    4. VIS für FireTablet *gelöst*
      Thomas Braun Most Active @gluecksmann last edited by
      @gluecksmann
      Tip: Die Steuerzeichen (vor dem Konsolenoutput) gehören in eine neue, eigene Zeile.
      Ansonsten sieht das gut aus.
        gluecksmann @Thomas Braun last edited by
        @thomas-braun Aber geht nicht...
          @gluecksmann
          Das heißt konkret?
          iobroker status
          sagt?
            @thomas-braun sagte in VIS für FireTablet:
            iobroker status
            pi@raspberrypi:/opt/iobroker $ iobroker status
            Objects type: jsonl
            States type: jsonl
              @gluecksmann
              Alles prima, ioBroker lüppt.
                gluecksmann @Thomas Braun last edited by gluecksmann
                @thomas-braun Nöe... beim Aufruf kommt dann...
                Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/lib/../www/index.html'
                    at Object.openSync (node:fs:585:3)
                    at Object.readFileSync (node:fs:453:35)
                    at prepareIndex (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:200:27)
                    at /opt/iobroker/node_modules/iobroker.admin/lib/web.js:763:46
                    at Layer.handle [as handle_request] (/opt/iobroker/node_modules/express/lib/router/layer.js:95:5)
                    at next (/opt/iobroker/node_modules/express/lib/router/route.js:144:13)
                    at Route.dispatch (/opt/iobroker/node_modules/express/lib/router/route.js:114:3)
                    at /opt/iobroker/node_modules/express/lib/router/index.js:284:15
                    at Function.process_params (/opt/iobroker/node_modules/express/lib/router/index.js:346:12)
                Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                  @gluecksmann
                  Mensch....
                  Setz die `` in eine neue Zeile!
                    crunchip Forum Testing Most Active @gluecksmann last edited by crunchip
                    @gluecksmann sagte in VIS für FireTablet:
                    bei welchem Aufruf?
                    ist dein admin nicht installiert, bzw Fehlerhaft
                    zeig mal
                    iob list instances
                    iob list adapters
                    G 2 Replies Last reply Reply Quote 0
                      gluecksmann @crunchip last edited by
                      @crunchip sagte in VIS für FireTablet:
                      iob list instances
                      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                          at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                          at node:internal/main/run_main_module:17:47 {
                        code: 'MODULE_NOT_FOUND',
                        requireStack: []
                      node:internal/modules/cjs/loader:936
                        throw err;
                      Error: Cannot find module './lib/setup'
                      Require stack:
                      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                          at Module.require (node:internal/modules/cjs/loader:1005:19)
                          at require (node:internal/modules/cjs/helpers:102:18)
                          at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:1)
                          at Module._compile (node:internal/modules/cjs/loader:1105:14)
                          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
                          at Module.load (node:internal/modules/cjs/loader:981:32)
                          at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12) {
                        requireStack: [ '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ]
                      Homoran crunchip 2 Replies Last reply Reply Quote 0
                        Homoran Global Moderator Administrators @gluecksmann last edited by
                        @gluecksmann warum zeigst du nicht alles? incl. Befehl und prompt?
                        crunchip G 2 Replies Last reply Reply Quote 0
                          @gluecksmann mal ganz ehrlich, hast du ne weitere Sd-Karte rum liegen?
                          dann installier dir ein neues raspi image, den iobroker drauf und spiel danach dein Backup ein
                            Homoran Global Moderator Administrators @crunchip last edited by
                            das auf der anderen Karte liegt
                              crunchip Forum Testing Most Active @Homoran last edited by crunchip
                              @homoran ist das vllt ein Fall fürs "neue Thomas Brown Tool" zum testen eines kaputten iobroker?😁
                              @homoran sagte in VIS für FireTablet:
                              tja🤷‍♂️
                                gluecksmann @Homoran last edited by
                                @homoran kwinw Ahnung was Du meinst...
                                  @gluecksmann das gesamte , incl Eingabe und nicht nur nen Ausschnitt
                                  https://de.wikipedia.org/wiki/Prompt
                                  falls eine Neuinstallation auf 2te Karte in Frage kommt
                                  https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht?_=1667927946069
                                    @crunchip
                                    Es ging mir primär um die VIS zu retten....und nach meinen ganzen Fragen..traue ich mich nicht zu da irgendwas mit einerzweiten Karte zu machen
                                      @crunchip
                                      pi@raspberrypi:/opt/iobroker $ iob list instances
                                      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
                                        system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
                                      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                        system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
                                        system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
                                        system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
                                        system.adapter.devices.0                : devices               : raspberrypi                              - disabled
                                        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                                        system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
                                        system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              - disabled
                                        system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
                                        system.adapter.govee.0                  : govee                 : raspberrypi                              - disabled
                                        system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              - disabled
                                        system.adapter.history.0                : history               : raspberrypi                              - disabled
                                        system.adapter.hue.0                    : hue                   : raspberrypi                              - disabled, port: 443
                                        system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
                                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                                        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
                                        system.adapter.info.0                   : info                  : raspberrypi                              - disabled
                                        system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
                                        system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
                                        system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              - disabled
                                        system.adapter.musiccast.0              : musiccast             : raspberrypi                              - disabled
                                        system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
                                        system.adapter.netatmo.0                : netatmo               : raspberrypi                              - disabled
                                        system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
                                        system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              - disabled
                                        system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
                                        system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              - disabled
                                        system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
                                        system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
                                        system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              - disabled
                                        system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
                                        system.adapter.sonos.0                  : sonos                 : raspberrypi                              - disabled
                                        system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
                                        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                                        system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
                                        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
                                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                                        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                                        system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
                                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                                        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                                        system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
                                        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
                                        system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled, port: /dev/ttyACM0
                                      + instance is alive
                                      pi@raspberrypi:/opt/iobroker $ iob list adapters
                                      system.adapter.admin                   : admin          - v6.2.22
                                      system.adapter.alexa2                  : alexa2         - v3.12.0
                                      system.adapter.alias-manager           : alias-manager  - v1.2.6
                                      system.adapter.backitup                : backitup       - v2.4.12
                                      system.adapter.ble                     : ble            - v0.13.0
                                      system.adapter.chromecast              : chromecast     - v2.3.1
                                      system.adapter.daswetter               : daswetter      - v3.1.3
                                      system.adapter.devices                 : devices        - v1.0.12
                                      system.adapter.discovery               : discovery      - v3.0.5
                                      system.adapter.dwd                     : dwd            - v2.8.3
                                      system.adapter.ecovacs-deebot          : ecovacs-deebot - v1.4.4
                                      system.adapter.fullybrowser            : fullybrowser   - v2.1.2
                                      system.adapter.govee                   : govee          - v0.0.5
                                      system.adapter.gruenbeck               : gruenbeck      - v0.0.42
                                      system.adapter.history                 : history        - v2.2.0
                                      system.adapter.hue                     : hue            - v3.7.1
                                      system.adapter.hue-extended            : hue-extended   - v2.0.0
                                      system.adapter.ical                    : ical           - v1.13.1
                                      system.adapter.icons-mfd-png           : icons-mfd-png  - v1.1.0
                                      system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.1.0
                                      system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
                                      system.adapter.info                    : info           - v1.9.19
                                      system.adapter.iot                     : iot            - v1.11.9
                                      system.adapter.javascript              : javascript     - v6.0.3
                                      system.adapter.mielecloudservice       : mielecloudservice - v6.3.2
                                      system.adapter.musiccast               : musiccast      - v0.2.2
                                      system.adapter.net-tools               : net-tools      - v0.2.0
                                      system.adapter.netatmo                 : netatmo        - v1.7.1
                                      system.adapter.onvif                   : onvif          - v0.4.4
                                      system.adapter.ping                    : ping           - v1.5.3
                                      system.adapter.pollenflug              : pollenflug     - v1.0.6
                                      system.adapter.scenes                  : scenes         - v2.3.9
                                      system.adapter.schoolfree              : schoolfree     - v1.0.1
                                      system.adapter.shelly                  : shelly         - v6.0.0
                                      system.adapter.shuttercontrol          : shuttercontrol - v1.4.14
                                      system.adapter.simple-api              : simple-api     - v2.7.0
                                      system.adapter.smartcontrol            : smartcontrol   - v1.2.1
                                      system.adapter.socketio                : socketio       - v6.1.7
                                      system.adapter.sonoff                  : sonoff         - v2.5.1
                                      system.adapter.sonos                   : sonos          - v2.2.3
                                      system.adapter.trashschedule           : trashschedule  - v2.0.3
                                      system.adapter.vis                     : vis            - v1.4.15
                                      system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
                                      system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.3.0
                                      system.adapter.vis-inventwo            : vis-inventwo   - v3.3.3
                                      system.adapter.vis-material-advanced   : vis-material-advanced - v1.7.2
                                      system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.94
                                      system.adapter.vis-metro               : vis-metro      - v1.2.0
                                      system.adapter.vis-players             : vis-players    - v0.1.6
                                      system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                                      system.adapter.vis-weather             : vis-weather    - v2.5.5
                                      system.adapter.weatherunderground      : weatherunderground - v3.4.2
                                      system.adapter.web                     : web            - v5.2.3
                                      system.adapter.ws                      : ws             - v2.1.2
                                      system.adapter.zigbee                  : zigbee         - v1.7.5
                                        Thomas Braun Most Active @crunchip last edited by
                                        @crunchip
                                          sigi234 Forum Testing Most Active @gluecksmann last edited by
                                          @gluecksmann
                                          Alle meine Views im Inwentwo Design sind für 10 Zoll Tabletts gemacht.
                                            Thomas Braun Most Active @crunchip last edited by Thomas Braun
                                            Na hoffentlich ist es kein Fall fürs "kaputte Thomas Brown Tool" zum testen eines neuen iobroker. 😄
                                            Wobei mich die Ausgabe hier schon interessieren würde...
                                            @gluecksmann
                                            Magst du mal beim testen mithelfen? Siehe hier:
                                            https://forum.iobroker.net/topic/59549/iob-diag-skript
                                            Das aber in einem neuen Thread, das hat ja mit 'Showcases' nix mehr zu tun.
                                            5180
