    4. VIS für FireTablet *gelöst*
      gluecksmann @Thomas Braun last edited by
      [Di Nov  8 12:37:27 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Di Nov  8 12:37:28 2022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Di Nov  8 12:37:28 2022] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Di Nov  8 12:37:30 2022] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        Thomas Braun Most Active @gluecksmann last edited by
        @gluecksmann
        Alles i.O.
          Warte immer noch drauf das er sich nach dem Update wieder meldet.... Übrigends ist leider NICHT meine alte VIS drauf... Aber da mache ich morgen weiter, wie man das extrahieren kannn...
            @gluecksmann sagte in VIS für FireTablet:
            Nach welchem?
              war glaube ich der Alexa Adapter...
                @gluecksmann
                iobroker status
                iobroker list instances
                sagt?
                  @thomas-braun sagte in VIS für FireTablet:
                  pi@raspberrypi:/opt/iobroker $ iobroker list instances
                  + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
                  + system.adapter.alexa2.0                 : alexa2                : raspberrypi        -  enabled
                    system.adapter.alias-manager.0          : alias-manager         : raspberrypi        - disabled
                  + system.adapter.backitup.0               : backitup              : raspberrypi        -  enabled
                  + system.adapter.ble.0                    : ble                   : raspberrypi        -  enabled
                  + system.adapter.chromecast.0             : chromecast            : raspberrypi        -  enabled
                    system.adapter.daswetter.0              : daswetter             : raspberrypi        - disabled
                    system.adapter.devices.0                : devices               : raspberrypi        - disabled
                  + system.adapter.discovery.0              : discovery             : raspberrypi        -  enabled
                    system.adapter.dwd.0                    : dwd                   : raspberrypi        - disabled
                    system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi        - disabled
                  + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi        -  enabled
                  + system.adapter.govee.0                  : govee                 : raspberrypi        -  enabled
                    system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi        - disabled
                    system.adapter.history.0                : history               : raspberrypi        - disabled
                  + system.adapter.hue.0                    : hue                   : raspberrypi        -  enabled, port: 443
                    system.adapter.ical.0                   : ical                  : raspberrypi        -  enabled
                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi        - disabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi        - disabled
                    system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi        - disabled
                  + system.adapter.info.0                   : info                  : raspberrypi        -  enabled
                  + system.adapter.iot.0                    : iot                   : raspberrypi        -  enabled
                  + system.adapter.javascript.0             : javascript            : raspberrypi        -  enabled
                    system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi        - disabled
                  + system.adapter.musiccast.0              : musiccast             : raspberrypi        -  enabled
                    system.adapter.net-tools.0              : net-tools             : raspberrypi        - disabled
                    system.adapter.netatmo.0                : netatmo               : raspberrypi        - disabled
                    system.adapter.ping.0                   : ping                  : raspberrypi        - disabled
                    system.adapter.pollenflug.0             : pollenflug            : raspberrypi        - disabled
                  + system.adapter.scenes.0                 : scenes                : raspberrypi        -  enabled
                    system.adapter.schoolfree.0             : schoolfree            : raspberrypi        -  enabled
                  + system.adapter.shelly.0                 : shelly                : raspberrypi        -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi        -  enabled
                    system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi        - disabled
                  + system.adapter.sonoff.0                 : sonoff                : raspberrypi        -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.sonos.0                  : sonos                 : raspberrypi        -  enabled
                  + system.adapter.trashschedule.0          : trashschedule         : raspberrypi        -  enabled
                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi        - disabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi        - disabled
                  + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi        -  enabled
                    system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi        - disabled
                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi        - disabled
                    system.adapter.vis-metro.0              : vis-metro             : raspberrypi        - disabled
                    system.adapter.vis-players.0            : vis-players           : raspberrypi        - disabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi        - disabled
                    system.adapter.vis-weather.0            : vis-weather           : raspberrypi        - disabled
                    system.adapter.vis.0                    : vis                   : raspberrypi        -  enabled
                    system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi        - disabled
                  + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
                  + system.adapter.zigbee.0                 : zigbee                : raspberrypi        -  enabled, port: /dev/ttyACM0
                  + instance is alive
                  Leider sagt der Zigbee Adapter das er sich nicht mit dem Dienst verbinden kann....
                    Thomas Braun Most Active last edited by Thomas Braun
                    @gluecksmann
                    Mach einen neuen, eigenen Thread auf. Und dann dort die vollständige Meldung rein.
                    Und mach das Fenster von puTTTY breiter, wenn du Text da raus kopierst.
                      @thomas-braun eigentlich bräuchte er nur seinen Titel oben ändern, und müsste verschoben werden, den mit showcase hat das hier eigentlich nichts zu tun
                        Hallo, habe ich aufgemacht, heißt "Zigbee Adapter läuft nicht mehr nach Systemwiederherstellung "
                        1.0k
                        5174
