    3. Off Topic
    4. Rundumglücklichsupport für @thorkillar ;-)
      thorkillar @Thomas Braun last edited by
      @thomas-braun sagte in Benötige Hilfe: Viele Adapter stürzen regelmäßige ab:
      Das stimmt schon mal nicht. Ebensowenig wie nodeJS auf Stand ist.
      Sorry, den Screenshot habe ich vor dem Update gemacht. Die Adapter hatte ich kurz vorm Post auf den aktuellen Stand gebracht.
      Okay, ich hoffe ich hab es richtig gemacht.
      #!/bin/bash
      # iobroker diagnostics
      # written to help getting information about the environment the ioBroker installation is running in
      clear;
      # VARIABLES
      export LC_ALL=C;
      SKRIPTV="0.0.6";
      XORGTEST=0;
      DOCKER=/opt/scripts/.docker_config/.thisisdocker;
      APT=0;
      INSTENV=0;
      INSTENV2=0;
      SYSTDDVIRT=0;
      #if [ $EUID -eq 0 ] | [ ! -f "$DOCKER" ]; then
      #  echo -e "Dieses Skript darf nicht von root ausgeführt werden! \nBitte als Standarduser ausführen!" 1>&2
      #  exit 1
      #fi
      echo "";
      echo -e "\033[34;107m*** ioBroker Diagnosis ***\033[0m";
      echo "";
      echo "Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen";
      echo "";
      echo "The following checks may give hints to potential malconfigurations or errors, please post them in our forum:";
      echo "";
      echo "https://forum.iobroker.net";
      echo "";
      echo "Just copy and paste the Summary Page, including the \`\`\` characters at start and end.";
      echo "It helps us to help you!"
      echo "";
              read -p "Press <Enter> to continue";
      echo "";
      echo -e "\033[33m======== Start marking the full check here =========\033[0m";
      echo -e "v.`echo $SKRIPTV`"
      echo "";
      echo "\`\`\`";
      echo -e "\033[34;107m*** BASE SYSTEM ***\033[0m";
      echo -e "Architecture: \t`uname -m`";
      if [ -f "$DOCKER" ]; then
          echo -e "Docker: \ttrue"
      else
          echo -e "Docker: \tfalse"
      fi;
      # Alternativer DockerCheck - Nicht getestet:
      # if [ -f /.dockerenv ]; then
      #    echo "I'm inside matrix ;(";
      # else
      #    echo "I'm living in real world!";
      # fi
      SYSTDDVIRT=$(systemd-detect-virt 2>/dev/null)
      if [ "$SYSTDDVIRT" != "" ]; then
          echo -e "Virtualization: `systemd-detect-virt`"
      else
          echo "Virtualization: Unknown (buanet/Synology?)"
      fi;
              lsb_release -idrc;
      echo "";
              cat /etc/os-release;
      echo "";
      echo "Systemuptime and Load:";
              uptime;
      echo "CPU threads: $(grep -c processor /proc/cpuinfo)"
      echo "";
      echo -e "\033[34;107m*** Time and Time Zones ***\033[0m";
              date -u;
              date;
              date +"%Z %z";
              cat /etc/timezone;
      echo "";
      echo -e "\033[34;107m*** User and Groups ***\033[0m";
              whoami;
              echo $HOME;
              groups;
      echo "";
      echo -e "\033[34;107m*** X-Server-Setup ***\033[0m";
      XORGTEST=`ps aux | grep -c 'Xorg'`
      if (("$XORGTEST" > 1)); then
          echo "X-Server: true"
      else
          echo "X-Server: false"
      fi
      echo -e "Desktop: $DESKTOP_SESSION";
      echo -e "Konsole: $XDG_SESSION_TYPE";
      echo "";
      echo -e "\033[34;107m*** MEMORY ***\033[0m";
              free -th --mega;
      echo "";
              vmstat -S M -s | head -n 10;
      echo "";
      echo -e "\033[34;107m*** FILESYSTEM ***\033[0m";
              df -PTh;
      echo "";
      echo -e "\033[32mFiles in neuralgic directories:\033[0m";
      echo "";
      echo -e  "\033[32m/var:\033[0m";
              sudo du -h /var/ | sort -rh | head -5;
      echo "";
      echo -e "\033[32m/opt/iobroker/backups:\033[0m";
              du -h /opt/iobroker/backups/ | sort -rh | head -5;
      echo "";
      echo -e "\033[32m/opt/iobroker/iobroker-data:\033[0m";
              du -h /opt/iobroker/iobroker-data/ | sort -rh | head -5;
      echo "";
      echo -e "\033[32mThe five biggest files in iobroker-data:\033[0m";
              find /opt/iobroker/iobroker-data -maxdepth 15 -type f -exec du -sh {} + | sort -rh | head -n 5;
      echo "";
      echo -e "\033[34;107m*** NodeJS-Installation ***\033[0m";
      sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null;
      echo -e "`type -P nodejs` \t`nodejs -v`";
      echo -e "`type -P node` \t\t`node -v`";
      echo -e "`type -P npm` \t\t`npm -v`";
      echo "";
              apt-cache policy nodejs;
      echo  "";
      echo -e "\033[34;107m*** ioBroker-Installation ***\033[0m";
      echo "";
      echo -e "\033[32mCore adapters versions\033[0m"
      echo -e "js-controller: \t`iob -v`";
      echo -e "admin: \t\t`iob version admin`";
      echo "";
      echo -e "\033[32mEnabled adapters with bindings\033[0m";
      iob list instances | grep enabled | grep port ;
      echo "";
      echo -e "\033[32mioBroker-Repositories\033[0m";
              iob repo list;
      echo "";
      echo -e "\033[32mioBroker-Instances\033[0m";
              iob update -i;
      echo "";
      echo -e "\033[32mObjects and States\033[0m";
      echo "Please stand by - This may take a while";
      IOBOBJECTS=$(iob list objects 2>/dev/null | wc -l);
      echo -e "Objects: \t`echo $IOBOBJECTS`";
      IOBSTATES=$(iob list states 2>/dev/null | wc -l);
      echo -e "States: \t`echo $IOBSTATES`";
      echo "";
      echo -e "\033[34;107m*** OS-Repositories and Updates ***\033[0m";
              sudo apt-get update 1>/dev/null && sudo apt-get update
              APT=`apt-get upgrade -s |grep -P '^\d+ upgraded'|cut -d" " -f1`
      echo -e "Pending Updates: `echo $APT`";
      echo "";
      echo -e "\033[34;107m*** Listening Ports ***\033[0m";
              sudo netstat -tulpen #| sed -n '1,2p;/LISTEN/p';
      # Alternativ - ss ist nicht ueberall installiert
      # sudo ss -tulwp | grep LISTEN;
      echo "";
      echo "\`\`\`";
      echo "";
      echo -e "\033[33m============ Mark until here for C&P =============\033[0m";
      echo "";
      echo "iob diag has finished.";
      echo "";
      echo "";
              read -p "For a Summary please press <Enter>";
      echo "";
              clear;
      echo "Copy text starting here:";
      echo "";
      echo "\`\`\`";
      echo "======================= SUMMARY =======================";
      echo -e "\t\t\tv.`echo $SKRIPTV`"
      echo "";
      echo "";
      echo -e "Operatingsystem: `lsb_release -d | tr -s ' ' | cut -d: -f 2`"
              INSTENV=2
      elif [ "$SYSTDDVIRT" != "none" ]; then
              INSTENV=1
      else
              INSTENV=0
      fi;
      INSTENV2=$(
      if [[ $INSTENV -eq 2 ]]; then
              echo "Docker";
      elif [ $INSTENV -eq 1 ]; then
              echo $SYSTDDVIRT;
      else
              echo "Native";
      fi;)
      echo -e "Installation: \t\t`echo $INSTENV2`";
      echo -e "Timezone: \t\t`cat /etc/timezone`";
      echo -e "User-ID: \t\t`echo $EUID`";
      echo -e "X-Server: \t\t`if [[ $XORGTEST -gt 1 ]]; then echo "true";else echo "false";fi`";
      echo "";
      echo -e "Pending OS-Updates: \t`echo $APT`";
      echo "";
      echo -e "Nodejs-Installation: \t`type -P nodejs` \t`nodejs -v`";
      echo -e "\t\t\t`type -P node` \t\t`node -v`";
      echo -e "\t\t\t`type -P npm` \t\t`npm -v`";
      echo "";
      echo -e "ioBroker Core: \t\tjs-controller \t\t`iob -v`";
      echo -e "\t\t\tadmin \t\t\t`iob version admin`";
      echo "";
      echo -e "Pending iob updates: \t`iob list instances | grep updat | wc -l`";
      echo "";
      iob repo list | tail -n1;
      echo "";
      echo -e "Objects: \t\t`echo $IOBOBJECTS`";
      echo -e "States: \t\t`echo $IOBSTATES`";
      echo "";
      echo -e "Size of iob-Database:";
      echo "";
      find /opt/iobroker/iobroker-data -maxdepth 1 -type f -name \*objects\* -exec du -sh {} + |sort -rh | head -n 5;
      find /opt/iobroker/iobroker-data -maxdepth 1 -type f -name \*states\* -exec du -sh {} + |sort -rh | head -n 5;
      echo "";
      echo "";
      echo "====================== END OF SUMMARY =================="
      echo -e "\`\`\`";
      unset LC_ALL
      exit;
        Thomas Braun Most Active @thorkillar last edited by
        @thorkillar
        Nein, nicht das Skript posten. Das kenne ich...
        Das Skript ausführen.
        chmod 744 iob_diag
        ./iob_diag
          thorkillar @Thomas Braun last edited by thorkillar
          @thomas-braun ähm, ja. 🤦‍♂️
          v.0.0.6
          *** BASE SYSTEM ***
          Architecture:   x86_64
          Docker:         true
          Virtualization: container-other
          Distributor ID: Debian
          Description:    Debian GNU/Linux 11 (bullseye)
          Release:        11
          Codename:       bullseye
          PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
          NAME="Debian GNU/Linux"
          VERSION_ID="11"
          VERSION="11 (bullseye)"
          VERSION_CODENAME=bullseye
          ID=debian
          HOME_URL="https://www.debian.org/"
          SUPPORT_URL="https://www.debian.org/support"
          BUG_REPORT_URL="https://bugs.debian.org/"
           11:18:36 up 12 days, 18:26,  0 users,  load average: 4.73, 6.55, 7.25
          CPU threads: 4
          Tue Nov  8 10:18:36 UTC 2022
          Tue Nov  8 11:18:36 CET 2022
          CET +0100
          Etc/UTC
          root
          /root
          root
          X-Server: false
          Desktop:
          Konsole:
          *** MEMORY ***
          Mem:             15G        6.3G        1.4G        430M        8.2G        8.9G
          Swap:            11G        1.0G         10G
          Total:           27G        7.3G         12G
                  15966 M total memory
                   6348 M used memory
                   8274 M active memory
                   4475 M inactive memory
                   1439 M free memory
                     37 M buffer memory
                   8141 M swap cache
                  11627 M total swap
                   1000 M used swap
                  10627 M free swap
          		*** FILESYSTEM ***
          Filesystem             Type   Size  Used Avail Use% Mounted on
          /dev/mapper/cachedev_0 btrfs   28T   20T  8.4T  71% /
          tmpfs                  tmpfs   64M     0   64M   0% /dev
          tmpfs                  tmpfs  7.8G     0  7.8G   0% /sys/fs/cgroup
          shm                    tmpfs   64M     0   64M   0% /dev/shm
          /dev/mapper/cachedev_0 btrfs   28T   20T  8.4T  71% /opt/iobroker
          /dev/mapper/cachedev_0 btrfs   28T   20T  8.4T  71% /etc/hosts
          tmpfs                  tmpfs  7.8G     0  7.8G   0% /proc/acpi
          tmpfs                  tmpfs  7.8G     0  7.8G   0% /proc/scsi
          tmpfs                  tmpfs  7.8G     0  7.8G   0% /sys/firmware
          /var:
          sudo: unable to resolve host buanet-iobroker-2022: Name or service not known
          33M     /var/
          31M     /var/lib
          18M     /var/lib/apt/lists
          18M     /var/lib/apt
          14M     /var/lib/dpkg
          2.3G    /opt/iobroker/backups/
          1.8G    /opt/iobroker/iobroker-data/
          415M    /opt/iobroker/iobroker-data/backup-objects
          308M    /opt/iobroker/iobroker-data/files
          234M    /opt/iobroker/iobroker-data/history
          78M     /opt/iobroker/iobroker-data/files/vis.0
          583M    /opt/iobroker/iobroker-data/states.jsonl
          63M     /opt/iobroker/iobroker-data/objects.json.migrated
          63M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
          55M     /opt/iobroker/iobroker-data/objects.jsonl
          21M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/2.00a59c14.chunk.js.map
          /usr/bin/nodejs         v14.18.2
          /usr/bin/node           v14.18.2
          /usr/bin/npm            6.14.15
          nodejs:
            Installed: 14.18.2-deb-1nodesource1
            Candidate: 14.21.1-deb-1nodesource1
            Version table:
               14.21.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
           *** 14.18.2-deb-1nodesource1 100
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u1 500
                  500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
               12.22.5~dfsg-2~11u1 500
                  500 http://deb.debian.org/debian bullseye/main amd64 Packages
          js-controller:  4.0.23
          admin:          6.2.23
          + system.adapter.admin.0                  : admin                 : buanet-iobroker-2022                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.hm-rpc.0                 : hm-rpc                : buanet-iobroker-2022                     -  enabled, port: 18701
          + system.adapter.hm-rpc.1                 : hm-rpc                : buanet-iobroker-2022                     -  enabled, port: 12001
          + system.adapter.hm-rpc.2                 : hm-rpc                : buanet-iobroker-2022                     -  enabled, port: 12010
          + system.adapter.hue.0                    : hue                   : buanet-iobroker-2022                     -  enabled, port: 80
          + system.adapter.hue.1                    : hue                   : buanet-iobroker-2022                     -  enabled, port: 80
          + system.adapter.telegram.0               : telegram              : buanet-iobroker-2022                     -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.web.0                    : web                   : buanet-iobroker-2022                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          Active repo(s): stable
          ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.2.23   , installed 6.2.23
          Adapter    "alexa2"       : 3.21.0   , installed 3.21.0
          Adapter    "apple-find-me": 0.0.14   , installed 0.0.14
          Adapter    "backitup"     : 2.4.12   , installed 2.4.12
          Adapter    "birthdays"    : 2.1.0    , installed 2.1.0
          Adapter    "bring"        : 1.8.1    , installed 1.8.1
          Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
          Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
          Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
          Adapter    "devices"      : 1.0.12   , installed 1.0.12
          Adapter    "discovery"    : 3.0.5    , installed 3.0.5
          Adapter    "dwd"          : 2.8.3    , installed 2.8.3
          Adapter    "email"        : 1.1.3    , installed 1.1.3
          Adapter    "emby"         : 1.0.2    , installed 1.0.2
          Adapter    "fb-checkpresence": 1.1.19, installed 1.1.19
          Adapter    "history"      : 2.2.0    , installed 2.2.0
          Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
          Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
          Adapter    "hue"          : 3.7.1    , installed 3.7.1
          Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
          Adapter    "ical"         : 1.13.1   , installed 1.13.1
          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
          Adapter    "info"         : 1.9.19   , installed 1.9.19
          Adapter    "iot"          : 1.11.9   , installed 1.11.9
          Adapter    "iqontrol"     : 2.0.0    , installed 2.0.0
          Adapter    "javascript"   : 6.0.3    , installed 6.0.3
          Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
          Adapter    "nina"         : 0.0.25   , installed 0.0.25
          Adapter    "nuki"         : 1.6.0    , installed 1.6.0
          Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
          Adapter    "odl"          : 2.0.5    , installed 2.0.5
          Adapter    "ping"         : 1.5.3    , installed 1.5.3
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "pushover"     : 3.0.3    , installed 3.0.3
          Adapter    "roomba"       : 1.1.4    , installed 1.1.4
          Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
          Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
          Adapter    "synology"     : 2.1.9    , installed 2.1.9
          Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
          Adapter    "telegram"     : 1.14.1   , installed 1.14.1
          Adapter    "text2command" : 2.2.2    , installed 2.2.2
          Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
          Adapter    "trashschedule": 2.0.3    , installed 2.0.3
          Adapter    "vis"          : 1.4.15   , installed 1.4.15
          Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
          Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
          Adapter    "vis-icontwo"  : 0.89.0   , installed 0.89.0
          Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
          Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
          Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
          Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
          Adapter    "weatherunderground": 3.4.2, installed 3.4.2
          Objects and States
          Objects:        43020
          States:         58939
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
          Reading package lists... Done
          Pending Updates: 104
          tcp        0      0 0.0.0.0:6011            0.0.0.0:*               LISTEN      254178     137800     -
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          59556      -
          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          92334111   -
          tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN      0          177055     -
          tcp        0      0 192.168.0.132:12001     0.0.0.0:*               LISTEN      1000       202208867  -
          tcp        0      0 127.0.0.1:161           0.0.0.0:*               LISTEN      0          77318      -
          tcp        0      0 0.0.0.0:6690            0.0.0.0:*               LISTEN      0          196908458  -
          tcp        0      0 192.168.0.132:9092      0.0.0.0:*               LISTEN      1000       202235420  -
          tcp        0      0 0.0.0.0:3493            0.0.0.0:*               LISTEN      0          155577480  -
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       202195329  -
          tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN      0          59550      -
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       202192647  -
          tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN      0          59552      -
          tcp        0      0 192.168.0.132:12010     0.0.0.0:*               LISTEN      1000       202209899  -
          tcp        0      0 0.0.0.0:554             0.0.0.0:*               LISTEN      0          125102     -
          tcp        0      0 127.0.0.1:38443         0.0.0.0:*               LISTEN      0          197016125  -
          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          92334112   -
          tcp        0      0 192.168.0.132:18701     0.0.0.0:*               LISTEN      1000       202211338  -
          tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN      0          92334089   -
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          59554      -
          tcp        0      0 192.168.0.132:49170     0.0.0.0:*               LISTEN      254178     137597     -
          tcp        0      0 127.0.0.1:914           0.0.0.0:*               LISTEN      0          117576     -
          tcp        0      0 127.0.0.1:5555          0.0.0.0:*               LISTEN      0          92238145   -
          tcp        0      0 127.0.0.1:915           0.0.0.0:*               LISTEN      0          92185235   -
          tcp        0      0 127.0.0.1:33300         0.0.0.0:*               LISTEN      0          84042      -
          tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      0          200927439  -
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          31409      -
          tcp        0      0 127.0.0.1:38008         0.0.0.0:*               LISTEN      0          197016123  -
          tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      55         120686     -
          tcp6       0      0 :::443                  :::*                    LISTEN      0          59557      -
          tcp6       0      0 :::445                  :::*                    LISTEN      0          92334109   -
          tcp6       0      0 :::3261                 :::*                    LISTEN      0          88245      -
          tcp6       0      0 :::5566                 :::*                    LISTEN      0          108373     -
          tcp6       0      0 :::3263                 :::*                    LISTEN      0          88243      -
          tcp6       0      0 :::8096                 :::*                    LISTEN      240699     111190140  -
          tcp6       0      0 :::3264                 :::*                    LISTEN      0          88248      -
          tcp6       0      0 :::3265                 :::*                    LISTEN      0          89256      -
          tcp6       0      0 :::6690                 :::*                    LISTEN      0          196908459  -
          tcp6       0      0 :::5000                 :::*                    LISTEN      0          59551      -
          tcp6       0      0 :::5001                 :::*                    LISTEN      0          59553      -
          tcp6       0      0 ::1:38443               :::*                    LISTEN      0          197016126  -
          tcp6       0      0 :::139                  :::*                    LISTEN      0          92334110   -
          tcp6       0      0 :::5357                 :::*                    LISTEN      0          92334090   -
          tcp6       0      0 :::80                   :::*                    LISTEN      0          59555      -
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       202198834  -
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       202229961  -
          tcp6       0      0 :::21                   :::*                    LISTEN      0          200927440  -
          tcp6       0      0 :::22                   :::*                    LISTEN      0          31411      -
          tcp6       0      0 ::1:38008               :::*                    LISTEN      0          197016124  -
          udp        0      0 127.0.0.1:45808         0.0.0.0:*                           240699     111190463  -
          udp        0      0 192.168.0.132:5353      0.0.0.0:*                           1000       202217237  -
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           0          183929551  -
          udp        0      0 192.168.0.132:55900     0.0.0.0:*                           254178     137599     -
          udp     8064      0 0.0.0.0:68              0.0.0.0:*                           0          41410      -
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          30078      -
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          28335      -
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          30926      -
          udp        0      0 192.168.0.132:123       0.0.0.0:*                           87         48711      -
          udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          32846      -
          udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          32842      -
          udp        0      0 192.168.0.255:137       0.0.0.0:*                           0          197706032  -
          udp        0      0 192.168.0.132:137       0.0.0.0:*                           0          197706031  -
          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          197705987  -
          udp        0      0 192.168.0.255:138       0.0.0.0:*                           0          197706034  -
          udp        0      0 192.168.0.132:138       0.0.0.0:*                           0          197706033  -
          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          197705988  -
          udp        0      0 127.0.0.1:161           0.0.0.0:*                           0          77317      -
          udp        0      0 0.0.0.0:33697           0.0.0.0:*                           0          183929553  -
          udp        0      0 0.0.0.0:9997            0.0.0.0:*                           0          30529      -
          udp        0      0 0.0.0.0:9998            0.0.0.0:*                           0          30528      -
          udp        0      0 0.0.0.0:9999            0.0.0.0:*                           0          30527      -
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           240699     111190460  -
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           254178     137600     -
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          61778      -
          udp        0      0 0.0.0.0:43723           0.0.0.0:*                           240699     111190461  -
          udp        0      0 127.0.0.1:60123         0.0.0.0:*                           254178     137598     -
          udp        0      0 192.168.0.132:43885     0.0.0.0:*                           240699     111190462  -
          udp        0      0 0.0.0.0:19996           0.0.0.0:*                           233155     121653     -
          udp        0      0 0.0.0.0:19997           0.0.0.0:*                           233155     121652     -
          udp        0      0 0.0.0.0:19998           0.0.0.0:*                           233155     121651     -
          udp        0      0 0.0.0.0:3702            0.0.0.0:*                           99         92330948   -
          udp6       0      0 :::5353                 :::*                                0          183929552  -
          udp6       0      0 :::7359                 :::*                                240699     111189747  -
          udp6       0      0 2001:9e8:1e9:7500:2:123 :::*                                87         196107477  -
          udp6       0      0 fe80::211:32ff:fe8d:123 :::*                                87         48716      -
          udp6       0      0 ::1:123                 :::*                                0          32848      -
          udp6       0      0 :::123                  :::*                                0          32839      -
          udp6       0      0 :::43940                :::*                                0          183929554  -
          udp6       0      0 :::3702                 :::*                                99         92330950   -
                                  v.0.0.6
          Operatingsystem:        Debian GNU/Linux 11 (bullseye)
          Installation:           Docker
          Timezone:               Etc/UTC
          User-ID:                0
          X-Server:               false
          Pending OS-Updates:     104
          Nodejs-Installation:    /usr/bin/nodejs         v14.18.2
          ioBroker Core:          js-controller           4.0.23
                                  admin                   6.2.23
          Pending iob updates:    0
          Objects:                43020
          States:                 58942
          0       /opt/iobroker/iobroker-data/objects.json.broken
          568M    /opt/iobroker/iobroker-data/states.jsonl
          17M     /opt/iobroker/iobroker-data/states.json.migrated
          17M     /opt/iobroker/iobroker-data/states.json.bak.migrated
          Thomas Braun Glasfaser crunchip 3 Replies Last reply Reply Quote 0
            @thorkillar sagte in Benötige Hilfe: Viele Adapter stürzen regelmäßige ab:
            Halt dein System auf Stand.
            • Glasfaser
              Glasfaser @thorkillar last edited by
              machst du nur deine Backups im Docker-Container !?
                crunchip Forum Testing Most Active @thorkillar last edited by
                da läuft wohl etwas nicht ganz rund, eventuell mit top oder htop
                nicht zielführend die backups hier zu lassen
                etwas groß
                • OliverIO
                  OliverIO @Glasfaser last edited by
                  @glasfaser sagte in Benötige Hilfe: Viele Adapter stürzen regelmäßige ab:
                  man kann den pfad in der docker compose ausserhalb des containers mappen.
                  von innerhalb des containers kann man es dann dort lassen.
                  Glasfaser 1 Reply Last reply Reply Quote 1
                  • mickym
                    mickym Most Active @crunchip last edited by
                    @crunchip
                    Wollte ich auch gerade sagen bei mir ist das Verzeichnis auf einen externen Datenträger gelinkt. Ist also nicht in jedem Fall so, dass es generell "schlecht" ist.
                      Thomas Braun Most Active @mickym last edited by
                      @mickym sagte in Benötige Hilfe: Viele Adapter stürzen regelmäßige ab:
                      Die 'mounts' lasse ich im diag-Skript noch anzeigen. Dann sieht man das auch dort... notier
                      • Glasfaser
                        Glasfaser @OliverIO last edited by
                        @oliverio sagte in Benötige Hilfe: Viele Adapter stürzen regelmäßige ab:
                        Das wäre die Frage an @thorkillar , so kann man es schlecht erkennen
                        • mickym
                          mickym Most Active @Thomas Braun last edited by mickym
                          @thomas-braun Nun ja bei mir ist ein externer Stick gemounted und das backup Verzeichnis verlinkt.
                           lsblk
                          NAME        MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
                          sda           8:0    1 29,3G  0 disk /data
                          mmcblk0     179:0    0 14,8G  0 disk
                          ├─mmcblk0p1 179:1    0  256M  0 part /boot
                          └─mmcblk0p2 179:2    0 14,1G  0 part /
                          pi@mwhome:/opt/iobroker $ ls -la backups
                          lrwxrwxrwx 1 iobroker iobroker 21  9. Aug 23:47 backups -> /data/backup/iobroker
                          Zumindest sollte man bei der Beurteilung solcher Infos halt aufpassen. Der Backitup Adapter warnt mich auch immer unsinnigerweise - das kann man dem aber anscheinend nicht abgewöhnen. 😉
                            @mickym
                            Die verlinkung sieht man nicht. Aber in
                            mount
                            müsste der Stick ja auftauchen.
                            • mickym
                              @thomas-braun Ja - habe ich doch gepostet.
                              mit lsblk siehst , dass der Stick unter /data gemounted ist und mit ls -la siehst man doch dass es ein Link ist.
                              Ich hab den Stick ja nicht direkt unter backups gelinkt.
                              Mit mount siehst das zwar auch
                              /dev/sda on /data type ext4 (rw,nosuid,nodev,noexec,relatime,sync)
                              aber bei mir kommt da ewig viel. 😉
                                Das kann man auch noch auf 'richtige' Dateisysteme einschränken. Muss ich mir mal überlegen, ob ich das besser per mount oder per lsblk abfrage.
                                • mickym
                                  Ja habe ich mir auch gerade überlegt. Also mount ist sicher besser, um alles abzudecken. Aber für das backups Verzeichnis würde ich halt auf jedenfall prüfen, ob das ein Link ist.
                                    Thomas Braun Most Active @mickym last edited by Thomas Braun
                                    Kann man, ist kein Problem.
                                    Notiz an mich:
                                    https://github.com/Grothesk242/iob_diag/issues/1
                                    Grothesk242 created this issue in Grothesk242/iob_diag
                                    closed Check mounts / linked backup directories #1
                                      Ich habe den kompletten Inhalt (Siehe Screenshot) auf der Synology ausserhalb des Dockers gelagert.
                                      Und dieser wird zweimal am Tag via HyperBackup auf zwei verschiedene Medien gesichert. Eine Anpassung des Speicherortes ist dennoch eine gute Idee. Denn etwas über 2GB Backupordner auf mehrere Platten gesichert, summiert sich irgendwann 🙂
                                      @crunchip
                                      Was kann ich da machen?
                                      etwas groß
                                      Wie kann ich die kleiner bekommen?
                                      Ich dachte eigentlich, dass ich das getan habe. Wie kann ich die Updates durchführen? Ist das das OS im Docker?
                                      • Glasfaser
                                        Glasfaser @thorkillar last edited by Glasfaser
                                        Ich würde da nicht rumfummeln , ( altes Image )
                                        Backup machen ...
                                        Neues ... aktuelles Image ziehen ... image/ Container mit ioBroker installieren und dann das Backup rein .
                                          OT: Sollte jetzt drin sein. In deinem Fall sollte hier
                                          TARGET  SOURCE    FSTYPE OPTIONS
                                          /       /dev/sda2 ext4   rw,noatime
                                          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                          noch ein Hinweis auf das verlinkte Verzeichnis auftauchen. Ist vermutlich ein seltener Fall, deswegen erscheint das nur wenn die Bedingung wahr ist.
                                          So jedenfalls der Plan. Kannste ja mal probieren.
                                          • mickym
                                            gelöscht
                                            133
                                            10971
