    2. English
    4. Onvif
    Onvif
    • Vraanaa
      Vraanaa last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: linux
      Node-Version: 14.18.3
      Nodejs-Version: 14.18.3
      NPM-Version: 6.14.15
      Installationsart: Skript
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      I have a issue with OnVif adapter - ist disconnect from REOLINK kameras sporadic. When Connected - all is working well.
      Dont know what can be issue of the connection's
      Cameras: REOLINK
      Model
      RLC-810A
      Build No.
      build 22041503
      Hardware No.
      IPC_523128M8MP
      Config Version
      v3.1.0.0
      Firmware Version
      v3.1.0.956_22041503
        arteck Developer Most Active @Vraanaa last edited by
        @vraanaa check you wifi.. in the moment when the cam is off
        Vraanaa 1 Reply Last reply Reply Quote 1
        • Vraanaa
          Vraanaa @arteck last edited by
          @arteck Thank you for reply - The cameras are Wired connected (PoE) - I use them also for Synology Surveillance and they recording all the time without some gap in recording.
          I performed Speed test during disconnection of Camera in Onvif adapter.
