    4. Solarman PV, Bosswerk MI & Deye
    • Rene55
      Rene55 @Burgi last edited by
      @burgi Hallo Thomas, ist ja fast perfekt. Die (derzeit) finale Version 0.2.0 habe ich gerade gebaut - da sollte man bei Gelegenheit updaten.
      LG Rainer
      • webwalker2001
        webwalker2001 last edited by
        Hallo in die Runde,
        ich bekomme ab und zu folgende Fehlermeldungen:
        solarmanpv.0 2022-11-08 08:00:11.819	error	DB closed
        solarmanpv.0 2022-11-08 08:00:11.818	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at TCP.<anonymous> (node:net:301:12)
        solarmanpv.0 2022-11-08 08:00:11.818	error	unhandled promise rejection: DB closed
        solarmanpv.0 2022-11-08 08:00:11.817	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        solarmanpv.0 2022-11-08 08:00:11.815	error	DB closed
        solarmanpv.0 2022-11-08 08:00:11.815	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at TCP.<anonymous> (node:net:301:12)
        solarmanpv.0 2022-11-08 08:00:11.814	error	unhandled promise rejection: DB closed
        solarmanpv.0 2022-11-08 08:00:11.813	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        solarmanpv.0 2022-11-08 08:00:11.809	error	DB closed
        solarmanpv.0 2022-11-08 08:00:11.808	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at TCP.<anonymous> (node:net:301:12)
        solarmanpv.0 2022-11-08 08:00:11.806	error	unhandled promise rejection: DB closed
        solarmanpv.0 2022-11-08 08:00:11.805	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        solarmanpv.0 2022-11-08 08:00:11.804	error	DB closed
        solarmanpv.0 2022-11-08 08:00:11.802	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at TCP.<anonymous> (node:net:301:12)
        solarmanpv.0 2022-11-08 08:00:11.801	error	unhandled promise rejection: DB closed
        solarmanpv.0 2022-11-08 08:00:11.798	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        solarmanpv.0 2022-11-08 08:00:11.794	error	DB closed
        solarmanpv.0 2022-11-08 08:00:11.793	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at TCP.<anonymous> (node:net:301:12)
        solarmanpv.0 2022-11-08 08:00:11.792	error	unhandled promise rejection: DB closed
        solarmanpv.0 2022-11-08 08:00:11.791	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        solarmanpv.0 2022-11-08 08:00:11.786	error	DB closed
        solarmanpv.0 2022-11-08 08:00:11.785	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at TCP.<anonymous> (node:net:301:12)
        solarmanpv.0 2022-11-08 08:00:11.780	error	unhandled promise rejection: DB closed
        solarmanpv.0 2022-11-08 08:00:11.779	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        solarmanpv.0 2022-11-08 08:00:11.776	error	DB closed
        Scheint aber sonst zu laufen.
        Mein System:
        RasPi4 mit 4GB
        Node.js v16.18.1
        NPM 8.19.2
        Admin v6.2.23
        LG
        webwalker2001
        • Rene55
          Rene55 @webwalker2001 last edited by
          @webwalker2001 Uiuiuiui! So sollte das aber nicht sein. Das System scheint auf den ersten Blick aktuell zu sein. Kannst du bitte den Adapter mal stoppen, etwas warten und dann neu starten. Und dann das Log mal hier einstellen. Dann schau ich mal drüber.
          webwalker2001 1 Reply Last reply Reply Quote 0
            matthias425 last edited by
            seit kurzem habe ich auch den MI600 von Bosswerk in Betrieb.
            Freudig habe ich gesehen das sich Rainer die Mühe gemacht hat einen Adapter bereit zu stellen. Vielen Dank dafür!!!
            Leider funktioniert es bei mir nicht. Ich poste mal was ich habe/bekomme, vielleicht hat jemand eine Idee die mich weiterbringt.
            Der Adapter ist installiert und läuft, Daten wurden beim Service angefragt und sind eingetragen.
            In den Objekten bekomme ich folgenden Baum:
            Fehlermeldung im Protokoll:
            2022-11-08 18:12:00.834 - info: solarmanpv.0 (1195) starting. Version 0.2.0 (non-npm: raschy/ioBroker.solarmanpv#3d5f8fd317909365be11f8677de5938a2182cc59) in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v14.19.0, js-controller: 4.0.23
            2022-11-08 18:12:04.288 - warn: solarmanpv.0 (1195) [initializeStation] error: could not retrieve token.
            2022-11-08 18:12:04.289 - info: solarmanpv.0 (1195) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
            2022-11-08 18:12:04.803 - info: host.iobroker instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            Mein System:
            Node.js: v14.19.0
            NPM: v6.14.16
            Admin: 6.2.22
            Vielen Dank und viele Grüße
            Matthias
            • Rene55
              Rene55 @matthias425 last edited by
              @matthias425 Hallo, wie ich sehen konnte, ist dein System noch auf mode.js 14.x. Kannst du bitte dein System auf node 16.x hochziehen. Das hatten wir gestern auch schon mal, das hat dann geholfen.
                @Rene55 : Hallo Rene, ich habe mein System hoch gezogen
                Node.js: v16.18.0
                NPM: 8.19.2
                Admin 6.2.23
                leider hat sich das Verhalten nicht geändert
                Hast du noch eine Idee? 🙂
                LG
                  @Rene55: Ergänzung, ich habe die Instanz neu installiert. Nun geht es.
                  Ich denke die Lösung war die Node.js 16
                  Vielen Dank!
                  • Rene55
                    @matthias425 Hallo Matthias,
                    schön dass es jetzt funktioniert hat. Ja irgendwas darin möchte gerne die aktuelle node.js Version haben. Hauptsache es fluppt.
                    LG
                      Burgi @Rene55 last edited by
                      @rene55 Hallo Rainer,
                      das ist ja super, vielen Dank.
                      Werde ich gleich heute Anend machen.
                      Viele Grüße
                      Thomas
                        cy_coe last edited by
                        Vielen Dank für den Adapter! Mein Microinverter ist ein Deye SUN600G3
                        -EU-230. Funktioniert bestens mit diesem Adapter.
                        Rene55 B 2 Replies Last reply Reply Quote 0
                        • Rene55
                          Rene55 @cy_coe last edited by
                          @cy_coe Danke für die Rückmeldung. Dann kann ich ja bald mal eine Liste mit funktionierenden Geräten aufstellen.
                          • webwalker2001
                            webwalker2001 @Rene55 last edited by
                            @rene55 Hi, hier der log.
                            Aber wie gesagt, die Fehlermeldungen kommen nur manchmal. Hab noch nicht den Zusammenhang herausgefunden.
                            solarmanpv.0 2022-11-10 22:54:39.800	debug	[onReady] started: solarmanpv.0
                            solarmanpv.02 022-11-10 22:54:39.731	info	starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v16.18.1, js-controller: 4.0.23
                            solarmanpv.0 2022-11-10 22:54:43.223	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                            solarmanpv.0 2022-11-10 22:54:43.221	debug	[onReady] finished - stopping instance
                            solarmanpv.0 2022-11-10 22:54:42.834	debug	[getDeviceData] Device ID >: 217801816 and Device SN >: 2205037328
                            solarmanpv.0 2022-11-10 22:54:42.546	debug	[initializeInverter] InverterTyp: MICRO_INVERTER
                            solarmanpv.0 2022-11-10 22:54:42.545	debug	[initializeInverter] StationID >: 2633791
                            solarmanpv.0 2022-11-10 22:54:39.731	info	starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v16.18.1, js-controller: 4.0.23
                            solarmanpv.0 2022-11-10 22:54:38.613	debug	States connected to redis: 127.0.0.1:9000
                            solarmanpv.0 2022-11-10 22:54:38.380	debug	States create User PubSub Client
                            solarmanpv.0 2022-11-10 22:54:38.376	debug	States create System PubSub Client
                            solarmanpv.0 2022-11-10 22:54:38.289	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                            solarmanpv.0 2022-11-10 22:54:38.150	debug	Objects connected to redis: 127.0.0.1:9001
                            solarmanpv.0 2022-11-10 22:54:38.060	debug	Objects client initialize lua scripts
                            solarmanpv.0 2022-11-10 22:54:37.837	debug	Objects create User PubSub Client
                            solarmanpv.0 2022-11-10 22:54:37.835	debug	Objects create System PubSub Client
                            solarmanpv.0 2022-11-10 22:54:37.827	debug	Objects client ready ... initialize now
                            solarmanpv.0 2022-11-10 22:54:37.718	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                            lg
                            Webwalker2001
                            • Rene55
                              Rene55 @webwalker2001 last edited by Rene55
                              @webwalker2001 Hallo, das sieht eigentlich ganz gut aus. Station und Device wurden erkannt. Im Protokoll sehen diese Zeilen:
                              wie dubletten aus. Ist dein System sehr ausgelastet?
                              Ab und an kann eine Warnung wie diese
                              solarmanpv.0
                              2022-11-11 09:30:06.711	warn	[getDeviceData] error: AxiosError: timeout of 2000ms exceeded
                              auftreten. Das ist normal und ist dem geschuldet, dass der China-Server gerade nicht schnell genug antworten konnte.
                              • webwalker2001
                                @rene55 Mein CPU-Load liegt so zwischen 35%-50%. RAM bei ca. 50%. Sollte eigentlich passen. Kann man den Timeout evtl. irgendwo einstellen?
                                lg
                                webwalker2001
                                • Rene55
                                  @webwalker2001 Das ist nicht vorgesehen bzw. macht auch keinen Sinn. Wenn der Server nicht in 2 Sekunden geantwortet hat, tuts der auch nicht in einer Minute. Also ignorieren und auf die nächste Abfrage warten.
                                    ralle last edited by
                                    Ich wolltw den Adapter auch nutzen, den API Key habe ich bekommen aber was ist der APP Secret ?
                                    Bekomme ich diesen auch von "Solarman", ansonsten habe ich nur 3 Angaben die ich machen kann.
                                    Starte ich den Adapter mit diesen 3 Angaben, wird dieser grün, jedoch stehen da nicht wirklich brauchbare Daten drin.
                                    Ralf
                                      A Former User @ralle last edited by
                                      @ralle Hello, wie in der Beschreibung angegeben vorgehen, dann klappt das!
                                      Ohne Appsecret und AppId funktioniert der Adapter nicht.
                                        JA, klappt. besten dank.
                                        Hatte die ID in der Mail nicht gesehen.
                                        • Rene55
                                          Rene55 @ralle last edited by
                                          @ralle Ja, schön, freut mich. Viel Spaß damit.
                                            Bambulko @cy_coe last edited by
                                            @cy_coe Kann man den Deye SUN600G3 auch über Zigbee auslesen? Ich überlege mir diesen zuzulegen. Funktioniert das auslesen auch zuverlässig?
                                            jetz
                                            67
                                            564
                                            136941
