    4. Test Adapter mihome-vacuum 3.8.x
    • DJMarc75
      DJMarc75 @D3ltoroxp last edited by
      @d3ltoroxp https://forum.iobroker.net/topic/59480/test-für-mihome-vacuum/20
      • D3ltoroxp
        D3ltoroxp @DJMarc75 last edited by
        @djmarc75 Sorry werde daraus nicht schlau, hatte das ja schon gelesen. Was willst du mir damit sagen ?
          dirkhe Developer @D3ltoroxp last edited by
          Ich habe mal die 3.8.4 veröffentlicht, da sollte das Log ruhiger sein....
          ? da_Woody 2 Replies Last reply Reply Quote 0
            A Former User @dirkhe last edited by
            @dirkhe sagte in Test für mihome-vacuum:
            Hallo, ja vielen Dank, ist es. Bis jetzt keine Fehler / Warnings im Log, meine vier S5 fahren nachher mal ne Runde, die Grundfunktionen hab ich getestet, gehen..
            • da_Woody
              da_Woody @dirkhe last edited by
              • Vumer
                Vumer last edited by
                Heute Nacht
                mihome-vacuum.0 2022-11-09 05:16:50.322	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                mihome-vacuum.0 2022-11-09 04:23:46.883	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: {"id":5047,"result":[{"msg_ver":2,"msg_seq":1535,"state":8,"battery":100,"clean_time":471,"clean_area":8785000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":207,"distance_off":60,"water_box_carriage_status":0,"mop_forbidden_enable":0,"adbumper_status":[0,0,0],"dock_type":0,"dust_collection_stat�Wiw�~ �j��r�k%���7TŕN��r��K���tA*��n9SWG f�t*U��J������vZ��p$;��j ڗ� ���k�^status":1}],"exe_time":11}
                mihome-vacuum.0 2022-11-09 04:23:46.880	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: {"id":5047,"result":[{"msg_ver":2,"msg_seq":1535,"state":8,"battery":100,"clean_time":471,"clean_area":8785000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":207,"distance_off":60,"water_box_carriage_status":0,"mop_forbidden_enable":0,"adbumper_status":[0,0,0],"dock_type":0,"dust_collection_stat�Wiw�~ �j��r�k%���7TŕN��r��K���tA*��n9SWG f�t*U��J������vZ��p$;��j ڗ� ���k�^status":1}],"exe_time":11}
                mihome-vacuum.0 2022-11-09 04:06:12.036	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: �j�>S&� �d��lt":["roboroommap%2F535262734%2F0"],"exe_time":10}
                mihome-vacuum.0 2022-11-09 04:06:12.033	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: �j�>S&� �d��lt":["roboroommap%2F535262734%2F0"],"exe_time":10}
                mihome-vacuum.0 2022-11-09 03:02:57.222	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: @50 r6�e���kVU��V7�Z�c]�l����(����������͍Y,��h���������\��L��Y�A �%�{�h⹟N��3_H0��U�xx:xx:xx:xx:xx:xx","rssi":-36},"exe_time":31}
                mihome-vacuum.0 2022-11-09 03:02:57.220	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: @50 r6�e���kVU��V7�Z�c]�l����(����������͍Y,��h���������\��L��Y�A �%�{�h⹟N��3_H0��U�xx:xx:xx:xx:xx:xx","rssi":-36},"exe_time":31}
                und während der Reinigung
                mihome-vacuum.0 2022-11-09 11:32:16.306	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                mihome-vacuum.0 2022-11-09 11:32:16.303	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                mihome-vacuum.0 2022-11-09 11:15:55.415	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                mihome-vacuum.0 2022-11-09 11:15:55.412	error	sendMessage throws error ==>MIIO MESSAGE CANT PARSE ANSWER: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                  dirkhe Developer @Vumer last edited by
                  @vumer ja da sind parserfehler, könnre man ggf. Auch nur ins debug schreiben, weil er macht ja weiter.... oder zumindest ins info
                  @da_Woody mach mal debug an, die fehlermeldungen kommen da genauso häufig
                  • Vumer
                    Ich hab auf rot Allergie und gelb macht mich nervös 😉
                      ChrisXY last edited by
                      puhhh ich verzweifel an der Pause / Resume Ich will es per GUI steuern lassen.
                      Leider gibt es keine art toogle ..
                      Es gibt nur Pause für Pause.. dann muss man wissen was man gemacht hat.
                      Raumreinigung eines Raums läuft ..
                      Dann will ich PAUSE absenden. Schalter bleibt auf True ..
                      Was nun ? Für Raumreinigung weitermachen gibt es nur resumeroom
                      Start= Alles wird Gereinigt ..
                      Es gibt keinen toogle? Leider wird auch Pause nicht wieder auf false gesetzt. Somit ist der state von dem schalter auch immer falsch ..
                      Müsste das jetzt per Blockly wohl lösen. Oder gibt es da eine bessere Möglichkeit.
                      Will blos ein Schalter egal was er macht Pause/Weiter
                        dirkhe Developer @ChrisXY last edited by
                        @chrisxy conttol.pauseResume sollte das machen, der status eird sogar verändert, wenn du ssuger per hand losfährst, ist also der toggle
                          ChrisXY @dirkhe last edited by
                          @dirkhe klappt nicht. Wenn ich ihn zu einem Raum schicke zum Reinigen. Kann ich nur mit "pause" stoppen und per "resumroom.." starten. Das pauseResume hat nie einen effekt 😞
                            @chrisxy reden wir vom gleichen adapter? Resumeroom gibt es gar nicht.
                            zeige mal ein debuglog, da kannst du dann mal psuseresum drücken, wichtig ack auf false
                            • Diginix
                              Diginix last edited by
                              @dirkhe 3.8.5 hat heute beim Saugen von 7 Räumen mit zT 3 im queue immer den korrekten room.state angezeigt und auch die CPU Last sieht über 12 Stunden wie mit 3.6.0 aus. Denke du hast die richtige Stelle gefixt.
                              Perfekt wäre es nun noch wenn man in den Instanzenstellungen die Farbwerte aus der mapcreator.js selbst einstellen könnte:
                              alt bis 3.6.0
                              neu seit 3.8.x (aber auf dunklem Hintergrund bei Saugern ohne Teppicherkennung nachteilig)
                                dirkhe Developer @Diginix last edited by
                                @diginix ich würde da jetzt quasi eine farbthemen liste (mit 2 einträgen) machen wollen. Jetzt bist du gefragt, hast du einevidee, wie man jeweils die farbthemes benennen könnte? So könnte man demnächst noch weitere themes hinzufügen
                                da_Woody Diginix 2 Replies Last reply Reply Quote 0
                                • da_Woody
                                  @dirkhe irgendwie versteh ich das nicht. da gibts im adapter ja
                                  hat aber 0 auswirkung. angezeigt wird ja
                                  wo bin ich da falsch abgebogen? 😵
                                  • Diginix
                                    Diginix @dirkhe last edited by Diginix
                                    @dirkhe Mir fällt nur "Light" und "Dark" ein für die zwei bisherigen Farbsets.
                                    Farben bis v3.6.0 "Light"
                                    Farben seit v3.8.0 "Dark"
                                    Aber es ginge natürlich noch heller bzw. dunkler.
                                    @da_woody Wenn du nur die eine feste Farbe für Boden und Wand haben willst, musst du den Haken bei "Use new Map format with room colors" entfernen. Dann haben aber eben auch alle Räume dieselbe Farbe.
                                    • da_Woody
                                      da_Woody @Diginix last edited by
                                      @diginix warum das ding aus einem raum 2 gemacht hat, ist schon länger suspekt.
                                      haken raus, gewartet bis das ding wieder grün ist, kein starten über iQontrol mehr möglich. jetzt komm ich nichtmal mehr auf die 3.6 zurück, da hatte ich die wenigsten probs... war ja eh immer ein bißchen problematisch. der s6pure stand ja nie wirklich in der liste.
                                      langsam hoff ich echt auf den roborock adapter...
                                      D Diginix 2 Replies Last reply Reply Quote 0
                                        dirkhe Developer @da_Woody last edited by
                                        @da_woody kann es sein, dass der eine teil teppich ist? Das ist wohl neu reingekommen.
                                        Wenn er dich nicht starten läßt, debug, dann kann ich mal schauen
                                        • Diginix
                                          Diginix @da_Woody last edited by
                                          @da_woody Die automatische Raumerkennung von Xiaomi ist nicht perfekt. Ich musste bei mir auch alle Räume manuell definieren. In der MiHome App kann man Räume zusammenfügen und teilen so dass es der realen Architektur entspricht.
                                          • da_Woody
                                            @dirkhe nein, da ist definitiv kein teppich. nachdem ich den haken wieder reingetan hab, konnte ich heute wieder starten.
                                            vllt brauch das ding einfach nur ewig lange bis er wieder reagiert?
                                            hab den haken wieder raus und versuchs am abend nochmal.
                                            ich werd berichten... 🙂
                                            @Diginix thnx, schau ich mir an.
                                            129
                                            9991
