    5. Daten aus URL in blocky
    • ingranu
      ingranu @paul53 last edited by
      @paul53 Da tuuuut sich jetzt was 🙂
      javascript.0 (4987) script.js.common.Mediola_states3: [{"type":"FS20","adr":"443525","state":"00:A6"},{"type":"FS20","adr":"2b063b","state":"FF:FF"},{"type":"EVENT","adr":"02","state":"1"},{"type":"FS20","adr":"8d3700","state":"FF:FF"},{"type":"FS20","adr":"aaf900","state":"FF:FF"},{"type":"FS20","adr":"20d600","state":"FF:FF"},{"type":"EVENT","adr":"03","state":"1"},{"type":"FS20","adr":"903702","state":"FF:FF"},{"type":"FS20","adr":"1c291e","state":"FF:FF"},{"type":"FS20","adr":"8d3702","state":"FF:FF"},{"type":"FS20","adr":"0b3212","state":"FF:FF"},{"type":"FS20","adr":"ffffa9","state":"FF:FF"},{"type":"FS20","adr":"015301","state":"FF:FF"},{"type":"FS20","adr":"231a42","state":"FF:FF"},{"type":"ELRO","adr":"123409","state":"FF:FF"},{"type":"FS20","adr":"ffff01","state":"FF:FF"},{"type":"IT","adr":"aa3c0080","state":"FF:FF"},{"type":"FS20","adr":"271b20","state":"FF:FF"},{"type":"FS20","adr":"800001","state":"FF:FF"},{"type":"ELRO","adr":"000550","state":"00:12"},{"type":"IT","adr":"518b1180","state":"06:12"},{"type":"IT","adr":"010","state":"FF:FF"},{"type":"ELRO","adr":"100550","state":"00:FF"},{"type":"IT","adr":"1db90080","state":"FF:FF"},{"type":"IT","adr":"b3930080","state":"FF:FF"},{"type":"IT","adr":"2e340080","state":"06:A6"},{"type":"IT","adr":"a5430080","state":"FF:FF"},{"type":"IT","adr":"7f450080","state":"FF:FF"},{"type":"IT","adr":"44240080","state":"06:12"},{"type":"FS20","adr":"1a0132","state":"FF:FF"},{"type":"IT","adr":"25ca0080","state":"06:FF"},{"type":"EVENT","adr":"01","state":"0"},{"type":"IT","adr":"60b5a280","state":"FF:FF"},{"type":"IT","adr":"518b1181","state":"06:7A"},{"type":"IT","adr":"6616a881","state":"FF:FF"},{"type":"IT","adr":"60b5a282","state":"06:54"},{"type":"IT","adr":"00","state":"FF:FF"},{"type":"IT","adr":"44205800","state":"FF:FF"},{"type":"IT","adr":"a1234561","state":"FF:FF"},{"type":"IT","adr":"af760080","state":"06:12"},{"type":"IT","adr":"13b80080","state":"FF:FF"},{"type":"IT","adr":"6616a880","state":"06:A6"}]
      • ingranu
        @paul53 said in Daten aus URL in blocky:
        @ingranu sagte: einfach nix..
        Bau Debug-Ausgaben ein, um zu sehen, was passiert.
        Weise bei "aktualisiere" noch einen Datenpunkt zu.
        EDIT: Der Schleifenabbruch erfolgt an der falschen Stelle: Die Schleife wird sofort abgebrochen und nicht erst bei erfüllter Bedingung.
          paul53 @ingranu last edited by paul53
          @ingranu sagte: Da tuuuut sich jetzt was
          Den Schleifenabbruch hast du korrigiert?
          ingranu 1 Reply Last reply Reply Quote 0
          • ingranu
            Ja die Schleife habe ich korrigiert, die Ausgabe erfolgt jetzt wie folgt, also alle Geräte:
            javascript.0 (4987) script.js.common.Mediola_states4: [{"type":"FS20","adr":"443525","state":"00:A7"},{"type":"FS20","adr":"2b063b","state":"FF:FF"},{"type":"EVENT","adr":"02","state":"1"},{"type":"FS20","adr":"8d3700","state":"FF:FF"},{"type":"FS20","adr":"aaf900","state":"FF:FF"},{"type":"FS20","adr":"20d600","state":"FF:FF"},{"type":"EVENT","adr":"03","state":"1"},{"type":"FS20","adr":"903702","state":"FF:FF"},{"type":"FS20","adr":"1c291e","state":"FF:FF"},{"type":"FS20","adr":"8d3702","state":"FF:FF"},{"type":"FS20","adr":"0b3212","state":"FF:FF"},{"type":"FS20","adr":"ffffa9","state":"FF:FF"},{"type":"FS20","adr":"015301","state":"FF:FF"},{"type":"FS20","adr":"231a42","state":"FF:FF"},{"type":"ELRO","adr":"123409","state":"FF:FF"},{"type":"FS20","adr":"ffff01","state":"FF:FF"},{"type":"IT","adr":"aa3c0080","state":"FF:FF"},{"type":"FS20","adr":"271b20","state":"FF:FF"},{"type":"FS20","adr":"800001","state":"FF:FF"},{"type":"ELRO","adr":"000550","state":"00:13"},{"type":"IT","adr":"518b1180","state":"06:13"},{"type":"IT","adr":"010","state":"FF:FF"},{"type":"ELRO","adr":"100550","state":"00:FF"},{"type":"IT","adr":"1db90080","state":"FF:FF"},{"type":"IT","adr":"b3930080","state":"FF:FF"},{"type":"IT","adr":"2e340080","state":"06:A7"},{"type":"IT","adr":"a5430080","state":"FF:FF"},{"type":"IT","adr":"7f450080","state":"FF:FF"},{"type":"IT","adr":"44240080","state":"06:13"},{"type":"FS20","adr":"1a0132","state":"FF:FF"},{"type":"IT","adr":"25ca0080","state":"06:FF"},{"type":"EVENT","adr":"01","state":"0"},{"type":"IT","adr":"60b5a280","state":"FF:FF"},{"type":"IT","adr":"518b1181","state":"06:7B"},{"type":"IT","adr":"6616a881","state":"FF:FF"},{"type":"IT","adr":"60b5a282","state":"06:55"},{"type":"IT","adr":"00","state":"FF:FF"},{"type":"IT","adr":"44205800","state":"FF:FF"},{"type":"IT","adr":"a1234561","state":"FF:FF"},{"type":"IT","adr":"af760080","state":"06:13"},{"type":"IT","adr":"13b80080","state":"FF:FF"},{"type":"IT","adr":"6616a880","state":"06:A7"}]
            Aber wie kann ich jetzt da ne Automation mache, respektive kann ich den Wert welche in benötige irgendwo als Variable eintragen lassen?
              @ingranu
              Da muss noch eine Log-Ausgabe hinterher kommen:
              06:13
              Deaktiviere mal den "Debug output json", denn offenbar kommt das JSON rein.
              @ingranu sagte in Daten aus URL in blocky:
              Der Block "aktualisiere" schreibt den Wert in einen unter "0_userdata.0" selbst erstellten Datenpunkt vom Typ "string".
              • ingranu
                @paul53 Welchen Debug meinst du? Diesen hier?
                  @ingranu sagte: Welchen Debug meinst du? Diesen hier?
                  Ja, und den ganz oben (debug output result). Dann bleibt nur noch der Debug-Block für das ausgefilterte "state".
                  • ingranu
                    @paul53 Sieht nur wie folgt aus:
                    unten keine Info Ausgabe mehr
                      @ingranu sagte: unten keine Info Ausgabe mehr
                      Wo befindet sich jetzt der Block "die Schleife abbrechen"?
                      • ingranu
                          @ingranu sagte: die Ausgabe erfolgt jetzt wie folgt, also alle Geräte:
                          Ist das die gesamte Log-Ausgabe (Variable result)?
                          Wenn ja, fehlt dort der Anfang "{XC_SUC}".
                          Dann frage mal zusätzlich ab:
                            @ingranu
                            Bei "aktualisiere" ist der Datenpunkt noch nicht zugewiesen.
                            • ingranu
                              @paul53 Wo fehlt das {XC_SUC} ?
                                Homoran Global Moderator Administrators @ingranu last edited by
                                im result! Deswegen wollte ich das result schon ganz am Anfang sehen
                                  @ingranu sagte: Wo fehlt das {XC_SUC} ?
                                  In der Log-Ausgabe von result.
                                  • ingranu
                                    @paul53 so ?
                                      @ingranu sagte: so ?
                                      Nein, result muss unverändert bleiben. So:
                                      Noch besser so:
                                      • ingranu
                                        @paul53 Folgende Ausgabe erhalte ich so:
                                        15:53:48.504	info	javascript.0 (4987) script.js.common.Mediola_states6: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                        15:53:50.003	info	javascript.0 (4987) script.js.common.Mediola_states6: request: http://192.168.3.97/command?XC_USER=admin&XC_PASS=D000000&XC_FNC=getstates
                                        15:53:55.002	info	javascript.0 (4987) script.js.common.Mediola_states6: request: http://192.168.3.97/command?XC_USER=admin&XC_PASS=D000000&XC_FNC=getstates
                                        15:54:00.002	info	javascript.0 (4987) script.js.common.Mediola_states6: request: http://192.168.3.97/command?XC_USER=admin&XC_PASS=D000000&XC_FNC=getstates
                                        15:54:05.002	info	javascript.0 (4987) script.js.common.Mediola_states6: request: http://192.168.3.97/command?XC_USER=admin&XC_PASS=D000000&XC_FNC=getstates
                                        15:54:07.465	info	javascript.0 (4987) Stop script script.js.common.Mediola_states6
                                          @ingranu sagte: Folgende Ausgabe erhalte ich so:
                                          Da hilft nur Debuggen:
                                          • ingranu
                                            Folgende Ausgabe nun:
                                            16:06:45.063	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'010','state':'FF:FF'}
                                            16:06:45.064	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'b3930080','state':'FF:FF'}
                                            16:06:45.063	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'ELRO','adr':'100550','state':'00:FF'}
                                            16:06:45.063	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'1db90080','state':'FF:FF'}
                                            16:06:45.065	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'7f450080','state':'FF:FF'}
                                            16:06:45.064	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'2e340080','state':'06:B2'}
                                            16:06:45.064	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'a5430080','state':'FF:FF'}
                                            16:06:45.065	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'44240080','state':'06:1E'}
                                            16:06:45.065	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'FS20','adr':'1a0132','state':'FF:FF'}
                                            16:06:45.065	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'25ca0080','state':'06:FF'}
                                            16:06:45.066	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'EVENT','adr':'01','state':'0'}
                                            16:06:45.066	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'60b5a280','state':'FF:FF'}
                                            16:06:45.066	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'518b1181','state':'06:86'}
                                            16:06:45.067	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'6616a881','state':'FF:FF'}
                                            16:06:45.067	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'00','state':'FF:FF'}
                                            16:06:45.068	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'a1234561','state':'FF:FF'}
                                            16:06:45.067	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'60b5a282','state':'06:60'}
                                            16:06:45.067	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'44205800','state':'FF:FF'}
                                            16:06:45.068	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'af760080','state':'06:1E'}
                                            16:06:45.068	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'13b80080','state':'FF:FF'}
                                            16:06:45.069	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'6616a880','state':'06:B2'}
                                            5573
