    4. Test Adapter HeatingControl v2.12.x
    • Dominik F.
      Dominik F. @Rene_HM last edited by
      @rene_hm
      Ich wundere mich etwas über die Warnungen im Log, kannst du mir einmal erklären? Besonders die hohen Temperaturen verstehe ich nicht:
      heatingcontrol.0
      2022-10-28 06:21:47.333	warn	Kinderzimmer_Finn manual mode 17 but ignored because already reduced
      heatingcontrol.0
      2022-10-28 06:19:30.023	warn	Kinderzimmer_Finn manual mode 19 but ignored because already reduced
      heatingcontrol.0
      2022-10-28 05:23:48.776	warn	Kinderzimmer_Finn manual mode 17 but ignored because already reduced
      heatingcontrol.0
      2022-10-28 05:21:19.779	warn	Kinderzimmer_Finn manual mode 26.5 but ignored because already reduced
      heatingcontrol.0
      2022-10-28 05:18:46.396	warn	Kinderzimmer_Finn manual mode 19 but ignored because already reduced
      heatingcontrol.0
      2022-10-28 05:15:38.527	warn	Kinderzimmer_Finn manual mode 17 but ignored because already reduced
      heatingcontrol.0
      2022-10-28 05:13:40.360	warn	Kinderzimmer_Finn manual mode 4.5 but ignored because already reduced
      heatingcontrol.0
      2022-10-28 04:36:03.181	warn	Kinderzimmer_Finn manual mode 17 but ignored because already reduced
      heatingcontrol.0
      2022-10-28 04:28:02.545	warn	Kinderzimmer_Finn manual mode 30.5 but ignored because already reduced
      heatingcontrol.0
      2022-10-28 02:24:14.474	warn	Kinderzimmer_Finn manual mode 17 but ignored because already reduced
      heatingcontrol.0
      2022-10-28 02:19:01.969	warn	Kinderzimmer_Finn manual mode 25 but ignored because already reduced
      heatingcontrol.0
      2022-10-28 02:04:02.202	warn	Kinderzimmer_Finn manual mode 17 but ignored because already reduced
      heatingcontrol.0
      2022-10-28 02:01:45.712	warn	Kinderzimmer_Finn manual mode 29 but ignored because already reduced
      heatingcontrol.0
      2022-10-28 00:12:01.205	warn	Kinderzimmer_Finn manual mode 17 but ignored because already reduced
      Hier ist der Log von dem Raum aus dem Datenpunkt:
      heatingcontrol.0.Rooms.Kinderzimmer_Finn.StatusLog
      28.10.2022 10:37:23 auto WindowOpen 17°C
      28.10.2022 10:37:03 manual WindowOpen 17°C
      28.10.2022 08:00:00 auto WindowOpen 17°C
      28.10.2022 00:09:50 manual WindowOpen 17°C
      28.10.2022 00:01:00 auto WindowOpen 17°C
      27.10.2022 23:14:17 manual WindowOpen 17°C
      27.10.2022 21:13:26 auto WindowOpen 17°C
      27.10.2022 21:04:53 manual WindowOpen 17°C
      27.10.2022 21:00:00 auto WindowOpen 17°C
      27.10.2022 18:17:57 manual WindowOpen 18°C
      26.10.2022 21:09:54 auto WindowOpen 17°C
      Hier wundern mich die sprünge zwischen Auto und Manual. Mein Thermostat ist auf Manual gestellt und wird nur durch Heatingcontrol gesteuert.
      • Rene_HM
        Rene_HM Developer @Dominik F. last edited by
        @dominik-f Die Warnung
        kommt, wenn der Raum bereits in manual ist, ein Fenster offen ist und dann eine neue Zieltemperatur vom Thermostat kommt. Normalerweise müsste diese neue Zieltemperatur übernommen werden und der Raum würde auf "manual" gesetzt, wenn er es nicht schon ist. Das mache ich aber in diesem Fall (Fenster offen) nicht, sondern gebe diese Warnung.
        Kann es sein, dass jemand am Thermostat dreht, während das Fenster offen ist?
        Dominik F. 1 Reply Last reply Reply Quote 0
        • Dominik F.
          @rene_hm
          Nein, es ist ausgeschlossen das da am Thermostat gedreht wurde. Der kleine ist noch zu jung dafür
          • Rene_HM
            @dominik-f dann schalte bitte debug log ein, dann sollten wir es sehen... Vieleicht sendet das Thermostat ja auch von sich aus etwas?
            • Dominik F.
              @rene_hm
              ich hab den Adapter seit gestern auf Debug stehen, bisher kam keine Warnung mehr. Ich melde mich wenn eine Warnung auftaucht die sich nicht erklären lässt
                eviltrooper @eviltrooper last edited by
                @eviltrooper said in Test Adapter HeatingControl v2.9.x:
                Wo stellt man den ein wenn man Abwesend ist?
                Hab den Datenpunkt verknüpft, er erkennt es auch. Und es steht auf 19°C wo kommt das den her?
                Hallo, jemand eine Idee? Wo stellt man die Abwesenheit Temperatur ein?
                • Dominik F.
                  Dominik F. @eviltrooper last edited by Dominik F.
                  @eviltrooper
                  Ich bin mir nicht sicher ob ich die Frage richtig verstehe.
                  Also du kannst im Adapter unter Datenpunkteinstellungen einen Datenpunkt für die Abwesenheit angeben.
                  In Vis kannst du dann einstellen, um wie viel sich die Temperatur dann absenkt. Wenn du kein Vis nutzt, dann über diesen Datenpunkt:
                  heatingcontrol.0.vis.TempDecreaseValues.AbsentDecrease
                    eviltrooper @Dominik F. last edited by eviltrooper
                    @dominik-f den Punkt „vis“ gibts gar nicht bei mir.21AEC58B-7C3F-4918-A589-E99A1F456D68.jpeg
                      Rickman last edited by
                      Guten Morgen zusammen,
                      der heatingcontrol Adapter läuft bei mir einwandfrei, aber da ich in der letzten Zeit kein Backup mehr erhalte, habe ich das mal manuell angestoßen und dabei folgende Felhermeldung erhalten:
                      [ERROR] [iobroker] - host.iobroker One or more optional files are corrupted: host.iobroker /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis.0/HeatingControl/iobroker-heatingcontrol-vis-master/.vscode/launch.json is not a valid json file
                      host.iobroker Please ensure that self-created JSON files are valid
                      Das war nicht der Fehler für das angehaltene Backup, aber vielleicht ist der Fehler ja anderweitig relevant.
                        jensven @eviltrooper last edited by
                        genau so sieht es bei mir auch aus. dachte schon ich habe bei der Installation was falsch gemacht 🙄
                          Michi_Pi @jensven last edited by
                          @jensven @eviltrooper habt ihr den Adapter schon mal neu installiert? Bzw. habt ihr bei den Visualisierungseinstellungen einen Hacken gesetzt bei einen von den beiden Punkten?
                            jensven @Michi_Pi last edited by
                            @michi_pi
                            da ich keine vis. benutze habe ich natürlich auch keinen Haken gesetzt 🤷
                            Aber ja dann ist der vis Ordner da und somit auch der die ganzen Datenpunkte 👍
                            @Rene_HM wäre es nicht sinnvoll diese Datenpunkte mit einzustellen auch wenn man keine vis nutzt?
                              Berlon @jensven last edited by Berlon
                              Hallo Rene,
                              ich wende mich nochmal mir meinem Wunsch an dich.
                              Mein Problem mit dem Adapter ist die Zuordnung der Räume zu den Profilen.
                              Ich heize mit 3 verschiedene Systemen die nie zusammen laufen. (Gas, Klima heizen und Klima kühlen) Dazu würde ich gerne 3 Profile verwenden um mittels Vis von Pittini die Heizzeiten der Systeme einzustellen. Je nachdem welche Heizung benutzt wird ist das entsprechend Profil aktiv.
                              Ich habe dazu mal ein Bild kreiert um es zu verdeutlichen.
                              Jeder Raum ist dann 3 mal vorhanden wegen den unterschiedlichen Datenpunkten.
                              in Profil 1 würden dann in der Vis nur die Räume 1-3, in Profil 2 die Räume 4-6 und die 3 letzten Räume in Profil 3 angezeigt werden.
                              Wenn mehr oder weniger Profile aktiv dann entsprechend mehr oder weniger Spalten.
                              Ein Raum sollte auch in mehreren Profilen anwählbar sein können.
                              Das hätte in der Vis den Vorteil das bei Auswahl eines Profils nur die dazugehörigen Räume auftauchen und eingestellt werden können.
                              So sind aktuell in jedem Profil auch immer alle Räume vorhanden.
                              Diese Lösung würde mir extrem viel Arbeit wegen mehreren Instanzen der Adapter mit allen Risiken ersparen.
                              Wäre schön wenn du das realisieren könntest.
                              Vermutlich ist auch für zukünftige Projekte auch gut zu gebrauchen.
                              Bernd
                              • Rene_HM
                                Rene_HM Developer @Berlon last edited by
                                @berlon ich bin noch nicht überzeugt, dass dies keine "Speziallösung" für deinen konkreten Anwendungsfall ist. Der Adapter ist schon ziemlich kompliziert geworden und mit vielen Optionen und Varianten vollgestopft. Wenn sich weitere user diese Änderung wünschen, könnte ich mal konkreter schauen.
                                Auf den ersten Blick ist das eine größere Änderung am Code. Ich müsste interne Datenstrukturen überarbeiten und anpassen, was wieder langwieriges Testen nach sich ziehen würde...
                                  TurboSasch @Rene_HM last edited by TurboSasch
                                  @rene_hm hallo Rene,
                                  Ich nutze den Heating Adapter schon seit 2 Jahren ohne Probleme. Jetzt wollte ich im Vis einige Pfade wiederherstellen, da ich einen kompletten Restore machen musste. Wenn ich jetzt etwas im Vis Heating Control ändern möchte, kommt kein Speichern mehr, sondern nur noch ein Ausrufezeichen oben rechts im Browser. Hast du vielleicht eine Idee, was da ein Problem macht?
                                  Sascha
                                  • Rene_HM
                                    Rene_HM Developer @TurboSasch last edited by
                                    @turbosasch Kannst du die Konsole des browser öffnen (Strg +Umschalt +J auf Windows) und das consolen log anschauen (oder mir zukommen lassen)?
                                      @rene_hm ja, ich habe einen Log für Dich:
                                      metro-bootstrap.css:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                                      iconFont.min.css:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                                      metro.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                                      fritzdect.js:46 Version fritzdect: 0.0.2
                                      conn.js:305 2022-11-05T08:44:35.394Z Connected => authenticate
                                      conn.js:326 2022-11-05T08:44:35.830Z Authenticated: true
                                      DevTools failed to load source map: Could not load content for http://192.168.178.36:8082/lib/js/socket.io.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                                      vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.lnav_fixed_width
                                      vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.primary_color
                                      vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.abar_color
                                      vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.tnav_color
                                      vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.bnav_color
                                      vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.lnav_color
                                      vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.secondary_color
                                      vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.content_color
                                      vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.color1
                                      vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.color1_dark
                                      vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.color2
                                      vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.color2_dark
                                      vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.color3
                                      vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.color3_dark
                                      vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.config_view
                                      vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.card_title
                                      vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.card_title_color
                                      vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.card_title_bg
                                      vis.js:3543 Create inner vis object deconz.0.Sensors.21.temperature
                                      vis.js:3543 Create inner vis object deconz.0.Sensors.17.on
                                      vis.js:3543 Create inner vis object hm-rpc.0.PEQ1315641.0.RSSI_PEER
                                      vis.js:3543 Create inner vis object hm-rpc.0.PEQ1315641.4.SET_TEMPERATURE
                                      vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Ankleide.ResetManual
                                      vis.js:3543 Create inner vis object hm-rpc.0.info.connection
                                      vis.js:3543 Create inner vis object deconz.0.Sensors.8.valve
                                      vis.js:3543 Create inner vis object deconz.0.Sensors.16.temperature
                                      vis.js:3543 Create inner vis object deconz.0.Sensors.12.on
                                      vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Badezimmer.ResetManual
                                      vis.js:3543 Create inner vis object deconz.0.Sensors.5.valve
                                      vis.js:3543 Create inner vis object deconz.0.Sensors.11.temperature
                                      vis.js:3543 Create inner vis object deconz.0.Sensors.21.on
                                      vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.GaesteWC.StatusLog
                                      vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.GaesteWC.ResetManual
                                      vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.GaesteWC.State
                                      vis.js:3543 Create inner vis object deconz.0.Sensors.4.valve
                                      vis.js:3543 Create inner vis object wid
                                      vis.js:3543 Create inner vis object deconz.0.Sensors.13.temperature
                                      vis.js:3543 Create inner vis object deconz.0.Sensors.23.on
                                      vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Kinderzimmer.ResetManual
                                      vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Kinderzimmer.State
                                      vis.js:3543 Create inner vis object deconz.0.Sensors.6.valve
                                      vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Kinderzimmer.StatusLog
                                      vis.js:3543 Create inner vis object deconz.0.Sensors.14.temperature
                                      vis.js:3543 Create inner vis object deconz.0.Sensors.20.on
                                      vis.js:3543 Create inner vis object hm-rpc.0.PEQ1315641.4.ACTUAL_TEMPERATURE
                                      vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Kueche.StatusLog
                                      vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Kueche.WindowIsOpen
                                      vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Kueche.ResetManual
                                      vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Kueche.State
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Fr.Periods.0.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Fr.Periods.0.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Bad.ActiveTimeSlot
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.4.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.3.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.2.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.2.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.1.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.1.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.0.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.0.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.3.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.4.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-Su.Periods.5.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-Su.Periods.5.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Fr.Periods.5.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Fr.Periods.5.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.5.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.4.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.1.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.1.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.2.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.2.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.3.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.3.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.4.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.5.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.5.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.4.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.3.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.3.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.2.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.2.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.1.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.1.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.4.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.5.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.5.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.4.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.3.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.3.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.2.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.2.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.1.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.1.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.4.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.5.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.5.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.4.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.3.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.3.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.2.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.2.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.1.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.1.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.4.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.5.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.5.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.4.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.3.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.3.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.2.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.2.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.1.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.1.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.4.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.5.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.5.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.4.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.3.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.3.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.2.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.2.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.1.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.1.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.4.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.5.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.5.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.4.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.3.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.3.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.2.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.2.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.1.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.1.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.4.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.5.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.5.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.4.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.3.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.3.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.2.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.2.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.1.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.1.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.4.Temperature
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.5.time
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.CopyPeriods
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.CopyPeriods
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.CopyPeriods
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.CopyPeriods
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.CopyPeriods
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.CopyPeriods
                                      vis.js:3543 Create inner vis object deconz.0.Sensors.15.temperature
                                      vis.js:3543 Create inner vis object deconz.0.Sensors.15.on
                                      vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Schlafzimmer.ResetManual
                                      vis.js:3543 Create inner vis object deconz.0.Sensors.7.valve
                                      vis.js:3543 Create inner vis object ham.0.Wohnzimmer-.000000BC.Current-Temperature
                                      vis.js:3543 Create inner vis object deconz.0.Sensors.2.valve
                                      vis.js:3543 Create inner vis object heatingcontrol_card_title
                                      vis.js:3543 Create inner vis object myhome_card_title_color
                                      vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.CopyProfile
                                      translate.js:20 "Use background": {"en": "Use background", "de": "Use background", "ru": "Use background"},
                                      message_socket_on.png:1 GET http://192.168.178.36:8082/vis/widgets/jqui-mfd/img/message_socket_on.png 404 (Not Found)
                                      Image (async)
                                      buildFragment @ jquery-1.11.2.min.js:3
                                      domManip @ jquery-1.11.2.min.js:3
                                      t.fn.domManip @ can.custom.min.js:28
                                      append @ jquery-1.11.2.min.js:3
                                      (anonymous) @ visEdit.js:2430
                                      each @ jquery-1.11.2.min.js:2
                                      editInitWidgetPreview @ visEdit.js:2415
                                      editInitNext @ visEdit.js:2940
                                      initNext @ vis.js:715
                                      (anonymous) @ vis.js:610
                                      loadWidgetSets @ vis.js:575
                                      init @ vis.js:609
                                      (anonymous) @ vis.js:3609
                                      (anonymous) @ conn.js:1350
                                      r.onack @ socket.io.js:8
                                      r.onpacket @ socket.io.js:8
                                      (anonymous) @ socket.io.js:8
                                      r.emit @ socket.io.js:6
                                      r.ondecoded @ socket.io.js:6
                                      a.add @ socket.io.js:6
                                      r.ondata @ socket.io.js:6
                                      r.onPacket @ socket.io.js:6
                                      (anonymous) @ socket.io.js:6
                                      r.onPacket @ socket.io.js:7
                                      r.onData @ socket.io.js:7
                                      ws.onmessage @ socket.io.js:8
                                      2conn.js:81 No connection!
                                      conn.js:157 Trying connect...
                                      conn.js:281 was offline for 10.042s
                                      conn.js:305 2022-11-05T08:44:55.569Z Connected => authenticate
                                      conn.js:326 2022-11-05T08:44:55.730Z Authenticated: true
                                      translate.js:20 "Änderungen": {"en": "Änderungen", "de": "Änderungen", "ru": "Änderungen"},`
                                      • Rene_HM
                                        @turbosasch ja, deine Vis verliert die Verbindung und baut sie neu auf. Die Ursache dazu sehe ich hier leider nicht. Wie hast du den restore gemacht? Fehlt da vielleicht noch etwas?
                                          @rene_hm Ich habe ein Backup genommen, welches ich jeden Tag erstelle. Ich habe Vis auch einmal deinstalliert und wieder installiert. Leider ohne irgendwelche Änderung. Und ich habe alle paar Monate das Projekt gesichert. Separat auf PC natürlich.
                                          • Rene_HM
                                            @turbosasch nutzt du die vis von pittini?
                                            T Dominik F. P B 5 Replies Last reply Reply Quote 0
                                            heating
                                            236
                                            3158
                                            1820426
