    2. Русский
    3. ioBroker
    4. Скрипты
    5. ioBroker скрипты
    6. Скрипт для счётчика
    Скрипт для счётчика
      smoker_vvo last edited by
      Что то не прет компиляция….Electro_Counter2, код взят с Githuba
      ! Arduino: 1.8.2 (Windows 7), Плата:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\count.ino:6:0: warning: "PWR_CTRL" redefined
      ! #define PWR_CTRL A0
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:7:0: note: this is the location of the previous definition
      ! #define PWR_CTRL A2 //Контроль напряжения
      ! count:14: error: conflicting declaration 'volatile long unsigned int cnt'
      ! volatile unsigned long cnt = 1 ;
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:34:15: note: previous declaration as 'long unsigned int cnt'
      ! unsigned long cnt = 0;
      ! count:15: error: conflicting declaration 'volatile long unsigned int prev_cnt'
      ! volatile unsigned long prev_cnt = 0;
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:35:15: note: previous declaration as 'long unsigned int prev_cnt'
      ! unsigned long prev_cnt = 2;
      ! count:16: error: conflicting declaration 'volatile long unsigned int pwr'
      ! volatile unsigned long pwr = 0;
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:36:15: note: previous declaration as 'long unsigned int pwr'
      ! unsigned long pwr = 0;
      ! count:17: error: conflicting declaration 'volatile long unsigned int prev_pwr'
      ! volatile unsigned long prev_pwr = 1;
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:37:15: note: previous declaration as 'long unsigned int prev_pwr'
      ! unsigned long prev_pwr = 2;
      ! count:18: error: conflicting declaration 'long unsigned int chk'
      ! unsigned long chk = 0;
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:44:5: note: previous declaration as 'int chk'
      ! int chk = 0;
      ! count:19: error: redefinition of 'int num'
      ! int num = 3200;
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:40:5: note: 'int num' previously defined here
      ! int num = 0;
      ! count:21: error: redefinition of 'int amp'
      ! int amp = 0;
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:38:5: note: 'int amp' previously defined here
      ! int amp = 0;
      ! count:22: error: redefinition of 'int prev_amp'
      ! int prev_amp = 0;
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:39:5: note: 'int prev_amp' previously defined here
      ! int prev_amp = 2;
      ! count:23: error: redefinition of 'int bounce'
      ! int bounce = 1;
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:42:5: note: 'int bounce' previously defined here
      ! int bounce = 10;
      ! count:31: error: redefinition of 'String cmd'
      ! String cmd = "";
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:50:8: note: 'String cmd' previously declared here
      ! String cmd = "";
      ! count:32: error: redefinition of 'bool strComplete'
      ! bool strComplete = false;
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:51:6: note: 'bool strComplete' previously defined here
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\count.ino: In function 'void setup()':
      ! count:35: error: redefinition of 'void setup()'
      ! void setup() {
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:67:6: note: 'void setup()' previously defined here
      ! void setup() {
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\count.ino: In function 'void loop()':
      ! count:60: error: redefinition of 'void loop()'
      ! void loop() {
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:265:6: note: 'void loop()' previously defined here
      ! void loop() {
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\count.ino: In function 'void serialEvent()':
      ! count:129: error: redefinition of 'void serialEvent()'
      ! void serialEvent() {
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:111:6: note: 'void serialEvent()' previously defined here
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\count.ino: In function 'void save()':
      ! count:139: error: redefinition of 'void save()'
      ! void save() {
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:175:6: note: 'void save()' previously defined here
      ! void save() {
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\count.ino: In function 'void EEPROMWriteLong(int, long unsigned int)':
      ! count:150: error: redefinition of 'void EEPROMWriteLong(int, long unsigned int)'
      ! void EEPROMWriteLong(int p_address, unsigned long p_value) {
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:195:6: note: 'void EEPROMWriteLong(int, long unsigned int)' previously defined here
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\count.ino: In function 'long unsigned int EEPROMReadLong(int)':
      ! count:161: error: redefinition of 'long unsigned int EEPROMReadLong(int)'
      ! unsigned long EEPROMReadLong(int p_address) {
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:206:15: note: 'long unsigned int EEPROMReadLong(int)' previously defined here
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\count.ino: In function 'void EEPROMWriteInt(int, int)':
      ! count:169: error: redefinition of 'void EEPROMWriteInt(int, int)'
      ! void EEPROMWriteInt(int p_address, int p_value) {
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:214:6: note: 'void EEPROMWriteInt(int, int)' previously defined here
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\count.ino: In function 'unsigned int EEPROMReadInt(int)':
      ! count:175: error: redefinition of 'unsigned int EEPROMReadInt(int)'
      ! unsigned int EEPROMReadInt(int p_address) {
      ! F:\Arduino MDM\Electro_Counter2-master\mqtt\mqtt.ino:220:14: note: 'unsigned int EEPROMReadInt(int)' previously defined here
      ! Несколько библиотек найдено для "SPI.h"
      ! Используется: C:\Users\5\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\libraries\SPI
      ! Не используется: C:\Program Files (x86)\Arduino\libraries\SPI
      ! Несколько библиотек найдено для "PubSubClient.h"
      ! Используется: C:\Users\5\Documents\Arduino\libraries\PubSubClient
      ! Не используется: C:\Program Files (x86)\Arduino\libraries\PubSubClient
      ! Несколько библиотек найдено для "EEPROM.h"
      ! Используется: C:\Users\5\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\libraries\EEPROM
      ! Не используется: C:\Program Files (x86)\Arduino\libraries\EEPROM
      ! exit status 1
      ! conflicting declaration 'volatile long unsigned int cnt'
      ! Этот отчёт будет иметь больше информации с
      ! включенной опцией Файл -> Настройки ->
      ! "Показать подробный вывод во время компиляции"
      • I
        instalator last edited by
        @smoker_vvo:
        ! int chk = 0;
        ! int num = 3200;
        ! int num = 0;
        ! int amp = 0;
        ! int amp = 0;
        ! int prev_amp = 0;
        ! int prev_amp = 2;
        ! int bounce = 1;
        ! int bounce = 10;
        ! String cmd = "";
        ! String cmd = "";
        ! void setup() {
        ! void setup() {
        ! void loop() {
        ! void loop() {
        ! void save() {
        ! void save() {
        ! exit status 1
        ! "Показать подробный вывод во время компиляции" `
        Потому что там два разных скетча.
        Один непосредственно для счетчика, второй для второго мк который для связи
          Таааак…. А вот с этого места поподробнее... Если я правильно понимаю, одна сборка снимает показания и передает их другой сборке, которая по MQTT их публикует.... Эт получается надо пару ардуин вешать?? А как обмен между ними организован??
          Сечас я использую одну 2560 для обработки температуры, датчиков освещения и контроля за насосом и промсетью, а на второй 2560 пытаюсь сделать счетчик КВт.....
          и возможно на нее же посажу управление вентиляцией и освещением...
            И еще, хотелось бы схемку, подключения счетчика…..
            Да, по отдельности оба скетча скомпилились без проблем...
              Обновил информацию по статье на твоем Блоге, но не дружу с UART, как это выглядит для домохозяек….
              • I
                @smoker_vvo:
                и возможно на нее же посажу управление вентиляцией и освещением... `
                Импульсы считает отдельный МК, сделано для того чтобы не пропускались импульсы и ни на что другое не влияло. Выдает данные на уарт, второй МК принимает эти данные и шлёт уже по mqtt.
                Возьми для счётчика например ардуиной про мини и ей считай только импульсы. А вся остальная логика - mqtt, датчики и ТД и тп
                  Попробовал залить скетч Count в 2560…. Результат отрицательный, в сериал ни чего не летит.... ПРверял Монитором порта от IDE Arduino 1.6.13.
                  Я правильно понимаю что один выход счетчика подключаем к А0, второй к GND или я не прав.
                  Вот типовая схема счетчика
                  • I
                    @smoker_vvo:
                    Вот типовая схема счетчика `
                    Нет, вход идет на вход прерывания INT0.
                      Все, сдаюсь. Ткните носом - куда подключать выводы от счетчика…. INT0- это какая нога(pin) на 2560, 21? или я уже ни чего не понимаю
                      И где в скетче это прописано....
                      Считывание идет, как я вижу со 2 pin.....
                      #include <eeprom.h>
                      #include <avr wdt.h="">
                      #include <avr io.h="">
                      #include <avr interrupt.h="">
                      #define CNT_ADR 10
                      #define PWR_ADR 20
                      #define IMP_ADR 30
                      #define BNC_ADR 40
                      #define NUM_ADR 50
                      #define CHK_ADR 100
                      int num = 3200;
                      int imp = 0;
                      int amp = 0;
                      int prev_amp = 0;
                      int bounce = 1;
                      unsigned long prev;
                      volatile unsigned long prev_millis;
                      volatile unsigned long cur_tmS = millis();
                      volatile unsigned long pre_tmS = cur_tmS;
                      volatile float diffS = 0;
                      volatile unsigned long tm_diffS = 0;
                      bool err = false;
                      String cmd = "";
                      void setup() {
                      MCUSR = 0;
                      wdt_disable();
                      Serial.begin(115200);
                      cmd.reserve(200);
                      Serial.print("Start");
                      pinMode(2, INPUT);
                      digitalWrite(2, HIGH);
                      delay(200);
                      if (EEPROM.read(1) != 88) { //Если первый запуск
                      EEPROM.write(1, 88);
                      } else {
                      chk = EEPROMReadLong(CHK_ADR);
                      cnt = EEPROMReadLong(CNT_ADR);
                      pwr = EEPROMReadLong(PWR_ADR);
                      imp = EEPROMReadInt(IMP_ADR);
                      num = EEPROMReadInt(NUM_ADR);
                      bounce = EEPROMReadInt(BNC_ADR);
                      if (chk != cnt + imp + bounce) {
                      err = true;
                      wdt_enable(WDTO_8S);
                      attachInterrupt(0, count, FALLING);
                      ! void loop() {
                      wdt_reset();
                      if (analogRead(PWR_CTRL) < 1000) {
                      save();
                      ! if (strComplete) {
                      // Serial.println(inputString);
                      if (cmd.substring(0, 1) == "S") {
                      if (cmd.substring(1, 2) == "N") {
                      num = cmd.substring(cmd.lastIndexOf('N') + 1).toInt();
                      else if (cmd.substring(1, 2) == "S") {
                      save();
                      else if (cmd.substring(1, 2) == "C") {
                      cnt = atol(cmd.substring(cmd.lastIndexOf('C') + 1).c_str());
                      else if (cmd.substring(1, 2) == "B") {
                      bounce = cmd.substring(cmd.lastIndexOf('B') + 1).toInt();
                      save();
                      cmd = "";
                      ! tm_diffS = cur_tmS - pre_tmS;
                      diffS = (float(tm_diffS) / 1000);
                      pwr = 3600000 / (num * diffS);
                      if ((cnt != prev_cnt || amp != prev_amp || pwr >= (prev_pwr + 10) || pwr <= (prev_pwr - 10)) && pwr > 0 && millis() - 2000 > prev) {
                      prev = millis();
                      Serial.print(cnt);
                      Serial.print(";");
                      if (pwr > (prev_pwr + 4000)) {
                      Serial.print(prev_pwr);
                      } else {
                      Serial.print(pwr);
                      Serial.print(";");
                      Serial.print(amp);
                      Serial.print(";");
                      Serial.print(bounce);
                      Serial.print(";");
                      Serial.print(num);
                      Serial.print(";");
                      Serial.print(err);
                      Serial.print('\n');
                      prev_cnt = cnt;
                      prev_amp = amp;
                      prev_pwr = pwr;
                      ! void count() {
                      detachInterrupt(0);
                      if (millis() - bounce > prev_millis) {
                      prev_millis = millis();
                      pre_tmS = cur_tmS;
                      cur_tmS = millis();
                      imp++;
                      if (imp >= num) {
                      imp = 0;
                      cnt++;
                      while (Serial.available() > 0) {
                      char inChar = (char)Serial.read();
                      cmd += inChar;
                      if (inChar == '\n') {
                      strComplete = true;
                      ! void save() {
                      chk = cnt + imp + bounce;
                      EEPROMWriteLong(CNT_ADR, cnt);
                      EEPROMWriteLong(PWR_ADR, pwr);
                      EEPROMWriteInt(IMP_ADR, imp);
                      EEPROMWriteInt(NUM_ADR, num);
                      EEPROMWriteInt(BNC_ADR, bounce);
                      EEPROMWriteLong(CHK_ADR, chk);
                      byte four = (p_value & 0xFF);
                      byte three = ((p_value >> 😎 & 0xFF);
                      byte two = ((p_value >> 16) & 0xFF);
                      byte one = ((p_value >> 24) & 0xFF);
                      EEPROM.write(p_address, four);
                      EEPROM.write(p_address + 1, three);
                      EEPROM.write(p_address + 2, two);
                      EEPROM.write(p_address + 3, one);
                      long four = EEPROM.read(p_address);
                      long three = EEPROM.read(p_address + 1);
                      long two = EEPROM.read(p_address + 2);
                      long one = EEPROM.read(p_address + 3);
                      return ((four << 0) & 0xFF) + ((three << 😎 & 0xFFFF) + ((two << 16) & 0xFFFFFF) + ((one << 24) & 0xFFFFFFFF);
                      byte lowByte = ((p_value >> 0) & 0xFF);
                      byte highByte = ((p_value >> 😎 & 0xFF);
                      EEPROM.write(p_address, lowByte);
                      EEPROM.write(p_address + 1, highByte);
                      byte lowByte = EEPROM.read(p_address);
                      byte highByte = EEPROM.read(p_address + 1);
                      return ((lowByte << 0) & 0xFF) + ((highByte << 😎 & 0xFF00);
                      }</avr></avr></avr></eeprom.h>
                        Хотя…. отключив логику и перелистав ДатаШИТ на 2560, понимаю что INT0 - это pin2 (RX0)
                        и тогда, о чудо.... я увидел вот это....
                        4278188031;4294427971;0;-5;-5;1
                        4278188031;4294427161;0;-5;-5;1
                        4278188031;4294414725;0;-5;-5;1
                        4278188031;4294429983;0;-5;-5;1
                        4278188031;4294433568;0;-5;-5;1
                        4278188031;4294428374;0;-5;-5;1
                        4278188031;4294415995;0;-5;-5;1
                        4278188031;4294428777;0;-5;-5;1
                        4278188031;4294413876;0;-5;-5;1
                        4278188031;4294422667;0;-5;-5;1
                        4278188031;4294426350;0;-5;-5;1
                        4278188031;4294425128;0;-5;-5;1
                        Это то что я ищу???
                        • I
                          @smoker_vvo:
                          Это то что я ищу??? `  да, только надо конфиг задать через уарт
                            как? И еще вопрос, просто хочется оперативно посмотреть результаты….
                            Как объединить этот код
                            `#include <spi.h> // Ethernet shield
                            #include <ethernet.h> // Ethernet shield
                            #include <pubsubclient.h> // MQTT
                            #include <servo.h>
                            #include <dht.h>
                            #include <onewire.h>
                            #include <dallastemperature.h>
                            Servo servo;
                            ! byte mac[] = { 0xC1, 0x7C, 0x38, 0x41, 0x89, 0x15 };
                            byte server[] = { 192, 168, 10, 15 }; //IP Брокера
                            byte ip[] = { 192, 168, 10, 88 }; //IP Клиента (Arduino)
                            void callback(char* topic, byte* payload, unsigned int length) {
                            payload[length] = '\0';
                            // Serial.print(topic);
                            // Serial.print("=");
                            String strTopic = String(topic);
                            String strPayload = String((char*)payload);
                            // Serial.println(strPayload);
                            callback_iobroker(strTopic, strPayload);
                            ! EthernetClient ethClient;
                            PubSubClient client(server, 1883, callback, ethClient);
                            #define id_connect "myhome-temp"
                            #define id_connect "myhome-status"
                            #define Prefix_subscribe "myhome/Temp/"
                            #define Prefix_subscribe "myhome/Status/"
                            ! ///////////////Объявляем порты ввода-вывода
                            #define ServoPin 3 //Порт к которому подключен сервопривод
                            ! const int start_DI_pin []= {2, 4, 5}; // Порты Ввода
                            int n_DI_pin = sizeof(start_DI_pin) / sizeof(start_DI_pin[0])-1; //Вычисляем длинну массива
                            ! const int start_DO_pin []= {6, 7}; //Порты Вывода
                            int n_DO_pin = sizeof(start_DO_pin) / sizeof(start_DO_pin[0])-1; //Вычисляем длинну массива
                            ! int DI[] = {0, 0, 0};
                            int old_DI[] = {0, 0, 0};
                            ! ///////////////////////////Переменные для работы с освещением//////////////////////////////////////
                            int ServoAngle = 100; //Угол сервопривода при включении
                            int flag = 0;
                            int flag2 = 0;
                            int pause = 0;
                            ! //------------------------------------------- Sensors -------------------------------------------//
                            const int MQ7_Pin = A0; // Куда подключили MQ7
                            //int MQ7Value = 0;
                            int MQ7Value = analogRead(MQ7_Pin);
                            const int foto_Pin = A1; // устанавливаем входную ногу для Фоторезистора
                            //unsigned int fotoValue = 0; // цифровое значение фоторезистора
                            unsigned int fotoValue = analogRead(foto_Pin);
                            ! #define ONE_WIRE_BUS 8
                            //#define TEMPERATURE_PRECISION 9
                            OneWire oneWire(ONE_WIRE_BUS);
                            DallasTemperature DS_sensors(&oneWire);
                            // 28 80 E9 3A 04 00 00 10
                            //T0:28 88 AD D7 02 00 00 42
                            //T1:28 14 A5 D7 02 00 00 B0
                            //T2:28 72 26 7B 04 00 00 2E
                            //T3:28 CA 1A 3B 04 00 00 CD
                            //T4:28 E6 D5 D7 02 00 00 C1
                            //T5:28 16 B4 7A 04 00 00 8A
                            //T6:28 2B 86 D7 02 00 00 CF
                            //T7:28 AB 9D D7 02 00 00 29
                            DeviceAddress addr_T1 = { 0x28, 0x80, 0xE9, 0x3A, 0x4, 0x0, 0x0, 0x10 };//кладовка
                            DeviceAddress addr_T2 = { 0x28, 0x88, 0xAD, 0xD7, 0x2, 0x0, 0x0, 0x42 };//кухня
                            DeviceAddress addr_T3 = { 0x28, 0x14, 0xA5, 0xD7, 0x2, 0x0, 0x0, 0xB0 };//детская
                            DeviceAddress addr_T4 = { 0x28, 0x72, 0x26, 0x7B, 0x4, 0x0, 0x0, 0x2E };//гараж
                            DeviceAddress addr_T5 = { 0x28, 0xCA, 0x1A, 0x3B, 0x4, 0x0, 0x0, 0xCD };//ванная
                            DeviceAddress addr_T6 = { 0x28, 0xE6, 0xD5, 0xD7, 0x2, 0x0, 0x0, 0xC1 };//улица
                            DeviceAddress addr_T7 = { 0x28, 0x16, 0xB4, 0x7A, 0x4, 0x0, 0x0, 0x8A };//спальня2
                            DeviceAddress addr_T8 = { 0x28, 0x2B, 0x86, 0xD7, 0x2, 0x0, 0x0, 0xCF };//зал
                            DeviceAddress addr_T9 = { 0x28, 0xAB, 0x9D, 0xD7, 0x2, 0x0, 0x0, 0x29 };//мансарда
                            ! float T1=0;
                            float T2=0;
                            float T3=0;
                            float T4=0;
                            float T5=0;
                            float T6=0;
                            float T7=0;
                            float T8=0;
                            float T9=0;
                            ! //dht DHT;
                            //#define DHT22_PIN 9
                            //float Hout = 0;
                            //float Tout = 0;
                            //void callback(char* topic, byte* payload, unsigned int length) {
                            // payload[length] = '\0';
                            // String strTopic = String(topic);
                            // String strPayload = String((char*)payload);
                            // callback_iobroker(strTopic, strPayload);
                            void setup() {
                            Serial.begin(57600);
                            Serial.println("start");
                            Serial.print("Locating devices...");
                            DS_sensors.begin();
                            Serial.print("Found ");
                            Serial.print(DS_sensors.getDeviceCount(), DEC);
                            Serial.println(" devices.");
                            ! // report parasite power requirements
                            Serial.print("Parasite power is: ");
                            if (DS_sensors.isParasitePowerMode()) Serial.println("ON");
                            else Serial.println("OFF");
                            //Объявляем порты Digital inputs/outputs
                            for(int i=0 ;i<=n_DI_pin; i++) { pinMode (start_DI_pin [i], INPUT); }
                            digitalWrite(5, HIGH); //Насос скважины
                            digitalWrite(4, HIGH); //Электрика
                            for(int i=0 ;i<=n_DO_pin; i++) { pinMode (start_DO_pin [i], OUTPUT); }
                            ! Ethernet.begin(mac, ip);
                            if (client.connect(id_connect)) {
                            getSensors();
                            control();
                            //client.publish("myhome/Kitchen/Change_Counter", "0");
                            //client.publish("myhome/Kitchen/Temp_room", "0");
                            //client.publish("myhome/Kitchen/Humidity_room", "0");
                            client.publish("myhome/Temp/Kladovka", "0");
                            client.publish("myhome/Temp/Kitchen", "0");
                            client.publish("myhome/Temp/Detskaya", "0");
                            client.publish("myhome/Temp/Garage", "0");
                            client.publish("myhome/Temp/Street", "0");
                            client.publish("myhome/Temp/Spalnya2", "0");
                            client.publish("myhome/Temp/Zal", "0");
                            client.publish("myhome/Temp/Mansarda", "0");
                            client.publish("myhome/Temp/Vannaya", "0");
                            //client.publish("myhome/Kitchen/Lux", "0");
                            //client.publish("myhome/Kitchen/Servo", "0");
                            client.publish("myhome/Temp/MQ7", "0");
                            client.publish("myhome/Status/Power", "0");
                            client.publish("myhome/Status/Pompe", "0");
                            client.subscribe("myhome/Temp/#");
                            client.subscribe("myhome/Status/#");
                            void loop() {
                            client.loop();
                            control();
                            getSensors();
                            if (!client.connected()) {
                            control();
                            getSensors();
                            }</dallastemperature.h></onewire.h></dht.h></servo.h></pubsubclient.h></ethernet.h></spi.h>`
                            ! function.ino
                            `[code]//--------------------------------- Functions ---------------------------------//
                            /////////////////////////////////От Брокера//////////////////////////////////////////////
                            void callback_iobroker(String strTopic, String strPayload){
                            if (strTopic == "myhome/Kitchen/Servo"){
                            ServoAngle=strPayload.toInt();
                            if (ServoAngle >= 0 && ServoAngle <= 255){
                            servo.attach(ServoPin);
                            //delay(200); //ждем 2 секунды
                            servo.write(ServoAngle); //ставим вал под 0
                            delay(1000); //ждем 2 секунды
                            //client.publish("myhome/Kitchen/Servo", b);
                            servo.detach();
                            ! ////////////////////////////////////Брокеру/////////////////////////////////////
                            void control(){
                               if(digitalRead(5)==HIGH && flag==0) { //если насос включен
                                  client.publish("myhome/Status/Pompe", "1");
                                  flag=1;
                               if(digitalRead(5)==LOW && flag==1){//если насос выключен
                                flag=0;//обнуляем переменную flag
                               if(digitalRead(4)==HIGH && flag2==0) { // Если электрика есть
                                  client.publish("myhome/Status/Power", "1");
                                  flag2=1;
                               if(digitalRead(4)==LOW && flag2==1){// Если эректрики нет
                                flag2=0;//обнуляем переменную flag
                            ///////////////////////////////Данные сенсоров////////////////////////////////////
                            ! void getSensors () {
                            ! MQ7Value = analogRead(MQ7_Pin);
                            fotoValue = analogRead(foto_Pin); // считываем значение с фоторезистора
                            // ServoAngle = analogRead(2);
                            ! //Обработка данных датчика DHT22. Подключение к порту цифровому P9 Arduino
                            //Глобальные переменные Hout и Tout типа флоат - влажность (%) и температура (град. С)
                            // if (DHT.read22(DHT22_PIN)== DHTLIB_OK) {
                            // Hout = DHT.humidity;
                            // Tout = DHT.temperature;
                            // if (Hout == 0 || Tout == 0){
                            // delay (1000);
                            //Обработка данных цифровых датчиков температуры типа DS18B20.
                            //Шина 1-Wire на цифровой пин P8 Arduino.
                            //Подключено 2 датчика температуры, адреса задаются в секции глобальных констант "Sensors"
                            //Три значение температуры T1, T2, типа float (град. С).
                            DS_sensors.setResolution(addr_T1, 9);
                            DS_sensors.setResolution(addr_T2, 9);
                            DS_sensors.setResolution(addr_T3, 9);
                            DS_sensors.setResolution(addr_T4, 9);
                            DS_sensors.setResolution(addr_T5, 9);
                            DS_sensors.setResolution(addr_T6, 9);
                            DS_sensors.setResolution(addr_T7, 9);
                            DS_sensors.setResolution(addr_T8, 9);
                            DS_sensors.setResolution(addr_T9, 9);
                            float T1 = DS_sensors.getTempC(addr_T1);
                            float T2 = DS_sensors.getTempC(addr_T2);
                            float T3 = DS_sensors.getTempC(addr_T3);
                            float T4 = DS_sensors.getTempC(addr_T4);
                            float T5 = DS_sensors.getTempC(addr_T5);
                            float T6 = DS_sensors.getTempC(addr_T6);
                            float T7 = DS_sensors.getTempC(addr_T7);
                            float T8 = DS_sensors.getTempC(addr_T8);
                            float T9 = DS_sensors.getTempC(addr_T9);
                            DS_sensors.requestTemperatures();
                            //Serial.print(DS_sensors.getResolution(addr_T1), DEC);
                            Serial.println();
                            Serial.print("Temp T1 😄 ");
                            Serial.print(T1);
                            Serial.println();
                            ! Serial.println();
                            Serial.print("Temp T2 😄 ");
                            Serial.print(T2);
                            Serial.println();
                            Serial.println();
                            Serial.print("Temp T3 😄 ");
                            Serial.print(T3);
                            Serial.println();
                            Serial.println();
                            Serial.print("Temp T4 😄 ");
                            Serial.print(T4);
                            Serial.println();
                            Serial.println();
                            Serial.print("Temp T5 😄 ");
                            Serial.print(T5);
                            Serial.println();
                            Serial.println();
                            Serial.print("Temp T6 😄 ");
                            Serial.print(T6);
                            Serial.println();
                            Serial.println();
                            Serial.print("Temp T7 😄 ");
                            Serial.print(T7);
                            Serial.println();
                            Serial.println();
                            Serial.print("Temp T8 😄 ");
                            Serial.print(T8);
                            Serial.println();
                            Serial.println();
                            Serial.print("Temp T9 😄 ");
                            Serial.print(T9);
                            Serial.println();
                            ///////////////////////Паблик данных сенсоров////////////////////////
                            if (pause == 50 || pause == 0){
                            char b[5];
                            // String char_Hout = String(Hout);
                            // char_Hout.toCharArray(b,5);
                            // client.publish("myhome/Kitchen/Humidity_room", b);
                            // String char_Tout = String(Tout);
                            // char_Tout.toCharArray(b,5);
                            // client.publish("myhome/Kitchen/Temp_room", b);
                            String char_T1 = String(T1);
                            char_T1.toCharArray(b,5);
                            client.publish("myhome/Temp/Kladovka", b);
                            String char_T2 = String(T2);
                            char_T2.toCharArray(b,5);
                            client.publish("myhome/Temp/Kitchen", b);
                            String char_T3 = String(T3);
                            char_T3.toCharArray(b,5);
                            client.publish("myhome/Temp/Detskaya", b);
                            String char_T4 = String(T4);
                            char_T4.toCharArray(b,5);
                            client.publish("myhome/Temp/Garage", b);
                            String char_T5 = String(T5);
                            char_T5.toCharArray(b,5);
                            client.publish("myhome/Temp/Vannaya", b);
                            String char_T6 = String(T6);
                            char_T6.toCharArray(b,5);
                            client.publish("myhome/Temp/Street", b);
                            String char_T7 = String(T7);
                            char_T7.toCharArray(b,5);
                            client.publish("myhome/Temp/Spalnya2", b);
                            String char_T8 = String(T8);
                            char_T8.toCharArray(b,5);
                            client.publish("myhome/Temp/Zal", b);
                            String char_T9 = String(T9);
                            char_T9.toCharArray(b,5);
                            client.publish("myhome/Temp/Mansarda", b);
                            //Serial.println(T1);
                            String char_fotoValue = String(fotoValue);
                            char_fotoValue.toCharArray(b,4);
                            client.publish("myhome/Kitchen/Lux", b);
                            String char_ServoAngle = String(ServoAngle);
                            char_ServoAngle.toCharArray(b,4);
                            String char_MQ7Value = String(MQ7Value);
                            char_MQ7Value.toCharArray(b,4);
                            client.publish("myhome/Temp/MQ7", b);
                            pause = 1;
                            else pause++;
                            ! [/code] и код вот этот... ! >! ~~[spoiler]~~[code]#include <spi.h>#include <ethernet.h>#include <pubsubclient.h>#include <eeprom.h>#include <avr wdt.h="">#define PWR_CTRL A2 //Контроль напряжения
                            #define LED 9 //Светодиод
                            #define CHK_ADR 100
                            #define CNT_ADR 10
                            #define PWR_ADR 20
                            #define POLL_ADR 30
                            #define RATIO_ADR 40
                            ! const char* topic_err = "myhome/elcounter/error";
                            const char* topic_cnt = "myhome/elcounter/count";
                            const char* topic_pwr = "myhome/elcounter/power";
                            const char* topic_amp = "myhome/elcounter/amp";
                            const char* topic_save = "myhome/elcounter/save";
                            const char* topic_correction = "myhome/elcounter/correction";
                            const char* topic_connection = "myhome/elcounter/connection";
                            const char* topic_ip = "myhome/elcounter/config/ip";
                            const char* topic_polling = "myhome/elcounter/config/polling";
                            const char* topic_bounce = "myhome/elcounter/config/bounce";
                            const char* topic_num = "myhome/elcounter/config/num";
                            const char* topic_reset = "myhome/elcounter/config/reset";
                            const char* topic_raw = "myhome/elcounter/RAW";
                            const char* subscr = "myhome/elcounter/#";
                            ! byte mac[6] = {0xC4, 0xE7, 0xC4, 0x9E, 0x83, 0x12};
                            byte ip[4] = {192, 168, 1, 52};
                            byte server[4] = {192, 168, 1, 190};
                            int amp = 0;
                            int prev_amp = 2;
                            int num = 0;
                            int prev_num;
                            int bounce = 10;
                            int prev_bounce;
                            int chk = 0;
                            int chk_S = 0;
                            unsigned long prevMillis = 0;
                            unsigned long prevMillis_cnt = 0;
                            int poll = 5000;
                            bool error = 0;
                            String cmd = "";
                            char buf [50];
                            char buffer[100];
                            char s[16];
                            PubSubClient client(ethClient);
                            ! void setup() {
                            MCUSR = 0;
                            wdt_disable();
                            cmd.reserve(100);
                            delay(10000);
                            if (EEPROM.read(1) != 99) { //Если первый запуск
                            EEPROM.write(1, 99);
                            for (int i = 0 ; i < 4; i++) {
                            EEPROM.write(110 + i, ip[i]);
                            EEPROM.write(120 + i, server[i]);
                            } else {
                            chk = EEPROMReadInt(CHK_ADR);
                            poll = EEPROMReadInt(POLL_ADR);
                            chk_S = poll - 500;
                            if (chk != chk_S) {
                            error = 2;
                            for (int i = 0; i < 4; i++) {
                            ip[i] = EEPROM.read(110 + i);
                            server[i] = EEPROM.read(120 + i);
                            ! pinMode(LED, OUTPUT);
                            client.setServer(server, 1883);
                            client.setCallback(callback);
                            delay(200);
                            if (client.connect("elcounter")) {
                            digitalWrite(LED, LOW);
                            Public();
                            cmd += inChar;
                            strComplete = true;
                            ! void callback_iobroker(String strTopic, String strPayload) {
                            if (strTopic == topic_correction) {
                            cnt = atol((strPayload).c_str());
                            Serial.print("SC");
                            Serial.println(cnt);
                            client.publish(topic_correction, "0");
                            else if (strTopic == topic_save) {
                            if (strPayload == "true") {
                            Serial.println("SS");
                            save();
                            client.publish(topic_save, "false");
                            else if (strTopic == topic_polling) {
                            poll = strPayload.toInt();
                            if (poll < 1000) {
                            poll = 1000;
                            } else if (poll > 32767) {
                            poll = 32767;
                            EEPROMWriteInt(POLL_ADR, poll); //Интервал публикации
                            client.publish(topic_polling, IntToChar(poll));
                            else if (strTopic == topic_reset) {
                            client.publish(topic_reset, "false");
                            reboot();
                            else if (strTopic == topic_bounce) {
                            bounce = strPayload.toInt();
                            if (bounce < 0) {
                            bounce = 0;
                            } else if (bounce > 10000) {
                            bounce = 10000;
                            Serial.print("SB");
                            Serial.println(bounce);
                            client.publish(topic_bounce, IntToChar(bounce));
                            else if (strTopic == topic_num) {
                            num = strPayload.toInt();
                            if (num < 0) {
                            num = 0;
                            } else if (num > 32767) {
                            num = 32767;
                            Serial.print("SN");
                            Serial.println(num);
                            client.publish(topic_num, IntToChar(num));
                            ! void save() {
                            chk = poll - 500;
                            EEPROMWriteLong(CNT_ADR, cnt); //Пишем показания счетчика в eeprom из переменной
                            EEPROMWriteInt(CHK_ADR, chk); //чек
                            ! void reboot() {
                            save();
                            delay(500);
                            wdt_enable(WDTO_1S);
                            for (;;) {}
                            ! char* StrToChar (String str) {
                            int length = str.length();
                            str.toCharArray(buf, length + 1);
                            return buf;
                            ! char* IntToChar (unsigned long a) {
                            sprintf(buf, "%lu", a);
                            return buf;
                            ! void Public(){
                            sprintf(s, "%d.%d.%d.%d", ip[0], ip[1], ip[2], ip[3]);
                            client.publish(topic_err, " ");
                            client.publish(topic_cnt, IntToChar(cnt));
                            client.publish(topic_pwr, IntToChar(pwr));
                            client.publish(topic_amp, IntToChar(amp));
                            client.publish(topic_connection, "true");
                            client.publish(topic_ip, s);
                            client.subscribe(subscr);
                            void reconnect() {
                            int a = 0;
                            while (!client.connected()) {
                            a++;
                            digitalWrite(LED, !digitalRead(LED));
                            wdt_reset();
                            Public();
                            } else {
                            delay(10000);
                            if (a >= 10) {
                            ! void loop() {
                            wdt_reset();
                            client.loop();
                            reconnect();
                            ! if (analogRead(PWR_CTRL) < 1000) {
                            save();
                            delay(10000);
                            cmd.toCharArray(buffer, 100);
                            cnt = atoi(strtok(buffer, ";"));
                            pwr = atoi(strtok(NULL, ";"));
                            amp = atoi(strtok(NULL, ";"));
                            bounce = atoi(strtok(NULL, ";"));
                            num = atoi(strtok(NULL, ";"));
                            error = atoi(strtok(NULL, ";"));
                            client.publish(topic_raw, StrToChar(cmd));
                            cmd = "";
                            ! if (millis() - prevMillis >= poll) {
                            wdt_reset();
                            prevMillis = millis();
                            if (cnt != prev_cnt || pwr != prev_pwr || amp != prev_amp) {
                            prev_cnt = cnt;
                            prev_pwr = pwr;
                            prev_amp = amp;
                            if (num != prev_num || bounce != prev_bounce) {
                            prev_num = num;
                            prev_bounce = bounce;
                            if (error > 0) {
                            client.publish(topic_err, "err");
                            } else {
                            }</avr></eeprom.h></pubsubclient.h></ethernet.h></spi.h>`
                            причина проста, есть две 2560 одна считает энергию и отдает другой 2560 которая, отвечает за температуру и все это публикует. И как правильно настроить UART между двумя 2560[/i][/i][/i][/i][/code][/spoiler][/i][/i]
                            • I
                              @smoker_vvo:
                              как? `
                              save();
                              save();
                              cmd = "";
                              т.о. чтобы задать bounce надо в уарт послать B1000 например.
                              или чтобы задать данные счетчика то - C51423
                              и код вот этот...
                                  cmd += inChar;
                                    strComplete = true;
                              if (strComplete) {
                                  cmd = "";
                              Тут мы как раз получаем данные из уарт и парсим их, а дальше делай что хочешь
                                ой мамочки…. У меня есть немного вопросов касаемо счетчика:
                                1. тип оборудования Arduino Uno + Mega 2560
                                2. Скетч Count - на УНО завелся без проблем, показания получаю.
                                3. Как правильно состыковать УНО и МЕГА, сделано так TX & RX Uno соединены с RX(0) & TX(1) Mega, ни чего нет на Меге.
                                4. Самое противное, при заливке скетча MQTT на 2560 получаю странную картину - постоянно мигает светодиод L и Мега ни как не реагирует на поступающие данные, и не пингуется по своему адресу. в кодах ни чего не менял кроме ip адресов
                                Куда рыть далее???
                                  по умолчанию считаю что в обоих скетчах - UART уже прописан. или я не прав?
                                    Пардон, не UNO а NANO
                                      и еще в Count и MQTT есть такие строки
                                      Count
                                      #define PWR_CTRL A0
                                      MQTT
                                      прошу пояснить их назначение и схемку подключения
                                      • I
                                        @smoker_vvo:
                                        Куда рыть далее??? ` убери из кода ватчдог либо залей оптибут в мегу.
                                        • I
                                          @smoker_vvo:
                                          Count
                                          #define PWR_CTRL A0
                                          MQTT
                                          прошу пояснить их назначение и схемку подключения ` контроль питания на порту. При пропадании питания сохраняются данные в епром
                                            Вачдог…
                                            Это
                                            void reboot() {
                                            save();
                                            delay(500);
                                            for (;;) {}
                                            13530
