    4. Test Adapter mihome-cloud
      Thomas Braun Most Active @tombox last edited by
      @tombox
      Ich vermute es liegt an den verschiedenen Servern. Meine Geräte sind alle 'Chinesen', die liegen in der dortigen Cloud.
        @thomas-braun habe mal die region hinzugefügt
          Thomas Braun Most Active @tombox last edited by Thomas Braun
          @tombox
          Danke. Da klemmt es aber noch:
          2022-11-05 10:15:18.021  - info: mihome-cloud.0 (50883) starting. Version 0.0.1 (non-npm: TA2k/ioBroker.mihome-cloud#71b29c7c083770ffa85128ad332c3b6a104744b0) in /opt/iobroker/node_modules/iobroker.mihome-cloud, node: v19.0.1, js-controller: 4.0.23
          2022-11-05 10:15:18.061  - info: mihome-cloud.0 (50883) Login to MiHome Cloud
          2022-11-05 10:15:18.532  - debug: mihome-cloud.0 (50883) "&&&START&&&{\"serviceParam\":\"{\\\"checkSafePhone\\\":false,\\\"checkSafeAddress\\\":false,\\\"lsrp_score\\\":0.0}\",\"qs\":\"%3Fsid%3Dxiaomiio%26_json%3Dtrue\",\"code\":70016,\"description\":\"登录验证失败\",\"securityStatus\":0,\"_sign\":\"0psX-KEY-GEAENDERT-bRqU=\",\"sid\":\"xiaomiio\",\"result\":\"error\",\"captchaUrl\":null,\"callback\":\"https://sts.api.io.mi.com/sts\",\"location\":\"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psX-KEY-GEAENDERT-bRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=\",\"pwd\":0,\"child\":0,\"desc\":\"登录验证失败\"}"
          2022-11-05 10:15:18.767  - debug: mihome-cloud.0 (50883) "&&&START&&&{\"qs\":\"%3Fsid%3Dxiaomiio%26_json%3Dtrue\",\"ssecurity\":\"LoED-KEY-GEAENDERT-3RMw==\",\"code\":0,\"passToken\":\"V1:DXmu-KEY-GEAENDERT--KEY-GEAENDERT--KEY-GEAENDERT--KEY-GEAENDERT-CME0=\",\"description\":\"成功\",\"securityStatus\":0,\"nonce\":1287-KEY-GEAENDERT-9440,\"userId\":1-ID-GEANDERT-2,\"cUserId\":\"Y15sv_vRiW-KEY-GEAENDERT-74Lc\",\"result\":\"ok\",\"psecurity\":\"fO12-KEY-GEAENDERT-jajg==\",\"captchaUrl\":null,\"location\":\"https://sts.api.io.mi.com/sts?d=wb_b-KEY-GEAENDERT-e00f&ticket=0&pwd=1&p_ts=1667-KEY-GEAENDERT-8000&fid=0&p_lm=1&auth=BsI3-KEY-GEAENDERT--KEY-GEAENDERT--KEY-GEAENDERT--KEY-GEAENDERT-3D&m=1&_group=DEFAULT&tsl=0&p_ca=0&p_ur=DE&p_idc=Europe&nonce=Laf2P-KEY-GEAENDERT-qBpL&_ssign=1lDi-KEY-GEAENDERT-A%3D\",\"pwd\":1,\"child\":0,\"desc\":\"成功\"}"
          2022-11-05 10:15:18.931  - debug: mihome-cloud.0 (50883) "ok"
          2022-11-05 10:15:18.961  - error: mihome-cloud.0 (50883) Error: getaddrinfo ENOTFOUND cn.api.io.mi.com
          2022-11-05 10:15:18.977  - error: mihome-cloud.0 (50883) Error: getaddrinfo ENOTFOUND cn.api.io.mi.com
          2022-11-05 10:15:18.993  - error: mihome-cloud.0 (50883) Error: getaddrinfo ENOTFOUND cn.api.io.mi.com
          2022-11-05 10:15:18.995  - error: mihome-cloud.0 (50883) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2022-11-05 10:15:18.996  - error: mihome-cloud.0 (50883) unhandled promise rejection: Cannot read properties of undefined (reading 'homelist')
          2022-11-05 10:15:18.997  - error: mihome-cloud.0 (50883) TypeError: Cannot read properties of undefined (reading 'homelist')
              at MihomeCloud.getActions (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:366:35)
              at MihomeCloud.onReady (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:90:18)
              at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
          2022-11-05 10:15:18.998  - error: mihome-cloud.0 (50883) Cannot read properties of undefined (reading 'homelist')
          2022-11-05 10:15:19.005  - info: mihome-cloud.0 (50883) terminating
          2022-11-05 10:15:19.007  - warn: mihome-cloud.0 (50883) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2022-11-05 10:15:19.652  - error: host.chet instance system.adapter.mihome-cloud.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2022-11-05 10:15:19.653  - info: host.chet Restart adapter system.adapter.mihome-cloud.0 because enabled
          2022-11-05 10:15:19.653  - warn: host.chet Do not restart adapter system.adapter.mihome-cloud.0 because restart loop detected
          Ping sagt:
          echad@chet:~ $ ping cn.api.io.mi.com
          ping: cn.api.io.mi.com: Name or service not known
          echad@chet:~ $ ping api.io.mi.com
          PING api.io.mi.com (183.84.6.21) 56(84) bytes of data.
          64 bytes from 183.84.6.21 (183.84.6.21): icmp_seq=1 ttl=41 time=319 ms
          64 bytes from 183.84.6.21 (183.84.6.21): icmp_seq=2 ttl=41 time=316 ms
          64 bytes from 183.84.6.21 (183.84.6.21): icmp_seq=3 ttl=41 time=316 ms
          ^C
          --- api.io.mi.com ping statistics ---
          4 packets transmitted, 3 received, 25% packet loss, time 3004ms
          rtt min/avg/max/mdev = 315.914/316.994/318.794/1.281 ms
            tombox @Thomas Braun last edited by
            @thomas-braun jap war die falsche url jetzt passt es
              @tombox
              Stimmt, jetzt passt es:
              2022-11-05 11:03:01.861  - info: mihome-cloud.0 (53948) Found 21 devices
                @thomas-braun wieviele haben davon unter Objekte ein status ordner?
                  @tombox
                  Nur der Staubsauger:
                    @thomas-braun Ok ja wenn mir jemand noch ein Gerät kann ich schauen wie die anders abgerufen werden
                      @tombox
                      Ein Gerät... was? 😉
                        @thomas-braun Ein gerät freigibt oder ein account gibt dann kann ich schauen was die app genau macht
                          A Former User last edited by
                          Mein 3 Smartmi Fans tauchen auch mit umfangreichen Infos auf. Klappt!
                          • JackDaniel
                            JackDaniel last edited by JackDaniel
                            mit der letzten version stürzt der adapter ab, wahrscheinlich weil der luftbefeuchter offline ist
                            mihome-cloud.0
                            2022-11-06 07:04:04.610	error	TypeError: Cannot read properties of undefined (reading '75543767')
                            mihome-cloud.0
                            2022-11-06 07:04:04.609	error	/home/rpc/75543767
                            mihome-cloud.0
                            2022-11-06 07:04:04.422	error	{"code":-8,"message":"invalid param","result":null}
                            mihome-cloud.0
                            2022-11-06 07:04:04.422	error	Error getting Events of the device for R2D2 (320373564)
                            mihome-cloud.0
                            2022-11-06 07:04:04.181	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                            mihome-cloud.0
                            2022-11-06 07:04:04.180	info	terminating
                            mihome-cloud.0
                            2022-11-06 07:04:04.175	error	Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus
                            mihome-cloud.0
                            2022-11-06 07:04:04.174	error	Error: Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._setObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2980:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3211:29) at processImmediate (node:internal/timers:468:21)
                            mihome-cloud.0
                            2022-11-06 07:04:04.173	error	unhandled promise rejection: Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus
                            mihome-cloud.0
                            2022-11-06 07:04:04.172	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            mihome-cloud.0
                            2022-11-06 07:04:04.123	error	TypeError: Cannot read properties of null (reading '0')
                            mihome-cloud.0
                            2022-11-06 07:04:03.050	info	Found plugin for deerma.humidifier.jsq
                            mihome-cloud.0
                            2022-11-06 07:04:03.050	info	Found 1 remote events for yeelink.light.bslamp1
                            mihome-cloud.0
                            2022-11-06 07:04:03.049	info	Found 3 remote commands for yeelink.light.bslamp1
                            mihome-cloud.0
                            2022-11-06 07:03:59.697	info	Found plugin for yeelink.light.bslamp1
                            mihome-cloud.0
                            2022-11-06 07:03:59.696	error	TypeError: Cannot read properties of null (reading '0')
                            mihome-cloud.0
                            2022-11-06 07:03:58.492	info	Found plugin for roborock.vacuum.s5
                            mihome-cloud.0
                            2022-11-06 07:03:58.350	info	Fetching Plugins
                            mihome-cloud.0
                            2022-11-06 07:03:58.339	info	prop.ct
                            mihome-cloud.0
                            2022-11-06 07:03:58.339	info	prop.bright
                            mihome-cloud.0
                            2022-11-06 07:03:58.338	info	prop.power
                            mihome-cloud.0
                            2022-11-06 07:03:58.338	info	Found yeelink.light.bslamp1 (Nachttischlampe) with 3 properties
                            mihome-cloud.0
                            2022-11-06 07:03:58.334	info	event.status
                            mihome-cloud.0
                            2022-11-06 07:03:58.334	info	Found roborock.vacuum.s5 (R2D2) with 1 properties
                            mihome-cloud.0
                            2022-11-06 07:03:58.329	info	Found 3 devices
                            mihome-cloud.0
                            2022-11-06 07:03:58.140	info	Get devices
                            mihome-cloud.0
                            2022-11-06 07:03:58.136	info	Login successful
                            mihome-cloud.0
                            2022-11-06 07:03:57.374	info	Login to MiHome Cloud
                            mihome-cloud.0
                            2022-11-06 07:03:57.353	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.mihome-cloud#567a013f3147de9ffcf2289a907b73fa852dd039) in /opt/iobroker/node_modules/iobroker.mihome-cloud, node: v16.18.1, js-controller: 4.0.23
                            edit, passiert auch wenn der luftbefeuchter online ist
                            mihome-cloud.0
                            2022-11-06 07:11:01.673	error	TypeError: Cannot read properties of undefined (reading '75543767')
                            mihome-cloud.0
                            2022-11-06 07:11:01.673	error	/home/rpc/75543767
                            mihome-cloud.0
                            2022-11-06 07:11:01.672	debug	{"code":0,"error":{"code":-32601,"message":"Method not found."},"exe_time":0,"id":6507368,"message":"ok","net_cost":0,"ot_cost":0,"otlocalts":1667715061666172}
                            mihome-cloud.0
                            2022-11-06 07:11:01.551	error	{"code":-8,"message":"invalid param","result":null}
                            mihome-cloud.0
                            2022-11-06 07:11:01.550	error	Error getting Events of the device for R2D2 (320373564)
                            mihome-cloud.0
                            2022-11-06 07:11:01.378	debug	undefined
                            mihome-cloud.0
                            2022-11-06 07:11:01.377	debug	{"code":0,"exe_time":1,"id":491585,"message":"ok","net_cost":30,"ot_cost":0,"otlocalts":1667715061367277,"result":"unknown_method"}
                            mihome-cloud.0
                            2022-11-06 07:11:01.282	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                            mihome-cloud.0
                            2022-11-06 07:11:01.282	info	terminating
                            mihome-cloud.0
                            2022-11-06 07:11:01.265	error	Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus
                            mihome-cloud.0
                            2022-11-06 07:11:01.265	error	Error: Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._setObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2980:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3211:29) at processImmediate (node:internal/timers:468:21)
                            mihome-cloud.0
                            2022-11-06 07:11:01.264	error	unhandled promise rejection: Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus
                            mihome-cloud.0
                            2022-11-06 07:11:01.263	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            mihome-cloud.0
                            2022-11-06 07:11:01.246	error	TypeError: Cannot read properties of null (reading '0')
                            mihome-cloud.0
                            2022-11-06 07:11:00.308	info	Found plugin for deerma.humidifier.jsq
                            mihome-cloud.0
                            2022-11-06 07:11:00.308	info	Found 1 remote events for yeelink.light.bslamp1
                            mihome-cloud.0
                            2022-11-06 07:11:00.308	info	Found 3 remote commands for yeelink.light.bslamp1
                            mihome-cloud.0
                            2022-11-06 07:10:56.845	info	Found plugin for yeelink.light.bslamp1
                            mihome-cloud.0
                            2022-11-06 07:10:56.845	error	TypeError: Cannot read properties of null (reading '0')
                            mihome-cloud.0
                            2022-11-06 07:10:55.756	info	Found plugin for roborock.vacuum.s5
                            mihome-cloud.0
                            2022-11-06 07:10:55.756	debug	{"code":0,"message":"","result":{"latest_info":[{"plugin_id":1000570,"plugin_package_id":1012902,"version":39,"sdk_version":10047,"change_log":"修复和优化一些问题,内部版本52","download_url":"https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2020-12-08/signed_10047_1000570_39_IOS_bundle_e6776fdd671602f308b9be25d889bb0c.zip","size":5443322,"model":"roborock.vacuum.s5","force_update_status":0,"status":8,"md5sum":"e6776fdd671602f308b9be25d889bb0c","gray_info":"{\"data\":[2263,5263],\"type\":\"range\"}","platform":2,"create_time":1607418709856,"dev_mode":1},{"plugin_id":1000708,"plugin_package_id":1002507,"version":2,"sdk_version":10026,"change_log":"1.修改jira。\n1.fix jira.","download_url":"https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2019-09-11/signed_10026_1000708_2_IOS_bundle_ec15991cae11aa91ee5abb3f8e94b0a3.zip","size":5913729,"model":"yeelink.light.bslamp1","force_update_status":0,"status":8,"md5sum":"ec15991cae11aa91ee5abb3f8e94b0a3","gray_info":"{\"data\":[903,3903],\"type\":\"range\"}","platform":2,"create_time":1568186512298,"dev_mode":1},{"plugin_id":1001591,"plugin_package_id":1007699,"version":20,"sdk_version":10039,"change_log":"1.修改部分地区非英语状态下用户协议和隐私政策 2.修复撤销授权后,重新绑定设备无授权弹窗 3.用户协议内隐私超链接跳转本地隐私 4.修复隐私政策滑动超出屏幕范围","download_url":"https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2020-06-03/signed_10039_1001591_20_IOS_bundle_9aff56ed7184c786c1f0f6db5e47ae4d.zip","size":6432439,"model":"deerma.humidifier.jsq","force_update_status":0,"status":8,"md5sum":"9aff56ed7184c786c1f0f6db5e47ae4d","gray_info":"[]","platform":2,"create_time":1591198078444,"dev_mode":1}],"backup_info":null,"stand_plugin_info":null}}
                            mihome-cloud.0
                            2022-11-06 07:10:55.638	info	Fetching Plugins
                            mihome-cloud.0
                            2022-11-06 07:10:55.634	debug	{"did":"238442715","uid":1754651949,"token":"b2e21761512e0ccb16c2ededd82218ab","name":"Luftbefeuchter","pid":0,"localip":"192.168.1.202","mac":"44:23:7C:BC:A3:DB","ssid":"JackDaniel","bssid":"18:E8:29:EA:04:B6","rssi":-50,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"deerma.humidifier.jsq","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:humidifier:0000A00E:deerma-jsq:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"2.0.7","mcu_version":"0113","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1642267702,"freqFlag":true,"hide_mode":0,"comFlag":129}
                            mihome-cloud.0
                            2022-11-06 07:10:55.634	info	prop.ct
                            mihome-cloud.0
                            2022-11-06 07:10:55.634	info	prop.bright
                            mihome-cloud.0
                            2022-11-06 07:10:55.634	info	prop.power
                            mihome-cloud.0
                            2022-11-06 07:10:55.633	info	Found yeelink.light.bslamp1 (Nachttischlampe) with 3 properties
                            mihome-cloud.0
                            2022-11-06 07:10:55.631	debug	{"did":"75543767","uid":1754651949,"token":"5da80bd97d0fe34520e531fbbb6ce41b","name":"Nachttischlampe","pid":0,"localip":"192.168.1.100","mac":"78:11:DC:92:75:AF","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-63,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"yeelink.light.bslamp1","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:light:0000A001:yeelink-bslamp1:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"1.6.6_0172","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1649341774,"freqFlag":true,"hide_mode":0,"comFlag":129}
                            mihome-cloud.0
                            2022-11-06 07:10:55.630	info	event.status
                            mihome-cloud.0
                            2022-11-06 07:10:55.630	info	Found roborock.vacuum.s5 (R2D2) with 1 properties
                            mihome-cloud.0
                            2022-11-06 07:10:55.626	debug	{"did":"320373564","uid":1754651949,"token":"717154435a79744d364d31494c577967","name":"R2D2","pid":0,"localip":"192.168.1.101","mac":"64:90:C1:02:7F:1F","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-70,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"roborock.vacuum.s5","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:vacuum:0000A006:roborock-s5:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"3.5.8_002034","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1635497246,"freqFlag":true,"hide_mode":0,"comFlag":129}
                            mihome-cloud.0
                            2022-11-06 07:10:55.626	info	Found 3 devices
                            mihome-cloud.0
                            2022-11-06 07:10:55.625	debug	{"code":0,"message":"","result":{"list":[{"did":"320373564","uid":1754651949,"token":"717154435a79744d364d31494c577967","name":"R2D2","pid":0,"localip":"192.168.1.101","mac":"64:90:C1:02:7F:1F","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-70,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"roborock.vacuum.s5","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:vacuum:0000A006:roborock-s5:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"3.5.8_002034","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1635497246,"freqFlag":true,"hide_mode":0,"comFlag":129},{"did":"75543767","uid":1754651949,"token":"5da80bd97d0fe34520e531fbbb6ce41b","name":"Nachttischlampe","pid":0,"localip":"192.168.1.100","mac":"78:11:DC:92:75:AF","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-63,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"yeelink.light.bslamp1","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:light:0000A001:yeelink-bslamp1:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"1.6.6_0172","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1649341774,"freqFlag":true,"hide_mode":0,"comFlag":129},{"did":"238442715","uid":1754651949,"token":"b2e21761512e0ccb16c2ededd82218ab","name":"Luftbefeuchter","pid":0,"localip":"192.168.1.202","mac":"44:23:7C:BC:A3:DB","ssid":"JackDaniel","bssid":"18:E8:29:EA:04:B6","rssi":-50,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"deerma.humidifier.jsq","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:humidifier:0000A00E:deerma-jsq:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"2.0.7","mcu_version":"0113","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1642267702,"freqFlag":true,"hide_mode":0,"comFlag":129}],"next_start_did":"","has_more":false}}
                            mihome-cloud.0
                            2022-11-06 07:10:55.437	info	Get devices
                            mihome-cloud.0
                            2022-11-06 07:10:55.433	info	Login successful
                            mihome-cloud.0
                            2022-11-06 07:10:55.433	debug	"ok"
                            mihome-cloud.0
                            2022-11-06 07:10:55.278	debug	"&&&START&&&{\"qs\":\"%3Fsid%3Dxiaomiio%26_json%3Dtrue\",\"ssecurity\":\"1nuzfaFwfYRR3E70kcw7zw==\",\"code\":0,\"passToken\":\"V1:DXmurwq2/R1BHTELu6obCfNOuAI0Iv5HC+ZKR4VeN98R0O9vyCJKsIYXPVOFB78uex4SRjcbOjr7weIKRtqnzu5WRyIhKTCSEArk1mLwKgY0hRPilk3p+TBNN8y68Fc2Sq9qEP+rVE1VBWCudmqMU1/uM+1Kg4PLjm1eZEDaxZVgSLfJN3v9j93Mgk+yl9sY76EW7qxmC+1Wrh0ML08e/yHd6SIjo2yH6gKuXMoNKMB9pY/W6z13Z2A33MyCWDbUNwqRkQab/BM9blbWOUBIRscQWSh+GfLk+9tDYJTmMXU=\",\"description\":\"成功\",\"securityStatus\":0,\"nonce\":1041428829432506368,\"userId\":1754651949,\"cUserId\":\"EzXMhMFs8J0wtEntUPSNUwO-ghA\",\"result\":\"ok\",\"psecurity\":\"pbMDCjbzPNpsXct3WxyWvA==\",\"captchaUrl\":null,\"location\":\"https://sts.api.io.mi.com/sts?d=wb_0bbef18b-a7e7-429b-99f5-151dafc6adaf&ticket=0&pwd=1&p_ts=1667715055000&fid=0&p_lm=1&auth=X72DCz5iXjCDRWr9tuuCbMlu3fcLNLKFJLiA8MCOOE0spfqHDH%2Bph3hLRKGO8Qwg5R7JtyFtWvSXfvIhTTXF9imqI50BRp3jtCfNBfHPnQXMsYtXtgajpV5C1Rduyt1mTaFyEvRdbnwoxQkUTaRqH4A61yLsk%2FLyHZDZaND%2FS9s%3D&m=1&_group=DEFAULT&tsl=0&p_ca=0&p_ur=AT&p_idc=Europe&nonce=dCEqK8f1jcoBqB8y&_ssign=QID%2FKBkWcArWOg8B2ZG%2FHPQiAic%3D\",\"pwd\":1,\"child\":0,\"desc\":\"成功\"}"
                            mihome-cloud.0
                            2022-11-06 07:10:55.036	debug	"&&&START&&&{\"serviceParam\":\"{\\\"checkSafePhone\\\":false,\\\"checkSafeAddress\\\":false,\\\"lsrp_score\\\":0.0}\",\"qs\":\"%3Fsid%3Dxiaomiio%26_json%3Dtrue\",\"code\":70016,\"description\":\"登录验证失败\",\"securityStatus\":0,\"_sign\":\"0psXfr43eNI0IX6q9Suk3qWbRqU=\",\"sid\":\"xiaomiio\",\"result\":\"error\",\"captchaUrl\":null,\"callback\":\"https://sts.api.io.mi.com/sts\",\"location\":\"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=\",\"pwd\":0,\"child\":0,\"desc\":\"登录验证失败\"}"
                            mihome-cloud.0
                            2022-11-06 07:10:54.727	info	Login to MiHome Cloud
                            mihome-cloud.0
                            2022-11-06 07:10:54.707	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.mihome-cloud#567a013f3147de9ffcf2289a907b73fa852dd039) in /opt/iobroker/node_modules/iobroker.mihome-cloud, node: v16.18.1, js-controller: 4.0.23
                              tombox @JackDaniel last edited by
                              @jackdaniel Danke für das feedback nochmal neu installieren und schauen was er dann ausgibt
                                tombox @Guest last edited by
                                @hannnes Kannst du ein screenshot zeigen. Gibt es remote commands die funktionieren?
                                • JackDaniel
                                  @tombox sagte in Test Adapter mihome-cloud:
                                  klemmt leider noch wo 😞
                                  mihome-cloud.0
                                  2022-11-06 10:37:01.173	info	{"code":-8,"message":"invalid param","result":null}
                                  mihome-cloud.0
                                  2022-11-06 10:37:01.172	info	Error getting Events of the device for Luftbefeuchter (238442715) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                                  mihome-cloud.0
                                  2022-11-06 10:37:01.018	info	{"code":-2,"error":{"code":-2,"message":"did offline"},"exe_time":0,"id":4927700,"message":"did offline","net_cost":0,"ot_cost":0}
                                  mihome-cloud.0
                                  2022-11-06 10:37:01.017	info	Error getting Status of the device for Luftbefeuchter (238442715) with {"id":0,"method":"Set_HumiValue","accessKey":"IOS00026747c5acafc2","params":[]}
                                  mihome-cloud.0
                                  2022-11-06 10:37:00.911	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                  mihome-cloud.0
                                  2022-11-06 10:37:00.910	info	terminating
                                  mihome-cloud.0
                                  2022-11-06 10:37:00.899	error	Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus
                                  mihome-cloud.0
                                  2022-11-06 10:37:00.898	error	Error: Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._setObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2980:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3211:29) at processImmediate (node:internal/timers:468:21)
                                  mihome-cloud.0
                                  2022-11-06 10:37:00.897	error	unhandled promise rejection: Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus
                                  mihome-cloud.0
                                  2022-11-06 10:37:00.897	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  mihome-cloud.0
                                  2022-11-06 10:37:00.881	info	Found 1 remote events for yeelink.light.bslamp1
                                  mihome-cloud.0
                                  2022-11-06 10:37:00.880	info	Found 3 remote commands for yeelink.light.bslamp1
                                  mihome-cloud.0
                                  2022-11-06 10:36:57.082	info	Found plugin for yeelink.light.bslamp1
                                  mihome-cloud.0
                                  2022-11-06 10:36:57.081	error	TypeError: Cannot read properties of null (reading '0')
                                  mihome-cloud.0
                                  2022-11-06 10:36:56.037	info	Found plugin for roborock.vacuum.s5
                                  mihome-cloud.0
                                  2022-11-06 10:36:56.037	error	TypeError: Cannot read properties of null (reading '0')
                                  mihome-cloud.0
                                  2022-11-06 10:36:51.936	info	Found plugin for deerma.humidifier.jsq
                                  mihome-cloud.0
                                  2022-11-06 10:36:51.936	debug	{"code":0,"message":"","result":{"latest_info":[{"plugin_id":1001591,"plugin_package_id":1007699,"version":20,"sdk_version":10039,"change_log":"1.修改部分地区非英语状态下用户协议和隐私政策 2.修复撤销授权后,重新绑定设备无授权弹窗 3.用户协议内隐私超链接跳转本地隐私 4.修复隐私政策滑动超出屏幕范围","download_url":"https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2020-06-03/signed_10039_1001591_20_IOS_bundle_9aff56ed7184c786c1f0f6db5e47ae4d.zip","size":6432439,"model":"deerma.humidifier.jsq","force_update_status":0,"status":8,"md5sum":"9aff56ed7184c786c1f0f6db5e47ae4d","gray_info":"[]","platform":2,"create_time":1591198078444,"dev_mode":1},{"plugin_id":1000570,"plugin_package_id":1012902,"version":39,"sdk_version":10047,"change_log":"修复和优化一些问题,内部版本52","download_url":"https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2020-12-08/signed_10047_1000570_39_IOS_bundle_e6776fdd671602f308b9be25d889bb0c.zip","size":5443322,"model":"roborock.vacuum.s5","force_update_status":0,"status":8,"md5sum":"e6776fdd671602f308b9be25d889bb0c","gray_info":"{\"data\":[2263,5263],\"type\":\"range\"}","platform":2,"create_time":1607418709856,"dev_mode":1},{"plugin_id":1000708,"plugin_package_id":1002507,"version":2,"sdk_version":10026,"change_log":"1.修改jira。\n1.fix jira.","download_url":"https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2019-09-11/signed_10026_1000708_2_IOS_bundle_ec15991cae11aa91ee5abb3f8e94b0a3.zip","size":5913729,"model":"yeelink.light.bslamp1","force_update_status":0,"status":8,"md5sum":"ec15991cae11aa91ee5abb3f8e94b0a3","gray_info":"{\"data\":[903,3903],\"type\":\"range\"}","platform":2,"create_time":1568186512298,"dev_mode":1}],"backup_info":null,"stand_plugin_info":null}}
                                  mihome-cloud.0
                                  2022-11-06 10:36:51.806	info	Fetching Plugins
                                  mihome-cloud.0
                                  2022-11-06 10:36:51.806	info	prop.ct
                                  mihome-cloud.0
                                  2022-11-06 10:36:51.806	info	prop.bright
                                  mihome-cloud.0
                                  2022-11-06 10:36:51.805	info	prop.power
                                  mihome-cloud.0
                                  2022-11-06 10:36:51.805	info	Found yeelink.light.bslamp1 (Nachttischlampe) with 3 properties
                                  mihome-cloud.0
                                  2022-11-06 10:36:51.797	debug	{"did":"75543767","uid":1754651949,"token":"5da80bd97d0fe34520e531fbbb6ce41b","name":"Nachttischlampe","pid":0,"localip":"192.168.1.100","mac":"78:11:DC:92:75:AF","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-63,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"yeelink.light.bslamp1","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:light:0000A001:yeelink-bslamp1:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"1.6.6_0172","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1649341774,"freqFlag":true,"hide_mode":0,"comFlag":129}
                                  mihome-cloud.0
                                  2022-11-06 10:36:51.796	info	event.status
                                  mihome-cloud.0
                                  2022-11-06 10:36:51.796	info	Found roborock.vacuum.s5 (R2D2) with 1 properties
                                  mihome-cloud.0
                                  2022-11-06 10:36:51.789	debug	{"did":"320373564","uid":1754651949,"token":"717154435a79744d364d31494c577967","name":"R2D2","pid":0,"localip":"192.168.1.101","mac":"64:90:C1:02:7F:1F","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-70,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"roborock.vacuum.s5","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:vacuum:0000A006:roborock-s5:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"3.5.8_002034","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1635497246,"freqFlag":true,"hide_mode":0,"comFlag":129}
                                  mihome-cloud.0
                                  2022-11-06 10:36:51.782	debug	{"did":"238442715","uid":1754651949,"token":"b2e21761512e0ccb16c2ededd82218ab","name":"Luftbefeuchter","pid":0,"localip":"192.168.1.202","mac":"44:23:7C:BC:A3:DB","ssid":"JackDaniel","bssid":"18:E8:29:EA:04:B6","rssi":-50,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"deerma.humidifier.jsq","permitLevel":16,"isOnline":false,"spec_type":"urn:miot-spec-v2:device:humidifier:0000A00E:deerma-jsq:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"2.0.7","mcu_version":"0113","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1642267702,"freqFlag":true,"hide_mode":0,"comFlag":129}
                                  mihome-cloud.0
                                  2022-11-06 10:36:51.782	info	Found 3 devices
                                  mihome-cloud.0
                                  2022-11-06 10:36:51.781	debug	{"code":0,"message":"","result":{"list":[{"did":"238442715","uid":1754651949,"token":"b2e21761512e0ccb16c2ededd82218ab","name":"Luftbefeuchter","pid":0,"localip":"192.168.1.202","mac":"44:23:7C:BC:A3:DB","ssid":"JackDaniel","bssid":"18:E8:29:EA:04:B6","rssi":-50,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"deerma.humidifier.jsq","permitLevel":16,"isOnline":false,"spec_type":"urn:miot-spec-v2:device:humidifier:0000A00E:deerma-jsq:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"2.0.7","mcu_version":"0113","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1642267702,"freqFlag":true,"hide_mode":0,"comFlag":129},{"did":"320373564","uid":1754651949,"token":"717154435a79744d364d31494c577967","name":"R2D2","pid":0,"localip":"192.168.1.101","mac":"64:90:C1:02:7F:1F","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-70,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"roborock.vacuum.s5","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:vacuum:0000A006:roborock-s5:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"3.5.8_002034","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1635497246,"freqFlag":true,"hide_mode":0,"comFlag":129},{"did":"75543767","uid":1754651949,"token":"5da80bd97d0fe34520e531fbbb6ce41b","name":"Nachttischlampe","pid":0,"localip":"192.168.1.100","mac":"78:11:DC:92:75:AF","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-63,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"yeelink.light.bslamp1","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:light:0000A001:yeelink-bslamp1:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"1.6.6_0172","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1649341774,"freqFlag":true,"hide_mode":0,"comFlag":129}],"next_start_did":"","has_more":false}}
                                  mihome-cloud.0
                                  2022-11-06 10:36:51.625	info	Get devices
                                  mihome-cloud.0
                                  2022-11-06 10:36:51.622	info	Login successful
                                  mihome-cloud.0
                                  2022-11-06 10:36:51.621	debug	"ok"
                                  mihome-cloud.0
                                  2022-11-06 10:36:51.481	debug	"&&&START&&&{\"qs\":\"%3Fsid%3Dxiaomiio%26_json%3Dtrue\",\"ssecurity\":\"eLbNG0p56Mp/DYQOdhf4Og==\",\"code\":0,\"passToken\":\"V1:DXmurwq2/R1BHTELu6obCcDnh9hauOPj3DoX5tdXCKVmnlboKcoPNH/WiZSEz6zf7fxMnuHG7xmQRLHGs3uv7uyCbSI8lsLiDgmEEHOhTF5Whl9SSqUCt3tLumfA45sFSRgVqLvdQ8AfxhRkghXsfI0qxmgMycGQ00ge+lIimNORPamxswjf4kjFymxLnQeNSlqJn4X/3o4ODLfMtEedBpxnbvW1+aR7mDWINn5mKxB033Nbs/IAHmk9TLjc8+JXvBG5KynMNvJ8Sf7Yv+eRvPsgkv3uuGZgxIEJK3B6EEg=\",\"description\":\"成功\",\"securityStatus\":0,\"nonce\":5768626167211188224,\"userId\":1754651949,\"cUserId\":\"EzXMhMFs8J0wtEntUPSNUwO-ghA\",\"result\":\"ok\",\"psecurity\":\"+YaMogoDNn2lP+ERYNRvZw==\",\"captchaUrl\":null,\"location\":\"https://sts.api.io.mi.com/sts?d=wb_ef2622a1-355d-43ff-8640-1d31120126f3&ticket=0&pwd=1&p_ts=1667727411000&fid=0&p_lm=1&auth=h4CrMYd5y3N817SPY26%2BiSeE5ATB1mvnplGu%2B4h6ooR9xWVTdeCgrzxlGS3bjLmQ3i5Ckt81U4aBAGuKcagHzrU4F1pMBiwH5tFf2y2Lff1GDmXBQntkQtGIx28D7lDioBs4qvZHPwwny0m%2B4liDXTmPovqEbZw7daMVVHS9QrQ%3D&m=1&_group=DEFAULT&tsl=0&p_ca=0&p_ur=AT&p_idc=Europe&nonce=YNSuCyLJsGUBqCAA&_ssign=RB5dvDQ2Jzs5EbFybwyUELNKrLA%3D\",\"pwd\":1,\"child\":0,\"desc\":\"成功\"}"
                                  mihome-cloud.0
                                  2022-11-06 10:36:51.204	debug	"&&&START&&&{\"serviceParam\":\"{\\\"checkSafePhone\\\":false,\\\"checkSafeAddress\\\":false,\\\"lsrp_score\\\":0.0}\",\"qs\":\"%3Fsid%3Dxiaomiio%26_json%3Dtrue\",\"code\":70016,\"description\":\"登录验证失败\",\"securityStatus\":0,\"_sign\":\"0psXfr43eNI0IX6q9Suk3qWbRqU=\",\"sid\":\"xiaomiio\",\"result\":\"error\",\"captchaUrl\":null,\"callback\":\"https://sts.api.io.mi.com/sts\",\"location\":\"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=\",\"pwd\":0,\"child\":0,\"desc\":\"登录验证失败\"}"
                                  mihome-cloud.0
                                  2022-11-06 10:36:50.917	info	Login to MiHome Cloud
                                  mihome-cloud.0
                                  2022-11-06 10:36:50.895	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.mihome-cloud#3a7857507ff5078425c0881211690537a9ccf6ce) in /opt/iobroker/node_modules/iobroker.mihome-cloud, node: v16.18.1, js-controller: 4.0.23
                                  mihome-cloud.0
                                  2022-11-06 10:36:50.478	debug	States connected to redis: 127.0.0.1:9000
                                  mihome-cloud.0
                                  2022-11-06 10:36:50.350	debug	States create User PubSub Client
                                  mihome-cloud.0
                                  2022-11-06 10:36:50.349	debug	States create System PubSub Client
                                  mihome-cloud.0
                                  2022-11-06 10:36:50.304	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                                  mihome-cloud.0
                                  2022-11-06 10:36:50.260	debug	Objects connected to redis: 127.0.0.1:9001
                                  mihome-cloud.0
                                  2022-11-06 10:36:50.254	debug	Objects client initialize lua scripts
                                  mihome-cloud.0
                                  2022-11-06 10:36:50.144	debug	Objects create User PubSub Client
                                  mihome-cloud.0
                                  2022-11-06 10:36:50.143	debug	Objects create System PubSub Client
                                  mihome-cloud.0
                                  2022-11-06 10:36:50.142	debug	Objects client ready ... initialize now
                                  mihome-cloud.0
                                  2022-11-06 10:36:50.082	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    in "remote" ist noch nichts drin.
                                    Wenn ich sonst noch wo nachsehen soll, bitte mit kurzer Wegbeschreibung für Dummys, wo ich hin muss.
                                    haselchen T 2 Replies Last reply Reply Quote 0
                                      @jackdaniel Habe noch mal was verbessert aber es scheint so aufgrund der Unterschiedlichkeit der Geräte nicht möglich ein generischen Ansatz für alle Geräte zu finden.
                                      JackDaniel 1 Reply Last reply Reply Quote 0
                                      • JackDaniel
                                        JackDaniel @tombox last edited by
                                        @tombox
                                        der crash ist nun weg, gibt aber noch fehler im log
                                        wird der zugang zu meiner cloud benötigt?
                                        mihome-cloud.0
                                        Zeit
                                        debug
                                        Nachricht
                                        mihome-cloud.0
                                        2022-11-06 16:55:27.957	info	{"code":-8,"message":"invalid param","result":null}
                                        mihome-cloud.0
                                        2022-11-06 16:55:27.957	info	Error getting Events of the device for Nachttischlampe (75543767) with {"expire":10,"method":["this.apiDataSource.registerProps"],"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                                        mihome-cloud.0
                                        2022-11-06 16:55:27.844	error	SyntaxError: Unexpected token o in JSON at position 1 at JSON.parse (<anonymous>) at MihomeCloud.parseResponse (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:660:19) at /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:618:37 at processTicksAndRejections (node:internal/process/task_queues:96:5) at async MihomeCloud.updateDevices (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:593:9) at async Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:779:11)
                                        mihome-cloud.0
                                        mihome-cloud.0
                                        2022-11-06 16:55:27.843	error	/home/rpc/75543767
                                        mihome-cloud.0
                                        2022-11-06 16:55:27.723	info	{"code":-8,"message":"invalid param","result":null}
                                        mihome-cloud.0
                                        2022-11-06 16:55:27.722	info	Error getting Events of the device for R2D2 (320373564) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                                        mihome-cloud.0
                                        2022-11-06 16:55:27.406	info	{"code":-8,"message":"invalid param","result":null}
                                        mihome-cloud.0
                                        2022-11-06 16:55:27.406	info	Error getting Events of the device for Luftbefeuchter (238442715) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                                        mihome-cloud.0
                                        2022-11-06 16:55:27.320	info	undefined is not a valid state value for id "mihome-cloud.0.238442715.status.status"
                                        mihome-cloud.0
                                        2022-11-06 16:55:27.011	info	Update devices
                                        mihome-cloud.0
                                        2022-11-06 16:55:18.727	info	{"code":-8,"message":"invalid param","result":null}
                                        mihome-cloud.0
                                        2022-11-06 16:55:18.727	info	Error getting Events of the device for Nachttischlampe (75543767) with {"expire":10,"method":["this.apiDataSource.registerProps"],"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                                        mihome-cloud.0
                                        2022-11-06 16:55:18.606	error	SyntaxError: Unexpected token o in JSON at position 1 at JSON.parse (<anonymous>) at MihomeCloud.parseResponse (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:660:19) at /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:618:37 at processTicksAndRejections (node:internal/process/task_queues:96:5) at async MihomeCloud.updateDevices (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:593:9) at async Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:779:11)
                                        mihome-cloud.0
                                        2022-11-06 16:55:18.605	error	SyntaxError: Unexpected token o in JSON at position 1
                                        mihome-cloud.0
                                        2022-11-06 16:55:18.605	error	/home/rpc/75543767
                                        mihome-cloud.0
                                        2022-11-06 16:55:18.443	info	{"code":-8,"message":"invalid param","result":null}
                                        mihome-cloud.0
                                        2022-11-06 16:55:18.443	info	Error getting Events of the device for R2D2 (320373564) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                                        mihome-cloud.0
                                        2022-11-06 16:55:18.183	info	{"code":-8,"message":"invalid param","result":null}
                                        mihome-cloud.0
                                        2022-11-06 16:55:18.183	info	Error getting Events of the device for Luftbefeuchter (238442715) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                                        mihome-cloud.0
                                        2022-11-06 16:55:18.068	info	undefined is not a valid state value for id "mihome-cloud.0.238442715.status.status"
                                        mihome-cloud.0
                                        2022-11-06 16:55:17.717	info	Update devices
                                        mihome-cloud.0
                                        2022-11-06 16:55:17.011	info	{"code":0,"exe_time":60,"id":9879399,"message":"ok","net_cost":74,"ot_cost":0,"otlocalts":1667750117003464,"result":["error"]}
                                        mihome-cloud.0
                                        2022-11-06 16:55:07.715	info	{"code":0,"exe_time":200,"id":8544340,"message":"ok","net_cost":65,"ot_cost":0,"otlocalts":1667750107708289,"result":["error"]}
                                        mihome-cloud.0
                                        2022-11-06 16:54:54.583	info	{"code":-8,"message":"invalid param","result":null}
                                        mihome-cloud.0
                                        2022-11-06 16:54:54.582	info	Error getting Events of the device for Nachttischlampe (75543767) with {"expire":10,"method":["this.apiDataSource.registerProps"],"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                                        mihome-cloud.0
                                        2022-11-06 16:54:54.464	error	SyntaxError: Unexpected token o in JSON at position 1 at JSON.parse (<anonymous>) at MihomeCloud.parseResponse (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:660:19) at /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:618:37 at processTicksAndRejections (node:internal/process/task_queues:96:5) at async MihomeCloud.updateDevices (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:593:9) at async Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:779:11)
                                        mihome-cloud.0
                                        2022-11-06 16:54:54.463	error	SyntaxError: Unexpected token o in JSON at position 1
                                        mihome-cloud.0
                                        2022-11-06 16:54:54.463	error	/home/rpc/75543767
                                        mihome-cloud.0
                                        2022-11-06 16:54:54.260	info	{"code":-8,"message":"invalid param","result":null}
                                        mihome-cloud.0
                                        2022-11-06 16:54:54.260	info	Error getting Events of the device for R2D2 (320373564) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                                        mihome-cloud.0
                                        2022-11-06 16:54:54.048	info	{"code":-8,"message":"invalid param","result":null}
                                        mihome-cloud.0
                                        2022-11-06 16:54:54.047	info	Error getting Events of the device for Luftbefeuchter (238442715) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                                        mihome-cloud.0
                                        2022-11-06 16:54:53.934	info	undefined is not a valid state value for id "mihome-cloud.0.238442715.status.status"
                                        mihome-cloud.0
                                        2022-11-06 16:54:53.652	info	Update devices
                                        mihome-cloud.0
                                        2022-11-06 16:54:43.651	info	{"code":0,"exe_time":240,"id":2281919,"message":"ok","net_cost":63,"ot_cost":0,"otlocalts":1667750083643273,"result":["error"]}
                                        mihome-cloud.0
                                        2022-11-06 16:54:38.739	info	{"code":-8,"message":"invalid param","result":null}
                                        mihome-cloud.0
                                        2022-11-06 16:54:38.739	info	Error getting Events of the device for Nachttischlampe (75543767) with {"expire":10,"method":["this.apiDataSource.registerProps"],"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                                        mihome-cloud.0
                                        2022-11-06 16:54:38.651	error	SyntaxError: Unexpected token o in JSON at position 1 at JSON.parse (<anonymous>) at MihomeCloud.parseResponse (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:660:19) at /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:618:37 at processTicksAndRejections (node:internal/process/task_queues:96:5) at async MihomeCloud.updateDevices (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:593:9) at async Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:779:11)
                                        mihome-cloud.0
                                        2022-11-06 16:54:38.650	error	SyntaxError: Unexpected token o in JSON at position 1
                                        mihome-cloud.0
                                        2022-11-06 16:54:38.650	error	/home/rpc/75543767
                                        mihome-cloud.0
                                        2022-11-06 16:54:38.492	info	{"code":-8,"message":"invalid param","result":null}
                                        mihome-cloud.0
                                        2022-11-06 16:54:38.492	info	Error getting Events of the device for R2D2 (320373564) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                                        mihome-cloud.0
                                        2022-11-06 16:54:38.236	info	{"code":-8,"message":"invalid param","result":null}
                                        mihome-cloud.0
                                        2022-11-06 16:54:38.236	info	Error getting Events of the device for Luftbefeuchter (238442715) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                                        mihome-cloud.0
                                        2022-11-06 16:54:38.151	info	undefined is not a valid state value for id "mihome-cloud.0.238442715.status.status"
                                        mihome-cloud.0
                                        2022-11-06 16:54:37.622	info	Update devices
                                        mihome-cloud.0
                                        2022-11-06 16:54:27.622	info	{"code":0,"exe_time":260,"id":5199127,"message":"ok","net_cost":103,"ot_cost":0,"otlocalts":1667750067604380,"result":["error"]}
                                        mihome-cloud.0
                                        2022-11-06 16:53:37.107	info	[{"sa_id":513,"model":"yeelink.light.bslamp1","name":"Turn on","keyName":"Turn on","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.color1.set_power","value":["on","smooth",500]},"protocol_type":1},{"sa_id":522,"model":"yeelink.light.bslamp1","name":"Turn off","keyName":"Turn off","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.color1.set_power","value":["off","smooth",500]},"protocol_type":1},{"sa_id":523,"model":"yeelink.light.bslamp1","name":"Turn on/off","keyName":"Turn on/off","type":0,"groupInfo":[],"tr_id":301,"payload":{"did":"","command":"yeelink.light.color1.toggle"},"protocol_type":1},{"sa_id":524,"model":"yeelink.light.bslamp1","name":"Light up for an adjustable period of time","keyName":"Light up for an adjustable period of time","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_scene","plug_id":"GET_YEELINK_DELAY_SETTING"},"protocol_type":1},{"sa_id":525,"model":"yeelink.light.bslamp1","name":"Turn on and set light","keyName":"Turn on and set light","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_scene","plug_id":"GET_YEELINK_SCENE"},"protocol_type":1},{"sa_id":526,"model":"yeelink.light.bslamp1","name":"Brightness up","keyName":"Brightness up","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["increase","bright"]},"protocol_type":1},{"sa_id":527,"model":"yeelink.light.bslamp1","name":"Brightness down","keyName":"Brightness down","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["decrease","bright"]},"protocol_type":1},{"sa_id":528,"model":"yeelink.light.bslamp1","name":"Switch brightness level","keyName":"Switch brightness level","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["circle","bright"]},"protocol_type":1},{"sa_id":529,"model":"yeelink.light.bslamp1","name":"Color temperature up","keyName":"Color temperature up","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["increase","ct"]},"protocol_type":1},{"sa_id":530,"model":"yeelink.light.bslamp1","name":"Color temperature down","keyName":"Color temperature down","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["decrease","ct"]},"protocol_type":1},{"sa_id":531,"model":"yeelink.light.bslamp1","name":"Switch color temperature level","keyName":"Switch color temperature level","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["circle","ct"]},"protocol_type":1},{"sa_id":532,"model":"yeelink.light.bslamp1","name":"Turn on or adjust brightness","keyName":"Turn on or adjust brightness","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["auto","bright"]},"protocol_type":1},{"sa_id":533,"model":"yeelink.light.bslamp1","name":"Turn on or adjust color temperature","keyName":"Turn on or adjust color temperature","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["auto","ct"]},"protocol_type":1},{"sa_id":534,"model":"yeelink.light.bslamp1","name":"Turn on or adjust color","keyName":"Turn on or adjust color","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["auto","color"]},"protocol_type":1},{"sa_id":535,"model":"yeelink.light.bslamp1","name":"Adjust brightness","keyName":"Adjust brightness","type":0,"groupInfo":[],"tr_id":302,"payload":{"did":"","command":"yeelink.light.bslamp1.adjust_bright"},"protocol_type":1},{"sa_id":536,"model":"yeelink.light.bslamp1","name":"Adjust color temperature","keyName":"Adjust color temperature","type":0,"groupInfo":[],"tr_id":302,"payload":{"did":"","command":"yeelink.light.bslamp1.adjust_ct"},"protocol_type":1},{"sa_id":537,"model":"yeelink.light.bslamp1","name":"Adjust color","keyName":"Adjust color","type":0,"groupInfo":[],"tr_id":302,"payload":{"did":"","command":"yeelink.light.bslamp1.adjust_color"},"protocol_type":1},{"sa_id":538,"model":"yeelink.light.bslamp1","name":"Switch color","keyName":"Switch color","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["circle","color"]},"protocol_type":1}]
                                        mihome-cloud.0
                                        2022-11-06 16:53:37.107	info	yeelink.light.bslamp1
                                        mihome-cloud.0
                                        2022-11-06 16:53:37.106	info	[{"sa_id":958,"model":"roborock.vacuum.s5","name":"Start cleaning","keyName":"Start cleaning","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"roborock.vacuum.s5.app_start"},"protocol_type":1},{"sa_id":959,"model":"roborock.vacuum.s5","name":"Switch to Balanced mode","keyName":"Switch to Balanced mode","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"roborock.vacuum.s5.set_custom_mode","value":60},"protocol_type":1},{"sa_id":960,"model":"roborock.vacuum.s5","name":"Switch to Quiet mode","keyName":"Switch to Quiet mode","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"roborock.vacuum.s5.set_custom_mode","value":38},"protocol_type":1},{"sa_id":961,"model":"roborock.vacuum.s5","name":"Pause cleaning","keyName":"Pause cleaning","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"roborock.vacuum.s5.app_pause"},"protocol_type":1},{"sa_id":962,"model":"roborock.vacuum.s5","name":"Switch to Turbo mode","keyName":"Switch to Turbo mode","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"roborock.vacuum.s5.set_custom_mode","value":77},"protocol_type":1},{"sa_id":963,"model":"roborock.vacuum.s5","name":"Go back to the dock","keyName":"Go back to the dock","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"roborock.vacuum.s5.app_smart_charge"},"protocol_type":1}]
                                        mihome-cloud.0
                                        2022-11-06 16:53:37.106	info	roborock.vacuum.s5
                                        mihome-cloud.0
                                        2022-11-06 16:53:37.106	info	[{"sa_id":6791,"model":"deerma.humidifier.jsq","name":"Turn off the humidifier","keyName":"Turn off the humidifier","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"deerma.humidifier.mjjsq.Set_OnOff","value":0},"protocol_type":1},{"sa_id":6792,"model":"deerma.humidifier.jsq","name":"Turn on the humidifier","keyName":"Turn on the humidifier","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"deerma.humidifier.mjjsq.Set_OnOff","value":1},"protocol_type":1},{"sa_id":6793,"model":"deerma.humidifier.jsq","name":"Set to constant humidity mode","keyName":"Set to constant humidity mode","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"deerma.humidifier.mjjsq.Set_HumidifierGears","value":4},"protocol_type":1},{"sa_id":6794,"model":"deerma.humidifier.jsq","name":"Set the humidifying speed to low","keyName":"Set the humidifying speed to low","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"deerma.humidifier.mjjsq.Set_HumidifierGears","value":1},"protocol_type":1},{"sa_id":6795,"model":"deerma.humidifier.jsq","name":"Set the humidifying speed to medium","keyName":"Set the humidifying speed to medium","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"deerma.humidifier.mjjsq.Set_HumidifierGears","value":2},"protocol_type":1},{"sa_id":6796,"model":"deerma.humidifier.jsq","name":"Set the humidifying speed to high","keyName":"Set the humidifying speed to high","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"deerma.humidifier.mjjsq.Set_HumidifierGears","value":3},"protocol_type":1}]
                                        mihome-cloud.0
                                        2022-11-06 16:53:37.106	info	deerma.humidifier.jsq
                                        mihome-cloud.0
                                        2022-11-06 16:53:37.006	info	{"code":0,"message":"","result":{"homelist":[{"id":"137001000499","name":"Da Ham","bssid":"","dids":[],"icon":"style_1_favorites","shareflag":0,"permit_level":10,"status":1,"background":"static1","smart_room_background":"style_1_favorites","longitude":0,"latitude":0,"city_id":0,"address":"","create_time":1519470799,"roomlist":[{"id":"137001034342","name":"Gästezimmer","bssid":"","parentid":"137001000499","dids":["75543767"],"icon":"more_1","background":"style_1_favorites","shareflag":0,"create_time":1636094924},{"id":"137001000503","name":"Wohnzimmer","bssid":"","parentid":"137001000499","dids":["238442715","320373564"],"icon":"livingroom_1","background":"style_1_favorites","shareflag":0,"create_time":1519494939}],"uid":1754651949}],"has_more":false,"max_id":"75543767"}}
                                        mihome-cloud.0
                                        2022-11-06 16:53:36.880	info	{"code":0,"message":"","result":{"local_list":[],"third_list":[]}}
                                        mihome-cloud.0
                                        2022-11-06 16:53:36.792	info	{"code":-8,"message":"invalid param","result":null}
                                        mihome-cloud.0
                                        2022-11-06 16:53:36.792	info	Error getting Events of the device for Nachttischlampe (75543767) with {"expire":10,"method":["this.apiDataSource.registerProps"],"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                                        mihome-cloud.0
                                        2022-11-06 16:53:36.647	error	SyntaxError: Unexpected token o in JSON at position 1 at JSON.parse (<anonymous>) at MihomeCloud.parseResponse (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:660:19) at /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:618:37 at runMicrotasks (<anonymous>) at processTicksAndRejections (node:internal/process/task_queues:96:5) at async MihomeCloud.updateDevices (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:593:9) at async MihomeCloud.onReady (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:93:7)
                                        mihome-cloud.0
                                        2022-11-06 16:53:36.646	error	SyntaxError: Unexpected token o in JSON at position 1
                                        mihome-cloud.0
                                        2022-11-06 16:53:36.646	error	/home/rpc/75543767
                                        mihome-cloud.0
                                        2022-11-06 16:53:33.509	info	{"code":-8,"message":"invalid param","result":null}
                                        mihome-cloud.0
                                        2022-11-06 16:53:33.509	info	Error getting Events of the device for R2D2 (320373564) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                                        mihome-cloud.0
                                        2022-11-06 16:53:33.252	info	{"code":-8,"message":"invalid param","result":null}
                                        mihome-cloud.0
                                        2022-11-06 16:53:33.252	info	Error getting Events of the device for Luftbefeuchter (238442715) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                                        mihome-cloud.0
                                        2022-11-06 16:53:33.196	info	undefined is not a valid state value for id "mihome-cloud.0.238442715.status.status"
                                        mihome-cloud.0
                                        2022-11-06 16:53:33.190	warn	This object will not be created in future versions. Please report this to the developer.
                                        mihome-cloud.0
                                        2022-11-06 16:53:33.190	warn	Object mihome-cloud.0.238442715.status.status is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
                                        mihome-cloud.0
                                        2022-11-06 16:53:32.401	info	Found 1 remote events for yeelink.light.bslamp1
                                        mihome-cloud.0
                                        2022-11-06 16:53:32.401	info	Found 80 remote commands for yeelink.light.bslamp1
                                        mihome-cloud.0
                                        2022-11-06 16:53:30.604	info	Found plugin for yeelink.light.bslamp1
                                        mihome-cloud.0
                                        2022-11-06 16:53:30.604	info	Found 0 remote events for roborock.vacuum.s5
                                        mihome-cloud.0
                                        2022-11-06 16:53:30.593	info	Found 247 remote commands for roborock.vacuum.s5
                                        mihome-cloud.0
                                        2022-11-06 16:53:30.567	warn	Please report this url to the developer: https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2020-12-08/signed_10047_1000570_39_IOS_bundle_e6776fdd671602f308b9be25d889bb0c.zip
                                        mihome-cloud.0
                                        2022-11-06 16:53:30.567	warn	Remote commmands too long for roborock.vacuum.s5
                                        mihome-cloud.0
                                        2022-11-06 16:53:26.974	info	Found plugin for roborock.vacuum.s5
                                        mihome-cloud.0
                                        2022-11-06 16:53:26.974	info	Found 0 remote events for deerma.humidifier.jsq
                                        mihome-cloud.0
                                        2022-11-06 16:53:26.973	info	Found 11 remote commands for deerma.humidifier.jsq
                                        mihome-cloud.0
                                        2022-11-06 16:53:25.843	info	Found plugin for deerma.humidifier.jsq
                                        mihome-cloud.0
                                        2022-11-06 16:53:25.723	info	Fetching Plugins
                                        mihome-cloud.0
                                        2022-11-06 16:53:25.722	info	prop.ct
                                        mihome-cloud.0
                                        2022-11-06 16:53:25.722	info	prop.bright
                                        mihome-cloud.0
                                        2022-11-06 16:53:25.722	info	prop.power
                                        mihome-cloud.0
                                        2022-11-06 16:53:25.722	info	Found yeelink.light.bslamp1 (Nachttischlampe) in configDes with 3 properties
                                        mihome-cloud.0
                                        2022-11-06 16:53:25.720	info	event.status
                                        mihome-cloud.0
                                        2022-11-06 16:53:25.719	info	Found roborock.vacuum.s5 (R2D2) in configDes with 1 properties
                                        mihome-cloud.0
                                        2022-11-06 16:53:25.715	info	Found 3 devices
                                        mihome-cloud.0
                                        2022-11-06 16:53:25.547	info	Get devices
                                        mihome-cloud.0
                                        2022-11-06 16:53:25.543	info	Login successful
                                        mihome-cloud.0
                                        2022-11-06 16:53:24.790	info	Login to MiHome Cloud
                                        mihome-cloud.0
                                        2022-11-06 16:53:24.756	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.mihome-cloud#ed6074fea8ada7e315fc8c159664cd8edfaa7007) in /opt/iobroker/node_modules/iobroker.mihome-cloud, node: v16.18.1, js-controller: 4.0.23
                                        • haselchen
                                          haselchen Most Active @Guest last edited by
                                          @hannnes
                                          Die Infos , die Du hast, gab es schon mit der 1.Version des Adapters.
                                          Sorry, dass ich dich da bremsen muss 🙂
                                          Ich denke, nun wird an den möglichen Einstellungen gefeilt, dass du das Teil auch steuern kannst.
                                            A Former User @haselchen last edited by A Former User
                                            @haselchen
                                            Achso, nee, Du musst mich nicht bremsen. Ich machen hier tatsächlich nur mit, um zu helfen. Ist mir völlig klar, dass das noch nicht von Anfang an geht. Ich frage nur, ob ich was nachsehen soll, was für Tom wichtig wäre. 🙂
                                            196
                                            23572
