    3. Einsteigerfragen
    4. Problem: "Error: libnode.so.72" mit Folgen
      BeneMUC @Thomas Braun last edited by BeneMUC
      @thomas-braun said in Problem: "Error: libnode.so.72" mit Folgen:
      Was sagt
      sudo apt update sudo apt full-upgrade
      pi@raspberrypi:/ $ sudo apt update
      Get:1 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
      Get:2 http://deb.debian.org/debian bullseye InRelease [116 kB]
      Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
      Get:4 http://deb.debian.org/debian bullseye-backports InRelease [49.0 kB]
      Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
      Err:1 http://security.debian.org/debian-security bullseye-security InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
      Err:2 http://deb.debian.org/debian bullseye InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F00D6C9793
      Hit:6 https://deb.nodesource.com/node_10.x bullseye InRelease
      Err:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
      Err:4 http://deb.debian.org/debian bullseye-backports InRelease
      Reading package lists... Done
      W: GPG error: http://security.debian.org/debian-security bullseye-security InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
      E: The repository 'http://security.debian.org/debian-security bullseye-security InRelease' is not signed.
      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
      W: GPG error: http://deb.debian.org/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F00D6C9793
      E: The repository 'http://deb.debian.org/debian bullseye InRelease' is not signed.
      W: GPG error: http://deb.debian.org/debian bullseye-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
      E: The repository 'http://deb.debian.org/debian bullseye-updates InRelease' is not signed.
      W: GPG error: http://deb.debian.org/debian bullseye-backports InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
      E: The repository 'http://deb.debian.org/debian bullseye-backports InRelease' is not signed.
      Building dependency tree... Done
      Calculating upgrade... Done
      The following packages were automatically installed and are no longer required:
        gyp libc-ares2 libfuse2 libjs-highlight.js libjs-inherits libjs-is-typedarray
        libjs-psl libjs-typedarray-to-buffer libssl-dev libuv1-dev node-chownr
        node-color-name node-err-code node-extsprintf node-fast-deep-equal node-indent-string
        node-ini node-is-typedarray node-json-parse-better-errors node-json-schema
        node-json-schema-traverse node-qs node-resolve-from node-through
        node-typedarray-to-buffer node-uuid
      Use 'sudo apt autoremove' to remove them.
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Werde die fehlenden Keys dann mal in den apt key manager einfügen.
      Und warum stehst du überhaupt in / herum?
      da bin ich jetzt überfragt^^ was ist denn hier das Stichwort mit dem ich dazu googeln kann? #noop
        Thomas Braun Most Active @BeneMUC last edited by Thomas Braun
        @benemuc sagte in Problem: "Error: libnode.so.72" mit Folgen:
        node-
        Neben den fehlenden keys...
        (Wie hast du die Kiste von wo aus upgegraded???)
        sudo apt remove node-*
        sudo apt update
        sudo apt autoremove
          Nach dem Fixen der Keys lasse ich jetzt sudo apt update und sudo apt full-upgrade durchlaufen. Schaut soweit gut aus aber dauert natürlich ein Weilchen.
          Kann ich dir leider nicht genau sagen. Hab die Kiste vor ca. 1,5 Jahren nach irgendeiner Anleitung aufgesetzt und mich seither nicht um System-Updates gekümmert. Gestern dann eben entsprechend deinem Werkzeugkasten versucht alles auf den neuesten Stand zu bringen.
            aktueller Stand sieht jetzt so aus:
            pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
            uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && o $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            ln: failed to create symbolic link '/usr/bin/nodejs': File exists
            armv7l
            Kein Docker
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v16.18.0
            v16.18.0
            8.19.2
            4.0.21
            pi
            pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
            tty
            /home/pi
            Hit:1 http://deb.debian.org/debian bullseye InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:4 http://deb.debian.org/debian bullseye-backports InRelease
            Hit:5 http://security.debian.org/debian-security bullseye-security InRelease
            All packages are up to date.
            nodejs:
              Installed: 16.18.0-deb-1nodesource1
              Candidate: 16.18.0-deb-1nodesource1
              Version table:
             *** 16.18.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                    100 /var/lib/dpkg/status
                 12.22.12~dfsg-1~deb11u1 500
                    500 http://security.debian.org/debian-security bullseye-security/main armhf Packages
                 12.22.5~dfsg-2~11u1 500
                    500 http://deb.debian.org/debian bullseye/main armhf Packages
                 10.24.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_10.x bullseye/main armhf Packages
            Um node- muss ich mich morgen kümmern - langsam fehlt die Konzentrtion 😉 Vielen Dank aber schonmal für Deine Hilfe bis hierher! 🙂
              @benemuc
              Ja, das schaut doch schon wesentlich anders aus. 🙂
                Eine Woche später...
                Da ich den libnode.so.72 Fehler trotz aller Maßnahmen nicht beseitigt bekommen habe, hab ich zwischenzeitlich den Raspberry komplett neu aufgesetzt (raspbian, nodejs, iobroker + Backup eingespielt).
                Ergebnis ist, dass der libnode.so.72 Fehler zwar weg ist aber der Zigbee Adapter immer noch nicht wieder startet.
                admin@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                aarch64
                Kein Docker
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v16.18.1
                v16.18.1
                8.19.2
                4.0.23
                admin
                admin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                tty
                /home/admin
                Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:5 http://deb.debian.org/debian bullseye-backports InRelease
                Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
                nodejs:
                  Installed: 16.18.1-deb-1nodesource1
                  Candidate: 16.18.1-deb-1nodesource1
                  Version table:
                 *** 16.18.1-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                Fehlerlog:
                2022-11-08 18:19:44.554  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                2022-11-08 18:19:44.724  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 12720
                2022-11-08 18:19:49.143  - info: zigbee.0 (12720) starting. Version 1.7.6 (non-npm: ioBroker/ioBroker.zigbee#90b31ec12c45cae433f13d23614d34a633baa2ca) in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.1, js-controller: 4.0.23
                2022-11-08 18:19:49.271  - info: zigbee.0 (12720) delete old Backup files. keep only last 10
                2022-11-08 18:19:49.274  - info: zigbee.0 (12720) Starting Zigbee  npm ...
                2022-11-08 18:19:49.960  - info: zigbee.0 (12720) Installed Version: ioBroker/ioBroker.zigbee#90b31ec12c45cae433f13d23614d34a633baa2ca
                2022-11-08 18:20:03.854  - error: javascript.0 (10979) Error in callback: TypeError: Cannot read properties of undefined (reading 'pmap_id')
                2022-11-08 18:20:03.854  - error: javascript.0 (10979)     at aktualisiere_datenpunkte (script.js.common.iRobot-Control:184:105)
                2022-11-08 18:20:03.855  - error: javascript.0 (10979)     at Object.<anonymous> (script.js.common.iRobot-Control:45:13)
                2022-11-08 18:20:03.855  - error: javascript.0 (10979)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1214:38)
                2022-11-08 18:20:03.856  - error: javascript.0 (10979)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:596:29)
                2022-11-08 18:20:03.856  - error: javascript.0 (10979)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
                2022-11-08 18:20:03.857  - error: javascript.0 (10979)     at processImmediate (node:internal/timers:466:21)
                2022-11-08 18:20:10.091  - error: zigbee.0 (12720) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                2022-11-08 18:20:10.129  - error: zigbee.0 (12720) Failed to start Zigbee
                2022-11-08 18:20:10.130  - error: zigbee.0 (12720) Error herdsman start
                2022-11-08 18:20:20.136  - info: zigbee.0 (12720) Try to reconnect. 1 attempts left
                2022-11-08 18:20:20.138  - info: zigbee.0 (12720) Starting Zigbee  npm ...
                2022-11-08 18:20:20.171  - info: zigbee.0 (12720) Installed Version: ioBroker/ioBroker.zigbee#90b31ec12c45cae433f13d23614d34a633baa2ca
                2022-11-08 18:20:20.469  - error: zigbee.0 (12720) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                2022-11-08 18:20:20.470  - error: zigbee.0 (12720) Failed to start Zigbee
                2022-11-08 18:20:20.471  - error: zigbee.0 (12720) Error herdsman start
                Leider fange ich mit den Fehler nicht viel an - sieht für mich sehr generisch aus.
                  @benemuc
                  Warum eine Version aus dem github?
                    Ehrlich gesagt keine Ahnung - ich hab einfach mit
                    curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
                    sudo apt install nodejs
                    installiert.
                    Woran siehst du, dass eine github Version installiert ist?
                      @benemuc
                      Ich meinte den zigbee-Adapter:
                      Die Meldung
                      hat im übrigen oftmals mit der Firmware des Sticks zu tun. Was ist da installiert?
                        Ach so, ich hatte den Adapter zunächst ganz normal über den iobroker installiert. Das selbe Problem bestand damit aber auch und ich hab auf der Suche nach einer Lösung irgendwo im Forum gelesen, dass man versuchen kann, den Adapter über die Katze aus git hub zu installieren. Am Fehlerbild hat das aber nichts geändert.
                        Hab den Stick auf die Conbee Version von hier vom 15 Mai 2022 aktualisiert. Geholfen hat es nicht.
                        Dann habe ich einen neuen Conbee II Stick gekauft und angesteckt (Pfad im Adapter natürlich geändert) - hat am Fehler aber leider auch nichts geändert.
                          @benemuc
                          Wie sehen die Einstellungen im zigbee-Adapter aus?
                            Ich hätte ehrlich gesagt andere Hardware gekauft.
                                @benemuc
                                Den Typ musst du auf 'Deconz/Conbee' einstellen.
                                  jaa mega, die Einstellung hat noch gefehlt - hab ich nach der Neuinstallation scheinbar nicht mehr angepasst. Jetzt funktioniert der Adapter endlich wieder 🙂
                                  Herzlichen Dank dir! ^^
                                  1074
