    4. Zigbee Adapter lässt sich nicht mehr installieren
      jfwillow @Thomas Braun last edited by
      die Zeilenumbrüche sollten jetz zumindest passen....sorry
      *** BASE SYSTEM ***
      Architecture:   armv7l
      Docker:         false
      Virtualization: none
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 10 (buster)
      Release:        10
      Codename:       buster
      PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="10"
      VERSION="10 (buster)"
      VERSION_CODENAME=buster
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       21:24:12 up 2 days, 11:54,  1 user,  load average: 0.82, 0.98, 1.01
      CPU threads: 4
      *** Time and Time Zones ***
      Fri Nov 11 20:24:12 UTC 2022
      Fri Nov 11 21:24:12 CET 2022
      CET +0100
      Europe/Vienna
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           3.8G        2.7G        490M         75M        610M        1.8G
      Swap:           99M         62M         37M
      Total:         3.9G        2.8G        527M
               3838 M total memory
               2738 M used memory
               1243 M active memory
               1973 M inactive memory
                490 M free memory
                111 M buffer memory
                498 M swap cache
                 99 M total swap
                 62 M used swap
                 37 M free swap
      *** FILESYSTEM ***
      /dev/root      ext4       29G   12G   17G  42% /
      devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
      tmpfs          tmpfs     1.9G  1.8M  1.9G   1% /dev/shm
      tmpfs          tmpfs     1.9G  105M  1.8G   6% /run
      tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
      /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     384M     0  384M   0% /run/user/998
      tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
      Show mounted filesystems (real ones only):
      TARGET        SOURCE         FSTYPE OPTIONS
      /             /dev/mmcblk0p2 ext4   rw,noatime
      |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
      `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.3G    /var/
      499M    /var/lib
      387M    /var/cache
      381M    /var/cache/apt
      319M    /var/cache/apt/archives
      /opt/iobroker/backups:
      1.5G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      841M    /opt/iobroker/iobroker-data/
      445M    /opt/iobroker/iobroker-data/history
      208M    /opt/iobroker/iobroker-data/files
      145M    /opt/iobroker/iobroker-data/backup-objects
      48M     /opt/iobroker/iobroker-data/files/javascript.admin
      15M     /opt/iobroker/iobroker-data/objects.jsonl
      12M     /opt/iobroker/iobroker-data/objects.json.migrated
      12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
      8.5M    /opt/iobroker/iobroker-data/files/vis.0/Import/vis-views.json
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v16.18.1
      /usr/bin/node           v16.18.1
      /usr/bin/npm            8.19.2
      nodejs:
        Installed: 16.18.1-deb-1nodesource1
        Candidate: 16.18.1-deb-1nodesource1
        Version table:
       *** 16.18.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u2 500
              500 https://archive.raspbian.org/raspbian buster/main armhf Packages
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.23
      admin:          6.2.23
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): Beta (latest)
      ioBroker-Instances
      Used repository: Beta (latest)
      Adapter    "admin"        : 6.2.23   , installed 6.2.23
      Adapter    "alexa-shoppinglist": 0.1.4, installed 0.1.4
      Adapter    "alexa2"       : 3.21.0   , installed 3.20.1 [Updatable]
      Adapter    "backitup"     : 2.5.4    , installed 2.4.12 [Updatable]
      Adapter    "ble"          : 0.13.0   , installed 0.13.0
      Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
      Adapter    "discovery"    : 3.1.0    , installed 3.0.5  [Updatable]
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
      Adapter    "history"      : 2.2.4    , installed 2.2.0  [Updatable]
      Adapter    "ical"         : 1.13.2   , installed 1.13.2
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.1.8  [Updatable]
      Adapter    "info"         : 1.9.21   , installed 1.9.19 [Updatable]
      Adapter    "iot"          : 1.12.5   , installed 1.11.9 [Updatable]
      Adapter    "javascript"   : 6.1.3    , installed 6.0.3  [Updatable]
      Adapter    "meross"       : 1.14.0   , installed 1.14.0
      Adapter    "mihome-vacuum": 3.8.5    , installed 3.8.3  [Updatable]
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "octoprint"    : 4.0.1    , installed 4.0.0  [Updatable]
      Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
      Adapter    "plex"         : 0.9.1    , installed 0.9.1
      Adapter    "shelly"       : 6.2.4    , installed 6.2.0  [Updatable]
      Adapter    "socketio"     : 6.2.0    , installed 4.2.0  [Updatable]
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
      Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
      Adapter    "telegram"     : 1.15.2   , installed 1.14.1 [Updatable]
      Adapter    "text2command" : 2.3.0    , installed 2.2.2  [Updatable]
      Adapter    "tr-064"       : 4.2.17   , installed 4.2.16 [Updatable]
      Adapter    "trashschedule": 2.0.3    , installed 2.0.3
      Adapter    "vis"          : 1.4.15   , installed 1.4.15
      Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
      Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.22
      Adapter    "web"          : 5.2.10   , installed 4.3.0  [Updatable]
      Adapter    "ws"           : 2.2.1    , installed 1.3.0  [Updatable]
      Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.0  [Updatable]
      Objects and States
      Objects:        11389
      States:         8720
      Get:1 http://giteduberger.fr rpimonitor/ InRelease [1933 B]
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:3 https://archive.raspbian.org/raspbian buster InRelease
      Hit:4 https://repos.influxdata.com/debian buster InRelease
      Hit:5 https://deb.nodesource.com/node_16.x buster InRelease
      Hit:6 http://archive.raspberrypi.org/debian buster InRelease
      Fetched 1933 B in 15s (125 B/s)
      Reading package lists... Done
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          18376      657/lighttpd
      tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      998        17646238   24085/pihole-FTL
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16826      658/sshd
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        16600      547/influxd
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18386820   16043/io.sonoff.0
      tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      998        17647877   24085/pihole-FTL
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18385666   15787/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18385659   15787/iobroker.js-c
      tcp6       0      0 :::80                   :::*                    LISTEN      0          18377      657/lighttpd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18387529   15805/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18392931   16957/io.web.0
      tcp6       0      0 :::53                   :::*                    LISTEN      998        17646240   24085/pihole-FTL
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        18726      547/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          16836      658/sshd
      tcp6       0      0 :::3000                 :::*                    LISTEN      109        18903      683/grafana-server
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       18389437   16103/io.harmony.0
      tcp6       0      0 ::1:4711                :::*                    LISTEN      998        17647878   24085/pihole-FTL
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       18389438   16103/io.harmony.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       18389310   16028/io.shelly.0
      udp    31488      0 0.0.0.0:53              0.0.0.0:*                           998        17646237   24085/pihole-FTL
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13680      529/dhcpcd
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       18387892   15953/io.mihome-vac
      udp        0      0 0.0.0.0:52910           0.0.0.0:*                           108        13626      341/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18386562   15908/io.chromecast
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13624      341/avahi-daemon: r
      udp     2624      0 0.0.0.0:57599           0.0.0.0:*                           998        19483847   24085/pihole-FTL
      udp6       0      0 :::36811                :::*                                108        13627      341/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          17383070   529/dhcpcd
      udp6       0      0 :::53                   :::*                                998        17646239   24085/pihole-FTL
      udp6       0      0 :::5353                 :::*                                108        13625      341/avahi-daemon: r
        Thomas Braun Most Active @jfwillow last edited by
        @jfwillow
        Entweder das iobroker-Repo auf 'Stable' setzen oder die Adapter alle auf den letzten Beta-Stand bringen. So bringt das ja gar nix.
          ok Repo auf 'Stable'. Backup- und Alexa-Adapter brauchten ein Update....hat funktioniert, aber dauert gefühlt eine Ewigkeit bis die Updates durch sind.
          *** BASE SYSTEM ***
          Docker:         false
          Release:        10
          Codename:       buster
          VERSION_ID="10"
          ID=raspbian
          ID_LIKE=debian
           08:42:07 up 2 days, 23:12,  1 user,  load average: 2.45, 1.26, 1.06
          CPU threads: 4
          Sat Nov 12 07:42:07 UTC 2022
          Sat Nov 12 08:42:07 CET 2022
          CET +0100
          Europe/Vienna
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:           3.8G        2.6G        511M         84M        741M        1.7G
          Swap:           99M         99M        0.0K
          Total:         3.9G        2.7G        511M
                   3838 M total memory
                   2586 M used memory
                   1116 M active memory
                   2086 M inactive memory
                    511 M free memory
                     84 M buffer memory
                    656 M swap cache
                     99 M total swap
                     99 M used swap
                      0 M free swap
          *** FILESYSTEM ***
          tmpfs          tmpfs     1.9G  2.4M  1.9G   1% /dev/shm
          tmpfs          tmpfs     1.9G  129M  1.8G   7% /run
          /var:
          1.3G    /var/
          495M    /var/lib
          387M    /var/cache
          381M    /var/cache/apt
          865M    /opt/iobroker/iobroker-data/
          444M    /opt/iobroker/iobroker-data/history
          25M     /opt/iobroker/iobroker-data/objects.jsonl
          17M     /opt/iobroker/iobroker-data/states.jsonl
          /usr/bin/npm            8.19.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.2.23
          Active repo(s): Stable (default)
          ioBroker-Instances
          Used repository: Stable (default)
          Adapter    "alexa2"       : 3.21.0   , installed 3.21.0
          Adapter    "backitup"     : 2.5.4    , installed 2.5.4
          Adapter    "chromecast"   : 2.3.1    , installed 3.0.3
          Adapter    "discovery"    : 3.0.5    , installed 3.0.5
          Adapter    "history"      : 2.2.0    , installed 2.2.0
          Adapter    "ical"         : 1.13.1   , installed 1.13.2
          Adapter    "influxdb"     : 3.1.8    , installed 3.1.8
          Adapter    "info"         : 1.9.19   , installed 1.9.19
          Adapter    "iot"          : 1.11.9   , installed 1.11.9
          Adapter    "javascript"   : 6.0.3    , installed 6.0.3
          Adapter    "mihome-vacuum": 3.4.2    , installed 3.8.3
          Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
          Adapter    "shelly"       : 6.0.0    , installed 6.2.0
          Adapter    "simple-api"   : 2.7.0    , installed 2.7.2
          Adapter    "telegram"     : 1.14.1   , installed 1.14.1
          Adapter    "text2command" : 2.2.2    , installed 2.2.2
          Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
          Adapter    "vis-canvas-gauges": 0.1.5, installed 1.0.1
          Adapter    "yeelight-2"   : 1.1.2    , installed 1.2.0
          Objects and States
          Objects:        11389
          States:         8720
          Fetched 1933 B in 3s (711 B/s)
          Pending Updates: 0
          udp        0      0 0.0.0.0:53              0.0.0.0:*                           998        17646237   24085/pihole-FTL
            Thomas Braun Most Active @jfwillow last edited by Thomas Braun
            @jfwillow
            Ich sehe nichts wirklich auffälliges bei dir.
            Den Serial Port hast du freigeschaltet?
              denke schon
              pi@iobroker:~ $ ls -l /dev/serial/by-id
              insgesamt 0
              lrwxrwxrwx 1 root root 13 Nov  9 09:27 usb-Texas_Instruments_CC2538_USB_CDC-if00 -> ../../ttyACM0
                @jfwillow
                In
                sudo raspi-config
                Unter Interfaces mal geschaut?
                  ehrlich gesagt nein.
                  login-shell und serial interface beide auf enable oder nur das interface?
                    @jfwillow
                    Nur das Interface.
                    Einloggen willst du dich nicht.
                      Zuerst einmal danke für deine Hilfe!
                      Interface enabled und reboot.
                      Hat sich nichts geändert beim Versuch den Zigbee-Adapter zu installieren. Leider fehlgeschlagen.
                        @jfwillow
                        Schaufel mal etwas RAM frei, bevor der Adapter installiert wird.
                        Andere Instanzen stoppen z. B.
                          Hat leider nicht wirklich was gebracht. Hab so ziemlich alles gestoppt. Trotzdem hat der Installationsversuch ewig gedauert und ist dann mit Error 25 abgebrochen. Mir ist aufgefallen, dass der SWAP immer mit 70% ausgelastet ist, hab in daraufhin deaktiviert...leider auch keine Veränderung 😞
                          Kurze Frage noch zum Bluetooth-Adapter...der ja auch seit dem Nnode.js-Update spinnt (also Gelb bleibt)...kannst du, oder jemand anderer, eventuell mit der Fehlermeldung etwas anfangen?
                          ble.0
                          2022-11-15 09:57:15.632	error	Cannot find module '@abandonware/bluetooth-hci-socket'Require stack:- /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/hci.js- /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/bindings.js- /opt/iobroker/node_modules/@abandonware/noble/lib/resolve-bindings.js- /opt/iobroker/node_modules/@abandonware/noble/index.js- /opt/iobroker/node_modules/iobroker.ble/build/scanProcess.js
                            @jfwillow sagte in Zigbee Adapter lässt sich nicht mehr installieren:
                            Äähhh, den Notausgang mauerst du auch noch zu? Das ist ja mega sinnvoll.... (nicht).
                            Der SWAP-Bereich wird ja gerade in 'Notsituationen' genutzt, wenn der reguläre Arbeitsspeicher zur Neige gegangen ist.
                            Edit: Der war ja auch oben schon übervoll. Hab ich gar nicht gesehen:
                            *** MEMORY ***
                            Swap:           99M         99M        0.0K
                            Zu Bluetooth:
                            cd /opt/iobroker/node_modules/iobroker.ble
                            sudo -H -u iobroker npm install --omit=dev
                              @thomas-braun sagte in Zigbee Adapter lässt sich nicht mehr installieren:
                              Zu Bluetooth:
                              Hat leider nichts gebracht. Ist zwar fehlerlos durch gelaufen, der Adapter ist aber weiterhin gelb bei identischer Fehlermeldung.
                              Wird wohl auf eine Neuinstallation hinauslaufen. Schade, weil ausser Zigbee und Bluetooth, gefühlt alles tadellos funktioniert. Mal abgesehen von der gefühlten Ewigkeit bei Adapter-Updates/Neuinstallationen.
                              337
