    5. Homematic Ip Thermostate und Xiaomi ( Gelöst )
      paul53 @lustig29 last edited by
      @lustig29 sagte:
      Tür auf - Temperatur bleibt auf 18 Grad stehen
      Das liegt nicht am Script wie das Log zeigt.
        lustig29 @paul53 last edited by
        @paul53 Hast du eine Idee wie ich das hinbekommen kann?
          @paul53 das steht im Log
          code_text
          ```hmip.0	2020-06-25 21:45:46.128	info	(28734) hmip adapter connected and ready
          hmip.0	2020-06-25 21:45:44.418	info	(28734) ws connection opened
          hmip.0	2020-06-25 21:45:39.770	info	(28734) starting. Version 0.0.11 in /opt/iobroker/node_modules/iobroker.hmip, node: v12.18.0, js-controller: 3.1.6
          host.raspberrypi	2020-06-25 21:45:36.180	info	instance system.adapter.hmip.0 started with pid 28734
          host.raspberrypi	2020-06-25 21:45:06.121	info	Restart adapter system.adapter.hmip.0 because enabled
          host.raspberrypi	2020-06-25 21:45:06.119	info	instance system.adapter.hmip.0 terminated with code 0 (NO_ERROR)
          hmip.0	2020-06-25 21:45:05.554	info	(28119) Terminated (NO_ERROR): Without reason
          hmip.0	2020-06-25 21:45:05.551	info	(28119) terminating
          hmip.0	2020-06-25 21:45:05.521	info	(28119) cleaned everything up...
          hmip.0	2020-06-25 21:45:05.519	error	at IncomingMessage.emit (events.js:327:22)
          hmip.0	2020-06-25 21:45:05.519	error	at Object.onceWrapper (events.js:421:28)
          hmip.0	2020-06-25 21:45:05.519	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
          hmip.0	2020-06-25 21:45:05.519	error	at Request.emit (events.js:315:20)
          hmip.0	2020-06-25 21:45:05.519	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
          hmip.0	2020-06-25 21:45:05.519	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
          hmip.0	2020-06-25 21:45:05.519	error	at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
          hmip.0	2020-06-25 21:45:05.519	error	at Request.plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:104:33)
          hmip.0	2020-06-25 21:45:05.519	error	at new StatusCodeError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:32:15)
          hmip.0	2020-06-25 21:45:05.519	error	(28119) StatusCodeError: 400 - {"errorCode":"NOT_HEATING_GROUP"}
          hmip.0	2020-06-25 21:45:05.516	error	(28119) unhandled promise rejection: 400 - {"errorCode":"NOT_HEATING_GROUP"}
            @lustig29 sagte:
            das steht im Log
            Mit HMIP(AP) kenne ich mich nicht aus.
              @paul53 Ok, trotzdem danke
                lustig29 @lustig29 last edited by
                @lustig29 Habe es hinbekommen.😊
                  Jetzt habe ich nur noch eine kurze Frage. Kann ich jetzt alle Räume in ein Skript packen, oder ist es besser für jeden Raum ein eigenes zu erstellen?
                    Wäre es auch möglich, dem Thermostat den Fenster offen Status mitzuteilen? Ich weiß, es ist nur Spielerei, aber es würde mich interessieren, ob es möglich ist.
                      da die Heizperiode ja jetzt so langsam anläuft, würde ich mich freuen, wenn mir jemand meine 2 Fragen beantworten könnte.😊
                      L JackDaniel 2 Replies Last reply Reply Quote 0
                        loverz @lustig29 last edited by
                        @lustig29 Fenstersensoren kann man nur innerhalb der App -und nur die Homematic eigenen- mit den Thermostaten koppeln.
                        Über die API scheint es keinen Datenpunkt für Fenster offen zu geben, ebenso fehlt der Datenpunkt externe Temperatur.
                        Sehr schade!
                        • JackDaniel
                          JackDaniel @lustig29 last edited by
                          @lustig29 sagte in Homematic Ip Thermostate und Xiaomi ( Gelöst ):
                          Zu 1: Ist Geschmackssache, funktionieren wird beides
                          Zu 2: Geht natürlich, dafür gibt's einen Datenpunkt (zb. hm-rpc.0.000A1A49A52334.1.WINDOW_STATE)
                          3380
