    3. Einsteigerfragen
    4. Automatisierung
    5. eCharts Zeitraum in Vis per Button ändern
      MCU @nettworker last edited by MCU
      @nettworker Steht im LOG / Protokolle irgendetwas dazu drin?
      Sonst einmal das System neu starten.
      Auf der console: (RaspberrySystem?)
      iob stop
      sudo reboot
      • N
        nettworker @MCU last edited by Homoran
        @mcu
        host.iobroker
        2022-11-07 19:31:13.471	info	Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
        host.iobroker
        2022-11-07 19:31:13.456	warn	Requested repository "latest" does not exist in config.
        host.iobroker
        2022-11-07 19:31:09.449	info	iobroker rebuild
        host.iobroker
        2022-11-07 19:31:09.448	warn	adapter "javascript" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
        host.iobroker
        2022-11-07 19:31:09.445	info	system.adapter.javascript.0 will be rebuilt
        host.iobroker
        2022-11-07 19:31:09.443	info	Adapter system.adapter.javascript.0 needs rebuild and will be restarted afterwards.
        host.iobroker
        2022-11-07 19:31:09.442	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.iobroker
        2022-11-07 19:31:09.440	error	Caught by controller[0]: }
        host.iobroker
        2022-11-07 19:31:09.439	error	Caught by controller[0]: requestPath: 'coffeescript'
        host.iobroker
        2022-11-07 19:31:09.438	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/package.json',
        host.iobroker
        2022-11-07 19:31:09.437	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        host.iobroker
        2022-11-07 19:31:09.436	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1033:32) {
        host.iobroker
        2022-11-07 19:31:09.435	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
        host.iobroker
        2022-11-07 19:31:09.434	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1155:14)
        host.iobroker
        2022-11-07 19:31:09.433	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:21:24)
        host.iobroker
        2022-11-07 19:31:09.431	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
        host.iobroker
        2022-11-07 19:31:09.430	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1057:19)
        N Homoran 2 Replies Last reply Reply Quote 0
        • N
          nettworker @nettworker last edited by
          Ich deinstalliere den noch mal
          M Thomas Braun 3 Replies Last reply Reply Quote 0
            @nettworker Du hast Einstellungen nicht korrekt.
            http://download.iobroker.net/sources-dist-latest.json
              Homoran Global Moderator Administrators @nettworker last edited by
              @nettworker was ist das für ein Schnipsel?
              wie alt Ist dein iobroker?
              wie und wo installiert?
                Thomas Braun Most Active @nettworker last edited by
                @nettworker
                Da scheint mir aber auch mit nodeJS was nicht zu stimmen.
                sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                iobroker repo list
                  @nettworker
                  Du könntest auch das iob diag - Skript noch testen:
                  https://forum.iobroker.net/topic/59549/iob-diag-skript
                  • N
                    nettworker @Homoran last edited by
                    Läuft auf nem Raspi 3B+ ( mehr schlecht als Recht 🙂 )
                    aktuelles Betriebssystem
                    aktueller iobroker ( alles erst vor ein paar Tagen isntalliert )
                    DJMarc75 Homoran 2 Replies Last reply Reply Quote 0
                    • N
                      nettworker @Thomas Braun last edited by
                      iobroker repo list
                      armv7l
                      Kein Docker
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.18.0
                      v16.18.0
                      8.19.2
                      4.0.23
                      pi
                      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                      tty
                      /home/pi
                      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                      Hit:4 https://repos.influxdata.com/debian bullseye InRelease
                      Hit:5 https://packages.grafana.com/enterprise/deb stable InRelease
                      Reading package lists... Done
                      nodejs:
                      Installed: 16.18.0-deb-1nodesource1
                      Candidate: 16.18.1-deb-1nodesource1
                      Version table:
                      16.18.1-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                      *** 16.18.0-deb-1nodesource1 100
                      100 /var/lib/dpkg/status
                      12.22.12~dfsg-1~deb11u1 500
                      500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                      stable : http://download.iobroker.net/sources-dist.json
                      beta : http://download.iobroker.net/sources-dist-latest.json
                      Active repo(s): latest, stable
                      • DJMarc75
                        DJMarc75 @nettworker last edited by
                        @nettworker sagte in eCharts Zeitraum in Vis per Button ändern:
                        Läuft auf nem Raspi 3B+ ( mehr schlecht als Recht )
                        1GB RAM --- System total überfordert bei Deinen installierten Adaptern.
                          @nettworker Für solche Dinge solltest du den CodeTag nutzen:
                          Einfach klicken und dann das einfügen.
                          Oder jetzt hinterher markieren und dann CodeTag klicken.
                          Dazu auf die drei Punkte auf dem Beitrag klicken, den du ändern möchtest ( du kannst nur Deine ändern) und dann bearbeiten.
                          • N
                            nettworker @MCU last edited by nettworker
                            @mcu
                            Lasst uns das Mal zurück stellen. Ich warte auf neue Hardware, dann gibt's eh ne Neuinstallation.
                            Wollte zwar hier noch was üben, aber das System scheint ja verbogen zu sein.
                            Was empfehlt ihr denn? Debian mit Docker?
                              Thomas Braun Most Active last edited by
                              Debian
                              Egal auf was...
                              Ich bevorzuge allerdings bei meinen Systemen eine native Installation.
                              • DJMarc75
                                @nettworker was für Hardware?
                                • N
                                  nettworker @DJMarc75 last edited by nettworker
                                  @djmarc75
                                  Micro PC, ist wohl ein i3 mit 8gb usw.
                                  • DJMarc75
                                    Ah, ok... also Du weisst nicht so genau was Du gekauft hast? Mutige Geschichte 😳
                                    N 2 Replies Last reply Reply Quote 0
                                    • N
                                      @djmarc75
                                      Ist von einem Kollegen aus einem It Systemhaus.
                                      Der war da nur kurzzeitig an einem Fernseher angeschlossen und kann jetzt weg.
                                      Da frag ich nicht lang 😂 für ne KB
                                      • N
                                        @djmarc75
                                        Die bekommen jetzt neue lüfterlose mit Atom Prozessor. Mal sehen ob ich da noch welche kaufen kann, die sind sehr günstig....
                                        • DJMarc75
                                          DJMarc75 @nettworker last edited by DJMarc75
                                          Jo, ist wie Aktiengeschäft wenn man sich nicht auskennt...
                                          Intel Atom ist der Markenname einer Reihe von Mikroprozessoren und Ein-Chip-Systemen, die von der Firma Intel für den Einsatz in besonders preisgünstigen und energiesparenden Systemen entwickelt werden. Die Erstvorstellung von Produkten unter diesem Markennamen erfolgte im Jahr 2008.
                                          Kann quasi alles sein 😁
                                          Aber jetzt wirds auch OffTopic !
                                          • N
                                            @djmarc75
                                            Ist mir schon alles klar.
                                            Ich hab nur noch keine genauen Daten, da die Kisten gerade erst bei Gigabyte produziert werden und noch nicht da sind.
                                            Und wenn der Preis stimmt der mir genannt wurde, dann kann ich für den derzeitigen Preis eines Raspi 4 2 Stück davon kaufen. Bei den derzeitigen Preisen also kaum Risiko und da ich nicht damit handeln will noch weniger Risiko 🤣
                                            DJMarc75 Homoran 2 Replies Last reply Reply Quote 1
                                            81.1k
                                            7436
