    4. Gelöst: Nach Restore: No connection to databases possible
      Thomas Braun Most Active @dragricola last edited by
      @dragricola
      Hat sich der host name der Kiste geändert?
        sudo apt update liefert:
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
        Hit:4 https://dl.yarnpkg.com/debian stable InRelease
        Reading package lists... Done
        Building dependency tree
        All packages are up to date.
        Hilft das Log aus meinem letzten Beitrag weiter?
          @dragricola sagte in Nach Restore: No connection to databases possible, restart:
          Jein.
          Hostname geändert?
          Bitte Auszüge in Textform in CodeTags eingebettet heir rein.
            dragricola @Thomas Braun last edited by
            Den Host-Namen habe ich meines Wissens wieder bei der Installation gleich vergeben. Allerdings ohne das präfix host. davor.
            2022-11-12 16:10:44.878  - info: host.raspberrypi4-iob iobroker _restart
            2022-11-12 16:10:50.341  - info: host.raspberrypi4-iob iobroker.js-controller version 4.0.23 js-controller starting
            2022-11-12 16:10:50.349  - info: host.raspberrypi4-iob Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
            2022-11-12 16:10:50.350  - info: host.raspberrypi4-iob hostname: raspberrypi4-iob, node: v16.18.1
            2022-11-12 16:10:50.353  - info: host.raspberrypi4-iob ip addresses: 192.168.178.126 fe80::436b:c1e:289f:c0ed
            2022-11-12 16:11:08.610  - error: host.raspberrypi4-iob Cannot read system.config: null (OK when migrating or restoring)
            2022-11-12 16:11:08.625  - error: host.raspberrypi4-iob Cannot find view "system" for search "host"
            2022-11-12 16:11:08.715  - info: host.raspberrypi4-iob connected to Objects and States
            2022-11-12 16:11:08.745  - info: host.raspberrypi4-iob Node.js version has changed from unknown to 16.18.1
            2022-11-12 16:11:08.793  - info: host.raspberrypi4-iob added notifications configuration of host
            2022-11-12 16:11:08.800  - info: host.raspberrypi4-iob Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
            2022-11-12 16:11:08.811  - error: host.raspberrypi4-iob Cannot find view "system" for search "instance"
            2022-11-12 16:11:08.813  - error: host.raspberrypi4-iob Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
            2022-11-12 16:11:08.826  - info: host.raspberrypi4-iob Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
            2022-11-12 16:11:08.836  - error: host.raspberrypi4-iob Cannot find view "system" for search "state"
            2022-11-12 16:11:08.837  - error: host.raspberrypi4-iob Cannot find view "system" for search "instance"
            2022-11-12 16:11:08.841  - error: host.raspberrypi4-iob Could not collect system.host.raspberrypi4-iob states to check for obsolete states: Error: Cannot find view "system"
            2022-11-12 16:11:08.842  - error: host.raspberrypi4-iob  _design/system missing - call node iobroker.js setup
            2022-11-12 16:11:08.843  - info: host.raspberrypi4-iob  no instances found
            2022-11-12 16:11:09.054  - info: host.raspberrypi4-iob Created UUID: 958fb34d-ae20-1453-74c4-b251ccab0b04
            2022-11-12 16:25:19.450  - info: host.raspberrypi4-iob received SIGTERM
            2022-11-12 16:25:19.469  - info: host.raspberrypi4-iob terminated
            2022-11-12 16:25:21.831  - info: host.raspberrypi4-iob iobroker.js-controller version 4.0.23 js-controller starting
            2022-11-12 16:25:21.838  - info: host.raspberrypi4-iob Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
            2022-11-12 16:25:21.840  - info: host.raspberrypi4-iob hostname: raspberrypi4-iob, node: v16.18.1
            2022-11-12 16:25:21.842  - info: host.raspberrypi4-iob ip addresses: 192.168.178.126 fe80::436b:c1e:289f:c0ed
            2022-11-12 16:25:21.936  - error: host.raspberrypi4-iob Cannot read system.config: null (OK when migrating or restoring)
            2022-11-12 16:25:21.948  - error: host.raspberrypi4-iob Cannot find view "system" for search "host"
            2022-11-12 16:25:22.013  - info: host.raspberrypi4-iob connected to Objects and States
            2022-11-12 16:25:22.035  - info: host.raspberrypi4-iob added notifications configuration of host
            2022-11-12 16:25:22.054  - error: host.raspberrypi4-iob Cannot find view "system" for search "instance"
            2022-11-12 16:25:22.057  - error: host.raspberrypi4-iob Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
            2022-11-12 16:25:22.085  - info: host.raspberrypi4-iob Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
            2022-11-12 16:25:22.097  - error: host.raspberrypi4-iob Cannot find view "system" for search "state"
            2022-11-12 16:25:22.099  - error: host.raspberrypi4-iob Cannot find view "system" for search "instance"
            2022-11-12 16:25:22.105  - error: host.raspberrypi4-iob Could not collect system.host.raspberrypi4-iob states to check for obsolete states: Error: Cannot find view "system"
            2022-11-12 16:25:22.107  - error: host.raspberrypi4-iob  _design/system missing - call node iobroker.js setup
            2022-11-12 16:25:22.108  - info: host.raspberrypi4-iob  no instances found
              @dragricola
              Versuch mal
              iob stop
              iob host this
              iob start
                pi@raspberrypi4-iob:~ $ iob stop
                pi@raspberrypi4-iob:~ $ iob host this
                An unknown error occurred: Cannot find view "system"
                pi@raspberrypi4-iob:~ $ iob start
                  Thomas Braun Most Active last edited by
                  @dragricola
                  iobroker setup first
                    jaa, ... jetzt meldet sich der admin wieder mit der Welcome-Seite und dem Setup Assistenten. Kann ich den irgendwie überspringen? Setup ist ja bereits erfolgt.
                    Ich würde das ganze auch nochmals mit bullseye durchführen. Was gibt es dabei zu beachten?
                      Weiß ich nicht, ich setze meine Kisten nicht sooooo oft neu auf.
                      Skip dich einfach durch, so viel ist da ja nicht einzustellen.
                      Das gleiche wie hier.
                        Hallo Thomas Braun,
                        dank Deiner Anleitung lief das System einigermaßen wieder auf buster, sodass ich hoffen konnte, dass ich es auch unter bullseye zum Laufen bringen kann. Es gab aber noch Probleme mit dem VIS-Adapter und nachdem ich im Forum zu diesem Problem nachgelesen habe, und dort empfohlen wurde vor dem Restart vis 1.4.0, web u.a. Adapter zu installieren, habe ich nun ioBroker auf Bullseye 64Bit neu aufgesetzt und vor dem Einspielen des Backups auch noch mariadb und pihole installiert. sudo apt update liefert nun:
                        pi@raspberrypi4-iob:~ $ sudo apt update
                        Hit:1 http://deb.debian.org/debian bullseye InRelease
                        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                        Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
                        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                        Fetched 48.4 kB in 1s (37.0 kB/s)
                        Building dependency tree... Done
                        Das Restore lief problemlois durch:
                        [EXIT] 0 **** Restore completed successfully!! ****
                        Allerdings war danach der Admin nicht mehr erreichbar. Ich habe daraufhin wieder die von Dir vorgeschlagenen Schritte durchgeführt:
                        Danach lief der Admin zwar wieder, allerdings gab es nur die Instanzen admin und backitup und offensichtlich kann iobroker die im restore eingespielten Adapter nicht nachladen:
                        admin.0
                        	2022-11-13 11:09:40.266	warn	Cannot update rating: connect ECONNREFUSED 79.143.182.215:443
                        admin.0
                        	2022-11-13 11:08:24.100	warn	Cannot update rating: connect ECONNREFUSED 79.143.182.215:443
                        	2022-11-13 11:07:53.372	info	Updating repository "live-stable" under "http://iobroker.live/repo/sources-dist.json"
                        admin.0
                        	2022-11-13 11:07:53.329	info	==> Connected system.user.admin from ::ffff:192.168.178.182
                        admin.0
                        	2022-11-13 11:07:52.926	info	<== Disconnect system.user.admin from ::ffff:192.168.178.182 admin
                        admin.0
                        	2022-11-13 11:06:55.164	warn	Active repository "stable" cannot be read
                        admin.0
                        	2022-11-13 11:06:55.163	warn	Repository cannot be read: Active repo - stable
                        	2022-11-13 11:06:53.019	error	Error by updating repository "stable" under "http://download.iobroker.net/sources-dist.json": Cannot download repository file from "http://download.iobroker.net/sources-dist.json": connect ECONNREFUSED 79.143.182.215:80
                        Nachdem ich das repository "live-stable" aktiviert hatte (Zeile6) ging wenigstens die Errormeldung (Zeile 16) weg. Aber
                        die Warnungen (Zeilen 2 und 4) kommen regelmäßig wieder. Ping auf download.iobroker.net und iobroker.live funktioniert problemlos:
                        pi@raspberrypi4-iob:~ $ ping download.iobroker.net
                        PING download.iobroker.net (79.143.182.215) 56(84) bytes of data.
                        64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=1 ttl=57 time=14.9 ms
                        64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=2 ttl=57 time=13.8 ms
                        64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=3 ttl=57 time=14.2 ms
                        64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=4 ttl=57 time=14.1 ms
                        64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=5 ttl=57 time=14.2 ms
                        64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=6 ttl=57 time=14.0 ms
                        64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=7 ttl=57 time=13.8 ms
                        64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=8 ttl=57 time=14.1 ms
                        64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=9 ttl=57 time=14.1 ms
                        64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=10 ttl=57 time=14.3 ms
                        ^C
                        --- download.iobroker.net ping statistics ---
                        10 packets transmitted, 10 received, 0% packet loss, time 9004ms
                        rtt min/avg/max/mdev = 13.801/14.141/14.853/0.281 ms
                        pi@raspberrypi4-iob:~ $ ping iobroker.live
                        PING iobroker.live (217.160.0.211) 56(84) bytes of data.
                        64 bytes from 217-160-0-211.elastic-ssl.ui-r.com (217.160.0.211): icmp_seq=1 ttl=58 time=9.40 ms
                        64 bytes from 217-160-0-211.elastic-ssl.ui-r.com (217.160.0.211): icmp_seq=2 ttl=58 time=8.51 ms
                        64 bytes from 217-160-0-211.elastic-ssl.ui-r.com (217.160.0.211): icmp_seq=3 ttl=58 time=8.54 ms
                        64 bytes from 217-160-0-211.elastic-ssl.ui-r.com (217.160.0.211): icmp_seq=4 ttl=58 time=8.55 ms
                        ^C
                        --- iobroker.live ping statistics ---
                        4 packets transmitted, 4 received, 0% packet loss, time 3002ms
                        rtt min/avg/max/mdev = 8.506/8.747/9.398/0.375 ms
                        Auch das Deaktivieren von pihole löste das Problem nicht. Was ist zu tun, damit die Adapter verfügbar werden?
                          @dragricola
                          Im Moment klemmt es auf dem iobroker-Server.
                          Versuch es später wieder.
                            dragricola @Thomas Braun last edited by dragricola
                            ja, da hatte ich wohl Pech beim Timing! Jetzt klappt der Zugriff auf download.iobroker.net wieder! Nach einem erneuten Zurückspielen des Backups konnte der Restore-Vorgang erfolgreich abgeschlossen werden. Nochmals ganz herzlichen Dank für Deine prompte bereitwillige Hilfe! Ohne diese hätte ich das nicht hinbekommen.
                            Es würde mich allerdings noch interessieren, was der ursprüngliche Fehler war. Liege ich richtig, dass mein Problem hauptsächlich dadurch verursacht wurde, dass ich bei der Backup-Konfiguration das Häkchen bei Redis nicht gesetzt hatte und somit Redis nicht im Backup eingeschlossen war? Wenn ja, hätte ich das kompensieren können, wenn ich vor dem Restore Redis installiert hätte?
                              @dragricola
                              Das Paket 'redis' wird nicht gesichert, das ist Teil des Betriebssystems.
                              Es werden nur die Daten selber gesichert, der redis-server muss dann natürlich zuvor wieder bereit gestellt werden.
                                Vielen Dank, damit ist mein Problem gelöst! Wie kann ich den Status des Beitrags auf "gelöst" setzten?
                                  @dragricola
                                  Dein Eröffnungsposting entsprechend im Titel ergänzen.
                                    nachdem nun nach der Umstellung auf Bullseye fast alle Funktionen meines Servers wieder laufen, bleibt jedoch noch das Restproblem, dass ich meine Visualisierung nicht mehr editieren kann. Die Instanz vis.0 läuft zwar wieder, jedoch immer, wenn ich neue Widgets einfügen oder andere Änderungen vornehmen will, werden sie nicht übernommen. Auch kann ich aus dem vis-editor nicht mehr mit dem kleinen schwarzen Dreieck in der linken oberen Ecke direkt in die runtime-umgebung der editierten Seite wechseln. Es erscheint dann manchmal in Rot der Hinweis "Verbindungsfehler".
                                    Des weiteren lassen sich die folgenden Instanzen nicht konfigurieren: vis-fancyswitch.0, vis-jqui-mfd.0, vis-hqwidgets.0, vis-materialdesign.0, vis-timeandweather.0. Wenn man auf den Schraubenschlüssel klickt erscheint die Meldung "File index_m.html not found". Diese Meldung erscheint auch bei den Instanzen simple-api.0 und sourceanalytix.0, die allerdings einen grünen Status bei Verbindung zum Host und Lebenszeichen haben.
                                    Wie komme ich hier weiter?
                                    Bin ich hier noch richtig oder sollte ich einen neuen Thread eröffnen?
                                      Thomas Braun Most Active @dragricola last edited by Thomas Braun
                                      @dragricola sagte in Gelöst: Nach Restore: No connection to databases possible:
                                      Mit Auszügen aus dem LogFile. Aber besser in einem neuen Thread, pro Problem einer.
                                      iobroker upload all
                                      ausgeführt?
                                        @thomas-braun said in Gelöst: Nach Restore: No connection to databases possible:
                                        iobroker upload all
                                        Ja gerade jetzt eben, aber ich werde nicht wirklich schlau daraus.
                                        Die Antwort ist zu lang für diesen Post. Ich habe deshalb viele Zeilen entfernt, die für miche keine neue Info enthielten. Ich hoffe ich habe nicht zu viel gekürzt.
                                        pi@raspberrypi4-iob:~ $ iobroker upload all
                                        upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.pn        g admin.png image/png
                                        upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/c        ustomComponents.js.map custom/customComponents.js.map application/json
                                        upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/t        ranslations.json i18n/pl/translations.json application/json
                                        upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/t        ranslations.json i18n/pt/translations.json application/json
                                        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/t        ranslations.json i18n/ru/translations.json application/json
                                        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/t        ranslations.json i18n/uk/translations.json application/json
                                        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-c        n/translations.json i18n/zh-cn/translations.json application/json
                                        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfi        g.json5 jsonConfig.json5 application/json5
                                        Update "system.adapter.admin.0"
                                        upload [21] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manage        r/admin/adapter-settings.js adapter-settings.js application/javascript
                                        upload [1] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager        /admin/type-detector.js type-detector.js application/javascript
                                        upload [0] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager        /admin/words.js words.js application/javascript
                                        INFO: Directory "/opt/iobroker/node_modules/iobroker.alias-manager/www" was not        found! Nothing was uploaded or deleted.
                                        upload [10] alpha2.admin /opt/iobroker/node_modules/iobroker.alpha2/admin/i18n/d        e/translations.json i18n/de/translations.json application/json
                                        upload [1] alpha2.admin /opt/iobroker/node_modules/iobroker.alpha2/admin/mh-logo        .png mh-logo.png image/png
                                        upload [0] alpha2.admin /opt/iobroker/node_modules/iobroker.alpha2/admin/words.j        s words.js application/javascript
                                        upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/ad        apter-settings.js adapter-settings.js application/javascript
                                        upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/ba        ckitup.png backitup.png image/png
                                        upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab        _m.html tab_m.html text/html
                                        upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab        _m.js tab_m.js application/javascript
                                        upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/wor        ds.js words.js application/javascript
                                        upload [4] coronavirus-statistics.admin /opt/iobroker/node_modules/iobroker.coro        navirus-statistics/admin/admin.d.ts admin.d.ts video/mp2t
                                        upload [1] coronavirus-statistics.admin /opt/iobroker/node_modules/iobroker.coro        navirus-statistics/admin/style.css style.css text/css
                                        upload [0] coronavirus-statistics.admin /opt/iobroker/node_modules/iobroker.coro        navirus-statistics/admin/words.js words.js application/javascript
                                        upload [482] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin        /daswettercom.png daswettercom.png image/png
                                        upload [450] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin        /icons/tiempo-weather/galeria1/10.png icons/tiempo-weather/galeria1/10.png image        /png
                                        upload [2] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i        ndex_m.html index_m.html text/html
                                        upload [1] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/j        sonConfig.json jsonConfig.json application/json
                                        upload [0] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/w        ords.js words.js application/javascript
                                        upload [12] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/denon.pn        g denon.png image/png
                                        upload [11] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/de/        translations.json i18n/de/translations.json application/json
                                        upload [1] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/index_m.h        tml index_m.html text/html
                                        upload [0] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/words.js        words.js application/javascript
                                        upload [136] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/ass        et-manifest.json asset-manifest.json application/json
                                        upload [100] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Consumption.fecd7a10.                                  svg static/media/Consumption.fecd7a10.svg image/svg+xml
                                        upload [2] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/names.e7efb528.txt stat                                  ic/media/names.e7efb528.txt text/plain
                                        upload [1] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/tab.html tab.html text/html
                                        upload [0] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/vendor/socket.io.js vendor/socket.io                                  .js application/javascript
                                        INFO: Directory "/opt/iobroker/node_modules/iobroker.devices/www" was not found! Nothing was uploaded or delete                                  d.
                                        upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png imag                                  e/png
                                        upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html                                   text/html
                                        upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools                                  .js application/javascript
                                        upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/ja                                  vascript
                                        upload [15] dwd.admin /opt/iobroker/node_modules/iobroker.dwd/admin/dwd.png dwd.png image/png
                                        upload [3] dwd.admin /opt/iobroker/node_modules/iobroker.dwd/admin/index_m.html index_m.html text/html
                                        upload [2] dwd.admin /opt/iobroker/node_modules/iobroker.dwd/admin/jsonConfig.json jsonConfig.json application/                                  json
                                        upload [1] dwd.admin /opt/iobroker/node_modules/iobroker.dwd/admin/regions.js regions.js application/javascript
                                        upload [0] dwd.admin /opt/iobroker/node_modules/iobroker.dwd/admin/words.js words.js application/javascript
                                        No alive host found which has the adapter echarts installed! No upload possible. Skipped.
                                        upload [4] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/feiertage.png feiertage.png imag                                  e/png
                                        upload [1] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/index_m.html index_m.html text/h                                  tml
                                        upload [0] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/words.js words.js application/ja                                  vascript
                                        upload [0] flot.admin /opt/iobroker/node_modules/iobroker.flot/admin/flot.png flot.png image/png
                                        upload [23] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar-alpha.png css/images/128/bar-a                                  lpha.png image/png
                                        upload [2] flot /opt/iobroker/node_modules/iobroker.flot/www/js/flot.js.map js/flot.js.map application/json
                                        upload [1] flot /opt/iobroker/node_modules/iobroker.flot/www/preset.html preset.html text/html
                                        upload [0] flot /opt/iobroker/node_modules/iobroker.flot/www/preset.html.map preset.html.map application/json
                                        upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
                                        upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_log                                  o.png image/png
                                        upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/h                                  tml
                                        upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
                                        upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/ja                                  vascript
                                        Adapter "system.adapter.vis.0" restarted.
                                        No alive host found which has the adapter history installed! No upload possible. Skipped.
                                        upload [13] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/homeconnect.png homeconnect                                  .png image/png
                                        upload [12] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/de/translations.json i                                  18n/de/translations.json application/json
                                        upload [11] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/en/translations.json i                                  18n/en/translations.json application/json
                                        upload [2] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/index_m.html index_m.html te                                  xt/html
                                        upload [1] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/style.css style.css text/css
                                        upload [0] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/words.js words.js applicatio                                  n/javascript
                                        upload [14] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/de/translations.json i18n/de/transla                                  tions.json application/json
                                        upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/index_m.html index_m.html text/html
                                        upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/jsonConfig.json jsonConfig.json applicatio                                  n/json
                                        upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
                                        upload [1] icons-mfd-svg.admin /opt/iobroker/node_modules/iobroker.icons-mfd-svg/admin/icons-mfd-svg.png icons-                                  mfd-svg.png image/png
                                        upload [0] icons-mfd-svg.admin /opt/iobroker/node_modules/iobroker.icons-mfd-svg/admin/index.html index.html te                                  xt/html
                                        upload [931] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/audio_audio.svg audio_audio.sv                                  g image/svg+xml
                                        upload [1] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_speed_ms.svg weathe                                  r_wind_speed_ms.svg image/svg+xml
                                        upload [0] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_winter.svg weather_winte                                  r.svg image/svg+xml
                                        upload [13] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/de/translations.json i18n/de                                  /translations.json application/json
                                        upload [2] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/jsonConfig.json jsonConfig.json ap                                  plication/json
                                        upload [1] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/jsonCustom.json jsonCustom.json ap                                  plication/json
                                        upload [0] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/words.js words.js application/java                                  script
                                        upload [90] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/de/translations.json i18n/de/transla                                  tions.json application/json
                                        upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                                        upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/updateAdapter.js lib/js/updateAdapt                                  er.js application/javascript
                                        upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/tab_m.html tab_m.html text/html
                                        upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
                                        upload [254] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js                                   application/javascript
                                        upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE googl                                  e-blockly/LICENSE null
                                        upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorke                                  r.js vs/language/typescript/tsWorker.js application/javascript
                                        upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js appl                                  ication/javascript
                                        upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts                                   video/mp2t
                                        upload [12] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/i18n/de/translations.json i18n/                                  de/translations.json application/json
                                        upload [2] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/index_m.html index_m.html text/h                                  tml
                                        upload [1] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/jsonConfig.json jsonConfig.json                                   application/json
                                        upload [0] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/luftdaten.png luftdaten.png imag                                  e/png
                                        upload [13] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/de/translations.json i18n/de/transla                                  tions.json application/json
                                        upload [2] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/jsonConfig.json jsonConfig.json applicatio                                  n/json
                                        upload [1] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/mqtt.png mqtt.png image/png
                                        upload [0] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/words.js words.js application/javascript
                                        upload [2] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/index_m.html index_m.html text/h                                  tml
                                        upload [1] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/net-tools.png net-tools.png imag                                  e/png
                                        upload [0] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/words.js words.js application/ja                                  vascript
                                        upload [4] nuki-extended.admin /opt/iobroker/node_modules/iobroker.nuki-extended/admin/admin.css admin.css text                                  /css
                                        upload [1] nuki-extended.admin /opt/iobroker/node_modules/iobroker.nuki-extended/admin/nuki-extended.png nuki-e                                  xtended.png image/png
                                        upload [0] nuki-extended.admin /opt/iobroker/node_modules/iobroker.nuki-extended/admin/words.js words.js applic                                  ation/javascript
                                        Adapter "system.adapter.web.0" restarted.
                                        upload [8] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/ICONS.js ICONS.js application/ja                                  vascript
                                        upload [1] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/vertical-timeline.css vertical-t                                  imeline.css text/css
                                        upload [0] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/vertical-timeline.js vertical-ti                                  meline.js application/javascript
                                        upload [12] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/i18n/de/translations.json i18n/                                  de/translations.json application/json
                                        upload [2] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/index_m.html index_m.html text/h                                  tml
                                        upload [1] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/jsonConfig.json jsonConfig.json                                   application/json
                                        upload [0] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/octoprint.png octoprint.png imag                                  e/png
                                        upload [3] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/index.html index.htm                                  l text/html
                                        upload [0] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/words.js words.js ap                                  plication/javascript
                                        upload [4] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/admin.d.ts admin.d.ts video/mp2t
                                        upload [0] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/words.js words.js application/javasc                                  ript
                                        upload [4] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/img/info-big.png img/info-big.png image/pn                                  g
                                        upload [1] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/ping.png ping.png image/png
                                        upload [0] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/words.js words.js application/javascript
                                        upload [14] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/blockly.js blockly.js application                                  /javascript
                                        upload [3] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/index_m.html index_m.html text/htm                                  l
                                        upload [2] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/jsonConfig.json jsonConfig.json ap                                  plication/json
                                        upload [1] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/pushover.png pushover.png image/pn                                  g
                                        upload [0] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/words.js words.js application/java                                  script
                                        upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/index_m.html index_m.html text/html
                                        upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi.png rpi.png image/png
                                        upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
                                        upload [5] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/img/info-big.png img/i                                  nfo-big.png image/png
                                        upload [1] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/style.css style.css te                                  xt/css
                                        upload [0] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/words.js words.js appl                                  ication/javascript
                                        upload [14] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/de/translations.json i18                                  n/de/translations.json application/json
                                        upload [2] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/jsonConfig.json jsonConfig.jso                                  n application/json
                                        upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png                                   image/png
                                        upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/                                  javascript
                                        Update "system.adapter.simple-api.0"
                                        upload [11] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/de/translations.json i18n/de                                  /translations.json application/json
                                        upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/jsonConfig.json jsonConfig.json ap                                  plication/json
                                        upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/pn                                  g
                                        upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
                                        INFO: Directory "for sourceanalytix.admin" was not found! Nothing was uploaded or deleted.
                                        Cannot find io-package.json for "sourceanalytix"
                                        INFO: Directory "for sourceanalytix" was not found! Nothing was uploaded or deleted.
                                        upload [13] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                        upload [1] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/sql.png sql.png image/png
                                        upload [0] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/words.js words.js application/javascript
                                        upload [19] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/_data.json _data.json application/json
                                        upload [3] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/synology.png synology.png image/png
                                        upload [2] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/synology_admin.png synology_admin.png image/png
                                        upload [1] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/tsconfig.json tsconfig.json application/json
                                        upload [0] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/words.js words.js application/javascript
                                        upload [3] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/index.html index.html text/html
                                        upload [2] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/index_m.html index_m.html text/html
                                        upload [1] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/tankerkoenig.png tankerkoenig.png image/png
                                        upload [0] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/words.js words.js application/javascript
                                        upload [52] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
                                        upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json
                                        upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
                                        upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
                                        upload [17] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/asset-manifest.json asset-manifest.json application/json
                                        upload [16] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                        upload [15] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/langModel.js langModel.js application/javascript
                                        upload [1] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/tab.html tab.html text/html
                                        upload [0] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/text2command.png text2command.png image/png
                                        upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
                                        upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                                        upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                                        Update "system.adapter.tr-064.2"
                                        upload [12] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                        upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/index_m.html index_m.html text/html
                                        upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json
                                        upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png
                                        upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                                        upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                                        upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                                        upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                                        Update "system.adapter.vis-metro.0"
                                        Update "system.adapter.vis-weather.0"
                                        Update "system.adapter.vis-colorpicker.0"
                                        upload [718] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                                        upload [700] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
                                        upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.js widgets/weather/lib/js/flot/jquery.js application/javascript
                                        upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/globalize.culture.en-US.js widgets/weather/lib/js/lib/globalize.culture.en-US.js application/javascript
                                        upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/globalize.js widgets/weather/lib/js/lib/globalize.js application/javascript
                                        upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/jquery.event.drag.js widgets/weather/lib/js/lib/jquery.event.drag.js application/javascript
                                        upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/jquery.mousewheel.js widgets/weather/lib/js/lib/jquery.mousewheel.js application/javascript
                                        upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather.html widgets/weather.html text/html
                                        upload [0] vis-colorpicker.admin /opt/iobroker/node_modules/iobroker.vis-colorpicker/admin/colorpicker.png colorpicker.png image/png
                                        INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-colorpicker/www" was not found! Nothing was uploaded or deleted.
                                        upload [1] vis-fancyswitch.admin /opt/iobroker/node_modules/iobroker.vis-fancyswitch/admin/fancyswitch.png fancyswitch.png image/png
                                        upload [0] vis-fancyswitch.admin /opt/iobroker/node_modules/iobroker.vis-fancyswitch/admin/index.html index.html text/html
                                        Update "system.adapter.vis-fancyswitch.0"
                                        INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-fancyswitch/www" was not found! Nothing was uploaded or deleted.
                                        upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
                                        upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
                                        Update "system.adapter.vis-hqwidgets.0"
                                        INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted.
                                        upload [0] vis-jqui-mfd.admin /opt/iobroker/node_modules/iobroker.vis-jqui-mfd/admin/jqui-mfd.png jqui-mfd.png image/png
                                        Update "system.adapter.vis-jqui-mfd.0"
                                        INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-jqui-mfd/www" was not found! Nothing was uploaded or deleted.
                                        INFO: Directory "for vis-materialdesign.admin" was not found! Nothing was uploaded or deleted.
                                        Cannot find io-package.json for "vis-materialdesign"
                                        INFO: Directory "for vis-materialdesign" was not found! Nothing was uploaded or deleted.
                                        upload [1] vis-metro.admin /opt/iobroker/node_modules/iobroker.vis-metro/admin/index.html index.html text/html
                                        upload [0] vis-metro.admin /opt/iobroker/node_modules/iobroker.vis-metro/admin/metro.png metro.png image/png
                                        INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-metro/www" was not found! Nothing was uploaded or deleted.
                                        upload [1] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/index.html index.html text/html
                                        upload [0] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/timeandweather.png timeandweather.png image/png
                                        Update "system.adapter.vis-timeandweather.0"
                                        INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-timeandweather/www" was not found! Nothing was uploaded or deleted.
                                        upload [3] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/index.html index.html text/html
                                        upload [2] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/index_m.html index_m.html text/html
                                        upload [1] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/vis-weather.png vis-weather.png image/png
                                        upload [0] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/words.js words.js application/javascript
                                        INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-weather/www" was not found! Nothing was uploaded or deleted.
                                        upload [2] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatherunderground/admin/index_m.html index_m.html text/html
                                        upload [1] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatherunderground/admin/words.js words.js application/javascript
                                        upload [0] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatherunderground/admin/wu.png wu.png image/png
                                        upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                                        upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                        upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
                                        upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
                                        upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
                                        upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
                                        upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
                                        upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
                                        upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js static/js/2.b1d56998.chunk.js application/javascript
                                        upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.LICENSE.txt static/js/2.b1d56998.chunk.js.LICENSE.txt text/plain
                                        upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.map static/js/2.b1d56998.chunk.js.map application/json
                                        upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js static/js/main.034751df.chunk.js application/javascript
                                        upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js.map static/js/main.034751df.chunk.js.map application/json
                                        upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js static/js/runtime-main.7278cf1c.js application/javascript
                                        upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js.map static/js/runtime-main.7278cf1c.js.map application/json
                                        upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
                                        upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                                        upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                                        upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
                                        upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
                                        upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
                                        upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
                                        upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
                                        upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
                                        upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
                                        upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
                                        upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
                                        upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
                                        upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
                                        upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
                                        upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
                                        upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
                                        upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
                                        upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
                                        upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
                                        upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
                                        upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
                                        upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
                                        upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
                                        upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
                                        upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
                                        upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
                                        upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
                                        upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
                                        upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
                                        upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
                                        upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
                                        upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                                        upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
                                        upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
                                        upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
                                        upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
                                        upload [314] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                                        upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_CO2.png img/DIYRuZ_CO2.png image/png
                                        upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
                                        upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
                                        upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
                                        Bei vis-hqwidgets.0 und vis-timeandweather.0 sind nun die Schraubenschlüssel verschwunden aber der Rest ist unverändert. Auch hatte ich vergessen zu erwähnen, dass der die Instanz socketio.0 ohne Verbindung zum Host und Lebenszeichen ist.
                                        connection to databases javascript update restart restore backup upgrade bullseye upgrade nodejs
                                        2086
