    4. npm ERR! code ENOTEMPTY - Adapter Upgrade nicht mehr möglich
    • Glasfaser
      Glasfaser @djsirius last edited by
      @djsirius sagte in npm ERR! code ENOTEMPTY - Adapter Upgrade nicht mehr möglich:
      iobroker is not running on this host.
      iobroker start
      mal versucht !?
        Thomas Braun Most Active @djsirius last edited by
        Wer schreibt dir denn hier Emails:
        Sie haben neue Post in /var/mail/iobroker.
        System aktuell halten:
        Aktualisierung für 14 Pakete verfügbar.
        Seit heute bekomme ich meinen iobroker nicht mehr gestartet.
        Konkret?
        iobroker start
        sagt?
          djsirius @Thomas Braun last edited by
          uodates sind gemacht. iobroker start bringt nichts.
          iobroker@debian:~$ iobroker start
          iobroker@debian:~$ iob status
          Objects type: jsonl
          States  type: jsonl
            Thomas Braun Most Active @djsirius last edited by Thomas Braun
            @djsirius
            iob logs
            sagt?
            Du bist aber auch etwas OffTopic hier.
              @thomas-braun said in npm ERR! code ENOTEMPTY - Adapter Upgrade nicht mehr möglich:
              iob logs
              iobroker@debian:~$ iob logs
              Uncaught Rejection: Error: Cannot find module 'moment'
              Require stack:
              - /opt/iobroker/node_modules/file-stream-rotator/FileStreamRotator.js
              - /opt/iobroker/node_modules/winston-daily-rotate-file/daily-rotate-file.js
              - /opt/iobroker/node_modules/winston-daily-rotate-file/index.js
              - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/logger.js
              - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
              - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
              - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                  at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
                  at Function.Module._load (node:internal/modules/cjs/loader:833:27)
                  at Module.require (node:internal/modules/cjs/loader:1057:19)
                  at require (node:internal/modules/cjs/helpers:103:18)
                  at Object.<anonymous> (/opt/iobroker/node_modules/file-stream-rotator/FileStreamRotator.js:15:14)
                  at Module._compile (node:internal/modules/cjs/loader:1155:14)
                  at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
                  at Module.load (node:internal/modules/cjs/loader:1033:32)
                  at Function.Module._load (node:internal/modules/cjs/loader:868:12)
                @djsirius
                cd /opt/iobroker
                sudo -H -u iobroker npm install iobroker.js-controller
                  iobroker@debian:~$ cd /opt/iobroker
                  iobroker@debian:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-contr        oller
                  npm ERR! syscall rename
                  npm ERR! path /opt/iobroker/node_modules/iobroker.admin
                  npm ERR! dest /opt/iobroker/node_modules/.iobroker.admin-TtUA2igk
                  npm ERR! errno -39
                  npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.admin' -> '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk'
                  npm ERR!     /home/iobroker/.npm/_logs/2022-11-03T12_22_25_791Z-debug-0.log
                    ENOTEMPTY:
                    Kennst du ja schon:
                    for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                      @thomas-braun Vielen Dank!
                      Aber warum habe ich so oft diese Probleme?
                        Das weiß ich nicht.
                        Ich hab das hier nie auf meinen Systemen. Und da ist eins dabei, das wird andauernd mit 'wilden Beta/Alpha-Versionen' beackert.
                        • Zelly
                          Zelly @Thomas Braun last edited by
                          ich traue mich schon fast gar nicht nachzufragen, weil ich vermutlich auch Murks gemacht habe. Ich kenne mich echt wenig aus und mein ganzes Wissen habe ich nur aus solchen Foren.
                          Zu meinem Problem: Auch ich kann keine Adapter installieren und upgraden.
                          Genau bei dem punkt habe ich folgende Ausgabe:
                          pi@raspberrypi:~ $ iobroker update -i
                          Used repository: stable
                          Objects database error: write EPIPE
                          Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                          States database error: connect ECONNREFUSED 127.0.0.1:9000
                          Adapter "admin" : 6.2.23 , installed 6.2.23
                          Adapter "alexa2" : 3.21.0 , installed 3.21.0
                          Adapter "backitup" : 2.5.4 , installed 2.4.12 [Updatable]
                          Adapter "daswetter" : 3.1.4 , installed 3.1.4
                          Adapter "deconz" : 1.3.21 , installed 2.0.5
                          Adapter "discovery" : 3.0.5 , installed 3.1.0
                          Adapter "email" : 1.1.3 , installed 1.1.4
                          Adapter "firetv" : 1.0.0 , installed 1.0.0
                          Adapter "geofency" : 1.1.1 , installed 1.2.4
                          Adapter "info" : 1.9.19 , installed 1.9.21
                          Adapter "javascript" : 6.0.3 , installed 6.0.3
                          Controller "js-controller": 4.0.23 , installed 4.0.23
                          Adapter "mihome-vacuum": 3.8.6 , installed 3.6.0 [Updatable]
                          Adapter "nuki" : 1.6.0 , installed 1.6.0
                          Adapter "pushover" : 3.0.3 , installed 3.0.3
                          Adapter "shelly" : 6.0.0 , installed 6.2.4
                          Adapter "shuttercontrol": 1.4.18 , installed 1.4.18
                          Adapter "simple-api" : 2.7.0 , installed 2.7.2
                          Adapter "socketio" : 4.2.0 , installed 6.1.10
                          Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1
                          Adapter "tuya" : 3.9.4 , installed 3.7.2 [Updatable]
                          Adapter "vis" : 1.4.15 , installed 1.4.15
                          Adapter "web" : 4.3.0 , installed 5.2.10
                          Adapter "ws" : 1.3.0 , installed 2.1.5
                          Für mich zu viel "Error" in den ersten Zeilen...
                          Kann mir vielleicht jemand helfen?
                            Thomas Braun Most Active @Zelly last edited by
                            @zelly
                            Da ist was mit der Datenbank.
                            du -h
                            iobroker restart
                            sagen z. B.
                            Zelly 1 Reply Last reply Reply Quote 0
                            • Zelly
                              Die Ausgabe ist zu lang, um sie hier zu posten... aber nach restart war immer noch das problem da.
                              Ist hier was falsch?
                              pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v18.12.1
                              v18.12.1
                              8.19.2
                              nodejs:
                              Installiert: 18.12.1-deb-1nodesource1
                              Installationskandidat: 18.12.1-deb-1nodesource1
                              Versionstabelle:
                              *** 18.12.1-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                              100 /var/lib/dpkg/status
                              10.24.0~dfsg-1~deb10u2 500
                                @zelly
                                df -h
                                meinte ich auch, sorry.
                                Nodejs ist grundsätzlich wohl sauber installiert, allerdings ist die Empfehlung v16.
                                Dein Betriebssystem ist aus dem regulären Support raus, installier da Bullseye.
                                • Zelly
                                  Zelly @Thomas Braun last edited by Homoran
                                  zunächst: vielen Dank für deine Unterstützung!
                                  pi@raspberrypi:~ $ df -h
                                  Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                                  /dev/root        15G    4,2G  9,6G   31% /
                                  devtmpfs        430M       0  430M    0% /dev
                                  tmpfs           462M       0  462M    0% /dev/shm
                                  tmpfs           462M     18M  444M    4% /run
                                  tmpfs           5,0M    4,0K  5,0M    1% /run/lock
                                  tmpfs           462M       0  462M    0% /sys/fs/cgroup
                                  /dev/mmcblk0p1  253M     49M  204M   20% /boot
                                  tmpfs            93M       0   93M    0% /run/user/1000
                                    @zelly
                                    iobroker status
                                    • Zelly
                                      pi@raspberrypi:~ $ iobroker status
                                      Objects type: jsonl
                                      States  type: jsonl
                                        @zelly
                                        Okay...
                                        iobroker stop
                                        iobroker fix
                                        iobroker update
                                        • Zelly
                                          so... ist jetzt einmal durchgelaufen:
                                          Kann ich jetzt wieder den iobroker starten?
                                          Ich vermute "Bullseye" muss nochmal separat installiert werden?
                                            Thomas Braun Most Active @Zelly last edited by Thomas Braun
                                            @zelly
                                            Dann zieh die Adapter jetzt auf den aktuellen Stand.
                                            Auf Bullseye kann u. U. online upgegraded werden.
                                            Ich hab das z. B. hier mal gemacht:
                                            https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                                            Ansonsten: Am besten eine frische Neuinstallation, Backup einspielen.
                                            13167
