    4. [Anleitung] WireGuard mit WireGuard-UI auf Proxmox
      saeft_2003 Most Active @CrunkFX last edited by
      @crunkfx
      ich erstelle auf meiner diskstation mal eine neue dyndns und melde mich wieder...
        @crunkfx
        Auch mit neuer dyndns (87.160.79.51) kein Erfolg. Hilft und das log von der app weiter?
        APP] Tunnel 'test' connection status changed to 'disconnected'
        2022-10-21 20:41:06.449
        [APP] Tunnel 'test' connection status changed to 'invalid'
        2022-10-21 20:41:32.738
        [APP] startActivation: Entering (tunnel: test)
        2022-10-21 20:41:32.740
        [APP] startActivation: Starting tunnel
        [APP] startActivation: Success
        2022-10-21 20:41:32.756
        [APP] Tunnel 'test' connection status changed to 'connecting'
        2022-10-21 20:41:32.911
        [NET] App version: 1.0.15 (26)
        2022-10-21 20:41:32.916
        [NET] Starting tunnel from the app
        2022-10-21 20:41:34.192
        [NET] DNS64: mapped 87.160.79.51 to itself.
        2022-10-21 20:41:34.193
        [NET] Attaching to interface
        [NET] Routine: encryption worker 1 - started
        [NET] Routine: decryption worker 1 - started
        2022-10-21 20:41:34.194
        [NET] Routine: handshake worker 2 - started
        [NET] UAPI: Updating private key
        [NET] Routine: decryption worker 3 - started
        [NET] Routine: handshake worker 3 - started
        [NET] Routine: decryption worker 4 - started
        [NET] Routine: handshake worker 1 - started
        [NET] Routine: encryption worker 3 - started
        [NET] Routine: encryption worker 4 - started
        [NET] Routine: event worker - started
        [NET] Routine: encryption worker 2 - started
        [NET] Routine: decryption worker 2 - started
        [NET] Routine: handshake worker 5 - started
        [NET] Routine: decryption worker 6 - started
        [NET] Routine: handshake worker 6 - started
        [NET] Routine: encryption worker 5 - started
        [NET] UAPI: Removing all peers
        [NET] Routine: TUN reader - started
        [NET] Routine: encryption worker 6 - started
        [NET] Routine: handshake worker 4 - started
        [NET] Routine: decryption worker 5 - started
        2022-10-21 20:41:34.195
        [NET] peer(4qO7…5tX0) - UAPI: Created
        [NET] peer(4qO7…5tX0) - UAPI: Updating preshared key
        [NET] peer(4qO7…5tX0) - UAPI: Updating endpoint
        [NET] peer(4qO7…5tX0) - UAPI: Updating persistent keepalive interval
        [NET] peer(4qO7…5tX0) - UAPI: Removing all allowedips
        [NET] peer(4qO7…5tX0) - UAPI: Adding allowedip
        2022-10-21 20:41:34.196
        [NET] UDP bind has been updated
        [NET] peer(4qO7…5tX0) - Starting
        [NET] Routine: receive incoming v6 - started
        [NET] Routine: receive incoming v4 - started
        [NET] peer(4qO7…5tX0) - Sending keepalive packet
        [NET] peer(4qO7…5tX0) - Routine: sequential receiver - started
        [NET] peer(4qO7…5tX0) - Sending handshake initiation
        [NET] peer(4qO7…5tX0) - Routine: sequential sender - started
        2022-10-21 20:41:34.197
        [NET] Interface state was Down, requested Up, now Up
        [NET] Device started
        [NET] Tunnel interface is utun5
        2022-10-21 20:41:34.199
        [APP] Tunnel 'test' connection status changed to 'connected'
        [NET] Network change detected with satisfied route and interface order [en0, pdp_ip0]
        2022-10-21 20:41:34.200
        [NET] Network change detected with satisfied route and interface order [en0, utun5, pdp_ip0]
        2022-10-21 20:41:34.201
        [NET] Routine: receive incoming v4 - stopped
        [NET] Routine: receive incoming v6 - stopped
        2022-10-21 20:41:34.202
        2022-10-21 20:41:37.741
        [APP] Status update notification timeout for tunnel 'test'. Tunnel status is now 'connected'.
        2022-10-21 20:41:39.467
        [NET] peer(4qO7…5tX0) - Handshake did not complete after 5 seconds, retrying (try 2)
        2022-10-21 20:41:39.468
        2022-10-21 20:41:44.632
        2022-10-21 20:41:49.878
        2022-10-21 20:41:55.058
        2022-10-21 20:42:00.312
        [NET] peer(4qO7…5tX0) - Handshake did not complete after 5 seconds, retrying (try 3)
        2022-10-21 20:42:00.313
        2022-10-21 20:42:05.640
        2022-10-21 20:42:05.641
        2022-10-21 20:42:10.723
        2022-10-21 20:42:10.724
        2022-10-21 20:42:16.031
        2022-10-21 20:42:21.174
        2022-10-21 20:42:26.318
        2022-10-21 20:42:31.359
        2022-10-21 20:42:36.362
        2022-10-21 20:42:41.440
        2022-10-21 20:42:46.552
        2022-10-21 20:42:46.553
        2022-10-21 20:42:48.798
        [APP] startDeactivation: Tunnel: test
        2022-10-21 20:42:48.803
        [APP] Tunnel 'test' connection status changed to 'disconnecting'
        2022-10-21 20:42:48.940
        2022-10-21 20:42:48.942
        2022-10-21 20:42:48.943
        2022-10-21 20:42:48.944
        2022-10-21 20:42:49.132
        [NET] Stopping tunnel
        [NET] Device closing
        [NET] Routine: TUN reader - stopped
        2022-10-21 20:42:49.133
        [NET] Routine: event worker - stopped
        [NET] peer(4qO7…5tX0) - Stopping
        [NET] peer(4qO7…5tX0) - Routine: sequential sender - stopped
        [NET] peer(4qO7…5tX0) - Routine: sequential receiver - stopped
        [NET] Device closed
        [NET] Routine: decryption worker 1 - stopped
        [NET] Routine: handshake worker 2 - stopped
        [NET] Routine: decryption worker 2 - stopped
        [NET] Routine: decryption worker 4 - stopped
        2022-10-21 20:42:49.134
        [NET] Routine: decryption worker 3 - stopped
        [NET] Routine: handshake worker 6 - stopped
        [NET] Routine: decryption worker 5 - stopped
        [NET] Routine: handshake worker 3 - stopped
        [NET] Routine: handshake worker 1 - stopped
        [NET] Routine: handshake worker 5 - stopped
        [NET] Routine: handshake worker 4 - stopped
        [NET] Routine: decryption worker 6 - stopped
        [NET] Routine: encryption worker 1 - stopped
        [NET] Routine: encryption worker 6 - stopped
        [NET] Routine: encryption worker 5 - stopped
        [NET] Routine: encryption worker 4 - stopped
        [NET] Routine: encryption worker 3 - stopped
        2022-10-21 20:42:49.135
        [NET] Routine: encryption worker 2 - stopped
        2022-10-21 20:42:49.146
        [APP] Tunnel 'test' connection status changed to 'disconnected'
        CrunkFX 1 Reply Last reply Reply Quote 0
        • CrunkFX
          CrunkFX Forum Testing @saeft_2003 last edited by
          @saeft_2003 Kannst du das mal mit der Desktop App machen, die ist etwas aufschlussreicher
            @crunkfx
            ok gib mir ein paar minuten
              @crunkfx
              hier:
              2022-10-21 20:50:47.577365: [TUN] [wireguradVPN] Starting WireGuard/0.5.3 (Windows 10.0.19043; amd64)
              2022-10-21 20:50:47.578250: [TUN] [wireguradVPN] Watching network interfaces
              2022-10-21 20:50:47.582038: [TUN] [wireguradVPN] Resolving DNS names
              2022-10-21 20:50:47.592735: [TUN] [wireguradVPN] Creating network adapter
              2022-10-21 20:50:47.853144: [TUN] [wireguradVPN] Using existing driver 0.10
              2022-10-21 20:50:47.863576: [TUN] [wireguradVPN] Creating adapter
              2022-10-21 20:50:48.110031: [TUN] [wireguradVPN] Using WireGuardNT/0.10
              2022-10-21 20:50:48.110031: [TUN] [wireguradVPN] Enabling firewall rules
              2022-10-21 20:50:48.051499: [TUN] [wireguradVPN] Interface created
              2022-10-21 20:50:48.123230: [TUN] [wireguradVPN] Dropping privileges
              2022-10-21 20:50:48.124285: [TUN] [wireguradVPN] Setting interface configuration
              2022-10-21 20:50:48.124804: [TUN] [wireguradVPN] Peer 1 created
              2022-10-21 20:50:48.127420: [TUN] [wireguradVPN] Monitoring MTU of default v4 routes
              2022-10-21 20:50:48.127420: [TUN] [wireguradVPN] Sending keepalive packet to peer 1 (87.160.79.50:51820)
              2022-10-21 20:50:48.127420: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:50:48.127420: [TUN] [wireguradVPN] Interface up
              2022-10-21 20:50:48.146596: [TUN] [wireguradVPN] Setting device v4 addresses
              2022-10-21 20:50:48.159207: [TUN] [wireguradVPN] Monitoring MTU of default v6 routes
              2022-10-21 20:50:48.164977: [TUN] [wireguradVPN] Setting device v6 addresses
              2022-10-21 20:50:48.202378: [TUN] [wireguradVPN] Startup complete
              2022-10-21 20:50:53.165337: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:50:58.270276: [TUN] [wireguradVPN] Handshake for peer 1 (87.160.79.50:51820) did not complete after 5 seconds, retrying (try 2)
              2022-10-21 20:50:58.270276: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:51:03.334727: [TUN] [wireguradVPN] Handshake for peer 1 (87.160.79.50:51820) did not complete after 5 seconds, retrying (try 2)
              2022-10-21 20:51:03.336295: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:51:08.353657: [TUN] [wireguradVPN] Handshake for peer 1 (87.160.79.50:51820) did not complete after 5 seconds, retrying (try 2)
              2022-10-21 20:51:08.353657: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:51:13.453828: [TUN] [wireguradVPN] Handshake for peer 1 (87.160.79.50:51820) did not complete after 5 seconds, retrying (try 2)
              2022-10-21 20:51:13.453828: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:51:18.455219: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:51:23.494192: [TUN] [wireguradVPN] Handshake for peer 1 (87.160.79.50:51820) did not complete after 5 seconds, retrying (try 2)
              2022-10-21 20:51:23.494192: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:51:28.568184: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:51:33.675120: [TUN] [wireguradVPN] Handshake for peer 1 (87.160.79.50:51820) did not complete after 5 seconds, retrying (try 2)
              2022-10-21 20:51:33.675120: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:51:38.691945: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:51:43.709706: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:51:48.734888: [TUN] [wireguradVPN] Handshake for peer 1 (87.160.79.50:51820) did not complete after 5 seconds, retrying (try 2)
              2022-10-21 20:51:48.734888: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:51:53.832496: [TUN] [wireguradVPN] Handshake for peer 1 (87.160.79.50:51820) did not complete after 5 seconds, retrying (try 2)
              2022-10-21 20:51:53.832496: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:51:58.975671: [TUN] [wireguradVPN] Handshake for peer 1 (87.160.79.50:51820) did not complete after 5 seconds, retrying (try 2)
              2022-10-21 20:51:58.975964: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:52:04.018414: [TUN] [wireguradVPN] Handshake for peer 1 (87.160.79.50:51820) did not complete after 5 seconds, retrying (try 2)
              2022-10-21 20:52:04.018414: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:52:09.150616: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:52:14.292485: [TUN] [wireguradVPN] Handshake for peer 1 (87.160.79.50:51820) did not complete after 5 seconds, retrying (try 2)
              2022-10-21 20:52:14.292485: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:52:19.303432: [TUN] [wireguradVPN] Handshake for peer 1 (87.160.79.50:51820) did not complete after 5 seconds, retrying (try 2)
              2022-10-21 20:52:19.304427: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:52:24.318120: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:52:29.333986: [TUN] [wireguradVPN] Handshake for peer 1 (87.160.79.50:51820) did not complete after 5 seconds, retrying (try 2)
              2022-10-21 20:52:29.333986: [TUN] [wireguradVPN] Sending handshake initiation to peer 1 (87.160.79.50:51820)
              2022-10-21 20:52:30.783476: [TUN] [wireguradVPN] Shutting down
              2022-10-21 20:52:30.785466: [MGR] [wireguradVPN] Tunnel service tracker finished
              • CrunkFX
                @saeft_2003 Hast du Proxmox geupdated? Oder wann ist das passiert?
                S 2 Replies Last reply Reply Quote 1
                  @crunkfx
                  nein ein proxmox update habe ich nicht gemacht. In letzter Zeit habe ich ein USG update gemacht und vor kurzem musste ich alles neustarten wegen USV tausch und danach ist es mir aufgefallen. wie lange es wirklich schon nicht mehr geht weiß ich nicht...
                    Vielen Dank an @crunkfx wireguard läuft wieder. War ein Fehler von mir da ich die wireguard IP doppelt belegt hab 😰
                      Andy61 @Kuddel last edited by
                      @kuddel
                      Hallo in die Runde,
                      Wireguard läuft derzeit an zwei Standorten auf Proxmox gut. Sehr stabil und schnell vom Macbook, Win11 und Handy. Auch ich wünsche mir jetzt eine side2side-Verbindung zwischen den 2 Standorten. Habe einiges probiert (z.B. https://schroederdennis.de/allgemein/wireguard-site-to-site-vpn-zwei-netzwerke-sicher-verbinden/) Leider hat es nicht funktioniert, die Daten werden in der wg0 wieder gelöscht. Ich wäre an einer Möglichkeit der permanenten Verbindung auch sehr interessiert.
                      LG Andreas
                      • CrunkFX
                        CrunkFX Forum Testing @Andy61 last edited by
                        @andy61 Moin, ich werde dir Idee Mal mit aufnehmen und schauen ob sich das Umsetzen lässt.
                        LG
                          Andy61 @CrunkFX last edited by
                          @crunkfx Ach, das wäre super. LG Andreas
                          • wendy2702
                            wendy2702 last edited by
                            Hat das jemand unter Proxmox V6 mit einem Debian Bullseye CT laufen?
                            Irgendwie erstellt es mir nie das „wg0“ Interface.
                            Jemand eine Idee dazu?
                              crunchip Forum Testing Most Active @wendy2702 last edited by
                              @wendy2702 sagte in [Anleitung] WireGuard mit WireGuard-UI auf Proxmox:
                              Proxmox V6
                              ich weiss nur von damals, siehe https://forum.iobroker.net/post/700421
                              • wendy2702
                                wendy2702 @crunchip last edited by
                                @crunchip ok.
                                Gesehen das du damals ja das „wg0“ interfaces hattest. Bei mir wird es aktuell nicht angelegt.
                                Mit den Kernel Headern muss ich mal schauen ob es das noch sein kann.
                                  Robbi12 last edited by
                                  Hallo. Ich habe den WireGuard am laufen. Nun gibt es aber schon neuere Versionen. Wie kann ich auf die neueste updaten. Mit dem Script update ändert sich nichts. Ich habe immer 0.3.5
                                  • Dr. Bakterius
                                    Dr. Bakterius Most Active @Robbi12 last edited by Dr. Bakterius
                                    @robbi12 sagte in [Anleitung] WireGuard mit WireGuard-UI auf Proxmox:
                                    Das würde mich auch interessieren. Ich habe zwar v0.3.7 würde aber trotzdem gerne aktuell bleiben. Wobei ich nicht weiß ob sich in WireGuard selbst etwas geändert hat oder nur in der UI. Vielleicht hat ja @crunkfx bald etwas?
                                    • Wal
                                      Wal Developer @Dr. Bakterius last edited by Wal
                                      @dr-bakterius, @Robbi12 ,
                                      wireguard wird über
                                      sudo apt update
                                      sudo apt upgrade
                                      aktualisiert.
                                      Die Wireguard-UI ist nur eine Datei, die kann man entpacken und tauschen.
                                      edit: funktioniert, eben getestet und bin bei wireguard-ui auf 0.4.0
                                      Dr. Bakterius Negalein 2 Replies Last reply Reply Quote 1
                                      • Dr. Bakterius
                                        Dr. Bakterius Most Active @Wal last edited by
                                        @wal Danke. Ich habe also v0.4.0 für Linux (unter Show all 20 assets) heruntergeladen und unter /opt/wireguard-ui die alte mit der entpackten wireguard-ui ersetzt. Erst nach einem Neustart war die neue UI aktiv.
                                        Ich schreibe das, weil ich erst die falsche Version geladen hatte und dann nach dem Neustart gar nichts mehr ging. Falls man die alte Datei umbenannt hat, muss man der neuen die richtigen Rechte (755) geben.
                                        Und die eigentliche WireGuard-Version ist aktuell auch schon wieder über ein Jahr alt. Stimmt das? Denn Updates habe ich heuer keine bekommen.
                                        Thomas Braun Wal 2 Replies Last reply Reply Quote 0
                                          Thomas Braun Most Active @Dr. Bakterius last edited by
                                          @dr-bakterius sagte in [Anleitung] WireGuard mit WireGuard-UI auf Proxmox:
                                          WireGuard ist ab Version 5.6 direkt im Linux-Kernel enthalten.
                                          • Negalein
                                            Negalein Global Moderator @Wal last edited by
                                            @wal sagte in [Anleitung] WireGuard mit WireGuard-UI auf Proxmox:
                                            geht das nur so?
                                            Dachte das wird bei einem upgrade erledigt.
                                            Wie komm ich zu der Datei und wo gehört die hin, usw.?
                                            portforwarding portfreigabe portfreischaltung proxmox vpn wireguard wireguard ios app
                                            64
                                            603
                                            169221
