Test Adapter ioBroker.backitup v3.1.x
Bitte keine Screenshots aus der Konsole.
Und zieh das Fenster etwas breiter. -
pi@raspberrypi:~ $ ls -lah /opt/iobroker/backups total 746M drwxrwxr-x+ 2 iobroker iobroker 4.0K Nov 7 14:03 . drwxrwxr-x+ 8 iobroker iobroker 4.0K Oct 26 17:43 .. -rw-rwxr--+ 1 iobroker iobroker 41M Sep 22 2021 2021_09_22-09_44_32_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 42M Nov 29 2021 2021_11_29-08_57_09_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 42M Dec 1 2021 2021_12_01-13_44_30_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 42M Dec 23 2021 2021_12_23-16_46_10_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 42M Feb 28 2022 2022_02_28-07_58_48_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 43M Mar 6 2022 2022_03_06-12_35_26_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 47M Mar 9 2022 2022_03_09-08_09_22_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 47M Mar 15 2022 2022_03_15-07_18_40_backupiobroker.tar.gz -rw-rwxr--+ 1 iobroker iobroker 48M Apr 26 2022 2022_04_26-12_25_30_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 50M Oct 19 07:00 iobroker_2022_10_19-07_00_10_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 50M Oct 21 07:00 iobroker_2022_10_21-07_00_10_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 50M Oct 23 07:01 iobroker_2022_10_23-07_00_10_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 50M Oct 27 07:00 iobroker_2022_10_27-07_00_10_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 50M Oct 29 07:00 iobroker_2022_10_29-07_00_10_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 50M Oct 31 07:00 iobroker_2022_10_31-07_00_10_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 50M Nov 3 07:51 iobroker_2022_11_03-07_50_34_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 882K Oct 31 07:00 javascripts_2022_10_31-07_00_57_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 882K Nov 1 07:00 javascripts_2022_11_01-07_00_40_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 884K Nov 3 07:00 javascripts_2022_11_03-07_00_41_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 884K Nov 3 07:05 javascripts_2022_11_03-07_05_51_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 884K Nov 3 07:51 javascripts_2022_11_03-07_51_21_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 885K Nov 5 07:00 javascripts_2022_11_05-07_00_39_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 885K Nov 7 07:00 javascripts_2022_11_07-07_00_38_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 885K Nov 7 11:11 javascripts_2022_11_07-11_11_03_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 885K Nov 7 11:44 javascripts_2022_11_07-11_44_04_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 885K Nov 7 11:45 javascripts_2022_11_07-11_45_57_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 884K Nov 7 11:57 javascripts_2022_11_07-11_57_56_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 885K Nov 7 14:03 javascripts_2022_11_07-14_03_25_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 3.3K Oct 31 07:00 zigbee.0_2022_10_31-07_00_56_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 3.3K Nov 1 07:00 zigbee.0_2022_11_01-07_00_39_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 3.3K Nov 3 07:00 zigbee.0_2022_11_03-07_00_40_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 3.3K Nov 3 07:05 zigbee.0_2022_11_03-07_05_50_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 3.3K Nov 3 07:51 zigbee.0_2022_11_03-07_51_20_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 3.3K Nov 5 07:00 zigbee.0_2022_11_05-07_00_39_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 3.3K Nov 7 07:00 zigbee.0_2022_11_07-07_00_38_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 3.3K Nov 7 11:11 zigbee.0_2022_11_07-11_11_02_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 3.3K Nov 7 11:44 zigbee.0_2022_11_07-11_44_03_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 3.3K Nov 7 11:45 zigbee.0_2022_11_07-11_45_56_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 3.3K Nov 7 11:57 zigbee.0_2022_11_07-11_57_55_backupiobroker.tar.gz -rw-rw-r--+ 1 iobroker iobroker 3.3K Nov 7 14:03 zigbee.0_2022_11_07-14_03_25_backupiobroker.tar.gz -
@biker1602 Das Backup vom 7.11. gibt es auch nicht lokal.
Lass mal den Fixer drüberlaufen und starte im Anschluss das System mal komplett neu. -
@simatec
Super es hat funktioniert.
Eine Frage habe ich noch. Bevor ich es auf Google Drive gesichert habe, hatte ich es mal auf meinem NAS Server gesichert. Das mache ich aber schon lange nicht mehr. Wenn ich jetzt aber wie eben die Sicherung manuell angestoßen habe, kommt immer noch die IP vom NAS Server mit im Test, obwohl Sicherung auf NAS gar nicht mehr angehakt ist.mountType":"CIFS","type":"storage","source":"googledrive","mount":"192.168.XX.XX","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=2.0","sMuss ich das irgendwie manuell rauslöschen?
Danke -
Mir fiel gerade folgende Meldung im Log auf.
chmod for Backup directory could not be completed: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please run "iobroker fix"!!Ein
iobroker fixhalf nicht.Eingestellt hab ich 3 Sicherungen. Sind aber aktuell 8 Sicherungen.
Hab die Logs bis 1. 11. durchgeschaut. Da kommt immer um 23:00 & 1:30 (Start des Backup) obige Meldung./opt/iobroker/backupsist in ein NAS gemountet.
Es wurde weder am NAS als auch beim ioB etwas verändert.
Einzig die letzten Backitup-Updates der letzten Tage. (aktuell auf 2.5.4).Im Log steht steht sonst nichts aussagekräftiges mehr.
@negalein sagte in Test Adapter ioBroker.backitup v2.5.x:
/opt/iobroker/backups ist in ein NAS gemountet.
Vermutlich meinst du es andersherum.
Die Freigabe des NAS wird in /opt/iobroker/backups gemountet.
Mit welchem Verfahren und mit welchen Parametern?Edit: Gerade erst das Log gefunden...
Da wird gar nix gemountet, das ist doofes FTP. Nutzt man nicht mehr, wenn man nicht unbedingt dazu gezwungen ist.Der Fehler liegt aber wohl hier:
2022-11-07 23:04:40.120 - [31merror[39m: backitup.0 (1895386) [iobroker/dropbox] upload Dropbox: {"error_summary":"payload_too_large/..","error":{".tag":"payload_too_large"},"code":409}Backup zu groß für die DropBox.
@thomas-braun sagte in Test Adapter ioBroker.backitup v2.5.x:
bei mir läuft Proxmox. ioB dann im LXC.
In
/etc/pve/lxc/100.confstehtarch: amd64 cores: 4 hostname: ioBroker memory: 6144 mp0: /mnt/backups,mp=/opt/iobroker/backups net0: name=eth0,bridge=vmbr0,firewall=1,hwaddr=F2:89:94:C1:D3:8C,ip=dhcp,type=veth onboot: 1 ostype: ubuntu rootfs: local-lvm:vm-100-disk-0,size=20G swap: 2048 unprivileged: 1gemountet wurde mit
mount -t nfs 10.0.1.21:/volume1/Backups /mnt/backups -
Irgendwas passt da nicht...
Warum mountest du nach /mnt/backups und nicht nach /opt/iobroker/backups? -
FTP ist auf den WEB-Server. Nicht aufs NAS.
Kann nicht sein
Kann nicht sein
Es ist die Größe der Backup-Datei gemeint, nicht wieviel Platz da noch ist.
hab ich mit der Hilfe von @Dutchman
https://drozmotix.github.io/languages/de/BasicSetup/03.ProxmoxLXC.html#_5-externes-laufwerk-einbinden-z-b-nas -
Ah, ok.
Sind nur 420 MB -
@negalein Das Thema hatte wir beide hier schonmal... Dropbox lässt leider keine Dateien < 150 MB zu.
Hier müsste man sich alternative Clouds wie Nextcloud oder GDrive zur Hilfe nehmen.Liegt leider an der Dropbox API
@simatec sagte in Test Adapter ioBroker.backitup v2.5.x:
Ah stimmt, hab ich ganz vergessen.
InfluxDB, MySQL und PostgreSQL sind immer ausgegraut.
Systeminfo:
Docker container buanet/iobroker v7.1.1
container mariadb v10.9.4
Adapter
iobroker v6.2.23
Backitup v2.5.4
sql v2.2.0
(Influxdb adapter nicht installiert)Warum werden die oben genannten Optionen von Backitup nicht angezeigt also ausgegraut. Liegt es daran, dass es ein docker system ist oder warum?
@tschak sagte in Test Adapter ioBroker.backitup v2.5.x:
oder warum?
Vermutlich eher daran, dass nicht alle benötigten Pakete lokal installiert sind.
@tschak Wird aktuell nicht für Docker Container unterstützt.
Wir arbeiten aber an Möglichkeiten -
ich habe es mit allen Installationen versucht
sudo apt install default-mysql-client
sudo apt install mariadb-client
habe auch die server temporär installiert aber ohne Erfolg@simatec Danke für die Info, warum ist das ein Problem, die Pakete defautl-mysql-client oder mariadb-client können doch einfach über docker ENV installiert werden.
