    4. Test Adapter mihome-cloud
    • JackDaniel
      JackDaniel last edited by JackDaniel
      mit der letzten version stürzt der adapter ab, wahrscheinlich weil der luftbefeuchter offline ist
      mihome-cloud.0
      2022-11-06 07:04:04.610	error	TypeError: Cannot read properties of undefined (reading '75543767')
      mihome-cloud.0
      2022-11-06 07:04:04.609	error	/home/rpc/75543767
      mihome-cloud.0
      2022-11-06 07:04:04.422	error	{"code":-8,"message":"invalid param","result":null}
      mihome-cloud.0
      2022-11-06 07:04:04.422	error	Error getting Events of the device for R2D2 (320373564)
      mihome-cloud.0
      2022-11-06 07:04:04.181	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      mihome-cloud.0
      2022-11-06 07:04:04.180	info	terminating
      mihome-cloud.0
      2022-11-06 07:04:04.175	error	Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus
      mihome-cloud.0
      2022-11-06 07:04:04.174	error	Error: Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._setObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2980:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3211:29) at processImmediate (node:internal/timers:468:21)
      mihome-cloud.0
      2022-11-06 07:04:04.173	error	unhandled promise rejection: Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus
      mihome-cloud.0
      2022-11-06 07:04:04.172	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      mihome-cloud.0
      2022-11-06 07:04:04.123	error	TypeError: Cannot read properties of null (reading '0')
      mihome-cloud.0
      2022-11-06 07:04:03.050	info	Found plugin for deerma.humidifier.jsq
      mihome-cloud.0
      2022-11-06 07:04:03.050	info	Found 1 remote events for yeelink.light.bslamp1
      mihome-cloud.0
      2022-11-06 07:04:03.049	info	Found 3 remote commands for yeelink.light.bslamp1
      mihome-cloud.0
      2022-11-06 07:03:59.697	info	Found plugin for yeelink.light.bslamp1
      mihome-cloud.0
      2022-11-06 07:03:59.696	error	TypeError: Cannot read properties of null (reading '0')
      mihome-cloud.0
      2022-11-06 07:03:58.492	info	Found plugin for roborock.vacuum.s5
      mihome-cloud.0
      2022-11-06 07:03:58.350	info	Fetching Plugins
      mihome-cloud.0
      2022-11-06 07:03:58.339	info	prop.ct
      mihome-cloud.0
      2022-11-06 07:03:58.339	info	prop.bright
      mihome-cloud.0
      2022-11-06 07:03:58.338	info	prop.power
      mihome-cloud.0
      2022-11-06 07:03:58.338	info	Found yeelink.light.bslamp1 (Nachttischlampe) with 3 properties
      mihome-cloud.0
      2022-11-06 07:03:58.334	info	event.status
      mihome-cloud.0
      2022-11-06 07:03:58.334	info	Found roborock.vacuum.s5 (R2D2) with 1 properties
      mihome-cloud.0
      2022-11-06 07:03:58.329	info	Found 3 devices
      mihome-cloud.0
      2022-11-06 07:03:58.140	info	Get devices
      mihome-cloud.0
      2022-11-06 07:03:58.136	info	Login successful
      mihome-cloud.0
      2022-11-06 07:03:57.374	info	Login to MiHome Cloud
      mihome-cloud.0
      2022-11-06 07:03:57.353	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.mihome-cloud#567a013f3147de9ffcf2289a907b73fa852dd039) in /opt/iobroker/node_modules/iobroker.mihome-cloud, node: v16.18.1, js-controller: 4.0.23
      edit, passiert auch wenn der luftbefeuchter online ist
      mihome-cloud.0
      2022-11-06 07:11:01.673	error	TypeError: Cannot read properties of undefined (reading '75543767')
      mihome-cloud.0
      2022-11-06 07:11:01.673	error	/home/rpc/75543767
      mihome-cloud.0
      2022-11-06 07:11:01.672	debug	{"code":0,"error":{"code":-32601,"message":"Method not found."},"exe_time":0,"id":6507368,"message":"ok","net_cost":0,"ot_cost":0,"otlocalts":1667715061666172}
      mihome-cloud.0
      2022-11-06 07:11:01.551	error	{"code":-8,"message":"invalid param","result":null}
      mihome-cloud.0
      2022-11-06 07:11:01.550	error	Error getting Events of the device for R2D2 (320373564)
      mihome-cloud.0
      2022-11-06 07:11:01.378	debug	undefined
      mihome-cloud.0
      2022-11-06 07:11:01.377	debug	{"code":0,"exe_time":1,"id":491585,"message":"ok","net_cost":30,"ot_cost":0,"otlocalts":1667715061367277,"result":"unknown_method"}
      mihome-cloud.0
      2022-11-06 07:11:01.282	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      mihome-cloud.0
      2022-11-06 07:11:01.282	info	terminating
      mihome-cloud.0
      2022-11-06 07:11:01.265	error	Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus
      mihome-cloud.0
      2022-11-06 07:11:01.265	error	Error: Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._setObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2980:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3211:29) at processImmediate (node:internal/timers:468:21)
      mihome-cloud.0
      2022-11-06 07:11:01.264	error	unhandled promise rejection: Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus
      mihome-cloud.0
      2022-11-06 07:11:01.263	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      mihome-cloud.0
      2022-11-06 07:11:01.246	error	TypeError: Cannot read properties of null (reading '0')
      mihome-cloud.0
      2022-11-06 07:11:00.308	info	Found plugin for deerma.humidifier.jsq
      mihome-cloud.0
      2022-11-06 07:11:00.308	info	Found 1 remote events for yeelink.light.bslamp1
      mihome-cloud.0
      2022-11-06 07:11:00.308	info	Found 3 remote commands for yeelink.light.bslamp1
      mihome-cloud.0
      2022-11-06 07:10:56.845	info	Found plugin for yeelink.light.bslamp1
      mihome-cloud.0
      2022-11-06 07:10:56.845	error	TypeError: Cannot read properties of null (reading '0')
      mihome-cloud.0
      2022-11-06 07:10:55.756	info	Found plugin for roborock.vacuum.s5
      mihome-cloud.0
      2022-11-06 07:10:55.756	debug	{"code":0,"message":"","result":{"latest_info":[{"plugin_id":1000570,"plugin_package_id":1012902,"version":39,"sdk_version":10047,"change_log":"修复和优化一些问题,内部版本52","download_url":"https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2020-12-08/signed_10047_1000570_39_IOS_bundle_e6776fdd671602f308b9be25d889bb0c.zip","size":5443322,"model":"roborock.vacuum.s5","force_update_status":0,"status":8,"md5sum":"e6776fdd671602f308b9be25d889bb0c","gray_info":"{\"data\":[2263,5263],\"type\":\"range\"}","platform":2,"create_time":1607418709856,"dev_mode":1},{"plugin_id":1000708,"plugin_package_id":1002507,"version":2,"sdk_version":10026,"change_log":"1.修改jira。\n1.fix jira.","download_url":"https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2019-09-11/signed_10026_1000708_2_IOS_bundle_ec15991cae11aa91ee5abb3f8e94b0a3.zip","size":5913729,"model":"yeelink.light.bslamp1","force_update_status":0,"status":8,"md5sum":"ec15991cae11aa91ee5abb3f8e94b0a3","gray_info":"{\"data\":[903,3903],\"type\":\"range\"}","platform":2,"create_time":1568186512298,"dev_mode":1},{"plugin_id":1001591,"plugin_package_id":1007699,"version":20,"sdk_version":10039,"change_log":"1.修改部分地区非英语状态下用户协议和隐私政策 2.修复撤销授权后,重新绑定设备无授权弹窗 3.用户协议内隐私超链接跳转本地隐私 4.修复隐私政策滑动超出屏幕范围","download_url":"https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2020-06-03/signed_10039_1001591_20_IOS_bundle_9aff56ed7184c786c1f0f6db5e47ae4d.zip","size":6432439,"model":"deerma.humidifier.jsq","force_update_status":0,"status":8,"md5sum":"9aff56ed7184c786c1f0f6db5e47ae4d","gray_info":"[]","platform":2,"create_time":1591198078444,"dev_mode":1}],"backup_info":null,"stand_plugin_info":null}}
      mihome-cloud.0
      2022-11-06 07:10:55.638	info	Fetching Plugins
      mihome-cloud.0
      2022-11-06 07:10:55.634	debug	{"did":"238442715","uid":1754651949,"token":"b2e21761512e0ccb16c2ededd82218ab","name":"Luftbefeuchter","pid":0,"localip":"192.168.1.202","mac":"44:23:7C:BC:A3:DB","ssid":"JackDaniel","bssid":"18:E8:29:EA:04:B6","rssi":-50,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"deerma.humidifier.jsq","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:humidifier:0000A00E:deerma-jsq:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"2.0.7","mcu_version":"0113","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1642267702,"freqFlag":true,"hide_mode":0,"comFlag":129}
      mihome-cloud.0
      2022-11-06 07:10:55.634	info	prop.ct
      mihome-cloud.0
      2022-11-06 07:10:55.634	info	prop.bright
      mihome-cloud.0
      2022-11-06 07:10:55.634	info	prop.power
      mihome-cloud.0
      2022-11-06 07:10:55.633	info	Found yeelink.light.bslamp1 (Nachttischlampe) with 3 properties
      mihome-cloud.0
      2022-11-06 07:10:55.631	debug	{"did":"75543767","uid":1754651949,"token":"5da80bd97d0fe34520e531fbbb6ce41b","name":"Nachttischlampe","pid":0,"localip":"192.168.1.100","mac":"78:11:DC:92:75:AF","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-63,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"yeelink.light.bslamp1","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:light:0000A001:yeelink-bslamp1:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"1.6.6_0172","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1649341774,"freqFlag":true,"hide_mode":0,"comFlag":129}
      mihome-cloud.0
      2022-11-06 07:10:55.630	info	event.status
      mihome-cloud.0
      2022-11-06 07:10:55.630	info	Found roborock.vacuum.s5 (R2D2) with 1 properties
      mihome-cloud.0
      2022-11-06 07:10:55.626	debug	{"did":"320373564","uid":1754651949,"token":"717154435a79744d364d31494c577967","name":"R2D2","pid":0,"localip":"192.168.1.101","mac":"64:90:C1:02:7F:1F","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-70,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"roborock.vacuum.s5","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:vacuum:0000A006:roborock-s5:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"3.5.8_002034","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1635497246,"freqFlag":true,"hide_mode":0,"comFlag":129}
      mihome-cloud.0
      2022-11-06 07:10:55.626	info	Found 3 devices
      mihome-cloud.0
      2022-11-06 07:10:55.625	debug	{"code":0,"message":"","result":{"list":[{"did":"320373564","uid":1754651949,"token":"717154435a79744d364d31494c577967","name":"R2D2","pid":0,"localip":"192.168.1.101","mac":"64:90:C1:02:7F:1F","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-70,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"roborock.vacuum.s5","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:vacuum:0000A006:roborock-s5:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"3.5.8_002034","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1635497246,"freqFlag":true,"hide_mode":0,"comFlag":129},{"did":"75543767","uid":1754651949,"token":"5da80bd97d0fe34520e531fbbb6ce41b","name":"Nachttischlampe","pid":0,"localip":"192.168.1.100","mac":"78:11:DC:92:75:AF","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-63,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"yeelink.light.bslamp1","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:light:0000A001:yeelink-bslamp1:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"1.6.6_0172","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1649341774,"freqFlag":true,"hide_mode":0,"comFlag":129},{"did":"238442715","uid":1754651949,"token":"b2e21761512e0ccb16c2ededd82218ab","name":"Luftbefeuchter","pid":0,"localip":"192.168.1.202","mac":"44:23:7C:BC:A3:DB","ssid":"JackDaniel","bssid":"18:E8:29:EA:04:B6","rssi":-50,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"deerma.humidifier.jsq","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:humidifier:0000A00E:deerma-jsq:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"2.0.7","mcu_version":"0113","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1642267702,"freqFlag":true,"hide_mode":0,"comFlag":129}],"next_start_did":"","has_more":false}}
      mihome-cloud.0
      2022-11-06 07:10:55.437	info	Get devices
      mihome-cloud.0
      2022-11-06 07:10:55.433	info	Login successful
      mihome-cloud.0
      2022-11-06 07:10:55.433	debug	"ok"
      mihome-cloud.0
      2022-11-06 07:10:55.278	debug	"&&&START&&&{\"qs\":\"%3Fsid%3Dxiaomiio%26_json%3Dtrue\",\"ssecurity\":\"1nuzfaFwfYRR3E70kcw7zw==\",\"code\":0,\"passToken\":\"V1:DXmurwq2/R1BHTELu6obCfNOuAI0Iv5HC+ZKR4VeN98R0O9vyCJKsIYXPVOFB78uex4SRjcbOjr7weIKRtqnzu5WRyIhKTCSEArk1mLwKgY0hRPilk3p+TBNN8y68Fc2Sq9qEP+rVE1VBWCudmqMU1/uM+1Kg4PLjm1eZEDaxZVgSLfJN3v9j93Mgk+yl9sY76EW7qxmC+1Wrh0ML08e/yHd6SIjo2yH6gKuXMoNKMB9pY/W6z13Z2A33MyCWDbUNwqRkQab/BM9blbWOUBIRscQWSh+GfLk+9tDYJTmMXU=\",\"description\":\"成功\",\"securityStatus\":0,\"nonce\":1041428829432506368,\"userId\":1754651949,\"cUserId\":\"EzXMhMFs8J0wtEntUPSNUwO-ghA\",\"result\":\"ok\",\"psecurity\":\"pbMDCjbzPNpsXct3WxyWvA==\",\"captchaUrl\":null,\"location\":\"https://sts.api.io.mi.com/sts?d=wb_0bbef18b-a7e7-429b-99f5-151dafc6adaf&ticket=0&pwd=1&p_ts=1667715055000&fid=0&p_lm=1&auth=X72DCz5iXjCDRWr9tuuCbMlu3fcLNLKFJLiA8MCOOE0spfqHDH%2Bph3hLRKGO8Qwg5R7JtyFtWvSXfvIhTTXF9imqI50BRp3jtCfNBfHPnQXMsYtXtgajpV5C1Rduyt1mTaFyEvRdbnwoxQkUTaRqH4A61yLsk%2FLyHZDZaND%2FS9s%3D&m=1&_group=DEFAULT&tsl=0&p_ca=0&p_ur=AT&p_idc=Europe&nonce=dCEqK8f1jcoBqB8y&_ssign=QID%2FKBkWcArWOg8B2ZG%2FHPQiAic%3D\",\"pwd\":1,\"child\":0,\"desc\":\"成功\"}"
      mihome-cloud.0
      2022-11-06 07:10:55.036	debug	"&&&START&&&{\"serviceParam\":\"{\\\"checkSafePhone\\\":false,\\\"checkSafeAddress\\\":false,\\\"lsrp_score\\\":0.0}\",\"qs\":\"%3Fsid%3Dxiaomiio%26_json%3Dtrue\",\"code\":70016,\"description\":\"登录验证失败\",\"securityStatus\":0,\"_sign\":\"0psXfr43eNI0IX6q9Suk3qWbRqU=\",\"sid\":\"xiaomiio\",\"result\":\"error\",\"captchaUrl\":null,\"callback\":\"https://sts.api.io.mi.com/sts\",\"location\":\"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=\",\"pwd\":0,\"child\":0,\"desc\":\"登录验证失败\"}"
      mihome-cloud.0
      2022-11-06 07:10:54.727	info	Login to MiHome Cloud
      mihome-cloud.0
      2022-11-06 07:10:54.707	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.mihome-cloud#567a013f3147de9ffcf2289a907b73fa852dd039) in /opt/iobroker/node_modules/iobroker.mihome-cloud, node: v16.18.1, js-controller: 4.0.23
        tombox @JackDaniel last edited by
        @jackdaniel Danke für das feedback nochmal neu installieren und schauen was er dann ausgibt
          tombox @Guest last edited by
          @hannnes Kannst du ein screenshot zeigen. Gibt es remote commands die funktionieren?
          • JackDaniel
            @tombox sagte in Test Adapter mihome-cloud:
            klemmt leider noch wo 😞
            mihome-cloud.0
            2022-11-06 10:37:01.173	info	{"code":-8,"message":"invalid param","result":null}
            mihome-cloud.0
            2022-11-06 10:37:01.172	info	Error getting Events of the device for Luftbefeuchter (238442715) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
            mihome-cloud.0
            2022-11-06 10:37:01.018	info	{"code":-2,"error":{"code":-2,"message":"did offline"},"exe_time":0,"id":4927700,"message":"did offline","net_cost":0,"ot_cost":0}
            mihome-cloud.0
            2022-11-06 10:37:01.017	info	Error getting Status of the device for Luftbefeuchter (238442715) with {"id":0,"method":"Set_HumiValue","accessKey":"IOS00026747c5acafc2","params":[]}
            mihome-cloud.0
            2022-11-06 10:37:00.911	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
            mihome-cloud.0
            2022-11-06 10:37:00.910	info	terminating
            mihome-cloud.0
            2022-11-06 10:37:00.899	error	Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus
            mihome-cloud.0
            2022-11-06 10:37:00.898	error	Error: Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._setObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2980:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3211:29) at processImmediate (node:internal/timers:468:21)
            mihome-cloud.0
            2022-11-06 10:37:00.897	error	unhandled promise rejection: Invalid ID: mihome-cloud.0.320373564.remote.tate == _RobotStatusManager.RobotState.REMOTE ? Protocol.Methods.AppRemoteControlEnd : Protocol.Methods.AppPaus
            mihome-cloud.0
            2022-11-06 10:37:00.897	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            mihome-cloud.0
            2022-11-06 10:37:00.881	info	Found 1 remote events for yeelink.light.bslamp1
            mihome-cloud.0
            2022-11-06 10:37:00.880	info	Found 3 remote commands for yeelink.light.bslamp1
            mihome-cloud.0
            2022-11-06 10:36:57.082	info	Found plugin for yeelink.light.bslamp1
            mihome-cloud.0
            2022-11-06 10:36:57.081	error	TypeError: Cannot read properties of null (reading '0')
            mihome-cloud.0
            2022-11-06 10:36:56.037	info	Found plugin for roborock.vacuum.s5
            mihome-cloud.0
            2022-11-06 10:36:56.037	error	TypeError: Cannot read properties of null (reading '0')
            mihome-cloud.0
            2022-11-06 10:36:51.936	info	Found plugin for deerma.humidifier.jsq
            mihome-cloud.0
            2022-11-06 10:36:51.936	debug	{"code":0,"message":"","result":{"latest_info":[{"plugin_id":1001591,"plugin_package_id":1007699,"version":20,"sdk_version":10039,"change_log":"1.修改部分地区非英语状态下用户协议和隐私政策 2.修复撤销授权后,重新绑定设备无授权弹窗 3.用户协议内隐私超链接跳转本地隐私 4.修复隐私政策滑动超出屏幕范围","download_url":"https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2020-06-03/signed_10039_1001591_20_IOS_bundle_9aff56ed7184c786c1f0f6db5e47ae4d.zip","size":6432439,"model":"deerma.humidifier.jsq","force_update_status":0,"status":8,"md5sum":"9aff56ed7184c786c1f0f6db5e47ae4d","gray_info":"[]","platform":2,"create_time":1591198078444,"dev_mode":1},{"plugin_id":1000570,"plugin_package_id":1012902,"version":39,"sdk_version":10047,"change_log":"修复和优化一些问题,内部版本52","download_url":"https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2020-12-08/signed_10047_1000570_39_IOS_bundle_e6776fdd671602f308b9be25d889bb0c.zip","size":5443322,"model":"roborock.vacuum.s5","force_update_status":0,"status":8,"md5sum":"e6776fdd671602f308b9be25d889bb0c","gray_info":"{\"data\":[2263,5263],\"type\":\"range\"}","platform":2,"create_time":1607418709856,"dev_mode":1},{"plugin_id":1000708,"plugin_package_id":1002507,"version":2,"sdk_version":10026,"change_log":"1.修改jira。\n1.fix jira.","download_url":"https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2019-09-11/signed_10026_1000708_2_IOS_bundle_ec15991cae11aa91ee5abb3f8e94b0a3.zip","size":5913729,"model":"yeelink.light.bslamp1","force_update_status":0,"status":8,"md5sum":"ec15991cae11aa91ee5abb3f8e94b0a3","gray_info":"{\"data\":[903,3903],\"type\":\"range\"}","platform":2,"create_time":1568186512298,"dev_mode":1}],"backup_info":null,"stand_plugin_info":null}}
            mihome-cloud.0
            2022-11-06 10:36:51.806	info	Fetching Plugins
            mihome-cloud.0
            2022-11-06 10:36:51.806	info	prop.ct
            mihome-cloud.0
            2022-11-06 10:36:51.806	info	prop.bright
            mihome-cloud.0
            2022-11-06 10:36:51.805	info	prop.power
            mihome-cloud.0
            2022-11-06 10:36:51.805	info	Found yeelink.light.bslamp1 (Nachttischlampe) with 3 properties
            mihome-cloud.0
            2022-11-06 10:36:51.797	debug	{"did":"75543767","uid":1754651949,"token":"5da80bd97d0fe34520e531fbbb6ce41b","name":"Nachttischlampe","pid":0,"localip":"192.168.1.100","mac":"78:11:DC:92:75:AF","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-63,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"yeelink.light.bslamp1","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:light:0000A001:yeelink-bslamp1:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"1.6.6_0172","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1649341774,"freqFlag":true,"hide_mode":0,"comFlag":129}
            mihome-cloud.0
            2022-11-06 10:36:51.796	info	event.status
            mihome-cloud.0
            2022-11-06 10:36:51.796	info	Found roborock.vacuum.s5 (R2D2) with 1 properties
            mihome-cloud.0
            2022-11-06 10:36:51.789	debug	{"did":"320373564","uid":1754651949,"token":"717154435a79744d364d31494c577967","name":"R2D2","pid":0,"localip":"192.168.1.101","mac":"64:90:C1:02:7F:1F","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-70,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"roborock.vacuum.s5","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:vacuum:0000A006:roborock-s5:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"3.5.8_002034","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1635497246,"freqFlag":true,"hide_mode":0,"comFlag":129}
            mihome-cloud.0
            2022-11-06 10:36:51.782	debug	{"did":"238442715","uid":1754651949,"token":"b2e21761512e0ccb16c2ededd82218ab","name":"Luftbefeuchter","pid":0,"localip":"192.168.1.202","mac":"44:23:7C:BC:A3:DB","ssid":"JackDaniel","bssid":"18:E8:29:EA:04:B6","rssi":-50,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"deerma.humidifier.jsq","permitLevel":16,"isOnline":false,"spec_type":"urn:miot-spec-v2:device:humidifier:0000A00E:deerma-jsq:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"2.0.7","mcu_version":"0113","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1642267702,"freqFlag":true,"hide_mode":0,"comFlag":129}
            mihome-cloud.0
            2022-11-06 10:36:51.782	info	Found 3 devices
            mihome-cloud.0
            2022-11-06 10:36:51.781	debug	{"code":0,"message":"","result":{"list":[{"did":"238442715","uid":1754651949,"token":"b2e21761512e0ccb16c2ededd82218ab","name":"Luftbefeuchter","pid":0,"localip":"192.168.1.202","mac":"44:23:7C:BC:A3:DB","ssid":"JackDaniel","bssid":"18:E8:29:EA:04:B6","rssi":-50,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"deerma.humidifier.jsq","permitLevel":16,"isOnline":false,"spec_type":"urn:miot-spec-v2:device:humidifier:0000A00E:deerma-jsq:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"2.0.7","mcu_version":"0113","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1642267702,"freqFlag":true,"hide_mode":0,"comFlag":129},{"did":"320373564","uid":1754651949,"token":"717154435a79744d364d31494c577967","name":"R2D2","pid":0,"localip":"192.168.1.101","mac":"64:90:C1:02:7F:1F","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-70,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"roborock.vacuum.s5","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:vacuum:0000A006:roborock-s5:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"3.5.8_002034","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1635497246,"freqFlag":true,"hide_mode":0,"comFlag":129},{"did":"75543767","uid":1754651949,"token":"5da80bd97d0fe34520e531fbbb6ce41b","name":"Nachttischlampe","pid":0,"localip":"192.168.1.100","mac":"78:11:DC:92:75:AF","ssid":"JackDaniel","bssid":"78:45:58:B1:95:32","rssi":-63,"longitude":"0.00000000","latitude":"0.00000000","show_mode":1,"model":"yeelink.light.bslamp1","permitLevel":16,"isOnline":true,"spec_type":"urn:miot-spec-v2:device:light:0000A001:yeelink-bslamp1:1","extra":{"isSetPincode":0,"pincodeType":0,"fw_version":"1.6.6_0172","isSubGroup":false,"showGroupMember":false,"split":{}},"orderTime":1649341774,"freqFlag":true,"hide_mode":0,"comFlag":129}],"next_start_did":"","has_more":false}}
            mihome-cloud.0
            2022-11-06 10:36:51.625	info	Get devices
            mihome-cloud.0
            2022-11-06 10:36:51.622	info	Login successful
            mihome-cloud.0
            2022-11-06 10:36:51.621	debug	"ok"
            mihome-cloud.0
            2022-11-06 10:36:51.481	debug	"&&&START&&&{\"qs\":\"%3Fsid%3Dxiaomiio%26_json%3Dtrue\",\"ssecurity\":\"eLbNG0p56Mp/DYQOdhf4Og==\",\"code\":0,\"passToken\":\"V1:DXmurwq2/R1BHTELu6obCcDnh9hauOPj3DoX5tdXCKVmnlboKcoPNH/WiZSEz6zf7fxMnuHG7xmQRLHGs3uv7uyCbSI8lsLiDgmEEHOhTF5Whl9SSqUCt3tLumfA45sFSRgVqLvdQ8AfxhRkghXsfI0qxmgMycGQ00ge+lIimNORPamxswjf4kjFymxLnQeNSlqJn4X/3o4ODLfMtEedBpxnbvW1+aR7mDWINn5mKxB033Nbs/IAHmk9TLjc8+JXvBG5KynMNvJ8Sf7Yv+eRvPsgkv3uuGZgxIEJK3B6EEg=\",\"description\":\"成功\",\"securityStatus\":0,\"nonce\":5768626167211188224,\"userId\":1754651949,\"cUserId\":\"EzXMhMFs8J0wtEntUPSNUwO-ghA\",\"result\":\"ok\",\"psecurity\":\"+YaMogoDNn2lP+ERYNRvZw==\",\"captchaUrl\":null,\"location\":\"https://sts.api.io.mi.com/sts?d=wb_ef2622a1-355d-43ff-8640-1d31120126f3&ticket=0&pwd=1&p_ts=1667727411000&fid=0&p_lm=1&auth=h4CrMYd5y3N817SPY26%2BiSeE5ATB1mvnplGu%2B4h6ooR9xWVTdeCgrzxlGS3bjLmQ3i5Ckt81U4aBAGuKcagHzrU4F1pMBiwH5tFf2y2Lff1GDmXBQntkQtGIx28D7lDioBs4qvZHPwwny0m%2B4liDXTmPovqEbZw7daMVVHS9QrQ%3D&m=1&_group=DEFAULT&tsl=0&p_ca=0&p_ur=AT&p_idc=Europe&nonce=YNSuCyLJsGUBqCAA&_ssign=RB5dvDQ2Jzs5EbFybwyUELNKrLA%3D\",\"pwd\":1,\"child\":0,\"desc\":\"成功\"}"
            mihome-cloud.0
            2022-11-06 10:36:51.204	debug	"&&&START&&&{\"serviceParam\":\"{\\\"checkSafePhone\\\":false,\\\"checkSafeAddress\\\":false,\\\"lsrp_score\\\":0.0}\",\"qs\":\"%3Fsid%3Dxiaomiio%26_json%3Dtrue\",\"code\":70016,\"description\":\"登录验证失败\",\"securityStatus\":0,\"_sign\":\"0psXfr43eNI0IX6q9Suk3qWbRqU=\",\"sid\":\"xiaomiio\",\"result\":\"error\",\"captchaUrl\":null,\"callback\":\"https://sts.api.io.mi.com/sts\",\"location\":\"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=\",\"pwd\":0,\"child\":0,\"desc\":\"登录验证失败\"}"
            mihome-cloud.0
            2022-11-06 10:36:50.917	info	Login to MiHome Cloud
            mihome-cloud.0
            2022-11-06 10:36:50.895	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.mihome-cloud#3a7857507ff5078425c0881211690537a9ccf6ce) in /opt/iobroker/node_modules/iobroker.mihome-cloud, node: v16.18.1, js-controller: 4.0.23
            mihome-cloud.0
            2022-11-06 10:36:50.478	debug	States connected to redis: 127.0.0.1:9000
            mihome-cloud.0
            2022-11-06 10:36:50.350	debug	States create User PubSub Client
            mihome-cloud.0
            2022-11-06 10:36:50.349	debug	States create System PubSub Client
            mihome-cloud.0
            2022-11-06 10:36:50.304	debug	Redis States: Use Redis connection: 127.0.0.1:9000
            mihome-cloud.0
            2022-11-06 10:36:50.260	debug	Objects connected to redis: 127.0.0.1:9001
            mihome-cloud.0
            2022-11-06 10:36:50.254	debug	Objects client initialize lua scripts
            mihome-cloud.0
            2022-11-06 10:36:50.144	debug	Objects create User PubSub Client
            mihome-cloud.0
            2022-11-06 10:36:50.143	debug	Objects create System PubSub Client
            mihome-cloud.0
            2022-11-06 10:36:50.142	debug	Objects client ready ... initialize now
            mihome-cloud.0
            2022-11-06 10:36:50.082	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
              A Former User last edited by
              in "remote" ist noch nichts drin.
              Wenn ich sonst noch wo nachsehen soll, bitte mit kurzer Wegbeschreibung für Dummys, wo ich hin muss.
              haselchen T 2 Replies Last reply Reply Quote 0
                @jackdaniel Habe noch mal was verbessert aber es scheint so aufgrund der Unterschiedlichkeit der Geräte nicht möglich ein generischen Ansatz für alle Geräte zu finden.
                JackDaniel 1 Reply Last reply Reply Quote 0
                • JackDaniel
                  JackDaniel @tombox last edited by
                  @tombox
                  der crash ist nun weg, gibt aber noch fehler im log
                  wird der zugang zu meiner cloud benötigt?
                  mihome-cloud.0
                  Zeit
                  debug
                  Nachricht
                  mihome-cloud.0
                  2022-11-06 16:55:27.957	info	{"code":-8,"message":"invalid param","result":null}
                  mihome-cloud.0
                  2022-11-06 16:55:27.957	info	Error getting Events of the device for Nachttischlampe (75543767) with {"expire":10,"method":["this.apiDataSource.registerProps"],"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                  mihome-cloud.0
                  2022-11-06 16:55:27.844	error	SyntaxError: Unexpected token o in JSON at position 1 at JSON.parse (<anonymous>) at MihomeCloud.parseResponse (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:660:19) at /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:618:37 at processTicksAndRejections (node:internal/process/task_queues:96:5) at async MihomeCloud.updateDevices (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:593:9) at async Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:779:11)
                  mihome-cloud.0
                  mihome-cloud.0
                  2022-11-06 16:55:27.843	error	/home/rpc/75543767
                  mihome-cloud.0
                  2022-11-06 16:55:27.723	info	{"code":-8,"message":"invalid param","result":null}
                  mihome-cloud.0
                  2022-11-06 16:55:27.722	info	Error getting Events of the device for R2D2 (320373564) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                  mihome-cloud.0
                  2022-11-06 16:55:27.406	info	{"code":-8,"message":"invalid param","result":null}
                  mihome-cloud.0
                  2022-11-06 16:55:27.406	info	Error getting Events of the device for Luftbefeuchter (238442715) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                  mihome-cloud.0
                  2022-11-06 16:55:27.320	info	undefined is not a valid state value for id "mihome-cloud.0.238442715.status.status"
                  mihome-cloud.0
                  2022-11-06 16:55:27.011	info	Update devices
                  mihome-cloud.0
                  2022-11-06 16:55:18.727	info	{"code":-8,"message":"invalid param","result":null}
                  mihome-cloud.0
                  2022-11-06 16:55:18.727	info	Error getting Events of the device for Nachttischlampe (75543767) with {"expire":10,"method":["this.apiDataSource.registerProps"],"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                  mihome-cloud.0
                  2022-11-06 16:55:18.606	error	SyntaxError: Unexpected token o in JSON at position 1 at JSON.parse (<anonymous>) at MihomeCloud.parseResponse (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:660:19) at /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:618:37 at processTicksAndRejections (node:internal/process/task_queues:96:5) at async MihomeCloud.updateDevices (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:593:9) at async Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:779:11)
                  mihome-cloud.0
                  2022-11-06 16:55:18.605	error	SyntaxError: Unexpected token o in JSON at position 1
                  mihome-cloud.0
                  2022-11-06 16:55:18.605	error	/home/rpc/75543767
                  mihome-cloud.0
                  2022-11-06 16:55:18.443	info	{"code":-8,"message":"invalid param","result":null}
                  mihome-cloud.0
                  2022-11-06 16:55:18.443	info	Error getting Events of the device for R2D2 (320373564) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                  mihome-cloud.0
                  2022-11-06 16:55:18.183	info	{"code":-8,"message":"invalid param","result":null}
                  mihome-cloud.0
                  2022-11-06 16:55:18.183	info	Error getting Events of the device for Luftbefeuchter (238442715) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                  mihome-cloud.0
                  2022-11-06 16:55:18.068	info	undefined is not a valid state value for id "mihome-cloud.0.238442715.status.status"
                  mihome-cloud.0
                  2022-11-06 16:55:17.717	info	Update devices
                  mihome-cloud.0
                  2022-11-06 16:55:17.011	info	{"code":0,"exe_time":60,"id":9879399,"message":"ok","net_cost":74,"ot_cost":0,"otlocalts":1667750117003464,"result":["error"]}
                  mihome-cloud.0
                  2022-11-06 16:55:07.715	info	{"code":0,"exe_time":200,"id":8544340,"message":"ok","net_cost":65,"ot_cost":0,"otlocalts":1667750107708289,"result":["error"]}
                  mihome-cloud.0
                  2022-11-06 16:54:54.583	info	{"code":-8,"message":"invalid param","result":null}
                  mihome-cloud.0
                  2022-11-06 16:54:54.582	info	Error getting Events of the device for Nachttischlampe (75543767) with {"expire":10,"method":["this.apiDataSource.registerProps"],"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                  mihome-cloud.0
                  2022-11-06 16:54:54.464	error	SyntaxError: Unexpected token o in JSON at position 1 at JSON.parse (<anonymous>) at MihomeCloud.parseResponse (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:660:19) at /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:618:37 at processTicksAndRejections (node:internal/process/task_queues:96:5) at async MihomeCloud.updateDevices (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:593:9) at async Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:779:11)
                  mihome-cloud.0
                  2022-11-06 16:54:54.463	error	SyntaxError: Unexpected token o in JSON at position 1
                  mihome-cloud.0
                  2022-11-06 16:54:54.463	error	/home/rpc/75543767
                  mihome-cloud.0
                  2022-11-06 16:54:54.260	info	{"code":-8,"message":"invalid param","result":null}
                  mihome-cloud.0
                  2022-11-06 16:54:54.260	info	Error getting Events of the device for R2D2 (320373564) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                  mihome-cloud.0
                  2022-11-06 16:54:54.048	info	{"code":-8,"message":"invalid param","result":null}
                  mihome-cloud.0
                  2022-11-06 16:54:54.047	info	Error getting Events of the device for Luftbefeuchter (238442715) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                  mihome-cloud.0
                  2022-11-06 16:54:53.934	info	undefined is not a valid state value for id "mihome-cloud.0.238442715.status.status"
                  mihome-cloud.0
                  2022-11-06 16:54:53.652	info	Update devices
                  mihome-cloud.0
                  2022-11-06 16:54:43.651	info	{"code":0,"exe_time":240,"id":2281919,"message":"ok","net_cost":63,"ot_cost":0,"otlocalts":1667750083643273,"result":["error"]}
                  mihome-cloud.0
                  2022-11-06 16:54:38.739	info	{"code":-8,"message":"invalid param","result":null}
                  mihome-cloud.0
                  2022-11-06 16:54:38.739	info	Error getting Events of the device for Nachttischlampe (75543767) with {"expire":10,"method":["this.apiDataSource.registerProps"],"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                  mihome-cloud.0
                  2022-11-06 16:54:38.651	error	SyntaxError: Unexpected token o in JSON at position 1 at JSON.parse (<anonymous>) at MihomeCloud.parseResponse (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:660:19) at /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:618:37 at processTicksAndRejections (node:internal/process/task_queues:96:5) at async MihomeCloud.updateDevices (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:593:9) at async Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:779:11)
                  mihome-cloud.0
                  2022-11-06 16:54:38.650	error	SyntaxError: Unexpected token o in JSON at position 1
                  mihome-cloud.0
                  2022-11-06 16:54:38.650	error	/home/rpc/75543767
                  mihome-cloud.0
                  2022-11-06 16:54:38.492	info	{"code":-8,"message":"invalid param","result":null}
                  mihome-cloud.0
                  2022-11-06 16:54:38.492	info	Error getting Events of the device for R2D2 (320373564) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                  mihome-cloud.0
                  2022-11-06 16:54:38.236	info	{"code":-8,"message":"invalid param","result":null}
                  mihome-cloud.0
                  2022-11-06 16:54:38.236	info	Error getting Events of the device for Luftbefeuchter (238442715) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                  mihome-cloud.0
                  2022-11-06 16:54:38.151	info	undefined is not a valid state value for id "mihome-cloud.0.238442715.status.status"
                  mihome-cloud.0
                  2022-11-06 16:54:37.622	info	Update devices
                  mihome-cloud.0
                  2022-11-06 16:54:27.622	info	{"code":0,"exe_time":260,"id":5199127,"message":"ok","net_cost":103,"ot_cost":0,"otlocalts":1667750067604380,"result":["error"]}
                  mihome-cloud.0
                  2022-11-06 16:53:37.107	info	[{"sa_id":513,"model":"yeelink.light.bslamp1","name":"Turn on","keyName":"Turn on","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.color1.set_power","value":["on","smooth",500]},"protocol_type":1},{"sa_id":522,"model":"yeelink.light.bslamp1","name":"Turn off","keyName":"Turn off","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.color1.set_power","value":["off","smooth",500]},"protocol_type":1},{"sa_id":523,"model":"yeelink.light.bslamp1","name":"Turn on/off","keyName":"Turn on/off","type":0,"groupInfo":[],"tr_id":301,"payload":{"did":"","command":"yeelink.light.color1.toggle"},"protocol_type":1},{"sa_id":524,"model":"yeelink.light.bslamp1","name":"Light up for an adjustable period of time","keyName":"Light up for an adjustable period of time","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_scene","plug_id":"GET_YEELINK_DELAY_SETTING"},"protocol_type":1},{"sa_id":525,"model":"yeelink.light.bslamp1","name":"Turn on and set light","keyName":"Turn on and set light","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_scene","plug_id":"GET_YEELINK_SCENE"},"protocol_type":1},{"sa_id":526,"model":"yeelink.light.bslamp1","name":"Brightness up","keyName":"Brightness up","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["increase","bright"]},"protocol_type":1},{"sa_id":527,"model":"yeelink.light.bslamp1","name":"Brightness down","keyName":"Brightness down","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["decrease","bright"]},"protocol_type":1},{"sa_id":528,"model":"yeelink.light.bslamp1","name":"Switch brightness level","keyName":"Switch brightness level","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["circle","bright"]},"protocol_type":1},{"sa_id":529,"model":"yeelink.light.bslamp1","name":"Color temperature up","keyName":"Color temperature up","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["increase","ct"]},"protocol_type":1},{"sa_id":530,"model":"yeelink.light.bslamp1","name":"Color temperature down","keyName":"Color temperature down","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["decrease","ct"]},"protocol_type":1},{"sa_id":531,"model":"yeelink.light.bslamp1","name":"Switch color temperature level","keyName":"Switch color temperature level","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["circle","ct"]},"protocol_type":1},{"sa_id":532,"model":"yeelink.light.bslamp1","name":"Turn on or adjust brightness","keyName":"Turn on or adjust brightness","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["auto","bright"]},"protocol_type":1},{"sa_id":533,"model":"yeelink.light.bslamp1","name":"Turn on or adjust color temperature","keyName":"Turn on or adjust color temperature","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["auto","ct"]},"protocol_type":1},{"sa_id":534,"model":"yeelink.light.bslamp1","name":"Turn on or adjust color","keyName":"Turn on or adjust color","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["auto","color"]},"protocol_type":1},{"sa_id":535,"model":"yeelink.light.bslamp1","name":"Adjust brightness","keyName":"Adjust brightness","type":0,"groupInfo":[],"tr_id":302,"payload":{"did":"","command":"yeelink.light.bslamp1.adjust_bright"},"protocol_type":1},{"sa_id":536,"model":"yeelink.light.bslamp1","name":"Adjust color temperature","keyName":"Adjust color temperature","type":0,"groupInfo":[],"tr_id":302,"payload":{"did":"","command":"yeelink.light.bslamp1.adjust_ct"},"protocol_type":1},{"sa_id":537,"model":"yeelink.light.bslamp1","name":"Adjust color","keyName":"Adjust color","type":0,"groupInfo":[],"tr_id":302,"payload":{"did":"","command":"yeelink.light.bslamp1.adjust_color"},"protocol_type":1},{"sa_id":538,"model":"yeelink.light.bslamp1","name":"Switch color","keyName":"Switch color","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"yeelink.light.bslamp1.set_adjust","value":["circle","color"]},"protocol_type":1}]
                  mihome-cloud.0
                  2022-11-06 16:53:37.107	info	yeelink.light.bslamp1
                  mihome-cloud.0
                  2022-11-06 16:53:37.106	info	[{"sa_id":958,"model":"roborock.vacuum.s5","name":"Start cleaning","keyName":"Start cleaning","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"roborock.vacuum.s5.app_start"},"protocol_type":1},{"sa_id":959,"model":"roborock.vacuum.s5","name":"Switch to Balanced mode","keyName":"Switch to Balanced mode","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"roborock.vacuum.s5.set_custom_mode","value":60},"protocol_type":1},{"sa_id":960,"model":"roborock.vacuum.s5","name":"Switch to Quiet mode","keyName":"Switch to Quiet mode","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"roborock.vacuum.s5.set_custom_mode","value":38},"protocol_type":1},{"sa_id":961,"model":"roborock.vacuum.s5","name":"Pause cleaning","keyName":"Pause cleaning","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"roborock.vacuum.s5.app_pause"},"protocol_type":1},{"sa_id":962,"model":"roborock.vacuum.s5","name":"Switch to Turbo mode","keyName":"Switch to Turbo mode","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"roborock.vacuum.s5.set_custom_mode","value":77},"protocol_type":1},{"sa_id":963,"model":"roborock.vacuum.s5","name":"Go back to the dock","keyName":"Go back to the dock","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"roborock.vacuum.s5.app_smart_charge"},"protocol_type":1}]
                  mihome-cloud.0
                  2022-11-06 16:53:37.106	info	roborock.vacuum.s5
                  mihome-cloud.0
                  2022-11-06 16:53:37.106	info	[{"sa_id":6791,"model":"deerma.humidifier.jsq","name":"Turn off the humidifier","keyName":"Turn off the humidifier","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"deerma.humidifier.mjjsq.Set_OnOff","value":0},"protocol_type":1},{"sa_id":6792,"model":"deerma.humidifier.jsq","name":"Turn on the humidifier","keyName":"Turn on the humidifier","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"deerma.humidifier.mjjsq.Set_OnOff","value":1},"protocol_type":1},{"sa_id":6793,"model":"deerma.humidifier.jsq","name":"Set to constant humidity mode","keyName":"Set to constant humidity mode","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"deerma.humidifier.mjjsq.Set_HumidifierGears","value":4},"protocol_type":1},{"sa_id":6794,"model":"deerma.humidifier.jsq","name":"Set the humidifying speed to low","keyName":"Set the humidifying speed to low","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"deerma.humidifier.mjjsq.Set_HumidifierGears","value":1},"protocol_type":1},{"sa_id":6795,"model":"deerma.humidifier.jsq","name":"Set the humidifying speed to medium","keyName":"Set the humidifying speed to medium","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"deerma.humidifier.mjjsq.Set_HumidifierGears","value":2},"protocol_type":1},{"sa_id":6796,"model":"deerma.humidifier.jsq","name":"Set the humidifying speed to high","keyName":"Set the humidifying speed to high","type":0,"groupInfo":[],"tr_id":201,"payload":{"did":"","command":"deerma.humidifier.mjjsq.Set_HumidifierGears","value":3},"protocol_type":1}]
                  mihome-cloud.0
                  2022-11-06 16:53:37.106	info	deerma.humidifier.jsq
                  mihome-cloud.0
                  2022-11-06 16:53:37.006	info	{"code":0,"message":"","result":{"homelist":[{"id":"137001000499","name":"Da Ham","bssid":"","dids":[],"icon":"style_1_favorites","shareflag":0,"permit_level":10,"status":1,"background":"static1","smart_room_background":"style_1_favorites","longitude":0,"latitude":0,"city_id":0,"address":"","create_time":1519470799,"roomlist":[{"id":"137001034342","name":"Gästezimmer","bssid":"","parentid":"137001000499","dids":["75543767"],"icon":"more_1","background":"style_1_favorites","shareflag":0,"create_time":1636094924},{"id":"137001000503","name":"Wohnzimmer","bssid":"","parentid":"137001000499","dids":["238442715","320373564"],"icon":"livingroom_1","background":"style_1_favorites","shareflag":0,"create_time":1519494939}],"uid":1754651949}],"has_more":false,"max_id":"75543767"}}
                  mihome-cloud.0
                  2022-11-06 16:53:36.880	info	{"code":0,"message":"","result":{"local_list":[],"third_list":[]}}
                  mihome-cloud.0
                  2022-11-06 16:53:36.792	info	{"code":-8,"message":"invalid param","result":null}
                  mihome-cloud.0
                  2022-11-06 16:53:36.792	info	Error getting Events of the device for Nachttischlampe (75543767) with {"expire":10,"method":["this.apiDataSource.registerProps"],"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                  mihome-cloud.0
                  2022-11-06 16:53:36.647	error	SyntaxError: Unexpected token o in JSON at position 1 at JSON.parse (<anonymous>) at MihomeCloud.parseResponse (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:660:19) at /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:618:37 at runMicrotasks (<anonymous>) at processTicksAndRejections (node:internal/process/task_queues:96:5) at async MihomeCloud.updateDevices (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:593:9) at async MihomeCloud.onReady (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:93:7)
                  mihome-cloud.0
                  2022-11-06 16:53:36.646	error	SyntaxError: Unexpected token o in JSON at position 1
                  mihome-cloud.0
                  2022-11-06 16:53:36.646	error	/home/rpc/75543767
                  mihome-cloud.0
                  2022-11-06 16:53:33.509	info	{"code":-8,"message":"invalid param","result":null}
                  mihome-cloud.0
                  2022-11-06 16:53:33.509	info	Error getting Events of the device for R2D2 (320373564) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                  mihome-cloud.0
                  2022-11-06 16:53:33.252	info	{"code":-8,"message":"invalid param","result":null}
                  mihome-cloud.0
                  2022-11-06 16:53:33.252	info	Error getting Events of the device for Luftbefeuchter (238442715) with {"expire":10,"did":"$DID","client":1,"subid":"0","accessKey":"IOS00026747c5acafc2","pid":0}
                  mihome-cloud.0
                  2022-11-06 16:53:33.196	info	undefined is not a valid state value for id "mihome-cloud.0.238442715.status.status"
                  mihome-cloud.0
                  2022-11-06 16:53:33.190	warn	This object will not be created in future versions. Please report this to the developer.
                  mihome-cloud.0
                  2022-11-06 16:53:33.190	warn	Object mihome-cloud.0.238442715.status.status is invalid: obj.common.type has an invalid value (undefined) but has to be one of number, string, boolean, array, object, mixed, file, json
                  mihome-cloud.0
                  2022-11-06 16:53:32.401	info	Found 1 remote events for yeelink.light.bslamp1
                  mihome-cloud.0
                  2022-11-06 16:53:32.401	info	Found 80 remote commands for yeelink.light.bslamp1
                  mihome-cloud.0
                  2022-11-06 16:53:30.604	info	Found plugin for yeelink.light.bslamp1
                  mihome-cloud.0
                  2022-11-06 16:53:30.604	info	Found 0 remote events for roborock.vacuum.s5
                  mihome-cloud.0
                  2022-11-06 16:53:30.593	info	Found 247 remote commands for roborock.vacuum.s5
                  mihome-cloud.0
                  2022-11-06 16:53:30.567	warn	Please report this url to the developer: https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2020-12-08/signed_10047_1000570_39_IOS_bundle_e6776fdd671602f308b9be25d889bb0c.zip
                  mihome-cloud.0
                  2022-11-06 16:53:30.567	warn	Remote commmands too long for roborock.vacuum.s5
                  mihome-cloud.0
                  2022-11-06 16:53:26.974	info	Found plugin for roborock.vacuum.s5
                  mihome-cloud.0
                  2022-11-06 16:53:26.974	info	Found 0 remote events for deerma.humidifier.jsq
                  mihome-cloud.0
                  2022-11-06 16:53:26.973	info	Found 11 remote commands for deerma.humidifier.jsq
                  mihome-cloud.0
                  2022-11-06 16:53:25.843	info	Found plugin for deerma.humidifier.jsq
                  mihome-cloud.0
                  2022-11-06 16:53:25.723	info	Fetching Plugins
                  mihome-cloud.0
                  2022-11-06 16:53:25.722	info	prop.ct
                  mihome-cloud.0
                  2022-11-06 16:53:25.722	info	prop.bright
                  mihome-cloud.0
                  2022-11-06 16:53:25.722	info	prop.power
                  mihome-cloud.0
                  2022-11-06 16:53:25.722	info	Found yeelink.light.bslamp1 (Nachttischlampe) in configDes with 3 properties
                  mihome-cloud.0
                  2022-11-06 16:53:25.720	info	event.status
                  mihome-cloud.0
                  2022-11-06 16:53:25.719	info	Found roborock.vacuum.s5 (R2D2) in configDes with 1 properties
                  mihome-cloud.0
                  2022-11-06 16:53:25.715	info	Found 3 devices
                  mihome-cloud.0
                  2022-11-06 16:53:25.547	info	Get devices
                  mihome-cloud.0
                  2022-11-06 16:53:25.543	info	Login successful
                  mihome-cloud.0
                  2022-11-06 16:53:24.790	info	Login to MiHome Cloud
                  mihome-cloud.0
                  2022-11-06 16:53:24.756	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.mihome-cloud#ed6074fea8ada7e315fc8c159664cd8edfaa7007) in /opt/iobroker/node_modules/iobroker.mihome-cloud, node: v16.18.1, js-controller: 4.0.23
                  • haselchen
                    haselchen Most Active @Guest last edited by
                    @hannnes
                    Die Infos , die Du hast, gab es schon mit der 1.Version des Adapters.
                    Sorry, dass ich dich da bremsen muss 🙂
                    Ich denke, nun wird an den möglichen Einstellungen gefeilt, dass du das Teil auch steuern kannst.
                      A Former User @haselchen last edited by A Former User
                      @haselchen
                      Achso, nee, Du musst mich nicht bremsen. Ich machen hier tatsächlich nur mit, um zu helfen. Ist mir völlig klar, dass das noch nicht von Anfang an geht. Ich frage nur, ob ich was nachsehen soll, was für Tom wichtig wäre. 🙂
                        @hannnes Könntest du mir so ein fan mal via miHome app teilen, würde mich interessieren wie der in der app ausgelesen wird
                        tombox2020@gmail.com
                          A Former User @tombox last edited by
                          @tombox
                          Ich versuche es später nochmal
                            A Former User @Guest last edited by A Former User
                            @tombox
                            Ok ein einzelnes Gerät konnte ich teilen. Das gesamte zuhause hat nicht geklappt. Siehst Du was?
                              @hannnes Ja sehe das Gerät aber ich denke ich muss den Adapter nochmal umschreiben. Denn der Aufbau wie Geräte bei mihome eingebunden werden ist sehr schwierig
                                @tombox
                                Bin schon sehr gespannt.
                                Bekommt ioBroker ein Update automatisch mit, oder installiert man dann manuell „drüber“?
                                  @hannnes Wenn der Adapter beta wird bekommt der iobroker das mit. ansonsten nach Aufforderung manuell installieren
                                  ? Thomas Braun 2 Replies Last reply Reply Quote 0
                                    @tombox 👍
                                      bob der 1. @tombox last edited by
                                      @tombox
                                      Cooler Adapter,mein Dreame D9 wird auch erkannt.
                                        Thomas Braun Most Active @tombox last edited by
                                        @tombox
                                        Gerade nochmal reingeschaut.
                                        Meine Kaffeemaschine kommt jetzt mit Datenpunkten ums Eck:
                                          bob der 1. @Thomas Braun last edited by
                                          Welche Maschiene ist das?
                                            Thomas Braun Most Active @bob der 1. last edited by
                                            @bob-der-1
                                            Ist die zweite Scishare Kaffeemaschine
                                            225
                                            37512
