    4. Test Adapter mihome-vacuum 3.8.x
    • da_Woody
      da_Woody @dirkhe last edited by da_Woody
      @dirkhe oopsdate auf 3.8.3 gemacht. vorher gestoppt, nach start...
      mihome-vacuum.0
      2022-11-01 14:40:02.340	debug	Receive <<< Helo <<< 21310020000000001329b535636121b2ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:39:55.864	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
      mihome-vacuum.0
      2022-11-01 14:39:53.862	debug	Message= {"id":16,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:39:53.561	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
      mihome-vacuum.0
      2022-11-01 14:39:52.338	debug	Receive <<< Helo <<< 21310020000000001329b535636121a8ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:39:51.560	debug	Message= {"id":15,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:39:51.259	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
      mihome-vacuum.0
      2022-11-01 14:39:49.257	debug	Message= {"id":14,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:39:48.955	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
      mihome-vacuum.0
      2022-11-01 14:39:46.953	debug	Message= {"id":13,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:39:46.652	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
      mihome-vacuum.0
      2022-11-01 14:39:44.652	debug	Message= {"id":12,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-11-01 14:39:44.652	debug	Startup: setGetConsumable Answer: false
      mihome-vacuum.0
      2022-11-01 14:39:44.651	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
      mihome-vacuum.0
      2022-11-01 14:39:42.650	debug	Message= {"id":11,"method":"get_consumable"}
      mihome-vacuum.0
      2022-11-01 14:39:42.650	debug	Startup: setGetCleanSummary Answer: false
      mihome-vacuum.0
      2022-11-01 14:39:42.650	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
      mihome-vacuum.0
      2022-11-01 14:39:42.335	debug	Receive <<< Helo <<< 21310020000000001329b5356361219effffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:39:40.648	debug	Message= {"id":10,"method":"get_clean_summary"}
      mihome-vacuum.0
      2022-11-01 14:39:40.648	debug	Startup: Delete getMultiMapsList
      mihome-vacuum.0
      2022-11-01 14:39:40.648	debug	Startup: getMultiMapsList Answer: true
      mihome-vacuum.0
      2022-11-01 14:39:40.647	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
      mihome-vacuum.0
      2022-11-01 14:39:38.646	debug	Message= {"id":9,"method":"get_multi_maps_list"}
      mihome-vacuum.0
      2022-11-01 14:39:38.645	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
      mihome-vacuum.0
      2022-11-01 14:39:36.644	debug	Message= {"id":8,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-11-01 14:39:36.643	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
      mihome-vacuum.0
      2022-11-01 14:39:34.643	debug	Message= {"id":7,"method":"get_network_info"}
      mihome-vacuum.0
      2022-11-01 14:39:34.642	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
      mihome-vacuum.0
      2022-11-01 14:39:32.973	info	settest next timer: not available
      mihome-vacuum.0
      2022-11-01 14:39:32.642	debug	Message= {"id":6,"method":"get_status"}
      mihome-vacuum.0
      2022-11-01 14:39:32.641	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-11-01 14:39:32.641	debug	Create State done!
      mihome-vacuum.0
      2022-11-01 14:39:32.641	debug	Create State for map: loadMap
      mihome-vacuum.0
      2022-11-01 14:39:32.641	debug	Create State for map: mapURL
      mihome-vacuum.0
      2022-11-01 14:39:32.641	debug	Create State for map: mapStatus
      mihome-vacuum.0
      2022-11-01 14:39:32.640	debug	Create State for map: actualMap
      mihome-vacuum.0
      2022-11-01 14:39:32.640	debug	Create State for map: map64
      mihome-vacuum.0
      2022-11-01 14:39:32.600	debug	Create State for map:
      mihome-vacuum.0
      2022-11-01 14:39:32.552	debug	Create State for Queue: clearQueue
      mihome-vacuum.0
      2022-11-01 14:39:32.513	debug	Create State for Queue: queue
      mihome-vacuum.0
      2022-11-01 14:39:32.416	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      mihome-vacuum.0
      2022-11-01 14:39:32.408	info	select standard vacuum protocol....
      mihome-vacuum.0
      2022-11-01 14:39:32.407	debug	DeviceModel selected to: roborock.vacuum.a08
      mihome-vacuum.0
      2022-11-01 14:39:32.342	warn	No Answer for DeviceModel use model from Config
      mihome-vacuum.0
      2022-11-01 14:39:32.342	warn	No Answer for DeviceModel use old one
      mihome-vacuum.0
      2022-11-01 14:39:32.342	error	YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
      mihome-vacuum.0
      2022-11-01 14:39:32.342	debug	Get Device data..4
      mihome-vacuum.0
      2022-11-01 14:39:32.342	debug	GETMODELFROMAPI:Data: {}
      mihome-vacuum.0
      2022-11-01 14:39:32.341	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
      mihome-vacuum.0
      2022-11-01 14:39:32.332	debug	Receive <<< Helo <<< 21310020000000001329b53563612194ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:39:30.341	debug	Message= {"id":5,"method":"miIO.info"}
      mihome-vacuum.0
      2022-11-01 14:39:30.340	debug	Get Device data..3
      mihome-vacuum.0
      2022-11-01 14:39:30.340	debug	GETMODELFROMAPI:Data: {}
      mihome-vacuum.0
      2022-11-01 14:39:30.340	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
      mihome-vacuum.0
      2022-11-01 14:39:28.340	debug	Message= {"id":4,"method":"miIO.info"}
      mihome-vacuum.0
      2022-11-01 14:39:28.340	debug	Get Device data..2
      mihome-vacuum.0
      2022-11-01 14:39:28.340	debug	GETMODELFROMAPI:Data: {}
      mihome-vacuum.0
      2022-11-01 14:39:28.337	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
      mihome-vacuum.0
      2022-11-01 14:39:26.336	debug	Message= {"id":3,"method":"miIO.info"}
      mihome-vacuum.0
      2022-11-01 14:39:26.336	debug	Get Device data..1
      mihome-vacuum.0
      2022-11-01 14:39:26.336	debug	GETMODELFROMAPI:Data: {}
      mihome-vacuum.0
      2022-11-01 14:39:26.335	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
      mihome-vacuum.0
      2022-11-01 14:39:24.334	debug	Message= {"id":2,"method":"miIO.info"}
      mihome-vacuum.0
      2022-11-01 14:39:24.334	debug	Get Device data..0
      mihome-vacuum.0
      2022-11-01 14:39:24.334	debug	GETMODELFROMAPI:Data: {}
      mihome-vacuum.0
      2022-11-01 14:39:24.334	warn	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
      mihome-vacuum.0
      2022-11-01 14:39:22.332	debug	Message= {"id":1,"method":"miIO.info"}
      mihome-vacuum.0
      2022-11-01 14:39:22.331	debug	GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.a08","ack":true,"ts":1667309865791,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1640205614333}
      mihome-vacuum.0
      2022-11-01 14:39:22.328	debug	MAIN: Connected to device, try to get model..
      mihome-vacuum.0
      2022-11-01 14:39:22.328	debug	Receive <<< Helo <<< 21310020000000001329b5356361218affffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-11-01 14:39:22.311	debug	server started on 0.0.0.0:53421
      mihome-vacuum.0
      2022-11-01 14:39:22.308	info	IOT enabled, create state
      mihome-vacuum.0
      2022-11-01 14:39:22.302	debug	MIIO: Config: ip:192.168.1.15 token: 544f6b574eXXXXXXXXX
      mihome-vacuum.0
      2022-11-01 14:39:22.301	debug	Create State for deviceInfowifi_signal
      mihome-vacuum.0
      2022-11-01 14:39:22.301	debug	Create State for deviceInfofw_ver
      mihome-vacuum.0
      2022-11-01 14:39:22.301	debug	Create State for deviceInfomodel
      mihome-vacuum.0
      2022-11-01 14:39:22.300	debug	Create State for deviceInfomac
      mihome-vacuum.0
      mihome-vacuum.0
      2022-11-01 14:39:22.213	info	starting. Version 3.8.3 (non-npm: iobroker-community-adapters/ioBroker.mihome-vacuum) in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.17.0, js-controller: 4.0.23
      mihome-vacuum.0
      2022-11-01 14:39:21.834	debug	Plugin sentry Initialize Plugin (enabled=true)
      nach umstellen auf warn ist wieder ruhe. aber tögal, mir gings ja eigentlich nur um die map wegen canvas. da liegt ja das prob mit der map...
      https://forum.iobroker.net/topic/59480/test-für-mihome-vacuum/31
      Thomas Braun D 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @da_Woody last edited by Thomas Braun
        @da_woody
        Setz canvas nochmal in das Verzeichnis.
        cd /opt/iobroker/node_modules/iobroker.mihome-vacuum/
        sudo -H -u iobroker npm install canvas --omit=dev
        • da_Woody
          da_Woody @Thomas Braun last edited by
          @thomas-braun ok...
          woody@ioBroker:/opt/iobroker/node_modules/iobroker.mihome-vacuum$ npm ls canvas
          iobroker.mihome-vacuum@3.8.3 /opt/iobroker/node_modules/iobroker.mihome-vacuum
          └── canvas@2.10.2
          sieht IMHO schon besser aus.
          den saubartel neu gestartet, adapter neu, grün, start einer reinigung, keine kartenaktualisierung.
          ich verwende in iQontrol mihome-vacuum.0.cleanmap.map64 für die map. hat ja auch einige zeit funktioniert.
            @da_woody
            cd /opt/iobroker
            npm ls canvas
            • da_Woody
              @thomas-braun sagte in Test für mihome-vacuum:
              npm ls canvas
              woody@ioBroker:/opt/iobroker$ npm ls canvas
              [sudo] Passwort für woody:
              iobroker.inst@3.0.0 /opt/iobroker
              ├── canvas@2.10.2
              ├─┬ iobroker.energiefluss@1.3.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#410151c990ec5f34351dbe28f14355cbc956be2d)
              │ └── canvas@2.10.2 deduped
              ├─┬ iobroker.iot@1.12.2
              │ ├── canvas@2.10.2 deduped
              │ └─┬ jsdom@20.0.0
              └─┬ iobroker.mihome-vacuum@3.8.3 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.mihome-vacuum.git#e388a842078214f55aaade2fdb3a91f8b2009035)
                └── canvas@2.10.2
                @da_woody
                Bei mir funktionierts es damit.
                Du hast aber auch mal canvas eine Verzeichnis-Ebene zu hoch reingehauen.
                Das sollte imho nicht direkt unter iobroker.inst hängen.
                Bei mir jedenfalls nicht.
                  dirkhe Developer @da_Woody last edited by
                  @da_woody Also wenn ich mir das log so ansehe, kommt da "Mappointer_updated" danach müsste im debug eigentlich ein 'update_Map Mimap enabled' kommen, tut es aber nicht. Kann es sein, dass der Haken bei der Karte nicht mehr aktiv ist?
                  @haselchen Es hat sich generell nichts an der Logik getan, also die 3.8.x is, was die timeouts angeht genauso wie die 3.6.0, nur das Logging ist anders. Egal welche Version des Adapters du nimmst, kann es sein, dass du bis zu 10 minuten nach dem Start warten mußt, bis alles funktioniert oder halt sofort.
                  • da_Woody
                    tja, als tux.png kennst du dich aus.
                    hast du nen tip, wie ich das wieder hinbiegen kann? offensichtlich wird das zeuch ja für einiges verwendet.
                    warum wird das ding dann immer wieder installiert und dann als "deduped" gekennzeichnet?
                      @da_woody sagte in Test für mihome-vacuum:
                      Es wird ja eben NICHT x-fach installiert, sondern 'deduped' bedeutet, dass die Doubletten entfernt wurden und da nur Links zur eigentlichen Installation liegen. Ich vermute allerdings, dass der mihome-vaccuum mit diesen Links nicht parat kommt und nur auf eine richtige Installation zurückgreifen kann.
                        dirkhe Developer @Thomas Braun last edited by
                        @thomas-braun Also in der node Javascript wird es so verwendet:
                        const {
                        	createCanvas,
                        	Canvas
                        } = require('canvas');
                        const {
                        und so in der package
                          "optionalDependencies": {
                            "canvas": "^2.10.2"
                        Also normalerweise löst npm das zur Laufzeit richtig auf.
                          Thomas Braun Most Active @dirkhe last edited by
                          @dirkhe
                          Ja, sollte.
                          Ich hab nur bei mir festgestellt, dass ein 'deduped' immer auch zu der Meldung führt, dass canvas gar nicht installiert sei. Wenn ich dann canvas nochmal direkt hart reingeknallt habe war die Meldung weg.
                          • da_Woody
                            @dirkhe in der tat, der war durch die testerei draußen. anhaken, neu starten
                            mihome-vacuum.0
                            2022-11-01 15:55:14.982	debug	Mappointer_updated
                            mihome-vacuum.0
                            2022-11-01 15:55:14.982	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F1"],"id":110}
                            mihome-vacuum.0
                            2022-11-01 15:55:14.976	debug	Message= {"id":110,"method":"get_map_v1"}
                            mihome-vacuum.0
                            2022-11-01 15:55:14.975	debug	MIIO RECIVE: {"result":[90],"id":109}
                            mihome-vacuum.0
                            2022-11-01 15:55:14.968	debug	Message= {"id":109,"method":"get_sound_volume"}
                            mihome-vacuum.0
                            2022-11-01 15:55:14.877	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-55},"id":108}
                            mihome-vacuum.0
                            2022-11-01 15:55:14.856	debug	Message= {"id":108,"method":"get_network_info"}
                            mihome-vacuum.0
                            2022-11-01 15:55:14.855	debug	setGetStatus {"msg_ver":2,"msg_seq":380,"state":8,"battery":100,"clean_time":38,"clean_area":242500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                            mihome-vacuum.0
                            2022-11-01 15:55:14.855	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":380,"state":8,"battery":100,"clean_time":38,"clean_area":242500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":107}
                            mihome-vacuum.0
                            2022-11-01 15:55:14.849	debug	Message= {"id":107,"method":"get_status"}
                            mihome-vacuum.0
                            2022-11-01 15:55:14.848	debug	get params for stock Vacuum
                            mihome-vacuum.0
                            2022-11-01 15:55:13.438	debug	Receive <<< Helo <<< 21310020000000001329b53563613351ffffffffffffffffffffffffffffffff
                            mihome-vacuum.0
                            2022-11-01 15:55:03.433	debug	Receive <<< Helo <<< 21310020000000001329b53563613347ffffffffffffffffffffffffffffffff
                            mihome-vacuum.0
                            2022-11-01 15:55:00.505	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":106}
                            mihome-vacuum.0
                            2022-11-01 15:55:00.493	debug	Message= {"id":106,"method":"get_carpet_mode"}
                            mihome-vacuum.0
                            2022-11-01 15:55:00.493	debug	Mappointer_updated
                            ioB neu gestartet, tropsdem die alte karte.
                              dirkhe Developer @da_Woody last edited by dirkhe
                              @da_woody das heist du jetzt am Anfang auch "load Map creator" im debug log?
                              und kein
                              "ANVAS package not installed....please install Canvas package manually or disable Map in config see also....."
                              • da_Woody
                                @dirkhe so, adapter gestoppt, log gelöscht, neu gestrartet. ich kann da nix rauslesen... im debug gehts hurtig zur sache.
                                mihome-vacuum.0
                                2022-11-01 16:15:15.688	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":50}
                                mihome-vacuum.0
                                2022-11-01 16:15:15.677	debug	Message= {"id":50,"method":"get_carpet_mode"}
                                mihome-vacuum.0
                                2022-11-01 16:15:15.677	debug	Mappointer_updated
                                mihome-vacuum.0
                                2022-11-01 16:15:15.677	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F8"],"id":49}
                                mihome-vacuum.0
                                2022-11-01 16:15:15.673	debug	Message= {"id":49,"method":"get_map_v1"}
                                mihome-vacuum.0
                                2022-11-01 16:15:15.673	debug	MIIO RECIVE: {"result":[90],"id":48}
                                mihome-vacuum.0
                                2022-11-01 16:15:15.668	debug	Message= {"id":48,"method":"get_sound_volume"}
                                mihome-vacuum.0
                                2022-11-01 16:15:15.573	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-55},"id":47}
                                mihome-vacuum.0
                                2022-11-01 16:15:15.551	debug	Message= {"id":47,"method":"get_network_info"}
                                mihome-vacuum.0
                                2022-11-01 16:15:15.551	debug	setGetStatus {"msg_ver":2,"msg_seq":636,"state":8,"battery":100,"clean_time":62,"clean_area":2010000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                mihome-vacuum.0
                                2022-11-01 16:15:15.551	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":636,"state":8,"battery":100,"clean_time":62,"clean_area":2010000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":46}
                                mihome-vacuum.0
                                2022-11-01 16:15:15.541	debug	Message= {"id":46,"method":"get_status"}
                                mihome-vacuum.0
                                2022-11-01 16:15:15.541	debug	get params for stock Vacuum
                                mihome-vacuum.0
                                2022-11-01 16:15:13.228	debug	Receive <<< Helo <<< 21310020000000001329b53563613801ffffffffffffffffffffffffffffffff
                                mihome-vacuum.0
                                2022-11-01 16:15:03.224	debug	Receive <<< Helo <<< 21310020000000001329b535636137f7ffffffffffffffffffffffffffffffff
                                mihome-vacuum.0
                                2022-11-01 16:14:55.449	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":45}
                                mihome-vacuum.0
                                2022-11-01 16:14:55.439	debug	Message= {"id":45,"method":"get_carpet_mode"}
                                mihome-vacuum.0
                                2022-11-01 16:14:55.439	debug	Mappointer_updated
                                mihome-vacuum.0
                                2022-11-01 16:14:55.438	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F7"],"id":44}
                                mihome-vacuum.0
                                2022-11-01 16:14:55.434	debug	Message= {"id":44,"method":"get_map_v1"}
                                mihome-vacuum.0
                                2022-11-01 16:14:55.434	debug	MIIO RECIVE: {"result":[90],"id":43}
                                mihome-vacuum.0
                                2022-11-01 16:14:55.428	debug	Message= {"id":43,"method":"get_sound_volume"}
                                mihome-vacuum.0
                                2022-11-01 16:14:55.320	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-55},"id":42}
                                mihome-vacuum.0
                                2022-11-01 16:14:55.297	debug	Message= {"id":42,"method":"get_network_info"}
                                mihome-vacuum.0
                                2022-11-01 16:14:55.296	debug	setGetStatus {"msg_ver":2,"msg_seq":635,"state":8,"battery":100,"clean_time":62,"clean_area":2010000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                mihome-vacuum.0
                                2022-11-01 16:14:55.296	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":635,"state":8,"battery":100,"clean_time":62,"clean_area":2010000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":41}
                                mihome-vacuum.0
                                2022-11-01 16:14:55.289	debug	Message= {"id":41,"method":"get_status"}
                                mihome-vacuum.0
                                2022-11-01 16:14:55.289	debug	get params for stock Vacuum
                                mihome-vacuum.0
                                2022-11-01 16:14:53.221	debug	Receive <<< Helo <<< 21310020000000001329b535636137edffffffffffffffffffffffffffffffff
                                mihome-vacuum.0
                                2022-11-01 16:14:43.217	debug	Receive <<< Helo <<< 21310020000000001329b535636137e3ffffffffffffffffffffffffffffffff
                                mihome-vacuum.0
                                2022-11-01 16:14:35.191	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":40}
                                mihome-vacuum.0
                                2022-11-01 16:14:35.182	debug	Message= {"id":40,"method":"get_carpet_mode"}
                                mihome-vacuum.0
                                2022-11-01 16:14:35.181	debug	Mappointer_updated
                                mihome-vacuum.0
                                2022-11-01 16:14:35.181	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F6"],"id":39}
                                mihome-vacuum.0
                                2022-11-01 16:14:35.176	debug	Message= {"id":39,"method":"get_map_v1"}
                                mihome-vacuum.0
                                2022-11-01 16:14:35.175	debug	MIIO RECIVE: {"result":[90],"id":38}
                                mihome-vacuum.0
                                2022-11-01 16:14:35.170	debug	Message= {"id":38,"method":"get_sound_volume"}
                                mihome-vacuum.0
                                2022-11-01 16:14:35.048	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-55},"id":37}
                                mihome-vacuum.0
                                2022-11-01 16:14:35.026	debug	Message= {"id":37,"method":"get_network_info"}
                                mihome-vacuum.0
                                2022-11-01 16:14:35.026	debug	setGetStatus {"msg_ver":2,"msg_seq":634,"state":8,"battery":100,"clean_time":62,"clean_area":2010000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                mihome-vacuum.0
                                2022-11-01 16:14:35.026	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":634,"state":8,"battery":100,"clean_time":62,"clean_area":2010000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":36}
                                mihome-vacuum.0
                                2022-11-01 16:14:35.017	debug	Message= {"id":36,"method":"get_status"}
                                mihome-vacuum.0
                                2022-11-01 16:14:35.017	debug	get params for stock Vacuum
                                mihome-vacuum.0
                                2022-11-01 16:14:33.212	debug	Receive <<< Helo <<< 21310020000000001329b535636137d9ffffffffffffffffffffffffffffffff
                                mihome-vacuum.0
                                2022-11-01 16:14:23.209	debug	Receive <<< Helo <<< 21310020000000001329b535636137cfffffffffffffffffffffffffffffffff
                                mihome-vacuum.0
                                2022-11-01 16:14:14.843	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":35}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.817	debug	finish logs all [{"Datum":"1.11","Start":"15:57","Saugzeit":"1 min","Fläche":"2.01 m²","Error":0,"Ende":false},{"Datum":"1.11","Start":"15:21","Saugzeit":"1 min","Fläche":"0.24 m²","Error":0,"Ende":false},{"Datum":"1.11","Start":"15:13","Saugzeit":"1 min","Fläche":"0.54 m²","Error":0,"Ende":false},{"Datum":"1.11","Start":"14:20","Saugzeit":"4 min","Fläche":"2.33 m²","Error":0,"Ende":false},{"Datum":"28.10","Start":"19:57","Saugzeit":"32 min","Fläche":"22.35 m²","Error":0,"Ende":true},{"Datum":"28.10","Start":"15:18","Saugzeit":"6 min","Fläche":"5.87 m²","Error":8,"Ende":false},{"Datum":"27.10","Start":"12:16","Saugzeit":"2 min","Fläche":"0 m²","Error":8,"Ende":false},{"Datum":"27.10","Start":"12:10","Saugzeit":"5 min","Fläche":"2.22 m²","Error":0,"Ende":false},{"Datum":"13.9","Start":"19:42","Saugzeit":"30 min","Fläche":"24.64 m²","Error":0,"Ende":true},{"Datum":"6.9","Start":"15:18","Saugzeit":"6 min","Fläche":"2 m²","Error":8,"Ende":false},{"Datum":"30.7","Start":"20:43","Saugzeit":"41 min","Fläche":"24.05 m²","Error":0,"Ende":true},{"Datum":"1.7","Start":"16:20","Saugzeit":"22 min","Fläche":"22.3 m²","Error":0,"Ende":true},{"Datum":"9.6","Start":"19:18","Saugzeit":"24 min","Fläche":"24.63 m²","Error":0,"Ende":true},{"Datum":"30.5","Start":"19:26","Saugzeit":"28 min","Fläche":"24.72 m²","Error":0,"Ende":true},{"Datum":"10.5","Start":"15:09","Saugzeit":"25 min","Fläche":"24.65 m²","Error":0,"Ende":true},{"Datum":"6.5","Start":"19:24","Saugzeit":"26 min","Fläche":"24.11 m²","Error":0,"Ende":true},{"Datum":"29.4","Start":"19:33","Saugzeit":"36 min","Fläche":"23.96 m²","Error":0,"Ende":true},{"Datum":"19.2","Start":"19:32","Saugzeit":"1 min","Fläche":"0.51 m²","Error":0,"Ende":false},{"Datum":"23.1","Start":"19:44","Saugzeit":"29 min","Fläche":"25.02 m²","Error":0,"Ende":true},{"Datum":"22.1","Start":"20:13","Saugzeit":"10 min","Fläche":"12.37 m²","Error":0,"Ende":false}]
                                mihome-vacuum.0
                                2022-11-01 16:14:14.817	debug	MIIO RECIVE: {"result":[[1642878816,1642879423,607,12367500,0,0,2,1,60]],"id":34}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.811	debug	Message= {"id":35,"method":"get_carpet_mode"}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.811	info	create state for carpet_mode
                                mihome-vacuum.0
                                2022-11-01 16:14:14.810	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":33}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.806	debug	Message= {"id":34,"method":"get_clean_record","params":[1642878816]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.805	debug	MIIO RECIVE: {"result":[[1642963476,1642965232,1756,25020000,0,1,2,1,52]],"id":32}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.805	debug	Message= {"id":33,"method":"get_carpet_mode"}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.804	debug	Mappointer_updated
                                mihome-vacuum.0
                                2022-11-01 16:14:14.804	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F5"],"id":31}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.799	debug	Message= {"id":32,"method":"get_clean_record","params":[1642963476]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.798	debug	MIIO RECIVE: {"result":[[1645295524,1645295556,32,512500,0,0,2,1,60]],"id":30}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.798	debug	Message= {"id":31,"method":"get_map_v1"}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.798	debug	Startup: Delete setGetConsumable
                                mihome-vacuum.0
                                2022-11-01 16:14:14.795	debug	Startup: setGetConsumable Answer: true
                                mihome-vacuum.0
                                2022-11-01 16:14:14.793	debug	MIIO RECIVE: {"result":[{"main_brush_work_time":42311,"side_brush_work_time":42311,"filter_work_time":42311,"filter_element_work_time":0,"sensor_dirty_time":71453}],"id":29}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.786	debug	Message= {"id":30,"method":"get_clean_record","params":[1645295524]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.786	debug	MIIO RECIVE: {"result":[[1651253588,1651255767,2179,23957500,0,1,2,1,52]],"id":28}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.785	debug	Message= {"id":29,"method":"get_consumable"}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.785	debug	Startup: Delete setGetCleanSummary
                                mihome-vacuum.0
                                2022-11-01 16:14:14.785	debug	Startup: setGetCleanSummary Answer: true
                                mihome-vacuum.0
                                2022-11-01 16:14:14.784	debug	MIIO RECIVE: {"result":[77113,997247500,80,[1667314644,1667312517,1667312033,1667308841,1666979871,1666963083,1666865760,1666865404,1663090972,1662470282,1659206624,1656685244,1654795117,1653931567,1652188174,1651857884,1651253588,1645295524,1642963476,1642878816]],"id":27}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.773	debug	Message= {"id":28,"method":"get_clean_record","params":[1651253588]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.773	debug	MIIO RECIVE: {"result":[[1651857884,1651859471,1587,24110000,0,1,2,1,52]],"id":26}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.770	debug	Message= {"id":27,"method":"get_clean_summary"}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.769	debug	Startup: Delete getMultiMapsList
                                mihome-vacuum.0
                                2022-11-01 16:14:14.768	debug	Startup: getMultiMapsList Answer: true
                                mihome-vacuum.0
                                2022-11-01 16:14:14.767	debug	States for Map: {"0":"0"}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.767	debug	States for 1 Map: [{"mapFlag":0,"add_time":1666981861,"length":0,"name":"","bak_maps":[]}]
                                mihome-vacuum.0
                                2022-11-01 16:14:14.765	debug	MIIO RECIVE: {"result":[{"max_multi_map":1,"max_bak_map":0,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1666981861,"length":0,"name":"","bak_maps":[]}]}],"id":25}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.758	debug	Message= {"id":26,"method":"get_clean_record","params":[1651857884]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.758	debug	MIIO RECIVE: {"result":[[1652188174,1652189692,1518,24647500,0,1,2,1,52]],"id":24}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.752	debug	Message= {"id":25,"method":"get_multi_maps_list"}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.751	debug	MIIO RECIVE: {"result":[90],"id":23}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.748	debug	Message= {"id":24,"method":"get_clean_record","params":[1652188174]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.747	debug	MIIO RECIVE: {"result":[[1653931567,1653933520,1684,24717500,0,1,2,1,52]],"id":22}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.740	debug	Message= {"id":23,"method":"get_sound_volume"}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.739	debug	Message= {"id":22,"method":"get_clean_record","params":[1653931567]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.721	debug	MIIO RECIVE: {"result":[[1654795117,1654796567,1450,24625000,0,1,2,1,52]],"id":21}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.699	debug	Message= {"id":21,"method":"get_clean_record","params":[1654795117]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.699	debug	MIIO RECIVE: {"result":[[1656685244,1656686572,1328,22302500,0,1,2,1,52]],"id":20}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.694	debug	Message= {"id":20,"method":"get_clean_record","params":[1656685244]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.694	debug	MIIO RECIVE: {"result":[[1659206624,1659209105,2481,24045000,0,1,2,1,52]],"id":19}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.688	debug	Message= {"id":19,"method":"get_clean_record","params":[1659206624]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.688	debug	MIIO RECIVE: {"result":[[1662470282,1662514759,383,2000000,8,0,2,1,34]],"id":18}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.684	debug	Message= {"id":18,"method":"get_clean_record","params":[1662470282]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.683	debug	MIIO RECIVE: {"result":[[1663090972,1663093345,1773,24642500,0,1,2,1,52]],"id":17}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.678	debug	Message= {"id":17,"method":"get_clean_record","params":[1663090972]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.678	debug	MIIO RECIVE: {"result":[[1666865404,1666865708,302,2215000,0,0,2,1,60]],"id":16}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.673	debug	Message= {"id":16,"method":"get_clean_record","params":[1666865404]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.672	debug	MIIO RECIVE: {"result":[[1666865760,1666909702,141,0,8,0,2,1,34]],"id":15}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.667	debug	Message= {"id":15,"method":"get_clean_record","params":[1666865760]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.667	debug	MIIO RECIVE: {"result":[[1666963083,1666979819,385,5867500,8,0,2,1,29]],"id":14}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.660	debug	Message= {"id":14,"method":"get_clean_record","params":[1666963083]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.658	debug	MIIO RECIVE: {"result":[[1666979871,1666981820,1949,22352500,0,1,2,1,52]],"id":13}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.649	debug	Message= {"id":13,"method":"get_clean_record","params":[1666979871]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.648	debug	MIIO RECIVE: {"result":[[1667308841,1667311681,232,2332500,0,0,2,1,60]],"id":12}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.623	debug	Message= {"id":12,"method":"get_clean_record","params":[1667308841]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.622	debug	MIIO RECIVE: {"result":[[1667312033,1667312065,32,542500,0,0,2,1,60]],"id":11}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.616	debug	Message= {"id":11,"method":"get_clean_record","params":[1667312033]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.616	debug	MIIO RECIVE: {"result":[[1667312517,1667312555,38,242500,0,0,2,1,60]],"id":10}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.609	debug	Message= {"id":10,"method":"get_clean_record","params":[1667312517]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.609	debug	MIIO RECIVE: {"result":[[1667314644,1667314706,62,2010000,0,0,2,1,60]],"id":9}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.601	debug	Message= {"id":9,"method":"get_clean_record","params":[1667314644]}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.600	debug	MIIO RECIVE: {"result":[77113,997247500,80,[1667314644,1667312517,1667312033,1667308841,1666979871,1666963083,1666865760,1666865404,1663090972,1662470282,1659206624,1656685244,1654795117,1653931567,1652188174,1651857884,1651253588,1645295524,1642963476,1642878816]],"id":8}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.596	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-55},"id":7}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.580	debug	Message= {"id":8,"method":"get_clean_summary"}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.579	debug	MIIO RECIVE: {"result":[{"main_brush_work_time":42311,"side_brush_work_time":42311,"filter_work_time":42311,"filter_element_work_time":0,"sensor_dirty_time":71453}],"id":6}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.574	debug	Message= {"id":7,"method":"get_network_info"}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.573	debug	Message= {"id":6,"method":"get_consumable"}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.572	debug	MIIO RECIVE: {"result":[],"id":5}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.567	debug	Message= {"id":5,"method":"get_room_mapping"}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.566	debug	Mappointer_updated
                                mihome-vacuum.0
                                2022-11-01 16:14:14.566	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F4"],"id":4}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.561	debug	Message= {"id":4,"method":"get_map_v1"}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.260	debug	MIIO RECIVE: {"result":["retry"],"id":3}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.254	debug	Message= {"id":3,"method":"get_map_v1"}
                                mihome-vacuum.0
                                2022-11-01 16:14:14.048	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                mihome-vacuum.0
                                2022-11-01 16:14:13.997	info	create states for water box
                                mihome-vacuum.0
                                2022-11-01 16:14:13.997	info	change states from State control.fan_power
                                mihome-vacuum.0
                                2022-11-01 16:14:13.996	debug	setGetStatus {"msg_ver":2,"msg_seq":633,"state":8,"battery":100,"clean_time":62,"clean_area":2010000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
                                mihome-vacuum.0
                                2022-11-01 16:14:13.996	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":633,"state":8,"battery":100,"clean_time":62,"clean_area":2010000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":2}
                                mihome-vacuum.0
                                2022-11-01 16:14:13.991	info	settest next timer: not available
                                mihome-vacuum.0
                                2022-11-01 16:14:13.989	debug	Message= {"id":2,"method":"get_status"}
                                mihome-vacuum.0
                                2022-11-01 16:14:13.989	debug	get params for stock Vacuum
                                mihome-vacuum.0
                                2022-11-01 16:14:13.989	debug	Create State done!
                                mihome-vacuum.0
                                2022-11-01 16:14:13.989	debug	Create State for map: loadMap
                                mihome-vacuum.0
                                2022-11-01 16:14:13.988	debug	Create State for map: mapURL
                                mihome-vacuum.0
                                2022-11-01 16:14:13.988	debug	Create State for map: mapStatus
                                mihome-vacuum.0
                                2022-11-01 16:14:13.988	debug	Create State for map: actualMap
                                mihome-vacuum.0
                                2022-11-01 16:14:13.988	debug	Create State for map: map64
                                mihome-vacuum.0
                                2022-11-01 16:14:13.948	debug	Create State for map:
                                mihome-vacuum.0
                                2022-11-01 16:14:13.873	debug	Create State for Queue: clearQueue
                                mihome-vacuum.0
                                2022-11-01 16:14:13.872	debug	Create State for Queue: queue
                                mihome-vacuum.0
                                2022-11-01 16:14:13.690	warn	Login failed
                                mihome-vacuum.0
                                2022-11-01 16:14:13.689	debug	Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"","pwd":0,"child":0,"desc":"登录验证失败"}
                                mihome-vacuum.0
                                2022-11-01 16:14:13.524	debug	Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"child":0,"desc":"登录验证失败"}
                                mihome-vacuum.0
                                2022-11-01 16:14:13.349	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                mihome-vacuum.0
                                2022-11-01 16:14:13.327	debug	Xiaomi Cloud: Logging in
                                mihome-vacuum.0
                                2022-11-01 16:14:13.324	info	select standard vacuum protocol....
                                mihome-vacuum.0
                                2022-11-01 16:14:13.324	debug	DeviceModel selected to: roborock.vacuum.a08
                                mihome-vacuum.0
                                2022-11-01 16:14:13.259	debug	Get Device data from robot.. {"hw_ver":"Linux","fw_ver":"3.5.8_1368","ap":{"ssid":"Headquarter","bssid":"80:3f:5d:ae:a7:13","rssi":-52},"netif":{"localIp":"192.168.1.15","mask":"255.255.248.0","gw":"192.168.0.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.a08","mac":"64:90:C1:13:B1:18","token":"544f6b574eXXXXXX":3735}
                                mihome-vacuum.0
                                2022-11-01 16:14:13.259	debug	Get Device data..0
                                mihome-vacuum.0
                                2022-11-01 16:14:13.259	debug	GETMODELFROMAPI:Data: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1368","ap":{"ssid":"Headquarter","bssid":"80:3f:5d:ae:a7:13","rssi":-52},"netif":{"localIp":"192.168.1.15","mask":"255.255.248.0","gw":"192.168.0.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.a08","mac":"64:90:C1:13:B1:18","token":"544f6b574eXXXXXX":3735}}
                                mihome-vacuum.0
                                2022-11-01 16:14:13.259	debug	MIIO RECIVE: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1368","ap":{"ssid":"Headquarter","bssid":"80:3f:5d:ae:a7:13","rssi":-52},"netif":{"localIp":"192.168.1.15","mask":"255.255.248.0","gw":"192.168.0.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.a08","mac":"64:90:C1:13:B1:18","token":"544f6b574e4e5868504d335933373635","life":3735}}
                                mihome-vacuum.0
                                2022-11-01 16:14:13.253	debug	Message= {"id":1,"method":"miIO.info"}
                                mihome-vacuum.0
                                2022-11-01 16:14:13.252	debug	GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.a08","ack":true,"ts":1667314929456,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1640205614333}
                                mihome-vacuum.0
                                2022-11-01 16:14:13.206	debug	MAIN: Connected to device, try to get model..
                                mihome-vacuum.0
                                2022-11-01 16:14:13.205	debug	Receive <<< Helo <<< 21310020000000001329b535636137c5ffffffffffffffffffffffffffffffff
                                mihome-vacuum.0
                                2022-11-01 16:14:13.200	debug	server started on 0.0.0.0:53421
                                mihome-vacuum.0
                                2022-11-01 16:14:13.199	info	IOT enabled, create state
                                mihome-vacuum.0
                                2022-11-01 16:14:13.197	debug	MIIO: Config: ip:192.168.1.15 token: 544f6b574eXXXXXXXXX
                                mihome-vacuum.0
                                2022-11-01 16:14:13.197	debug	Create State for deviceInfowifi_signal
                                mihome-vacuum.0
                                2022-11-01 16:14:13.197	debug	Create State for deviceInfofw_ver
                                mihome-vacuum.0
                                2022-11-01 16:14:13.197	debug	Create State for deviceInfomodel
                                mihome-vacuum.0
                                2022-11-01 16:14:13.196	debug	Create State for deviceInfomac
                                mihome-vacuum.0
                                mihome-vacuum.0
                                2022-11-01 16:14:13.120	debug	load Map creator... true
                                mihome-vacuum.0
                                2022-11-01 16:14:13.087	info	starting. Version 3.8.3 (non-npm: iobroker-community-adapters/ioBroker.mihome-vacuum) in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.17.0, js-controller: 4.0.23
                                mihome-vacuum.0
                                2022-11-01 16:14:12.796	debug	Plugin sentry Initialize Plugin (enabled=true)
                                  @da_woody
                                  Nimm das Token aus dem Log.
                                  €dit: War schon verändert, ich seh's.
                                    da ist das Problem, du kannst dich nicht in die cloud einloggen, warum auch immer
                                      @thomas-braun habe ich jetzt im code gemacht, zeige immer nur die ersten 10 Zeichen + XXXX. Kann ja mal hilfreich sein, wenn man mehrere hat...
                                      • da_Woody
                                        @dirkhe gute frage. das passwort war immer drinnen.
                                        warum da ein anderes drinnen stand? wenn ich jetzt auf "get device" klicke, kein fehler...
                                        und wie durch zauberei:
                                        danke.gif von einem noch zuviel unwissenden...
                                        mihome-vacuum.0
                                        2022-11-01 16:30:45.132	debug	Xiaomi Cloud: Login successful
                                        mihome-vacuum.0
                                        2022-11-01 16:30:45.122	debug	Login step3: [{"key":"userId","value":"6363339872","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-11-01T15:30:45.103Z","lastAccessed":"2022-11-01T15:30:45.122Z"},{"key":"cUserId","value":"Wk6OEyZydMH9GynK--l9q0BrBCg","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-11-01T15:30:45.105Z","lastAccessed":"2022-11-01T15:30:45.122Z"},{"key":"serviceToken","value":"XiC7u4iJjhpMFpCfWbATGVSWq2VCxgx6lTg3aJLc12gog6z5dut+qQyGrQDJstxzaxRh6U0Ul/w2xxQgMNSdK+UM7XulN8BKsHTOlPL+UVvoJkVaEV8b6QA/C0+j6rZM4qjUR6jnN31P4XUTtkxn4g6lbqk7aX8wrsrQQVOQrAg=","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-11-01T15:30:45.110Z","lastAccessed":"2022-11-01T15:30:45.122Z"}]
                                        mihome-vacuum.0
                                        2022-11-01 16:30:44.969	debug	Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"PY7PSsYXvAHRTL6+ltOSxQ==","code":0,"passToken":"V1:DXmurwq2/R1BHTELu6obCZs94kheKAWp0c+OapjBK4xlLT16Y4m5coFz1Qf3fGspZ2baTWVTL3M4eZSAcGxxbndFW5SwEmbtuxOSkaXx3uYYVhMWqm924q+/DQ5O6Ll6jz1HDph5bQoVrBAWPIarFTLtmfBcjZo0IU1I9wE7ZcTti4qVIYKsXWY4uyr1mtyOlZS1N1GwSE1jNrVpDaxPz64+wP6NndqRuwEwPrlgaJ1UB1rAjMBi4yk1sD3hFkaXGhe7niiy+AklXO8cTNUJ8n6fZxp1s5GTk26yQs5HNL8=","description":"成功","securityStatus":0,"nonce":838939435468006400,"userId":6363339872,"cUserId":"Wk6OEyZydMH9GynK--l9q0BrBCg","result":"ok","psecurity":"TXVEVY9mrvKtcLJO0TazhA==","captchaUrl":null,"location":"https://sts.api.io.mi.com/sts?d=rntslw&ticket=0&pwd=1&p_ts=1667316644000&fid=0&p_lm=1&auth=vrYPXm9eBVDU3BWHczoBrJCdjsSqpT9yl%2BH2jOmyjvOdnJCRGp2%2BaxZw8FfEP4aTGgNaizzslBkz0R3O28JHWP3G5x5iVO36JxzyD8CdZ335tkUt1t8pl5yomtb8Ue8Izss5%2BsrUfkzS4VlDqmCA8Ljkwtj6NVW7HaL8RFF32Tc%3D&m=1&_group=DEFAULT&tsl=0&p_ca=0&p_ur=AT&p_idc=Europe&nonce=Qmca5Ef72NIBqAVC&_ssign=ZReaVuK%2BsuBOLPBJ7sODdjhTMrQ%3D","pwd":1,"child":0,"desc":"成功"}
                                        mihome-vacuum.0
                                        2022-11-01 16:30:44.812	debug	Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"child":0,"desc":"登录验证失败"}
                                        mihome-vacuum.0
                                        2022-11-01 16:29:04.116	debug	Xiaomi Cloud: Login successful
                                        mihome-vacuum.0
                                        2022-11-01 16:29:04.115	debug	Login step3: [{"key":"userId","value":"6363339872","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-11-01T15:29:04.101Z","lastAccessed":"2022-11-01T15:29:04.110Z"},{"key":"cUserId","value":"Wk6OEyZydMH9GynK--l9q0BrBCg","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-11-01T15:29:04.104Z","lastAccessed":"2022-11-01T15:29:04.110Z"},{"key":"serviceToken","value":"qhYz9Uf/JsqBHA/+by4wDbA+mT7kqHvreYzAdra4Q4MOv1U/dbHZJJBL+yCwR3nyeC30+wPntHp1iumNCbVZ+hIYlnITHDu7iuvC0Eqwgx4S7odx/jlW2LKjv0cu3w/pCNreN3TnUm52LYoeiob2PcVjKFUmVdFLbquyp1zBSG0=","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-11-01T15:29:04.106Z","lastAccessed":"2022-11-01T15:29:04.110Z"}]
                                        mihome-vacuum.0
                                        2022-11-01 16:29:03.877	debug	Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"qdLvClhT4fWnEVsKvzHaxA==","code":0,"passToken":"V1:DXmurwq2/R1BHTELu6obCSX7/Af4P+j1I3J4sGkAtOtQ3+0+OevoRwV4yAXR6ZcIEFCisumlgeob+GaX28PzGbk7uQkk4nTkCgaocsycQpEw580xSRYvjLMhiz5QQsbcO6lXOwNDEqgIlpdlLgTu2WPlYy31Ynj5TBpYrl9h3ikk5Wyn9BgmyoL7lU5MEKnCaz2KSklJJ1cQWo6Sh/1+oYdEuV/iF6rQ1f609EeXzMdYdUPzDXD10OEWyU9WiYdcJeukV8r63U+yWAneEPlzgyQtjrrmn0CTnfocJ8xbNBo=","description":"成功","securityStatus":0,"nonce":1584612509642027008,"userId":6363339872,"cUserId":"Wk6OEyZydMH9GynK--l9q0BrBCg","result":"ok","psecurity":"3AYWGOeDrpIaxzOEToalow==","captchaUrl":null,"location":"https://sts.api.io.mi.com/sts?d=rntslw&ticket=0&pwd=1&p_ts=1667316543000&fid=0&p_lm=1&auth=NF3nob%2B02HvTV7GA1vMDUWwjn%2Bp5H7ouAOTDPl8P8hl2bZk6Qe%2B1gjezJOJGH3VC5wOLYYMkGCDX8rAvy0y1jFj4%2BoRbYeALjtXU5Nf%2B8ZtKKlHbCPsIIwxftBmXGO5R9C21EIJRKshZgIZgO0t%2FnMmWwqNoDox7%2BgLF8M42%2BYI%3D&m=1&_group=DEFAULT&tsl=0&p_ca=0&p_ur=AT&p_idc=Europe&nonce=9LbLkzUiluwBqAVB&_ssign=g2YtX6aW9E%2BjdG%2Fns1cPNZGrGGk%3D","pwd":1,"child":0,"desc":"成功"}
                                        mihome-vacuum.0
                                        2022-11-01 16:29:03.674	debug	Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"child":0,"desc":"登录验证失败"}
                                          @da_woody Das mit den Farben kommt vom meisterTR, glaube ich, da waren Änderungen an den Farben. Er hat ja jetzt auch Teppich mit drin und so.
                                          Aber gut, wenn es jetzt geht
                                            @dirkhe
                                            Der Adapter knüppelt mir immer noch das Log voll:
                                            2022-11-01 17:47:58.990  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 17:47:58.991  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 17:47:58.992  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 17:47:59.292  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 17:47:59.593  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 17:47:59.894  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 17:48:00.195  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 17:48:00.496  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 17:48:06.457  - info: mihome-vacuum.0 (234862) select standard vacuum protocol....
                                            2022-11-01 17:48:07.035  - info: mihome-vacuum.0 (234862) settest next timer: not available
                                            2022-11-01 17:48:25.438  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 17:48:25.977  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 17:49:55.616  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 17:53:26.494  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 17:59:27.661  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 17:59:57.783  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:01:28.323  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:01:29.942  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:01:29.943  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:01:29.944  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:01:30.245  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:01:30.546  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:01:30.848  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:01:31.149  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:01:31.450  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:01:35.751  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:01:35.752  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:01:35.753  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:01:36.054  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:01:36.355  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:01:36.656  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:01:36.957  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:01:37.258  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:01:38.921  - info: mihome-vacuum.0 (234862) select standard vacuum protocol....
                                            2022-11-01 18:01:39.504  - info: mihome-vacuum.0 (234862) settest next timer: not available
                                            2022-11-01 18:05:28.351  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:06:59.359  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:12:29.868  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:14:00.691  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:15:00.136  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:17:00.663  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:18:00.767  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:18:01.383  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:19:01.675  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:19:31.099  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:19:37.859  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:19:37.860  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:19:38.162  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:19:38.463  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:19:38.764  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:19:39.065  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:19:39.366  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:19:42.231  - info: mihome-vacuum.0 (234862) select standard vacuum protocol....
                                            2022-11-01 18:19:42.765  - info: mihome-vacuum.0 (234862) settest next timer: not available
                                            2022-11-01 18:22:02.079  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:23:09.419  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:28:02.848  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:29:32.945  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:31:03.405  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:34:50.197  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:34:52.198  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:34:54.201  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:34:56.202  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:34:56.495  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:34:56.496  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:34:56.498  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:34:56.499  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:34:56.503  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:34:56.800  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:34:56.805  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:34:57.101  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:34:57.107  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:34:57.403  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:34:57.410  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:34:57.705  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:34:57.712  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:34:58.007  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:34:58.496  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:34:58.500  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:34:58.501  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:34:58.505  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:34:59.995  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:34:59.997  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:34:59.998  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:34:59.999  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:35:00.300  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:35:00.601  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:35:00.903  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:35:01.204  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:35:01.505  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:35:01.627  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:35:01.628  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:35:01.932  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:35:02.233  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:35:02.534  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:35:02.836  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:35:03.137  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:35:03.933  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:35:04.234  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:35:04.535  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:35:05.071  - info: mihome-vacuum.0 (234862) select standard vacuum protocol....
                                            2022-11-01 18:35:05.663  - info: mihome-vacuum.0 (234862) settest next timer: not available
                                            2022-11-01 18:36:04.507  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:36:34.471  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:40:05.252  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:40:05.490  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:43:35.747  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:45:36.253  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:45:36.442  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:47:36.693  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:48:36.528  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:48:37.071  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:49:36.547  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:49:37.679  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:38.204  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:38.205  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:38.206  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:38.207  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:38.508  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:38.809  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:38.955  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:38.956  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:39.110  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:39.257  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:39.411  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:39.558  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:39.712  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:39.859  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:40.160  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:40.462  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:40.730  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:40.731  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:40.929  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:40.930  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:40.931  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:41.032  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:41.232  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:41.333  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:41.534  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:41.634  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:41.835  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:41.935  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:42.136  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:42.236  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:42.438  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:42.630  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:42.631  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:42.632  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:42.934  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:43.235  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:43.537  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:43.838  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:44.140  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 18:49:47.746  - info: mihome-vacuum.0 (234862) select standard vacuum protocol....
                                            2022-11-01 18:49:48.290  - info: mihome-vacuum.0 (234862) settest next timer: not available
                                            2022-11-01 18:51:37.023  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 18:58:32.389  - error: parcel.0 (89450) AxiosError: Request failed with status code 429
                                            2022-11-01 18:58:32.392  - error: parcel.0 (89450) {"response":{"errors":[{"code":"10429","message":"Too Many Requests"}]}}
                                            2022-11-01 18:58:38.895  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 19:00:09.042  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 19:01:39.428  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 19:02:11.299  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 19:02:11.301  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 19:02:11.302  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 19:02:11.303  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 19:02:11.604  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 19:02:11.907  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 19:02:12.208  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 19:02:12.509  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 19:02:12.811  - error: mihome-vacuum.0 (234862) sendMessage throws error ==>not connected
                                            2022-11-01 19:02:20.063  - info: mihome-vacuum.0 (234862) select standard vacuum protocol....
                                            2022-11-01 19:02:20.646  - info: mihome-vacuum.0 (234862) settest next timer: not available
                                            2022-11-01 19:03:39.625  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 19:05:39.350  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 19:05:39.455  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 19:07:09.672  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 19:07:10.500  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 19:09:40.520  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 19:09:40.743  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 19:12:11.016  - warn: mihome-vacuum.0 (234862) your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                                            2022-11-01 19:13:48.898  - info: parcel.0 (89450) ups receive 401 error. Refresh Token in 60 seconds
                                            Dabei ist da eigentlich alles ausgeschaltet. Map deaktiviert, die anderen Dinge alle auf 0.
                                            Vumer 1 Reply Last reply Reply Quote 0
                                            129
                                            9948
