    • N
      nhet last edited by nhet
      Moinsen, gibt es logische Erklärungen warum die folgende Werte nicht korrekt erkannt wurden?
      Hier ist meine Config:
      [MakeImage]
      ;LogImageLocation = /log/source
      WaitBeforeTakingPicture = 5
      ;LogfileRetentionInDays = 15
      Brightness = 0
      Contrast = 0
      Saturation = 0
      LEDIntensity = 10
      ImageQuality = 12
      ImageSize = VGA
      FixedExposure = false
      [Alignment]
      InitialRotate = -2
      InitialMirror = false
      SearchFieldX = 20
      SearchFieldY = 20
      AlignmentAlgo = default
      FlipImageSize = false
      /config/ref0.jpg 139 369
      /config/ref1.jpg 549 253
      [Digits]
      Model = /config/dig-s1d-md-v1.0-q.tflite
      ;CNNGoodThreshold =
      ;LogImageLocation = /log/digit
      ;LogfileRetentionInDays = 3
      strom.1000 229 32 50 85 0
      strom.100 273 32 50 85 0
      strom.10 313 32 50 85 0
      strom.1 351 32 50 85 0
      strom.01 397 32 50 85 0
      ;[Analog]
      Model = /config/ana1000s2.tflite
      ;LogImageLocation = /log/analog
      [PostProcessing]
      strom.DecimalShift = -1
      PreValueUse = true
      PreValueAgeStartup = 720
      AllowNegativeRates = false
      strom.MaxRateValue = 1
      strom.MaxRateType = AbsoluteChange
      strom.ExtendedResolution = true
      strom.IgnoreLeadingNaN = true
      ErrorMessage = true
      CheckDigitIncreaseConsistency = false
      [MQTT]
      Uri = mqtt://192.168.0. Xyz:1883
      MainTopic = stromzaehler
      ClientID = strom
      user = iob
      password =
      SetRetainFlag = false
      ;[InfluxDB]
      ;Uri =
      ;Database =
      ;Measurement =
      ;user =
      ;password =
      ;[GPIO]
      ;IO0 = input disabled 10 false false
      ;IO1 = input disabled 10 false false
      ;IO3 = input disabled 10 false false
      ;IO4 = built-in-led disabled 10 false false
      ;IO12 = input-pullup disabled 10 false false
      ;IO13 = input-pullup disabled 10 false false
      LEDType = WS2812
      LEDNumbers = 2
      LEDColor = 150 150 150
      [AutoTimer]
      AutoStart = true
      Intervall = 10
      [Debug]
      Logfile = false
      [System]
      ;TimeZone = CET-1CEST,M3.5.0,M10.5.0/3
      ;TimeServer = undefined
      ;AutoAdjustSummertime = false
      ;Hostname = undefined
      SetupMode = false
        ChrisXY @jomjol last edited by
        @jomjol okay schade. Kann man das Foto den als Link abrufen irgendwie ? Dann würde ich es vielleicht anders wo "Auswerten"
        J C 2 Replies Last reply Reply Quote 0
          jomjol @ChrisXY last edited by
          @chrisxy
          http://IP-ADRESS/img_tmp/raw.jpg
          • ESP8266
            ESP8266 @nhet last edited by ESP8266
            @nhet , ja die Reflexion auf der 2. Die beiden davor werden auch mal Probleme machen. Zu dem sind die Umrahmungen nicht wie in der Wiki beschrieben. Deine Cam scheint auch schräg von der Seite zu fotografieren, dadurch gibt es zusätzliche Verfälschungen.
            Auch wenn es sich hier um eine Wasseruhr handelt, sollten die Rahmen exakt ausgerichtet sein:
            und jeder Rahmen hat die gleiche Größe und y Position.
            btw...Wo lassen sie sich die RSSI und die Temp Werte aktivieren?
            • N
              nhet @ESP8266 last edited by
              @esp8266
              Ich hab's jetzt versucht den ESP besser auszurichten und die Felder neu einzustellen.
              Hier sind mal die Werte. Die Felder sind alle gleich groß und liegen alle auf demselben Y Punkt.
              strom.1000 336 48 39 67 0
              strom.100 378 48 39 67 0
              strom.10 417 48 39 67 0
              strom.1 459 48 39 67 0
              strom.01 510 48 39 67 0
              • ESP8266
                ESP8266 last edited by ESP8266
                @nhet , aber das innere Feld umschließt nicht die Zahlen. Jetzt sieht alles einigermaßen gerade aus.
                Deine Spiegelungen sind an Ziffer 2 , 3 und 4 noch immer vorhanden. Sie haben einen weißen Unterstrich.
                Du hast noch nicht meine Frage beantwortet.
                • N
                  @esp8266 Das mit den Spiegelungen muss ich noch mal versuchen zu eliminieren. Geht vermutlich aber nur mit zusätzlichen LEDs?
                  Du meinst mit Frage, die Frage nach dem RSSI und CPU-Temp Wert? Das kann ich dir leider nicht beantworten die Werte waren plötzlich da. Ich hatte gestern mal einige Updates von 11.1.1 bis nach 12.0.3 gemacht. Dabei hab ich jedes Release schön nach einander mit Firmware und html geflasht.
                  • ESP8266
                    @nhet , ok danke, ich habe noch nicht aktualisiert. Werde ich morgen machen. So wie ich das in deiner Config gelesen habe, nutzt du doch schon externe LED´s. Da würde ich mit der Position spielen. Die hatte ich auch und musste in der Röhre das LED Band runter schieben. Damit ging es.
                    • N
                      @esp8266 Nein, ich nutze aktuell die auf dem ESP fest verbaute LED
                      • ESP8266
                        @nhet , nicht richtig hin geguckt. Dann versuche es mit ext. LED's.
                          A Former User last edited by
                          Hallo zusammen.
                          Ich habe gelegentlich das Problem, dass der PreValue größer als der RawValue ist. In der Config sind negative Werte sind nicht erlaubt, somit bekomme ich auch eine Fehlermeldung. Soweit ok.
                          Den PreValue kann ich nur über die Weboberfläche ändern. Gibt es eine Möglichkeit den PreValue über mqtt oder api zu setzen? In einem Fehlerfall könnte ich dass dann über ein Skript lösen.
                          • ESP8266
                            ESP8266 @Guest last edited by ESP8266
                            @achbz , wäre für mich auch intressant. Dazu müsste der Datenpunkt "Prevalue" zur Verfügung gestellt werden. Ein 2. Datenpunkt für die Neueingabe.
                            @jomjol ginge das? Wäre Nett wenn du das in den Code mit einbringen würdest.
                            Da drüber habe ich mir schon mal Gedanken gemacht und doch vergessen.
                              jomjol @ESP8266 last edited by
                              @esp8266 sagte in Wasserzähler - Version 2 - all-in-device:
                              Über API geht:
                              /setPreValue?value=VALUE&numbers=NUMBERNAME
                                A Former User @jomjol last edited by
                                Über API geht:
                                Hallo @jomjol, danke für den Hinweis.
                                Ich musste allerdings den Befehl erweitern um ein ".html", da ich sonst immer die Meldung "Failed to read existing file" erhalten habe.
                                Also /setPreValue.html?value=xxxx&numbers=main
                                  jomjol @Guest last edited by
                                  @achbz Kann gut sein - in den neuen Versionen versuchen wir das html wieder abzuschaffen
                                  • ESP8266
                                    @jomjol sagte in Wasserzähler - Version 2 - all-in-device
                                    Über API geht:
                                    Eine bitte an dich, wenn es möglich ist.
                                    Bei mir, was ich vorhabe funktioniert das nicht und das wäre mit einem Datenpunkt der Schreibbar ist besser zu lösen. Ein zweiter wäre Luxus, aber nicht schlecht. Also wie beim value oder raw zusätzlich den pre. Das wäre zur Kontrolle im IOB besser.
                                    Ich möchte mit einem Script bei einem error aus dem Raw Wert den Prevalue setzen und das Automatisch. Ich wüsste jetzt nicht , wie ich das via API und Blocky zusammen fummeln könnte. Mein Java-Script Kenntnisse reichen dafür nicht aus.
                                    Ich hoffe dass ich mich verständlich genug ausgedrückt habe. Sonst Sorry....
                                      @esp8266 Ist verständlich, aber die Firmware ist komplet auf Senden ausgerichtet und empfängt keine Datenpunkte. Dass will ich jetzt für den einen Spezialfall nicht einbauen.
                                      Du musst eigentlich nur eine URL mit dem o.g. Format ansurfen. Müsste eigentlich mit jeder Umgebung auch mit Blockly einfach gehen.
                                        @jomjol Danke 😉 Damit kann ich dann ja schon arbeiten. Nen tipp für ne "relativ" einfache OCR Software ? Hab schon überlegt über meine Kamera Sofware Blueiris zu gehen " Alarm" wenn Gegenstand weg/da ... aber da wird es ja sicher was besseres für geben.
                                        • David G.
                                          ich habe nun auch so weit alles fertig für meinen Wasserzähler.
                                          Die Konstruktion habe ich schonmal aufgebaut und getestet.
                                          Allerdings wackelt alles etwas, der Zähler (bzw die relevanten Bereiche) sind aber immer komplett zu erkennen.
                                          Ist das tragisch?
                                          Ich vermute um das zu kompensieren werden wenn ich die Bereiche mit den Zahlen erstelle noch die roten Felder gesetzt?
                                          EDIT
                                          Kann es sein, dass die Einstellungen für die LED keinen Effekt haben?
                                          Jens Meyer 1 Reply Last reply Reply Quote 0
                                          • Jens Meyer
                                            Jens Meyer @David G. last edited by
                                            @david-g
                                            Wackeln ist nicht gut u d du musst dann schon erstmal das komplette Setup durchlaufen
                                            238
                                            3411
                                            2005027
