    5. [gelöst]NUKI SmartLock-Prüfung&Schließung in der Nacht z.B.
      A Former User @ste_glei last edited by
      @ste_glei
      Suuuuper, vielen herzlichen Dank für Deine Hilfe und Blockly. Damit ich diesen nicht komplett neu Schreiben muss --- wär natürlich schon möglich - könntest Du den Script in Textform hochladen?
      LG
      Vazi
      ste_glei 1 Reply Last reply Reply Quote 0
      • ste_glei
        ste_glei @Guest last edited by ste_glei
        @vazi
          <variables>
            <variable type="timeout" id="timeout2">timeout2</variable>
          </variables>
          <block type="on_ext" id="x;4xNgX6mM$*qr#?jxNI" x="37" y="600">
            <value name="OID0">
              <shadow type="field_oid" id="@GekrU8kUz]ft(]lq!Fl">
                <field name="oid">alias.0.NUKI.Haustür.Status</field>
            <value name="OID1">
              <shadow type="field_oid" id="vZ*o+ZAp_RLb{[pD:Tv+">
                <field name="oid">alias.0.NUKI.Keller.Status</field>
              <block type="controls_if" id="WaM.e`j`E$#1!sMV.LO4">
                  <block type="time_compare" id="lea/p!DXp*9;FEk%1Gnb">
                    <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true"></mutation>
                    <field name="START_TIME">22:00</field>
                    <field name="END_TIME">6:00</field>
                  <block type="controls_if" id="AwPF)ew`OmNToVgCoMee">
                      <block type="logic_compare" id="|o|EX-f`r.(R4yo#KFru">
                        <field name="OP">EQ</field>
                          <block type="get_value" id="5E}svIdLycJp}ZkaobC:">
                            <field name="OID">alias.0.NUKI.Haustür.Status</field>
                          <block type="math_number" id="=ExRte}=QvWB]UR_|VOf">
                            <field name="NUM">3</field>
                      <block type="timeouts_settimeout" id="FbaB4|S){wrFovunRjEi">
                        <field name="DELAY">15</field>
                          <block type="controls_if" id="13dspbl6vd*R5sGSR:i3">
                              <block type="logic_compare" id="Wq(rlu$Lh{*}]gBfhQcf">
                                <field name="OP">NEQ</field>
                                  <block type="get_value" id=";QYn)@U{-PYyK-97#?~w">
                                  <block type="math_number" id="/F*!{T%W$zf9J1)(Efu~">
                              <block type="procedures_callnoreturn" id="hZq^JRseF(1Up?X!))!=">
                                <mutation name="haustür-zusperren"></mutation>
                      <block type="controls_if" id="r#d83]C^BdQs-=Jtn4{r">
                          <block type="logic_compare" id="lE[mqm}j,~lpaG7/mf1F">
                              <block type="get_value" id=",4X-$0Ad5}AI{zjZJ3xQ">
                                <field name="OID">alias.0.NUKI.Keller.Status</field>
                              <block type="math_number" id="EUxSyR;v|ws{bM6Y`e4R">
                          <block type="timeouts_settimeout" id="li5n4cV{?T8M|As]7}jB">
                              <block type="controls_if" id="b~YZN[U%JLi?q*C)J9dG">
                                  <block type="logic_compare" id="FAG~$gI3m%[6*JGl/S=Q">
                                      <block type="get_value" id="EfH:yLFkp$k14vP+,,Df">
                                      <block type="math_number" id="mQR:O_2?c/Q7+?fV9g.Z">
                                  <block type="procedures_callnoreturn" id="o/YfDRG*WApFn^%*[3L9">
                                    <mutation name="keller-zusperren"></mutation>
          <block type="procedures_defnoreturn" id="miyhJPhMD!P6V51XlRKU" x="63" y="1213">
            <field name="NAME">haustür-zusperren</field>
            <statement name="STACK">
              <block type="control" id="=}CniOj9c_D!+RF[i?_{">
                <field name="OID">alias.0.NUKI.Haustür.Aktion</field>
                <field name="DELAY_MS">10</field>
                  <block type="math_number" id="UoCm1entnk}Gd]5JZE0j">
                    <field name="NUM">1</field>
          <block type="procedures_defnoreturn" id="[UYf/wtLb|JYZBLAui=v" x="62" y="1287">
            <field name="NAME">keller-zusperren</field>
              <block type="control" id="bJA.H0S$;c8WfgC:6L-f">
                <field name="OID">alias.0.NUKI.Keller.Aktion</field>
                  <block type="math_number" id="lI_B..).Xm5S4,%_7Qc5">
        Da ich den Nuki-Adapter nicht verwende bitte die Werte "3=entrieglelt" und "1=zusperren" noch überprüfen ob die richtig sind.
        mfg
          A Former User @denjo last edited by
          @denjo
          Danke für die Info. Der Status wird bei NUKI direkt abgefragt, sprich hat einen eigenen Datenpunkt mit LOCK und UNLOCK. Somit betrifft es nicht den Sensor und von daher versuche ich nun die Hilfeleistung unten von @ste_glei . Das sollte eigentlich meine Bedürfnisse abdecken.
          PS: Was die Zuverlässigkeit der Sensore von NUKI anbelangt, muss ich die zustimmen. Beim Modell Smart Lock 2.0 sind halt noch die Magnetsensoren dabei. Diese sind (immer noch) nur in Beta ..... beim 3.0 werden nun separate, mit Batteriebetriebene Sensoren mitgeliefert und diese sollten problemlos funktionieren. Somit kommt Dein Vorschlag, andere Tür- und Fensterkontakte zu besorgen um diesen Status auch korrekt angezeigt zu bekommen.
          Sind Xiaomi Aqara hierfür gut geeignet? Habe bis jetzt lediglich 2 Homatic Tür- und Fenstersensoren im Einsatz.
            @ste_glei
            Wahnsinn, was für ein Service von Dir 👍 . Mir bleibt nur zu Danken und heute Abend zu Testen.
              A Former User @Guest last edited by
              @ste_glei
              Ich erlaube mir nochmals Deine Hilfe in Anspruch zu nehmen. Auf dem Bild vom Blockly sieht man nicht alles....
              Braucht es die beiden Felder bzw. einer davon?(da ich ja nur eine Türe habe) Habe diese weggelassen....
              Ich habe dann Dein Skript importiert und angepasst... Soweit so gut.
              Die Schließung um 22:00 funktioniert, jedoch nicht die "wiederschliessung" falls die Türe nochmals geöffnet wird... Siehst Du ev. wo ich den Fehler habe?
              DJMarc75 Cinimod ste_glei 3 Replies Last reply Reply Quote 0
              • DJMarc75
                DJMarc75 @Guest last edited by
                @vazi sagte in NUKI SmartLock - Prüfung & Schließung in der Nacht z.B.:
                möglicherweise wird folgender Block helfen:
                • Cinimod
                  Cinimod Most Active @Guest last edited by Cinimod
                  @vazi
                  Genau, nimm lieber "zeit nicht zwischen". Tag-übergreifend kann es da zu Problemen kommen. Und den Timer solltest du irgendwo stoppen, am besten direkt nach dem trigger. Damit ist eine zweite abfrage nach dem Timer auch überflüssig.
                  • ste_glei
                    @vazi
                    ich vermute "gleich" und "nicht gleich" machen dir einen Strich durch die Rechnung
                      A Former User @ste_glei last edited by A Former User
                      Hallo Leute
                      Auf Euch kann man zählen, echt. Tolle Hilfeleistung. Vielen Dank schon einmal. Werde Eure Hinweise heute Abend mal testen.
                      @Cinimod Frage....ich finde einfach den Block mit "und" der vor "Aktuelle zeit....." nicht....?
                      • Cinimod
                        @vazi
                          A Former User @Cinimod last edited by A Former User
                          @cinimod Vielen Dank für Deine Hilfe - und genau das war nun auch die Lösung!👍 Man(n) lernt nie aus.
                          Eventuell kann es auch noch jemand anders verwenden. So sieht nun mein Blockly aus:
                          Ich danke Euch allen für die tolle Hilfe - tragt Sorge zu Euch, bleibt gesund!
                          Gruss
                          Vazi
                          ? 1 Reply Last reply Reply Quote 1
                            Sorry Leute, darf ich doch nochmals "nachhaken.."?
                            Wie müsste ich es handhaben, wenn das Schloss nur um 22:00 Uhr schliesst, sofern die Türe nicht bereits geschlossen ist? Wenn jemand die Türe bereits vorher zusperrt, dann sollte das Schloss um 22:00 Uhr nicht nochmals den Sperrvorgang vornehmen. Dies würde den Batterien gut tun, da das Schloss dann keinen unnötigen Vorgang vornehmen muss, da ja die Türe bereits zugesperrt ist.
                            Danke und Gruss
                            Vazi
                            • Cinimod
                              @vazi
                              Einach die schließen Aktion in einen falls block schieben und abfragen ob current lock state ungleich 1.
                              Wobei die 1 nur geraten ist, die Nummer des verschlossenen Zustands muss da natürlich hin.
                                @cinimod sagte in NUKI SmartLock-Prüfung&Schließung in der Nacht z.B.:
                                @vazi
                                Danke cinimod. War auf der gleichen "Spur"... nur, wo platziere ich nun den Block genau? Siehe mein Blockly oben... vor Zeitplan oder nachher?.... stehe glaube ich gerade auf der Leitung...sorry
                                • Cinimod
                                  @vazi
                                  Um 22 Uhr -> Falls Tür nicht verriegelt (ungleich/nicht 1) -> steuere verriegeln
                                  Sollte das nicht nicht zutreffen passiert auch nichts !
                                    @vazi
                                    Wunderbar, funktioniert tadellos. 👍 👏
                                    Auf Euch (Dich) ist hier im Forum echt Verlass, vielen Dank dafür.
                                    Gruss
                                    Vazi
                                    • I
                                      iobroker_anfaenger @Guest last edited by
                                      @vazi Hänge mich mal dran.
                                      Habe den Nuki Smart Lock Adapter installiert. Bei den Objekten ist nuki aber komplett leer. Die Instant läuft aber und hat Kontakt zum Nuki. Habe auch die 2er Version.
                                      Kann so natürlich nicht den Status abfragen da kein DP vorhanden ist in der Instants.
                                      Hast du einen Tipp?
                                        A Former User @iobroker_anfaenger last edited by
                                        @iobroker_anfaenger
                                        Hallo und willkommen im Forum.
                                        Nun, ich habe den nuki-extended installiert. Ich verwende zudem 2 Bridges. Ich weiss halt nicht, wie es bei Dir aussieht.....
                                        Unter Konfiguration habe ich dann jeweils den API Token eingetragen, welcher ja in der Nuki App ersichtlich ist.
                                        • I
                                          iobroker_anfaenger @Guest last edited by iobroker_anfaenger
                                          @vazi Hi, danke,jetzt klappt es
                                          ? 2 Replies Last reply Reply Quote 0
                                            @iobroker_anfaenger
                                            In der Nuki App. Sie müssen zuerst die Bridge in den Wartungsmodus versetzen. Hie wird es beschrieben:
                                            Auf der Website von NUKI
                                            1895
