    5. Daten aus URL in blocky
    • ingranu
      ingranu @paul53 last edited by
      @paul53 so ?
        paul53 @ingranu last edited by paul53
        @ingranu sagte: so ?
        Nein, result muss unverändert bleiben. So:
        Noch besser so:
        ingranu 1 Reply Last reply Reply Quote 0
        • ingranu
          @paul53 Folgende Ausgabe erhalte ich so:
          15:53:48.504	info	javascript.0 (4987) script.js.common.Mediola_states6: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
          15:53:50.003	info	javascript.0 (4987) script.js.common.Mediola_states6: request: http://192.168.3.97/command?XC_USER=admin&XC_PASS=D000000&XC_FNC=getstates
          15:53:55.002	info	javascript.0 (4987) script.js.common.Mediola_states6: request: http://192.168.3.97/command?XC_USER=admin&XC_PASS=D000000&XC_FNC=getstates
          15:54:00.002	info	javascript.0 (4987) script.js.common.Mediola_states6: request: http://192.168.3.97/command?XC_USER=admin&XC_PASS=D000000&XC_FNC=getstates
          15:54:05.002	info	javascript.0 (4987) script.js.common.Mediola_states6: request: http://192.168.3.97/command?XC_USER=admin&XC_PASS=D000000&XC_FNC=getstates
          15:54:07.465	info	javascript.0 (4987) Stop script script.js.common.Mediola_states6
            @ingranu sagte: Folgende Ausgabe erhalte ich so:
            Da hilft nur Debuggen:
            • ingranu
              @paul53 said in Daten aus URL in blocky:
              Folgende Ausgabe nun:
              16:06:45.063	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'010','state':'FF:FF'}
              16:06:45.064	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'b3930080','state':'FF:FF'}
              16:06:45.063	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'ELRO','adr':'100550','state':'00:FF'}
              16:06:45.063	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'1db90080','state':'FF:FF'}
              16:06:45.065	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'7f450080','state':'FF:FF'}
              16:06:45.064	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'2e340080','state':'06:B2'}
              16:06:45.064	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'a5430080','state':'FF:FF'}
              16:06:45.065	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'44240080','state':'06:1E'}
              16:06:45.065	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'FS20','adr':'1a0132','state':'FF:FF'}
              16:06:45.065	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'25ca0080','state':'06:FF'}
              16:06:45.066	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'EVENT','adr':'01','state':'0'}
              16:06:45.066	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'60b5a280','state':'FF:FF'}
              16:06:45.066	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'518b1181','state':'06:86'}
              16:06:45.067	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'6616a881','state':'FF:FF'}
              16:06:45.067	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'00','state':'FF:FF'}
              16:06:45.068	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'a1234561','state':'FF:FF'}
              16:06:45.067	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'60b5a282','state':'06:60'}
              16:06:45.067	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'44205800','state':'FF:FF'}
              16:06:45.068	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'af760080','state':'06:1E'}
              16:06:45.068	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'13b80080','state':'FF:FF'}
              16:06:45.069	info	javascript.0 (4987) script.js.common.Mediola_states6: {'type':'IT','adr':'6616a880','state':'06:B2'}
                @ingranu sagte:
                Hinter dieser Zeile 11 müsste noch eine Ausgabe
                06:1E
                hinterher kommen und die Schleife abgebrochen werden.
                Poste bitte den erzeugten Javascript-Code in Code tags, denn im Blockly kann ich keinen Fehler erkennen.
                ingranu 2 Replies Last reply Reply Quote 0
                • ingranu
                  @paul53 Also eine Ausgabe das es ins LOG geschrieben wird oder welche?
                  • ingranu
                    @ingranu sagte:
                    06:1E
                      <variables>
                        <variable id="a53#cD`9m.m^/sDvE|%/">result</variable>
                        <variable id="pggQh3[cd#U:nf-=7B}2">arrayStart</variable>
                        <variable id="OsWBYNgKRnY1AT._O^]O">json</variable>
                        <variable id="T[V(!A,H,F8FBIfq_jn^">obj</variable>
                      </variables>
                      <block type="schedule" id="D]Ns;]+7ol~%34IWt{0e" x="-862" y="-1137">
                        <field name="SCHEDULE">*/5 * * * * *</field>
                          <block type="request" id="%by~Y1|my.FF[3LR)p8O">
                            <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
                            <field name="WITH_STATEMENT">TRUE</field>
                            <field name="LOG">log</field>
                            <value name="URL">
                              <shadow type="text" id="/uoTPJtK:4`s1yeNPV`c">
                                <field name="TEXT">http://192.168.3.97/command?XC_USER=admin&amp;XC_PASS=D000000&amp;XC_FNC=getstates</field>
                              <block type="debug" id="_P!k1cg`T%frNRj1/|^p">
                                <field name="Severity">debug</field>
                                <value name="TEXT">
                                  <shadow type="text">
                                  <block type="variables_get" id="{~hez)S@#_:Ne|E;`h]e">
                                    <field name="VAR" id="a53#cD`9m.m^/sDvE|%/">result</field>
                                  <block type="controls_if" id="Z+k7e33N~b+5?+NN/7LZ">
                                      <block type="variables_get" id="#qSkV3?-?Y]8n-o}8v^=">
                                      <block type="variables_set" id="j#0`q5Y2LNM^Z8@j;btG">
                                        <field name="VAR" id="pggQh3[cd#U:nf-=7B}2">arrayStart</field>
                                          <block type="text_indexOf" id="fghnaP5Z,6Xp]vQ{4-mg">
                                            <field name="END">FIRST</field>
                                              <block type="variables_get" id="5lw,irPU/N4OBfLbmO;C">
                                            <value name="FIND">
                                              <shadow type="text" id="QWdXUZxDk+OaWER}058N">
                                                <field name="TEXT">[</field>
                                          <block type="variables_set" id="b[i]jip4Oy;w)`8#1*S[">
                                            <field name="VAR" id="OsWBYNgKRnY1AT._O^]O">json</field>
                                              <block type="text_getSubstring" id="x-8rm|IpRnTt_m)k%VX2">
                                                <mutation at1="true" at2="false"></mutation>
                                                <field name="WHERE1">FROM_START</field>
                                                <field name="WHERE2">LAST</field>
                                                <value name="STRING">
                                                  <block type="variables_get" id="o~s|WPoNyhUb;Vl@|B1i">
                                                <value name="AT1">
                                                  <block type="variables_get" id="/)d^~Jn+Y-6]7F(,,wm;">
                                              <block type="debug" id="S(eR(-#t91[Y)ZJ|DYs!">
                                                <value name="TEXT">
                                                  <shadow type="text" id="2/2ub}SKk)9zAWV4FTvK">
                                                  <block type="variables_get" id="f4k,FmPzkG:Ql.EsZswV">
                                                  <block type="controls_forEach" id="?8QxPrns1xMcVUonzy;C">
                                                    <field name="VAR" id="T[V(!A,H,F8FBIfq_jn^">obj</field>
                                                    <value name="LIST">
                                                      <block type="convert_json2object" id="Nu09x`s%H3?Qr#SYjx@2">
                                                          <block type="variables_get" id="ieUi9aOpO4:+9HT^Z$9E">
                                                    <statement name="DO">
                                                      <block type="debug" id="WwKX./zJO!bQdy7Dp#RQ">
                                                        <value name="TEXT">
                                                          <block type="variables_get" id="f!8O3?=+]3|2t+Sd0iWS">
                                                          <block type="controls_if" id="Q^MF/(]`v@bN=auz8e4:">
                                                              <block type="logic_operation" id="Ddp+,dBTw~dWG7$Wvr^o" inline="false">
        <field name="OP">AND</field>
        <block type="get_attr" id="AB}QS3Katqvs2HzfGPA0">
        <value name="PATH">
        <shadow type="text" id="*F=*NkXztw%R)UGbTgSU">
        <field name="TEXT">type</field>
        <value name="OBJECT">
        <block type="logic_compare" id="m3U*;T=Gj7lvn?69?VlB">
        <field name="OP">EQ</field>
        <block type="variables_get" id="?nz#C/d0i`,R4#gg*/7.">
        <block type="text" id="Q3jHkZF?)$q#V,KAmAxj">
        <field name="TEXT">IT</field>
        <block type="get_attr" id=",6Q30We6V(OpV$J.,Z:I">
        <value name="PATH">
        <shadow type="text" id="V(^430l{^2BEGNn5lXO7">
        <field name="TEXT">adr</field>
        <block type="logic_compare" id="(MO0RnbIZ6d6WR@C_%U$">
        <block type="variables_get" id="3k`ILAOI;-[3HBa4yC~;">
        <block type="text" id="-dmm]cBqu[i,MU;=hS}6">
        <field name="TEXT">44240080</field>
                                                              <block type="debug" id="uh@rKCjV,Ib@SX7W_3S;">
        <value name="TEXT">
        <shadow type="text" id="#q^Tr+m{O3]i+=3z{fY7">
        <field name="TEXT">state</field>
        <block type="get_attr" id="-NNE,jc@4qz=!9E-4lO~">
        <value name="PATH">
        <shadow type="text" id="Nw?A#mALg$Kvu`k/2IZk">
        <block type="variables_get" id="wOPFu7erG.7NDn*en9t;">
        <block type="update" id="a%[3P:karCgR(B3M$}~K">
        <field name="OID">0_userdata.0.FS20</field>
        <block type="get_attr" id="rQ$pWfT!1`AwYS_EQ`wV">
        <value name="PATH">
        <shadow type="text" id="HYsU9Dol@9GPv[CH8(*?">
        <field name="TEXT">state.state</field>
        <block type="variables_get" id="w|Ul2(,0)!,^%(}X@QCW">
        <block type="controls_flow_statements" id="y[YT8RCRfpgN.[u?V{%G">
        <field name="FLOW">BREAK</field>
                      @ingranu
                      Habe jetzt den Fehler gesehen: Die Blöcke sind falsch verschachtelt. Richtig:
                      Der Vergleich außen und innen "Attribut type vom Objekt obj".
                      • ingranu
                        @paul53 ist ja so drin. stimmt das nicht?
                          @ingranu sagte: ist ja so drin.
                          Nein, ist so drin:
                          obj wird mit den Strings verglichen.
                          • ingranu
                            @paul53 okey hab geändert Ausgabe nun so:
                            BlocklyJavascriptTypeScriptRules
                            Skript läuft nicht
                            16:26:05.003	info	javascript.0 (4987) script.js.common.Mediola_states7: request: http://192.168.3.97/command?XC_USER=admin&XC_PASS=D000000&XC_FNC=getstates
                            16:26:05.056	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'443525','state':'00:B5'}
                            16:26:05.056	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'2b063b','state':'FF:FF'}
                            16:26:05.057	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'EVENT','adr':'02','state':'1'}
                            16:26:05.057	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'8d3700','state':'FF:FF'}
                            16:26:05.057	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'aaf900','state':'FF:FF'}
                            16:26:05.058	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'20d600','state':'FF:FF'}
                            16:26:05.058	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'EVENT','adr':'03','state':'1'}
                            16:26:05.058	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'903702','state':'FF:FF'}
                            16:26:05.058	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'1c291e','state':'FF:FF'}
                            16:26:05.059	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'8d3702','state':'FF:FF'}
                            16:26:05.059	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'0b3212','state':'FF:FF'}
                            16:26:05.059	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'ffffa9','state':'FF:FF'}
                            16:26:05.059	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'015301','state':'FF:FF'}
                            16:26:05.064	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'231a42','state':'FF:FF'}
                            16:26:05.065	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'ELRO','adr':'123409','state':'FF:FF'}
                            16:26:05.065	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'ffff01','state':'FF:FF'}
                            16:26:05.066	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'aa3c0080','state':'FF:FF'}
                            16:26:05.066	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'271b20','state':'FF:FF'}
                            16:26:05.066	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'FS20','adr':'800001','state':'FF:FF'}
                            16:26:05.066	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'ELRO','adr':'000550','state':'00:21'}
                            16:26:05.067	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'518b1180','state':'06:21'}
                            16:26:05.067	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'010','state':'FF:FF'}
                            16:26:05.067	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'ELRO','adr':'100550','state':'00:FF'}
                            16:26:05.068	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'1db90080','state':'FF:FF'}
                            16:26:05.068	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'b3930080','state':'FF:FF'}
                            16:26:05.069	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'2e340080','state':'06:B5'}
                            16:26:05.069	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'a5430080','state':'FF:FF'}
                            16:26:05.069	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'7f450080','state':'FF:FF'}
                            16:26:05.070	info	javascript.0 (4987) script.js.common.Mediola_states7: {'type':'IT','adr':'44240080','state':'06:21'}
                            • ingranu
                              ingranu @paul53 last edited by ingranu
                              @ingranu Es wird nun ein Wert geschrieben.
                                @ingranu sagte: Ausgabe nun so:
                                Nach der letzten Zeile müsste noch kommen:
                                06:21
                                Der Schleifenabbruch erfolgte anscheinend (falls es nicht der letzte Eintrag im Array war).
                                • ingranu
                                    @ingranu
                                    Passt. Was soll mit der Variable id passieren?
                                    Die Debug-Blöcke können nun deaktiviert oder gelöscht werden.
                                    • ingranu
                                      @paul53 Sorry das mit dem Block ID ist falsch habe ich raus.
                                      Aber für mein Verständnis: Das Script schreibt nun nur von meinem Gerät 44240080 ins Logfile?
                                        @ingranu sagte: Das Script schreibt nun nur von meinem Gerät 44240080 ins Logfile?
                                        Das Script schreibt nur von diesem Gerät in den Datenpunkt "FS20".
                                        Sollen mehrere Datenpunkte geschrieben werden, sind innerhalb der Schleife weitere Abfragen erforderlich.
                                        • ingranu
                                          @paul53 In der TAT es geht 🙂 Vielen Dank, ohne Dich hätte ich das niemals hingekriegt !!
                                          Bewundere sowas echt das hier einem so toll geholfen wird!
                                          Danke dir für den tollen Support!
                                          5573
