    3. Einsteigerfragen
    4. *gelöst* Zigbee Adapter läuft nicht mehr nach
      gluecksmann @Thomas Braun last edited by
      *** BASE SYSTEM ***
      Architecture:   armv7l
      Docker:         false
      Virtualization: none
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 10 (buster)
      Release:        10
      Codename:       buster
      PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="10"
      VERSION="10 (buster)"
      VERSION_CODENAME=buster
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       08:52:17 up 2 days,  1:10,  1 user,  load average: 0.68, 0.46, 0.44
      CPU threads: 4
      *** Time and Time Zones ***
      Fri Nov 11 07:52:17 UTC 2022
      Fri Nov 11 08:52:17 CET 2022
      CET +0100
      Europe/Berlin
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           7.9G        1.4G        4.8G         55M        1.8G        6.4G
      Swap:           99M         22M         77M
      Total:         8.0G        1.4G        4.8G
               7898 M total memory
               1354 M used memory
                695 M active memory
               2205 M inactive memory
               4769 M free memory
                203 M buffer memory
               1571 M swap cache
                 99 M total swap
                 22 M used swap
                 77 M free swap
      *** FILESYSTEM ***
      /dev/root      ext4       29G  7.6G   21G  28% /
      devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     3.9G   66M  3.8G   2% /run
      tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
      /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
      Show mounted filesystems (real ones only):
      TARGET        SOURCE         FSTYPE OPTIONS
      /             /dev/mmcblk0p2 ext4   rw,noatime
      |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
      `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      372M    /var/
      116M    /var/lib
      77M     /var/log
      76M     /var/cache
      69M     /var/lib/apt/lists
      /opt/iobroker/backups:
      94M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      480M    /opt/iobroker/iobroker-data/
      206M    /opt/iobroker/iobroker-data/files
      135M    /opt/iobroker/iobroker-data/backup-objects
      79M     /opt/iobroker/iobroker-data/sonosCache
      48M     /opt/iobroker/iobroker-data/files/javascript.admin
      21M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/2.00a59c14.chunk.js.map
      20M     /opt/iobroker/iobroker-data/states.jsonl
      14M     /opt/iobroker/iobroker-data/objects.jsonl
      12M     /opt/iobroker/iobroker-data/objects.json.migrated
      12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v16.15.1
      /usr/bin/node           v16.15.1
      /usr/bin/npm            8.11.0
      nodejs:
        Installed: 16.15.1-deb-1nodesource1
        Candidate: 16.18.1-deb-1nodesource1
        Version table:
           16.18.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
       *** 16.15.1-deb-1nodesource1 100
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u2 500
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.23
      admin:          6.2.23
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
      ioBroker-Repositories
      Active repo(s): stable
      ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.2.23   , installed 6.2.23
      Adapter    "alexa2"       : 3.21.0   , installed 3.21.0
      Adapter    "alias-manager": 1.2.4    , installed 1.2.6
      Adapter    "backitup"     : 2.5.4    , installed 2.4.12 [Updatable]
      Adapter    "ble"          : 0.13.0   , installed 0.13.0
      Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
      Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
      Adapter    "devices"      : 1.0.12   , installed 1.0.12
      Adapter    "discovery"    : 3.0.5    , installed 3.0.5
      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
      Adapter    "ecovacs-deebot": 1.4.4   , installed 1.4.4
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
      Adapter    "history"      : 2.2.0    , installed 2.2.0
      Adapter    "hue"          : 3.7.1    , installed 3.7.1
      Adapter    "ical"         : 1.13.1   , installed 1.13.1
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.11.9   , installed 1.11.9
      Adapter    "javascript"   : 6.0.3    , installed 6.0.3
      Adapter    "mielecloudservice": 6.4.0, installed 6.3.2  [Updatable]
      Adapter    "musiccast"    : 0.1.5    , installed 0.2.2
      Adapter    "netatmo"      : 2.0.5    , installed 1.7.1  [Updatable]
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "shelly"       : 6.0.0    , installed 6.0.0
      Adapter    "shuttercontrol": 1.4.18  , installed 1.4.14 [Updatable]
      Adapter    "simple-api"   : 2.7.0    , installed 2.7.2
      Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
      Adapter    "socketio"     : 4.2.0    , installed 6.1.7
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "sonos"        : 2.2.3    , installed 2.2.3
      Adapter    "trashschedule": 2.0.3    , installed 2.0.3
      Adapter    "vis"          : 1.4.15   , installed 1.4.15
      Adapter    "weatherunderground": 3.4.2, installed 3.4.2
      Adapter    "web"          : 4.3.0    , installed 5.2.3
      Adapter    "ws"           : 1.3.0    , installed 2.1.2
      Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
      Objects and States
      Objects:        10643
      States:         8595
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
      Reading package lists... Done
      Pending Updates: 194
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18832      648/sshd
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14012910   21240/cupsd
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       4769369    14907/io.sonoff.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       4769178    14772/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4771258    14772/iobroker.js-c
      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       4772280    14938/io.sonos.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       4772087    14791/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10039177   10195/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          18834      648/sshd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14012909   21240/cupsd
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       4772234    14892/io.shelly.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16023      637/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14012293   21242/cups-browsed
      udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       4774195    15209/io.musiccast.
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       4772424    15006/io.chromecast
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11164      368/avahi-daemon: r
      udp        0      0 0.0.0.0:57313           0.0.0.0:*                           108        11166      368/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          16515      637/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        11165      368/avahi-daemon: r
      udp6       0      0 :::56623                :::*                                108        11167      368/avahi-daemon: r
      Thomas Braun G 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @gluecksmann last edited by Thomas Braun
        @gluecksmann
        iob stop
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
        Künftig regelmäßig machen!
        Und die Adapter auch aktuell halten.
          Diese Angabe verstehe ich nicht... was ist da zu Updaten? Bei den Adaptern werden mir nur 3 oder 4 Angezeigt das es Updates gibt
          • Codierknecht
            Codierknecht Developer Most Active @gluecksmann last edited by
            @gluecksmann
              gluecksmann @Codierknecht last edited by
              @codierknecht
              Ja, das habe ich schon gesehen... ich möchte aber wissen WAS das ist. Ich das z.B. wie ein Windowsupdate zu verstehen, also Aktualisierungen des Betriebssystems?
                @gluecksmann
                Ja, das ist vom OS=Operating System = Betriebssystem
                  Ah, ok... Und da gibt es keine richtige Aufforderung das zu machen.... läut noch das Update...
                  Thomas Braun Codierknecht 2 Replies Last reply Reply Quote 0
                    @gluecksmann
                    Was ist denn eine 'richtige Aufforderung'?
                    Das schaut man sich regelmäßig an.
                      Da könnte man jetzt drüber streiten... aber ich habe es auf meine ToDO Liste gesetzt das regelmäßig zu machen... Schauen wir mal ob wir jetzt weiterkommen...
                      • Codierknecht
                        Codierknecht Developer Most Active @gluecksmann last edited by Codierknecht
                        @gluecksmann sagte in *gelöst* Zigbee Adapter läuft nicht mehr nach:
                        Du hast halt hier keinen Desktop-Aufsatz, der das Ganze in Form von Meldungen o.ä. präsentiert.
                        Ein Linux soll vor allem eins: Laufen!
                        Um Updates muss man sich schon selbst kümmern.
                        Ich bin ja auch eher "WIndows-ianer". Die "Linux-er" ticken da anders 😁 😁 😁
                          gluecksmann @gluecksmann last edited by
                          @gluecksmann
                          So, das wäre erledigt...stehe ich leider immer noch vor dem Problem die vis-view.json in den Ordner Main zu bekommen...
                            Thomas Braun Most Active @Codierknecht last edited by
                            @codierknecht
                            Ist ja nicht so, als wenn es nicht drölftrilliarden Desktops oder Fenstermanager für Linux gäbe. Aber im Serverbetrieb verbietet sich der Betrieb eines Desktops.
                            Die 'pending Updates' wurden in früheren Versionen in der Konsole bei der motd Begrüßung angezeigt.
                            Wurde aber wegen Sicherheitsbedenken wieder abgeschafft.
                            Codierknecht G 2 Replies Last reply Reply Quote 0
                            • Codierknecht
                              Codierknecht Developer Most Active @Thomas Braun last edited by
                              OT:
                              @thomas-braun sagte in *gelöst* Zigbee Adapter läuft nicht mehr nach:
                              Wir hatten mal einen Kollegen, der in einem (Windows-)Serverprozess Fehlermeldungen per MessageBox ausgegeben hat.
                              Das war ein Spaß ...
                                Verstehe kein Wort... Sorry... DAU
                                  hast du denn wie oben die alte gelöscht? bzw du hast doch den Adapter neu installiert, richtig, somit ist alles leer, hast du schon ein Projekt erstellt? oder ist auch kein main mehr vorhanden?
                                    gluecksmann @crunchip last edited by
                                    @crunchip
                                    Ich habe den VIS Adaper gelöscht...inkl alles darauf beruhenden Komponenten.
                                    Beim Start legt er ja ein neues Projekt an, deswegen ist da wieder ein Main Ordner vorhanden
                                      crunchip Forum Testing Most Active @gluecksmann last edited by crunchip
                                      @gluecksmann dann versuchen wir es mal so
                                      iob stop
                                      danach
                                      cd /opt/iobroker/iobroker-data/files/vis.0
                                      mv main MeinAltesProjekt
                                      anschließend iobroker wieder starten und dein Projekt main importieren
                                        @crunchip sagte in *gelöst* Zigbee Adapter läuft nicht mehr nach:
                                        iob stop
                                        danach
                                        wie importiere ich das Projekt?
                                          @gluecksmann na vis editor, Dateimanager
                                          zeig mal was für Projekt nun angezeigt wird im Editor
                                            @crunchip
                                            wenn ich VIS starte, sagt er mir das er noch kein Projekt hat.. wenn ich es ihn anlegen lasse, habe ich wieder den Ordner MAIN, wo ich aber meine Datei NICHT reinkopiert bekomme...
                                            6164
