    5. Daten aus URL in blocky
    • ingranu
      ingranu @paul53 last edited by
      @paul53 einfach nix..
      Ausgabe kommt bei Abruf der URL aber immer
      13:56:24.492	info	javascript.0 (4987) Stop script script.js.common.Mediola_states2
      13:56:24.502	info	javascript.0 (4987) Start javascript script.js.common.Mediola_states2
      13:56:24.509	info	javascript.0 (4987) script.js.common.Mediola_states2: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
        paul53 @ingranu last edited by paul53
        @ingranu sagte: einfach nix..
        Bau Debug-Ausgaben ein, um zu sehen, was passiert.
        Weise bei "aktualisiere" noch einen Datenpunkt zu.
        EDIT: Der Schleifenabbruch erfolgt an der falschen Stelle: Die Schleife wird sofort abgebrochen und nicht erst bei erfüllter Bedingung.
        ingranu 2 Replies Last reply Reply Quote 0
          @ingranu sagte: Ausgabe kommt bei Abruf der URL aber immer
          Wenn ich es mit dem oben angegeben String in result teste, erhalte ich das erwartete Ergebnis:
          Schleifenabbruch korrigieren!!
          • ingranu
            @paul53 Da tuuuut sich jetzt was 🙂
            javascript.0 (4987) script.js.common.Mediola_states3: [{"type":"FS20","adr":"443525","state":"00:A6"},{"type":"FS20","adr":"2b063b","state":"FF:FF"},{"type":"EVENT","adr":"02","state":"1"},{"type":"FS20","adr":"8d3700","state":"FF:FF"},{"type":"FS20","adr":"aaf900","state":"FF:FF"},{"type":"FS20","adr":"20d600","state":"FF:FF"},{"type":"EVENT","adr":"03","state":"1"},{"type":"FS20","adr":"903702","state":"FF:FF"},{"type":"FS20","adr":"1c291e","state":"FF:FF"},{"type":"FS20","adr":"8d3702","state":"FF:FF"},{"type":"FS20","adr":"0b3212","state":"FF:FF"},{"type":"FS20","adr":"ffffa9","state":"FF:FF"},{"type":"FS20","adr":"015301","state":"FF:FF"},{"type":"FS20","adr":"231a42","state":"FF:FF"},{"type":"ELRO","adr":"123409","state":"FF:FF"},{"type":"FS20","adr":"ffff01","state":"FF:FF"},{"type":"IT","adr":"aa3c0080","state":"FF:FF"},{"type":"FS20","adr":"271b20","state":"FF:FF"},{"type":"FS20","adr":"800001","state":"FF:FF"},{"type":"ELRO","adr":"000550","state":"00:12"},{"type":"IT","adr":"518b1180","state":"06:12"},{"type":"IT","adr":"010","state":"FF:FF"},{"type":"ELRO","adr":"100550","state":"00:FF"},{"type":"IT","adr":"1db90080","state":"FF:FF"},{"type":"IT","adr":"b3930080","state":"FF:FF"},{"type":"IT","adr":"2e340080","state":"06:A6"},{"type":"IT","adr":"a5430080","state":"FF:FF"},{"type":"IT","adr":"7f450080","state":"FF:FF"},{"type":"IT","adr":"44240080","state":"06:12"},{"type":"FS20","adr":"1a0132","state":"FF:FF"},{"type":"IT","adr":"25ca0080","state":"06:FF"},{"type":"EVENT","adr":"01","state":"0"},{"type":"IT","adr":"60b5a280","state":"FF:FF"},{"type":"IT","adr":"518b1181","state":"06:7A"},{"type":"IT","adr":"6616a881","state":"FF:FF"},{"type":"IT","adr":"60b5a282","state":"06:54"},{"type":"IT","adr":"00","state":"FF:FF"},{"type":"IT","adr":"44205800","state":"FF:FF"},{"type":"IT","adr":"a1234561","state":"FF:FF"},{"type":"IT","adr":"af760080","state":"06:12"},{"type":"IT","adr":"13b80080","state":"FF:FF"},{"type":"IT","adr":"6616a880","state":"06:A6"}]
            • ingranu
              @paul53 said in Daten aus URL in blocky:
                @ingranu sagte: Da tuuuut sich jetzt was
                Den Schleifenabbruch hast du korrigiert?
                ingranu 1 Reply Last reply Reply Quote 0
                • ingranu
                  Ja die Schleife habe ich korrigiert, die Ausgabe erfolgt jetzt wie folgt, also alle Geräte:
                  javascript.0 (4987) script.js.common.Mediola_states4: [{"type":"FS20","adr":"443525","state":"00:A7"},{"type":"FS20","adr":"2b063b","state":"FF:FF"},{"type":"EVENT","adr":"02","state":"1"},{"type":"FS20","adr":"8d3700","state":"FF:FF"},{"type":"FS20","adr":"aaf900","state":"FF:FF"},{"type":"FS20","adr":"20d600","state":"FF:FF"},{"type":"EVENT","adr":"03","state":"1"},{"type":"FS20","adr":"903702","state":"FF:FF"},{"type":"FS20","adr":"1c291e","state":"FF:FF"},{"type":"FS20","adr":"8d3702","state":"FF:FF"},{"type":"FS20","adr":"0b3212","state":"FF:FF"},{"type":"FS20","adr":"ffffa9","state":"FF:FF"},{"type":"FS20","adr":"015301","state":"FF:FF"},{"type":"FS20","adr":"231a42","state":"FF:FF"},{"type":"ELRO","adr":"123409","state":"FF:FF"},{"type":"FS20","adr":"ffff01","state":"FF:FF"},{"type":"IT","adr":"aa3c0080","state":"FF:FF"},{"type":"FS20","adr":"271b20","state":"FF:FF"},{"type":"FS20","adr":"800001","state":"FF:FF"},{"type":"ELRO","adr":"000550","state":"00:13"},{"type":"IT","adr":"518b1180","state":"06:13"},{"type":"IT","adr":"010","state":"FF:FF"},{"type":"ELRO","adr":"100550","state":"00:FF"},{"type":"IT","adr":"1db90080","state":"FF:FF"},{"type":"IT","adr":"b3930080","state":"FF:FF"},{"type":"IT","adr":"2e340080","state":"06:A7"},{"type":"IT","adr":"a5430080","state":"FF:FF"},{"type":"IT","adr":"7f450080","state":"FF:FF"},{"type":"IT","adr":"44240080","state":"06:13"},{"type":"FS20","adr":"1a0132","state":"FF:FF"},{"type":"IT","adr":"25ca0080","state":"06:FF"},{"type":"EVENT","adr":"01","state":"0"},{"type":"IT","adr":"60b5a280","state":"FF:FF"},{"type":"IT","adr":"518b1181","state":"06:7B"},{"type":"IT","adr":"6616a881","state":"FF:FF"},{"type":"IT","adr":"60b5a282","state":"06:55"},{"type":"IT","adr":"00","state":"FF:FF"},{"type":"IT","adr":"44205800","state":"FF:FF"},{"type":"IT","adr":"a1234561","state":"FF:FF"},{"type":"IT","adr":"af760080","state":"06:13"},{"type":"IT","adr":"13b80080","state":"FF:FF"},{"type":"IT","adr":"6616a880","state":"06:A7"}]
                  Aber wie kann ich jetzt da ne Automation mache, respektive kann ich den Wert welche in benötige irgendwo als Variable eintragen lassen?
                    @ingranu
                    Da muss noch eine Log-Ausgabe hinterher kommen:
                    06:13
                    Deaktiviere mal den "Debug output json", denn offenbar kommt das JSON rein.
                    @ingranu sagte in Daten aus URL in blocky:
                    Der Block "aktualisiere" schreibt den Wert in einen unter "0_userdata.0" selbst erstellten Datenpunkt vom Typ "string".
                    • ingranu
                      @paul53 Welchen Debug meinst du? Diesen hier?
                        @ingranu sagte: Welchen Debug meinst du? Diesen hier?
                        Ja, und den ganz oben (debug output result). Dann bleibt nur noch der Debug-Block für das ausgefilterte "state".
                        • ingranu
                          @paul53 Sieht nur wie folgt aus:
                          unten keine Info Ausgabe mehr
                            @ingranu sagte: unten keine Info Ausgabe mehr
                            Wo befindet sich jetzt der Block "die Schleife abbrechen"?
                            • ingranu
                                @ingranu sagte: die Ausgabe erfolgt jetzt wie folgt, also alle Geräte:
                                Ist das die gesamte Log-Ausgabe (Variable result)?
                                Wenn ja, fehlt dort der Anfang "{XC_SUC}".
                                Dann frage mal zusätzlich ab:
                                  @ingranu
                                  Bei "aktualisiere" ist der Datenpunkt noch nicht zugewiesen.
                                  • ingranu
                                    @paul53 Wo fehlt das {XC_SUC} ?
                                      Homoran Global Moderator Administrators @ingranu last edited by
                                      im result! Deswegen wollte ich das result schon ganz am Anfang sehen
                                        @ingranu sagte: Wo fehlt das {XC_SUC} ?
                                        In der Log-Ausgabe von result.
                                        • ingranu
                                          @paul53 so ?
                                            @ingranu sagte: so ?
                                            Nein, result muss unverändert bleiben. So:
                                            Noch besser so:
                                            5573
