function(dp) {
                  if(typeof dp.state.val == 'string'){
                  if(dp.state.val.indexOf('on') != -1) aktor_Notlicht = true;
                  else aktor_Notlicht = false;
                  ! on({id: idAktor_Heizung, ack: true}, function(dp) {
                  if(dp.state.val.indexOf('on') != -1) aktor_Heizung = true;
                  else aktor_Heizung = false;
                    @paul53:
                    Allerdings hätte ich erwartet, dass der FHEM-Adapter diese Anpassungen vornimmt. `
                    Habe mir den FHEM-Adapter mal angesehen und festgestellt, dass der Adapter die Anpassung macht: ' on' –> true, ' off' --> false.
                    Allerdings kann er er mit 'Swi: on' und 'Swi: off' nichts anfangen. Woher kommt das 'Swi:' ? Hast Du eventuell die FHEM-Namenskonventionen nicht beachtet ?
                    • N
                      noxx last edited by
                      Bekomme immer noch einen Fehler bei deiner Anpassung
                      javascript.0	2017-07-18 19:08:16.743	error	at script.js.common.Hühnerstall:112:37
                      javascript.0	2017-07-18 19:08:16.743	error	script.js.common.Hühnerstall: TypeError: getState(...).val.indexOf is not a function
                      javascript.0	2017-07-18 19:08:16.683	warn	Cannot calculate "night" for 53.0000, 7.0000
                      javascript.0	2017-07-18 19:08:16.679	warn	Cannot calculate "nightEnd" for 53.0000, 7.0000
                      javascript.0	2017-07-18 19:08:16.676	warn	Cannot calculate "night" for 53.0000, 7.0000
                      javascript.0	2017-07-18 19:08:16.613	info	Start javascript script.js.common.Hühnerstall
                      sowie diese Warnung
                      javascript.0	2017-07-18 21:09:44.246	warn	Wrong type of fhem.0.ESP03_Notlicht.state: "boolean". Please fix, while deprecated and will not work in next versions.
                      Wo? Wird eigentlich alles von selbst erkannt, habe nichts einstellen müssen.
                      Sehe aber, das das SWI aus dem FHEM Modul kommt. Muss mal gucken, wie man das
                      ändert
                      • N
                        noxx last edited by
                        FHEM ist nun angepasst, nun haben ich einen "Schalter" in den Objekten:
                        21:20:13.829	[info]	javascript.0 Start javascript script.js.common.test
                        21:20:13.832	[info]	javascript.0 script.js.common.test: Temp 22.5 number
                        21:20:13.832	[info]	javascript.0 script.js.common.test: Innen false boolean
                        21:20:13.832	[info]	javascript.0 script.js.common.test: Not true boolean
                        21:20:13.832	[info]	javascript.0 script.js.common.test: Heizung false boolean
                        21:20:13.832	[info]	javascript.0 script.js.common.test: registered 0 subscriptions and 9 schedules
                        Notlicht springt aber immer noch sofort an.
                        Hänge mal die FHEM Settings an, nicht das ich das mal vergesse 🙂
                        EDIT
                        Habe nun mal wieder die erste Version drauf, mal sehen obs nun geht. Bisher ist "Notlicht" aus
                          @noxx:
                          FHEM ist nun angepasst, nun haben ich einen "Schalter" in den Objekten: `
                          Das sieht gut aus !
                          @noxx:
                          Notlicht springt aber immer noch sofort an. `
                          Dann ergänze mal im on() im Skript aus meinem ersten Beitrag
                          on({id: idAktor_Innenlicht, change: 'ne', ack: true}, function(dp) {
                          • N
                            noxx last edited by
                            gemacht, ich warte ab.
                            das Astroscript spinnt aber wohl rum
                            javascript.0 2017-07-18 21:28:34.135 warn Cannot calculate "night" for 53.0000, 7.0000
                            javascript.0 2017-07-18 21:28:34.122 warn Cannot calculate "nightEnd" for 53.0000, 7.0000
                            javascript.0 2017-07-18 21:28:34.117 warn Cannot calculate "night" for 53.0000, 7.0000
                            • N
                              noxx last edited by
                              hmm, nun ist das Innenlicht an. sollte ab 22:00 dunkel sein 🙂
                              > javascript.0 2017-07-18 22:11:00.364 info script.js.common.Hühnerstall: Innenlicht: true
                              var timer = null;
                              log('User-Log: Innenlicht: ' + aktor_Innenlicht);
                              log('User-Log: Nacht: ' + nacht);
                              if (temp < 1)
                              heizung();
                              ! on(idAktor_Innenlicht, function(dp) {
                              aktor_Innenlicht = dp.state.val;
                              ! on(idAktor_Notlicht, function(dp) {
                              aktor_Notlicht = dp.state.val;
                              ! on(idAktor_Heizung, function(dp) {
                              aktor_Heizung = dp.state.val;
                              22:16:00.542 [info] javascript.0 script.js.common.Hühnerstall: User-Log: Innenlicht: true
                              22:16:00.544 [info] javascript.0 script.js.common.Hühnerstall: User-Log: Nacht: true
                              EDIT
                              Habs mal umgedreht, nun gehts wie es soll (hoffe ich)
                              var nacht = compareTime('06:00', '22:00', 'between');
                                Ach so, vor 22:00 soll das Licht einschalten, wenn es draußen dunkel wird. Dann so:
                                   var tag = compareTime('06:00', '22:00', 'between');
                                   if(tag && !isAstroDay())
                                  @noxx:
                                  javascript.0 2017-07-18 21:28:34.117 warn Cannot calculate "night" for 53.0000, 7.0000 `
                                  Bei 53° nördlicher Breite sollte es funktionieren (habe es damit gerade getestet). Weiter nördlich kann es im Sommer zu solchen Warnungen kommen.
                                    change: 'ne', ack: true gleichzeitig zu verwenden, ist wohl eher unproduktiv (triggert nie), da die Wertänderung Folge von setState() ist und ack = true Folge der Rückmeldung des Aktors (FHEM) bei unverändertem Wert. Außerdem sollte bei der Heizung eine Hysterese verwendet werden, da sonst zu häufig ein- und ausgeschaltet wird. So sollte es funktionieren:
                                    var timer = null;
                                    function Zeitschaltung() {
                                        if(tag && !isAstroDay()) {
                                    function heizung() {
                                        if (temp < 0 && !aktor_Heizung) setState(idAktor_Heizung, true);
                                        else if (temp > 1 && aktor_Heizung) setState(idAktor_Heizung, false);
                                        heizung();
                                        if(!aktor_Innenlicht) setState(idAktor_Notlicht, true);  // Notlicht ein
                                        if(aktor_Notlicht) {  // hat eingeschaltet
                                    • N
                                      noxx last edited by
                                      danke, aber habe dann wieder das Problem, das die Notlampe dauer leuchtet.
                                        @noxx:
                                        habe dann wieder das Problem, das die Notlampe dauer leuchtet. `
                                        Wie sieht der Zustand (Wert, Bestätigt) des Aktors Notlicht im Reiter Zustände aus, wenn die Notlampe leuchtet ?
                                        • N
                                          noxx last edited by
                                          Notlicht An:
                                          fhem.0.ESP03_Notlicht.off ESP03_Notlicht off ESP03_Notlicht off
                                          fhem.0.ESP03_Notlicht.on ESP03_Notlicht on ESP03_Notlicht on
                                          fhem.0.ESP03_Notlicht.check ESP03_Notlicht check ESP03_Notlicht check
                                          fhem.0.ESP03_Notlicht.buzzer ESP03_Notlicht buzzer ESP03_Notlicht buzzer
                                          fhem.0.ESP03_Notlicht.candle ESP03_Notlicht candle ESP03_Notlicht candle
                                          fhem.0.ESP03_Notlicht.clearreadings ESP03_Notlicht clearreadings ESP03_Notlicht clearreadings
                                          fhem.0.ESP03_Notlicht.dmx ESP03_Notlicht dmx ESP03_Notlicht dmx
                                          fhem.0.ESP03_Notlicht.dots ESP03_Notlicht dots ESP03_Notlicht dots
                                          fhem.0.ESP03_Notlicht.erase ESP03_Notlicht erase ESP03_Notlicht erase
                                          fhem.0.ESP03_Notlicht.event ESP03_Notlicht event ESP03_Notlicht event
                                          fhem.0.ESP03_Notlicht.gpio ESP03_Notlicht gpio ESP03_Notlicht gpio
                                          fhem.0.ESP03_Notlicht.help ESP03_Notlicht help ESP03_Notlicht help
                                          fhem.0.ESP03_Notlicht.inputswitchstate ESP03_Notlicht inputswitchstate ESP03_Notlicht inputswitchstate
                                          fhem.0.ESP03_Notlicht.irsend ESP03_Notlicht irsend ESP03_Notlicht irsend
                                          fhem.0.ESP03_Notlicht.lcd ESP03_Notlicht lcd ESP03_Notlicht lcd
                                          fhem.0.ESP03_Notlicht.lcdcmd ESP03_Notlicht lcdcmd ESP03_Notlicht lcdcmd
                                          fhem.0.ESP03_Notlicht.lights ESP03_Notlicht lights ESP03_Notlicht lights
                                          fhem.0.ESP03_Notlicht.longpulse ESP03_Notlicht longpulse ESP03_Notlicht longpulse
                                          fhem.0.ESP03_Notlicht.mcpgpio ESP03_Notlicht mcpgpio ESP03_Notlicht mcpgpio
                                          fhem.0.ESP03_Notlicht.motorshieldcmd ESP03_Notlicht motorshieldcmd ESP03_Notlicht motorshieldcmd
                                          fhem.0.ESP03_Notlicht.neopixel ESP03_Notlicht neopixel ESP03_Notlicht neopixel
                                          fhem.0.ESP03_Notlicht.neopixelall ESP03_Notlicht neopixelall ESP03_Notlicht neopixelall
                                          fhem.0.ESP03_Notlicht.neopixelfx ESP03_Notlicht neopixelfx ESP03_Notlicht neopixelfx
                                          fhem.0.ESP03_Notlicht.neopixelline ESP03_Notlicht neopixelline ESP03_Notlicht neopixelline
                                          fhem.0.ESP03_Notlicht.oled ESP03_Notlicht oled ESP03_Notlicht oled
                                          fhem.0.ESP03_Notlicht.oledcmd ESP03_Notlicht oledcmd ESP03_Notlicht oledcmd
                                          fhem.0.ESP03_Notlicht.oledframedcmd ESP03_Notlicht oledframedcmd ESP03_Notlicht oledframedcmd
                                          fhem.0.ESP03_Notlicht.pcapwm ESP03_Notlicht pcapwm ESP03_Notlicht pcapwm
                                          fhem.0.ESP03_Notlicht.pcfgpio ESP03_Notlicht pcfgpio ESP03_Notlicht pcfgpio
                                          fhem.0.ESP03_Notlicht.pcflongpulse ESP03_Notlicht pcflongpulse ESP03_Notlicht pcflongpulse
                                          fhem.0.ESP03_Notlicht.pcfpulse ESP03_Notlicht pcfpulse ESP03_Notlicht pcfpulse
                                          fhem.0.ESP03_Notlicht.pulse ESP03_Notlicht pulse ESP03_Notlicht pulse
                                          fhem.0.ESP03_Notlicht.pwm ESP03_Notlicht pwm ESP03_Notlicht pwm
                                          fhem.0.ESP03_Notlicht.pwmfade ESP03_Notlicht pwmfade ESP03_Notlicht pwmfade
                                          fhem.0.ESP03_Notlicht.raw ESP03_Notlicht raw ESP03_Notlicht raw false admin.0 2017-07-18 21:19:21.723 2017-07-18 21:19:21.723
                                          fhem.0.ESP03_Notlicht.reboot ESP03_Notlicht reboot ESP03_Notlicht reboot
                                          fhem.0.ESP03_Notlicht.reset ESP03_Notlicht reset ESP03_Notlicht reset
                                          fhem.0.ESP03_Notlicht.rtttl ESP03_Notlicht rtttl ESP03_Notlicht rtttl
                                          fhem.0.ESP03_Notlicht.serialsend ESP03_Notlicht serialsend ESP03_Notlicht serialsend
                                          fhem.0.ESP03_Notlicht.servo ESP03_Notlicht servo ESP03_Notlicht servo
                                          fhem.0.ESP03_Notlicht.status ESP03_Notlicht status ESP03_Notlicht status
                                          fhem.0.ESP03_Notlicht.statusrequest ESP03_Notlicht statusrequest ESP03_Notlicht statusrequest
                                          fhem.0.ESP03_Notlicht.tone ESP03_Notlicht tone ESP03_Notlicht tone
                                          fhem.0.ESP03_Notlicht.Switch ESP03_Notlicht Switch ESP03_Notlicht Switch true true fhem.0 2017-07-20 22:01:02.155 2017-07-18 21:17:38.590
                                          fhem.0.ESP03_Notlicht.presence ESP03_Notlicht presence ESP03_Notlicht presence present true fhem.0 2017-07-20 21:59:53.648 2017-07-18 21:21:56.434
                                          fhem.0.ESP03_Notlicht.state ESP03_Notlicht state ESP03_Notlicht state true true fhem.0 2017-07-20 22:01:02.163 2017-07-20 21:59:43.319
                                          Notlicht Aus:
                                          fhem.0.ESP03_Notlicht.Switch	ESP03_Notlicht Switch	ESP03_Notlicht Switch	true	true	fhem.0	2017-07-20 22:02:21.741	2017-07-18 21:17:38.590
                                          fhem.0.ESP03_Notlicht.state	ESP03_Notlicht state	ESP03_Notlicht state	false	true	fhem.0	2017-07-20 22:02:21.754	2017-07-20 22:02:21.583
                                            Wenn Wert und Bestätigt true sind, müsste das Notlicht nach 10 Minuten ausschalten. Bau mal zum Testen Logs ein:
                                                log('Notlicht: ' + aktor_Notlicht + ' bestätigt: ' + dp.state.ack);
                                                        log('10 Minuten sind um');
                                            4872
