    4. Gelöst: Nach Restore: No connection to databases possible
      dragricola last edited by
      sudo apt update liefert:
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
      Hit:4 https://dl.yarnpkg.com/debian stable InRelease
      Reading package lists... Done
      Building dependency tree
      All packages are up to date.
      Hilft das Log aus meinem letzten Beitrag weiter?
        Thomas Braun Most Active @dragricola last edited by
        @dragricola sagte in Nach Restore: No connection to databases possible, restart:
        Jein.
        Hostname geändert?
        Bitte Auszüge in Textform in CodeTags eingebettet heir rein.
          dragricola @Thomas Braun last edited by
          Den Host-Namen habe ich meines Wissens wieder bei der Installation gleich vergeben. Allerdings ohne das präfix host. davor.
          2022-11-12 16:10:44.878  - info: host.raspberrypi4-iob iobroker _restart
          2022-11-12 16:10:50.341  - info: host.raspberrypi4-iob iobroker.js-controller version 4.0.23 js-controller starting
          2022-11-12 16:10:50.349  - info: host.raspberrypi4-iob Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
          2022-11-12 16:10:50.350  - info: host.raspberrypi4-iob hostname: raspberrypi4-iob, node: v16.18.1
          2022-11-12 16:10:50.353  - info: host.raspberrypi4-iob ip addresses: 192.168.178.126 fe80::436b:c1e:289f:c0ed
          2022-11-12 16:11:08.610  - error: host.raspberrypi4-iob Cannot read system.config: null (OK when migrating or restoring)
          2022-11-12 16:11:08.625  - error: host.raspberrypi4-iob Cannot find view "system" for search "host"
          2022-11-12 16:11:08.715  - info: host.raspberrypi4-iob connected to Objects and States
          2022-11-12 16:11:08.745  - info: host.raspberrypi4-iob Node.js version has changed from unknown to 16.18.1
          2022-11-12 16:11:08.793  - info: host.raspberrypi4-iob added notifications configuration of host
          2022-11-12 16:11:08.800  - info: host.raspberrypi4-iob Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
          2022-11-12 16:11:08.811  - error: host.raspberrypi4-iob Cannot find view "system" for search "instance"
          2022-11-12 16:11:08.813  - error: host.raspberrypi4-iob Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
          2022-11-12 16:11:08.826  - info: host.raspberrypi4-iob Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
          2022-11-12 16:11:08.836  - error: host.raspberrypi4-iob Cannot find view "system" for search "state"
          2022-11-12 16:11:08.837  - error: host.raspberrypi4-iob Cannot find view "system" for search "instance"
          2022-11-12 16:11:08.841  - error: host.raspberrypi4-iob Could not collect system.host.raspberrypi4-iob states to check for obsolete states: Error: Cannot find view "system"
          2022-11-12 16:11:08.842  - error: host.raspberrypi4-iob  _design/system missing - call node iobroker.js setup
          2022-11-12 16:11:08.843  - info: host.raspberrypi4-iob  no instances found
          2022-11-12 16:11:09.054  - info: host.raspberrypi4-iob Created UUID: 958fb34d-ae20-1453-74c4-b251ccab0b04
          2022-11-12 16:25:19.450  - info: host.raspberrypi4-iob received SIGTERM
          2022-11-12 16:25:19.469  - info: host.raspberrypi4-iob terminated
          2022-11-12 16:25:21.831  - info: host.raspberrypi4-iob iobroker.js-controller version 4.0.23 js-controller starting
          2022-11-12 16:25:21.838  - info: host.raspberrypi4-iob Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
          2022-11-12 16:25:21.840  - info: host.raspberrypi4-iob hostname: raspberrypi4-iob, node: v16.18.1
          2022-11-12 16:25:21.842  - info: host.raspberrypi4-iob ip addresses: 192.168.178.126 fe80::436b:c1e:289f:c0ed
          2022-11-12 16:25:21.936  - error: host.raspberrypi4-iob Cannot read system.config: null (OK when migrating or restoring)
          2022-11-12 16:25:21.948  - error: host.raspberrypi4-iob Cannot find view "system" for search "host"
          2022-11-12 16:25:22.013  - info: host.raspberrypi4-iob connected to Objects and States
          2022-11-12 16:25:22.035  - info: host.raspberrypi4-iob added notifications configuration of host
          2022-11-12 16:25:22.054  - error: host.raspberrypi4-iob Cannot find view "system" for search "instance"
          2022-11-12 16:25:22.057  - error: host.raspberrypi4-iob Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
          2022-11-12 16:25:22.085  - info: host.raspberrypi4-iob Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
          2022-11-12 16:25:22.097  - error: host.raspberrypi4-iob Cannot find view "system" for search "state"
          2022-11-12 16:25:22.099  - error: host.raspberrypi4-iob Cannot find view "system" for search "instance"
          2022-11-12 16:25:22.105  - error: host.raspberrypi4-iob Could not collect system.host.raspberrypi4-iob states to check for obsolete states: Error: Cannot find view "system"
          2022-11-12 16:25:22.107  - error: host.raspberrypi4-iob  _design/system missing - call node iobroker.js setup
          2022-11-12 16:25:22.108  - info: host.raspberrypi4-iob  no instances found
            @dragricola
            Versuch mal
            iob stop
            iob host this
            iob start
              pi@raspberrypi4-iob:~ $ iob stop
              pi@raspberrypi4-iob:~ $ iob host this
              An unknown error occurred: Cannot find view "system"
              pi@raspberrypi4-iob:~ $ iob start
                Thomas Braun Most Active last edited by
                @dragricola
                iobroker setup first
                  jaa, ... jetzt meldet sich der admin wieder mit der Welcome-Seite und dem Setup Assistenten. Kann ich den irgendwie überspringen? Setup ist ja bereits erfolgt.
                  Ich würde das ganze auch nochmals mit bullseye durchführen. Was gibt es dabei zu beachten?
                    Weiß ich nicht, ich setze meine Kisten nicht sooooo oft neu auf.
                    Skip dich einfach durch, so viel ist da ja nicht einzustellen.
                    Das gleiche wie hier.
                      Hallo Thomas Braun,
                      dank Deiner Anleitung lief das System einigermaßen wieder auf buster, sodass ich hoffen konnte, dass ich es auch unter bullseye zum Laufen bringen kann. Es gab aber noch Probleme mit dem VIS-Adapter und nachdem ich im Forum zu diesem Problem nachgelesen habe, und dort empfohlen wurde vor dem Restart vis 1.4.0, web u.a. Adapter zu installieren, habe ich nun ioBroker auf Bullseye 64Bit neu aufgesetzt und vor dem Einspielen des Backups auch noch mariadb und pihole installiert. sudo apt update liefert nun:
                      pi@raspberrypi4-iob:~ $ sudo apt update
                      Hit:1 http://deb.debian.org/debian bullseye InRelease
                      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                      Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
                      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                      Fetched 48.4 kB in 1s (37.0 kB/s)
                      Building dependency tree... Done
                      Das Restore lief problemlois durch:
                      [EXIT] 0 **** Restore completed successfully!! ****
                      Allerdings war danach der Admin nicht mehr erreichbar. Ich habe daraufhin wieder die von Dir vorgeschlagenen Schritte durchgeführt:
                      Danach lief der Admin zwar wieder, allerdings gab es nur die Instanzen admin und backitup und offensichtlich kann iobroker die im restore eingespielten Adapter nicht nachladen:
                      admin.0
                      	2022-11-13 11:09:40.266	warn	Cannot update rating: connect ECONNREFUSED 79.143.182.215:443
                      admin.0
                      	2022-11-13 11:08:24.100	warn	Cannot update rating: connect ECONNREFUSED 79.143.182.215:443
                      	2022-11-13 11:07:53.372	info	Updating repository "live-stable" under "http://iobroker.live/repo/sources-dist.json"
                      admin.0
                      	2022-11-13 11:07:53.329	info	==> Connected system.user.admin from ::ffff:192.168.178.182
                      admin.0
                      	2022-11-13 11:07:52.926	info	<== Disconnect system.user.admin from ::ffff:192.168.178.182 admin
                      admin.0
                      	2022-11-13 11:06:55.164	warn	Active repository "stable" cannot be read
                      admin.0
                      	2022-11-13 11:06:55.163	warn	Repository cannot be read: Active repo - stable
                      	2022-11-13 11:06:53.019	error	Error by updating repository "stable" under "http://download.iobroker.net/sources-dist.json": Cannot download repository file from "http://download.iobroker.net/sources-dist.json": connect ECONNREFUSED 79.143.182.215:80
                      Nachdem ich das repository "live-stable" aktiviert hatte (Zeile6) ging wenigstens die Errormeldung (Zeile 16) weg. Aber
                      die Warnungen (Zeilen 2 und 4) kommen regelmäßig wieder. Ping auf download.iobroker.net und iobroker.live funktioniert problemlos:
                      pi@raspberrypi4-iob:~ $ ping download.iobroker.net
                      PING download.iobroker.net (79.143.182.215) 56(84) bytes of data.
                      64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=1 ttl=57 time=14.9 ms
                      64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=2 ttl=57 time=13.8 ms
                      64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=3 ttl=57 time=14.2 ms
                      64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=4 ttl=57 time=14.1 ms
                      64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=5 ttl=57 time=14.2 ms
                      64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=6 ttl=57 time=14.0 ms
                      64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=7 ttl=57 time=13.8 ms
                      64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=8 ttl=57 time=14.1 ms
                      64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=9 ttl=57 time=14.1 ms
                      64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=10 ttl=57 time=14.3 ms
                      ^C
                      --- download.iobroker.net ping statistics ---
                      10 packets transmitted, 10 received, 0% packet loss, time 9004ms
                      rtt min/avg/max/mdev = 13.801/14.141/14.853/0.281 ms
                      pi@raspberrypi4-iob:~ $ ping iobroker.live
                      PING iobroker.live (217.160.0.211) 56(84) bytes of data.
                      64 bytes from 217-160-0-211.elastic-ssl.ui-r.com (217.160.0.211): icmp_seq=1 ttl=58 time=9.40 ms
                      64 bytes from 217-160-0-211.elastic-ssl.ui-r.com (217.160.0.211): icmp_seq=2 ttl=58 time=8.51 ms
                      64 bytes from 217-160-0-211.elastic-ssl.ui-r.com (217.160.0.211): icmp_seq=3 ttl=58 time=8.54 ms
                      64 bytes from 217-160-0-211.elastic-ssl.ui-r.com (217.160.0.211): icmp_seq=4 ttl=58 time=8.55 ms
                      ^C
                      --- iobroker.live ping statistics ---
                      4 packets transmitted, 4 received, 0% packet loss, time 3002ms
                      rtt min/avg/max/mdev = 8.506/8.747/9.398/0.375 ms
                      Auch das Deaktivieren von pihole löste das Problem nicht. Was ist zu tun, damit die Adapter verfügbar werden?
                        @dragricola
                        Im Moment klemmt es auf dem iobroker-Server.
                        Versuch es später wieder.
                          dragricola @Thomas Braun last edited by dragricola
                          ja, da hatte ich wohl Pech beim Timing! Jetzt klappt der Zugriff auf download.iobroker.net wieder! Nach einem erneuten Zurückspielen des Backups konnte der Restore-Vorgang erfolgreich abgeschlossen werden. Nochmals ganz herzlichen Dank für Deine prompte bereitwillige Hilfe! Ohne diese hätte ich das nicht hinbekommen.
                          Es würde mich allerdings noch interessieren, was der ursprüngliche Fehler war. Liege ich richtig, dass mein Problem hauptsächlich dadurch verursacht wurde, dass ich bei der Backup-Konfiguration das Häkchen bei Redis nicht gesetzt hatte und somit Redis nicht im Backup eingeschlossen war? Wenn ja, hätte ich das kompensieren können, wenn ich vor dem Restore Redis installiert hätte?
                            @dragricola
                            Das Paket 'redis' wird nicht gesichert, das ist Teil des Betriebssystems.
                            Es werden nur die Daten selber gesichert, der redis-server muss dann natürlich zuvor wieder bereit gestellt werden.
                              Vielen Dank, damit ist mein Problem gelöst! Wie kann ich den Status des Beitrags auf "gelöst" setzten?
                                @dragricola
                                Dein Eröffnungsposting entsprechend im Titel ergänzen.
                                  nachdem nun nach der Umstellung auf Bullseye fast alle Funktionen meines Servers wieder laufen, bleibt jedoch noch das Restproblem, dass ich meine Visualisierung nicht mehr editieren kann. Die Instanz vis.0 läuft zwar wieder, jedoch immer, wenn ich neue Widgets einfügen oder andere Änderungen vornehmen will, werden sie nicht übernommen. Auch kann ich aus dem vis-editor nicht mehr mit dem kleinen schwarzen Dreieck in der linken oberen Ecke direkt in die runtime-umgebung der editierten Seite wechseln. Es erscheint dann manchmal in Rot der Hinweis "Verbindungsfehler".
                                  Des weiteren lassen sich die folgenden Instanzen nicht konfigurieren: vis-fancyswitch.0, vis-jqui-mfd.0, vis-hqwidgets.0, vis-materialdesign.0, vis-timeandweather.0. Wenn man auf den Schraubenschlüssel klickt erscheint die Meldung "File index_m.html not found". Diese Meldung erscheint auch bei den Instanzen simple-api.0 und sourceanalytix.0, die allerdings einen grünen Status bei Verbindung zum Host und Lebenszeichen haben.
                                  Wie komme ich hier weiter?
                                  Bin ich hier noch richtig oder sollte ich einen neuen Thread eröffnen?
                                    Thomas Braun Most Active @dragricola last edited by Thomas Braun
                                    @dragricola sagte in Gelöst: Nach Restore: No connection to databases possible:
                                    Mit Auszügen aus dem LogFile. Aber besser in einem neuen Thread, pro Problem einer.
                                    iobroker upload all
                                    ausgeführt?
                                      @thomas-braun said in Gelöst: Nach Restore: No connection to databases possible:
                                      iobroker upload all
                                      Ja gerade jetzt eben, aber ich werde nicht wirklich schlau daraus.
                                      Die Antwort ist zu lang für diesen Post. Ich habe deshalb viele Zeilen entfernt, die für miche keine neue Info enthielten. Ich hoffe ich habe nicht zu viel gekürzt.
                                      pi@raspberrypi4-iob:~ $ iobroker upload all
                                      upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.pn        g admin.png image/png
                                      upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/c        ustomComponents.js.map custom/customComponents.js.map application/json
                                      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/t        ranslations.json i18n/pl/translations.json application/json
                                      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/t        ranslations.json i18n/pt/translations.json application/json
                                      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/t        ranslations.json i18n/ru/translations.json application/json
                                      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/t        ranslations.json i18n/uk/translations.json application/json
                                      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-c        n/translations.json i18n/zh-cn/translations.json application/json
                                      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfi        g.json5 jsonConfig.json5 application/json5
                                      Update "system.adapter.admin.0"
                                      upload [21] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manage        r/admin/adapter-settings.js adapter-settings.js application/javascript
                                      upload [1] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager        /admin/type-detector.js type-detector.js application/javascript
                                      upload [0] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager        /admin/words.js words.js application/javascript
                                      INFO: Directory "/opt/iobroker/node_modules/iobroker.alias-manager/www" was not        found! Nothing was uploaded or deleted.
                                      upload [10] alpha2.admin /opt/iobroker/node_modules/iobroker.alpha2/admin/i18n/d        e/translations.json i18n/de/translations.json application/json
                                      upload [1] alpha2.admin /opt/iobroker/node_modules/iobroker.alpha2/admin/mh-logo        .png mh-logo.png image/png
                                      upload [0] alpha2.admin /opt/iobroker/node_modules/iobroker.alpha2/admin/words.j        s words.js application/javascript
                                      upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/ad        apter-settings.js adapter-settings.js application/javascript
                                      upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/ba        ckitup.png backitup.png image/png
                                      upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab        _m.html tab_m.html text/html
                                      upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab        _m.js tab_m.js application/javascript
                                      upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/wor        ds.js words.js application/javascript
                                      upload [4] coronavirus-statistics.admin /opt/iobroker/node_modules/iobroker.coro        navirus-statistics/admin/admin.d.ts admin.d.ts video/mp2t
                                      upload [1] coronavirus-statistics.admin /opt/iobroker/node_modules/iobroker.coro        navirus-statistics/admin/style.css style.css text/css
                                      upload [0] coronavirus-statistics.admin /opt/iobroker/node_modules/iobroker.coro        navirus-statistics/admin/words.js words.js application/javascript
                                      upload [482] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin        /daswettercom.png daswettercom.png image/png
                                      upload [450] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin        /icons/tiempo-weather/galeria1/10.png icons/tiempo-weather/galeria1/10.png image        /png
                                      upload [2] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i        ndex_m.html index_m.html text/html
                                      upload [1] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/j        sonConfig.json jsonConfig.json application/json
                                      upload [0] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/w        ords.js words.js application/javascript
                                      upload [12] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/denon.pn        g denon.png image/png
                                      upload [11] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/de/        translations.json i18n/de/translations.json application/json
                                      upload [1] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/index_m.h        tml index_m.html text/html
                                      upload [0] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/words.js        words.js application/javascript
                                      upload [136] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/ass        et-manifest.json asset-manifest.json application/json
                                      upload [100] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Consumption.fecd7a10.                                  svg static/media/Consumption.fecd7a10.svg image/svg+xml
                                      upload [2] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/names.e7efb528.txt stat                                  ic/media/names.e7efb528.txt text/plain
                                      upload [1] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/tab.html tab.html text/html
                                      upload [0] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/vendor/socket.io.js vendor/socket.io                                  .js application/javascript
                                      INFO: Directory "/opt/iobroker/node_modules/iobroker.devices/www" was not found! Nothing was uploaded or delete                                  d.
                                      upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png imag                                  e/png
                                      upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html                                   text/html
                                      upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools                                  .js application/javascript
                                      upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/ja                                  vascript
                                      upload [15] dwd.admin /opt/iobroker/node_modules/iobroker.dwd/admin/dwd.png dwd.png image/png
                                      upload [3] dwd.admin /opt/iobroker/node_modules/iobroker.dwd/admin/index_m.html index_m.html text/html
                                      upload [2] dwd.admin /opt/iobroker/node_modules/iobroker.dwd/admin/jsonConfig.json jsonConfig.json application/                                  json
                                      upload [1] dwd.admin /opt/iobroker/node_modules/iobroker.dwd/admin/regions.js regions.js application/javascript
                                      upload [0] dwd.admin /opt/iobroker/node_modules/iobroker.dwd/admin/words.js words.js application/javascript
                                      No alive host found which has the adapter echarts installed! No upload possible. Skipped.
                                      upload [4] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/feiertage.png feiertage.png imag                                  e/png
                                      upload [1] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/index_m.html index_m.html text/h                                  tml
                                      upload [0] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/words.js words.js application/ja                                  vascript
                                      upload [0] flot.admin /opt/iobroker/node_modules/iobroker.flot/admin/flot.png flot.png image/png
                                      upload [23] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar-alpha.png css/images/128/bar-a                                  lpha.png image/png
                                      upload [2] flot /opt/iobroker/node_modules/iobroker.flot/www/js/flot.js.map js/flot.js.map application/json
                                      upload [1] flot /opt/iobroker/node_modules/iobroker.flot/www/preset.html preset.html text/html
                                      upload [0] flot /opt/iobroker/node_modules/iobroker.flot/www/preset.html.map preset.html.map application/json
                                      upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
                                      upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_log                                  o.png image/png
                                      upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/h                                  tml
                                      upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
                                      upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/ja                                  vascript
                                      Adapter "system.adapter.vis.0" restarted.
                                      No alive host found which has the adapter history installed! No upload possible. Skipped.
                                      upload [13] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/homeconnect.png homeconnect                                  .png image/png
                                      upload [12] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/de/translations.json i                                  18n/de/translations.json application/json
                                      upload [11] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/en/translations.json i                                  18n/en/translations.json application/json
                                      upload [2] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/index_m.html index_m.html te                                  xt/html
                                      upload [1] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/style.css style.css text/css
                                      upload [0] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/words.js words.js applicatio                                  n/javascript
                                      upload [14] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/de/translations.json i18n/de/transla                                  tions.json application/json
                                      upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/index_m.html index_m.html text/html
                                      upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/jsonConfig.json jsonConfig.json applicatio                                  n/json
                                      upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
                                      upload [1] icons-mfd-svg.admin /opt/iobroker/node_modules/iobroker.icons-mfd-svg/admin/icons-mfd-svg.png icons-                                  mfd-svg.png image/png
                                      upload [0] icons-mfd-svg.admin /opt/iobroker/node_modules/iobroker.icons-mfd-svg/admin/index.html index.html te                                  xt/html
                                      upload [931] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/audio_audio.svg audio_audio.sv                                  g image/svg+xml
                                      upload [1] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_speed_ms.svg weathe                                  r_wind_speed_ms.svg image/svg+xml
                                      upload [0] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_winter.svg weather_winte                                  r.svg image/svg+xml
                                      upload [13] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/de/translations.json i18n/de                                  /translations.json application/json
                                      upload [2] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/jsonConfig.json jsonConfig.json ap                                  plication/json
                                      upload [1] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/jsonCustom.json jsonCustom.json ap                                  plication/json
                                      upload [0] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/words.js words.js application/java                                  script
                                      upload [90] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/de/translations.json i18n/de/transla                                  tions.json application/json
                                      upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                                      upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/updateAdapter.js lib/js/updateAdapt                                  er.js application/javascript
                                      upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/tab_m.html tab_m.html text/html
                                      upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
                                      upload [254] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js                                   application/javascript
                                      upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE googl                                  e-blockly/LICENSE null
                                      upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorke                                  r.js vs/language/typescript/tsWorker.js application/javascript
                                      upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js appl                                  ication/javascript
                                      upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts                                   video/mp2t
                                      upload [12] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/i18n/de/translations.json i18n/                                  de/translations.json application/json
                                      upload [2] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/index_m.html index_m.html text/h                                  tml
                                      upload [1] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/jsonConfig.json jsonConfig.json                                   application/json
                                      upload [0] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/luftdaten.png luftdaten.png imag                                  e/png
                                      upload [13] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/de/translations.json i18n/de/transla                                  tions.json application/json
                                      upload [2] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/jsonConfig.json jsonConfig.json applicatio                                  n/json
                                      upload [1] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/mqtt.png mqtt.png image/png
                                      upload [0] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/words.js words.js application/javascript
                                      upload [2] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/index_m.html index_m.html text/h                                  tml
                                      upload [1] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/net-tools.png net-tools.png imag                                  e/png
                                      upload [0] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/words.js words.js application/ja                                  vascript
                                      upload [4] nuki-extended.admin /opt/iobroker/node_modules/iobroker.nuki-extended/admin/admin.css admin.css text                                  /css
                                      upload [1] nuki-extended.admin /opt/iobroker/node_modules/iobroker.nuki-extended/admin/nuki-extended.png nuki-e                                  xtended.png image/png
                                      upload [0] nuki-extended.admin /opt/iobroker/node_modules/iobroker.nuki-extended/admin/words.js words.js applic                                  ation/javascript
                                      Adapter "system.adapter.web.0" restarted.
                                      upload [8] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/ICONS.js ICONS.js application/ja                                  vascript
                                      upload [1] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/vertical-timeline.css vertical-t                                  imeline.css text/css
                                      upload [0] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/vertical-timeline.js vertical-ti                                  meline.js application/javascript
                                      upload [12] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/i18n/de/translations.json i18n/                                  de/translations.json application/json
                                      upload [2] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/index_m.html index_m.html text/h                                  tml
                                      upload [1] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/jsonConfig.json jsonConfig.json                                   application/json
                                      upload [0] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/octoprint.png octoprint.png imag                                  e/png
                                      upload [3] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/index.html index.htm                                  l text/html
                                      upload [0] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/words.js words.js ap                                  plication/javascript
                                      upload [4] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/admin.d.ts admin.d.ts video/mp2t
                                      upload [0] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/words.js words.js application/javasc                                  ript
                                      upload [4] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/img/info-big.png img/info-big.png image/pn                                  g
                                      upload [1] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/ping.png ping.png image/png
                                      upload [0] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/words.js words.js application/javascript
                                      upload [14] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/blockly.js blockly.js application                                  /javascript
                                      upload [3] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/index_m.html index_m.html text/htm                                  l
                                      upload [2] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/jsonConfig.json jsonConfig.json ap                                  plication/json
                                      upload [1] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/pushover.png pushover.png image/pn                                  g
                                      upload [0] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/words.js words.js application/java                                  script
                                      upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/index_m.html index_m.html text/html
                                      upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi.png rpi.png image/png
                                      upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
                                      upload [5] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/img/info-big.png img/i                                  nfo-big.png image/png
                                      upload [1] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/style.css style.css te                                  xt/css
                                      upload [0] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/words.js words.js appl                                  ication/javascript
                                      upload [14] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/de/translations.json i18                                  n/de/translations.json application/json
                                      upload [2] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/jsonConfig.json jsonConfig.jso                                  n application/json
                                      upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png                                   image/png
                                      upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/                                  javascript
                                      Update "system.adapter.simple-api.0"
                                      upload [11] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/de/translations.json i18n/de                                  /translations.json application/json
                                      upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/jsonConfig.json jsonConfig.json ap                                  plication/json
                                      upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/pn                                  g
                                      upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
                                      INFO: Directory "for sourceanalytix.admin" was not found! Nothing was uploaded or deleted.
                                      Cannot find io-package.json for "sourceanalytix"
                                      INFO: Directory "for sourceanalytix" was not found! Nothing was uploaded or deleted.
                                      upload [13] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                      upload [1] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/sql.png sql.png image/png
                                      upload [0] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/words.js words.js application/javascript
                                      upload [19] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/_data.json _data.json application/json
                                      upload [3] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/synology.png synology.png image/png
                                      upload [2] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/synology_admin.png synology_admin.png image/png
                                      upload [1] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/tsconfig.json tsconfig.json application/json
                                      upload [0] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/words.js words.js application/javascript
                                      upload [3] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/index.html index.html text/html
                                      upload [2] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/index_m.html index_m.html text/html
                                      upload [1] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/tankerkoenig.png tankerkoenig.png image/png
                                      upload [0] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/words.js words.js application/javascript
                                      upload [52] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
                                      upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json
                                      upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
                                      upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
                                      upload [17] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/asset-manifest.json asset-manifest.json application/json
                                      upload [16] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                      upload [15] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/langModel.js langModel.js application/javascript
                                      upload [1] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/tab.html tab.html text/html
                                      upload [0] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/text2command.png text2command.png image/png
                                      upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
                                      upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                                      upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                                      Update "system.adapter.tr-064.2"
                                      upload [12] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                      upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/index_m.html index_m.html text/html
                                      upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json
                                      upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png
                                      upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                                      upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                                      upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                                      upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                                      Update "system.adapter.vis-metro.0"
                                      Update "system.adapter.vis-weather.0"
                                      Update "system.adapter.vis-colorpicker.0"
                                      upload [718] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                                      upload [700] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
                                      upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.js widgets/weather/lib/js/flot/jquery.js application/javascript
                                      upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/globalize.culture.en-US.js widgets/weather/lib/js/lib/globalize.culture.en-US.js application/javascript
                                      upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/globalize.js widgets/weather/lib/js/lib/globalize.js application/javascript
                                      upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/jquery.event.drag.js widgets/weather/lib/js/lib/jquery.event.drag.js application/javascript
                                      upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/jquery.mousewheel.js widgets/weather/lib/js/lib/jquery.mousewheel.js application/javascript
                                      upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather.html widgets/weather.html text/html
                                      upload [0] vis-colorpicker.admin /opt/iobroker/node_modules/iobroker.vis-colorpicker/admin/colorpicker.png colorpicker.png image/png
                                      INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-colorpicker/www" was not found! Nothing was uploaded or deleted.
                                      upload [1] vis-fancyswitch.admin /opt/iobroker/node_modules/iobroker.vis-fancyswitch/admin/fancyswitch.png fancyswitch.png image/png
                                      upload [0] vis-fancyswitch.admin /opt/iobroker/node_modules/iobroker.vis-fancyswitch/admin/index.html index.html text/html
                                      Update "system.adapter.vis-fancyswitch.0"
                                      INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-fancyswitch/www" was not found! Nothing was uploaded or deleted.
                                      upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
                                      upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
                                      Update "system.adapter.vis-hqwidgets.0"
                                      INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted.
                                      upload [0] vis-jqui-mfd.admin /opt/iobroker/node_modules/iobroker.vis-jqui-mfd/admin/jqui-mfd.png jqui-mfd.png image/png
                                      Update "system.adapter.vis-jqui-mfd.0"
                                      INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-jqui-mfd/www" was not found! Nothing was uploaded or deleted.
                                      INFO: Directory "for vis-materialdesign.admin" was not found! Nothing was uploaded or deleted.
                                      Cannot find io-package.json for "vis-materialdesign"
                                      INFO: Directory "for vis-materialdesign" was not found! Nothing was uploaded or deleted.
                                      upload [1] vis-metro.admin /opt/iobroker/node_modules/iobroker.vis-metro/admin/index.html index.html text/html
                                      upload [0] vis-metro.admin /opt/iobroker/node_modules/iobroker.vis-metro/admin/metro.png metro.png image/png
                                      INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-metro/www" was not found! Nothing was uploaded or deleted.
                                      upload [1] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/index.html index.html text/html
                                      upload [0] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/timeandweather.png timeandweather.png image/png
                                      Update "system.adapter.vis-timeandweather.0"
                                      INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-timeandweather/www" was not found! Nothing was uploaded or deleted.
                                      upload [3] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/index.html index.html text/html
                                      upload [2] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/index_m.html index_m.html text/html
                                      upload [1] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/vis-weather.png vis-weather.png image/png
                                      upload [0] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/words.js words.js application/javascript
                                      INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-weather/www" was not found! Nothing was uploaded or deleted.
                                      upload [2] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatherunderground/admin/index_m.html index_m.html text/html
                                      upload [1] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatherunderground/admin/words.js words.js application/javascript
                                      upload [0] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatherunderground/admin/wu.png wu.png image/png
                                      upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                                      upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                      upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
                                      upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
                                      upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
                                      upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
                                      upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
                                      upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
                                      upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js static/js/2.b1d56998.chunk.js application/javascript
                                      upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.LICENSE.txt static/js/2.b1d56998.chunk.js.LICENSE.txt text/plain
                                      upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.map static/js/2.b1d56998.chunk.js.map application/json
                                      upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js static/js/main.034751df.chunk.js application/javascript
                                      upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js.map static/js/main.034751df.chunk.js.map application/json
                                      upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js static/js/runtime-main.7278cf1c.js application/javascript
                                      upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js.map static/js/runtime-main.7278cf1c.js.map application/json
                                      upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
                                      upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                                      upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                                      upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
                                      upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
                                      upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
                                      upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
                                      upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
                                      upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
                                      upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
                                      upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
                                      upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
                                      upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
                                      upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
                                      upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
                                      upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
                                      upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
                                      upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
                                      upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
                                      upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
                                      upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
                                      upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
                                      upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
                                      upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
                                      upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
                                      upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
                                      upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
                                      upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
                                      upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
                                      upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
                                      upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
                                      upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
                                      upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                                      upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
                                      upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
                                      upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
                                      upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
                                      upload [314] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                                      upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_CO2.png img/DIYRuZ_CO2.png image/png
                                      upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
                                      upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
                                      upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
                                      Bei vis-hqwidgets.0 und vis-timeandweather.0 sind nun die Schraubenschlüssel verschwunden aber der Rest ist unverändert. Auch hatte ich vergessen zu erwähnen, dass der die Instanz socketio.0 ohne Verbindung zum Host und Lebenszeichen ist.
                                      connection to databases javascript update restart restore backup upgrade bullseye upgrade nodejs
                                      2086
